I am trying to have multiple actions triggered at a certain time very week night, using this code in my automations.yaml:
- alias: 'Turn ON Bath2 Water Heater every weekday evening'
platform: time
at: '21:40:00'
condition:
condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
service: telegram_bot.send_message
data_template:
title: '*HA Alert!*'
target: '142454348'
message: 1. Guest bathroom water heater turned ON for the evening cycle.
service: switch.turn_on
entity_id:
- switch.bath2_water_heater
data_template:
target: '142454348'
message: 2. Guest bathroom water heater turned ON for the evening cycle.
data_template:
target: '142454348'
message: 3. Guest bathroom water heater turned ON for the evening cycle.
Originally I just had 2 services; turn on the switch and then send the Telegram message to notify me.
What was happening was the switch would not turn on but I would get the Telegram message.
I modified the code to see if the problem was with the switch service, and it doesn’t seem to be because when I trigger this automation I only get the message 3 - the first 2 messages don’t get sent and the switch doesn’t turn on.
Do I have a mistake in my code that would cause only the last service call to be processed?
I obviously have some more learning to do - I have other automations that don’t have the - before the service: and even some of the examples don’t have it, such as this one:
But making the changes you suggested works perfectly! Not my water heater can turn on & off at the optimal times!
When there is one action the dash is not necessary.
The template switch is a switch btw, not a automation. As far as I know the examples in the docs are correct.
The condition in your automation is useless btw. It checks if today is one of the listed days, but all 7 days are listed. So it is always true. If that is what you want, you can leave it out.
