mattvirus
(Matt Virus)
1
Hass .93.2 running in hassbian.
2x Roborock S5 vacuums. using the ‘name’ configuration entity throws error.
vacuum:
- platform: xiaomi_miio
host: 10.x.x.x
token: xxxx
host: 10.xxxx
token: xxx
^^ this configuration throws the following error
If i comment out the ‘name’ line, there are no errors and hass will start, but I can’t clearly tell which vacuum is which.
Xaiomi Docs here - Xiaomi Miio - Home Assistant
show this:
host
(string)(Required)The IP address of your robot.
token
(string)(Required)The API token of your robot.
name
(string)(Optional)The name of your robot.
Default value: Xiaomi Vacuum cleaner
What am I missing? Thanks!
Either put quotes around basement vacuum
or replace the space with an underscore.
mattvirus
(Matt Virus)
3
Tried that already. Same result.
mattvirus
(Matt Virus)
4
Not sure what the heck was wrong with me yesterday — but…
Tried your suggestion again just now, and it works!
thanks so much!
varmluft
(peter)
5
Hi mattvirus,
sry for bumping, but i have a (silly) question. are you using the same token for the two vacums or is it the same one?
i just got an extra s5 and i cannot get a second token (I tried for days now).
br peter
EDIT:
I continued my search and came across this guide: Guide to retrieve Xiaomi Roborock (and other) tokens!
Started from scrach and this time it worked. (sometimes sleep and a restart can be a viable solution)
now i can see all my xiaomi tokens - one for each vac and sensor (i have a lot)
sry for the inconvenience.
/br
