Hi there! I am having major problems submitting the login form for https://www.bayrol-poolaccess.de
My config:
resource: ‘https://www.bayrol-poolaccess.de/webview/p/plants.php’
scan_interval: 30
log_response: true
form_submit:
submit_once: True
#resource: ‘https://www.bayrol-poolaccess.de’input:
username: ‘xxxxxxxxxx’
password: ‘rxxxxxxxx’
autologin: “false”
sensor:- select: ‘div > div:nth-child(2)’
Could someone please help me here?
Log:
2023-09-22 16:18:07.079 DEBUG (MainThread) [custom_components.multiscrape] # Start processing config from configuration.yaml
2023-09-22 16:18:07.079 DEBUG (MainThread) [custom_components.multiscrape] # Found no name for scraper, generated a unique name: Scraper_noname_0
2023-09-22 16:18:07.079 DEBUG (MainThread) [custom_components.multiscrape] Scraper_noname_0 # Setting up multiscrape with config:
2023-09-22 16:18:07.079 DEBUG (MainThread) [custom_components.multiscrape] Scraper_noname_0 # Log responses enabled, creating logging folder: /config/multiscrape/scraper_noname_0/
2023-09-22 16:18:07.081 DEBUG (MainThread) [custom_components.multiscrape.http] Scraper_noname_0 # Initializing http wrapper
2023-09-22 16:18:07.081 DEBUG (MainThread) [custom_components.multiscrape.form] Scraper_noname_0 # Initializing form submitter
2023-09-22 16:18:07.081 DEBUG (MainThread) [custom_components.multiscrape] Scraper_noname_0 # Initializing scraper
2023-09-22 16:18:07.081 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Initializing scraper
2023-09-22 16:18:07.081 DEBUG (MainThread) [custom_components.multiscrape] Scraper_noname_0 # Initializing coordinator
2023-09-22 16:18:07.081 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Scraper_noname_0 # Scan interval is 0:00:30
2023-09-22 16:18:07.083 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Scraper_noname_0 # New run: start (re)loading data from resource
2023-09-22 16:18:07.083 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Scraper_noname_0 # Deleting logging files from previous run
2023-09-22 16:18:07.085 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Scraper_noname_0 # Rendered resource template into: https://www.bayrol-poolaccess.de/webview/p/plants.php
2023-09-22 16:18:07.085 DEBUG (MainThread) [custom_components.multiscrape.form] Scraper_noname_0 # Starting with form-submit
2023-09-22 16:18:07.085 DEBUG (MainThread) [custom_components.multiscrape.form] Scraper_noname_0 # Skip scraping form, assuming all input is given in config.
2023-09-22 16:18:07.085 DEBUG (MainThread) [custom_components.multiscrape.form] Scraper_noname_0 # Merged input fields with input data in config. Result: {‘username’: ‘[email protected]’, ‘password’: ‘rybce9-kenxyh-tivTax’, ‘autologin’: ‘false’}
2023-09-22 16:18:07.085 DEBUG (MainThread) [custom_components.multiscrape.form] Scraper_noname_0 # Determined the url to submit the form to: https://www.bayrol-poolaccess.de/webview/p/plants.php
2023-09-22 16:18:07.085 DEBUG (MainThread) [custom_components.multiscrape.form] Scraper_noname_0 # Submitting the form
2023-09-22 16:18:07.085 DEBUG (MainThread) [custom_components.multiscrape.http] Scraper_noname_0 # Executing form_submit-request with a POST to url: https://www.bayrol-poolaccess.de/webview/p/plants.php.
2023-09-22 16:18:07.086 DEBUG (MainThread) [custom_components.multiscrape.http] Scraper_noname_0 # request_headers written to file: form_submit_request_headers.txt
2023-09-22 16:18:07.087 DEBUG (MainThread) [custom_components.multiscrape.http] Scraper_noname_0 # request_body written to file: form_submit_request_body.txt
2023-09-22 16:18:07.128 DEBUG (MainThread) [custom_components.multiscrape.http] Scraper_noname_0 # Response status code received: 200
2023-09-22 16:18:07.129 DEBUG (MainThread) [custom_components.multiscrape.http] Scraper_noname_0 # response_headers written to file: form_submit_response_headers.txt
2023-09-22 16:18:07.131 DEBUG (MainThread) [custom_components.multiscrape.http] Scraper_noname_0 # response_body written to file: form_submit_response_body.txt
2023-09-22 16:18:07.131 DEBUG (MainThread) [custom_components.multiscrape.form] Scraper_noname_0 # Form seems to be submitted succesfully (to be sure, use log_response and check file). Now continuing to retrieve target page.
2023-09-22 16:18:07.131 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Scraper_noname_0 # Using response from form-submit as data. Now ready to be scraped by sensors.
2023-09-22 16:18:07.131 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # Loading the content in BeautifulSoup.
2023-09-22 16:18:07.146 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # page_soup written to file: page_soup.txt
2023-09-22 16:18:07.146 DEBUG (MainThread) [custom_components.multiscrape.coordinator] Finished fetching multiscrape data in 0.064 seconds (success: True)
2023-09-22 16:18:07.147 DEBUG (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # pH_pool_muc # Setting up sensor
2023-09-22 16:18:07.152 DEBUG (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # pH_pool_muc # Start scraping to update sensor
2023-09-22 16:18:07.153 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # pH_pool_muc # Tag selected:
2023-09-22 16:18:07.153 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # pH_pool_muc # Selector result:
2023-09-22 16:18:07.153 DEBUG (MainThread) [custom_components.multiscrape.scraper] Scraper_noname_0 # pH_pool_muc # Final selector value:
2023-09-22 16:18:07.153 DEBUG (MainThread) [custom_components.multiscrape.sensor] Scraper_noname_0 # pH_pool_muc # Selected:
2023-09-22 16:18:07.153 DEBUG (MainThread) [custom_components.multiscrape.entity] Scraper_noname_0 # pH_pool_muc # Updated sensor and attributes, now adding to HA
Page_soup.txt still shows login page:
BAYROL Webportal div.field:nth-child(0){display:none;} #T5c01230d75 {width: 220px;}Bitte melden Sie sich mit Ihrer E-Mail-Adresse (=Benutzername) und Passwort an
