Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Thanks a LOT!
    card_mod:
      style: |
        ha-card {
          --control-height: 20px;
Thank you…
How to change the button colors for media player ?
Is it possible to blur the background image of a card? It can be challenging to read with busy cover art, adding a blur filter is blurring the whole card and I’m having a hard time targeting just the image
type: custom:mushroom-media-player-card
entity: media_player.andrews_room_media
use_media_artwork: true
use_media_info: true
collapsible_controls: true
show_volume_level: false
fill_container: false
tap_action:
  action: call-service
  service: media_player.media_play_pause
  data: {}
    entity_id: media_player.andrews_room_media
card_mod:
  style: |
    ha-card {
      border-radius: 16px 16px 0px 0px;
      {% if is_state(config.entity, 'playing') or is_state(config.entity, 'paused') %}
        background: rgba(var(--rgb-card-background-color), 0.7) url( '{{ state_attr(config.entity, "entity_picture" ) }}' ) center no-repeat;
        background-size: cover;
        background-blend-mode: overlay;
Your CSS is not quite right. Should be:
card_mod:
  style:
    mushroom-media-player-media-control$: |
      mushroom-button {
        --bg-color: rgba(var(--rgb-green), 0.05);
    mushroom-media-player-volume-control$: |
      mushroom-button {
      mushroom-button {
        --bg-color: rgba(var(--rgb-yellow), 0.05);
      :host {
        --mush-rgb-state-media-player: var(--rgb-pink);
How to add fonts to Home Assistant:
  1. Go to https://fonts.google.com/ and find the font you want to use.
  2. Select the font
    Add font
    and then view the selected font
    View selected font
  3. Copy the font URL
    Font URL
  4. In HA, go to Settings → Dashboards and then Resources in the top right corner
    Dashboard Resources
  5. Add the Resource as a Stylesheet
    and you should see your new font resource listed
    Check resource
  6. Go back to Google Fonts and copy the CSS Rule for the font
    CSS rule
  7. Add the CSS to your card
type: custom:mushroom-template-card
icon: mdi:mushroom
icon_color: orange
primary: Mushroom
card_mod:
  style:
    mushroom-state-info$: |
      .primary {
        font-family: 'Bungee Spice', cursive;
        --card-primary-font-size: 30px;
  1. Or to your theme if you want to use it globally
    # Fonts
    primary-font-family: 'Bungee Spice, cursive'
    paper-font-common-base_-_font-family: "var(--primary-font-family)"
    paper-font-common-code_-_font-family: "var(--primary-font-family)"
    paper-font-body1_-_font-family: "var(--primary-font-family)"
    paper-font-subhead_-_font-family: "var(--primary-font-family)"
    paper-font-headline_-_font-family: "var(--primary-font-family)"
    paper-font-caption_-_font-family: "var(--primary-font-family)"
    paper-font-title_-_font-family: "var(--primary-font-family)"
    ha-card-header-font-family: "var(--primary-font-family)"
Exactly copy-pasted your code but still only the icon color is changing along with slider.
entity: media_player.music
volume_controls:
  - volume_mute
  - volume_set
  - volume_buttons
card_mod:
  style:
      mushroom-button {
      mushroom-button {
      mushroom-button {
      :host {
What am I doing wrong ?
Looks like the opacity of the colour is turned wayy down try changing the 0.05 value up to something like 0.2
card_mod:
  style:
      mushroom-button {
        --bg-color: rgba(var(--rgb-green), 0.2);
      mushroom-button {
      mushroom-button {
        --bg-color: rgba(var(--rgb-yellow), 0.5);
      :host {
thank you @theandouz @rhysb, changing the opacity worked…
  1. Please guide how to change the color from white to any color of the icons (the blue encircled ones)?
  2. How to change the color of the media_info e.g. “Music” and “Playing” in this case?
    Screenshot (44)
Thank you…
You can like this:
card_mod:
  style:
      mushroom-button {
        --primary-text-color: rgb(var(--rgb-green));
      mushroom-button {
        --bg-color: rgba(var(--rgb-blue), 0.2);
        --primary-text-color: rgb(var(--rgb-blue));
      mushroom-button {
        --bg-color: rgba(var(--rgb-yellow), 0.2);
        --primary-text-color: rgb(var(--rgb-yellow));
      :host {
        --secondary-text-color: rgb(var(--rgb-cyan));
What can I add in the mushroom theme yaml to change the color of the chips icon when the entity is inactive?
I would like to make them darker
Thank you
Can you share the code?
Thank you so much @rhysb… Really appreciate your help… :smiling_face_with_three_hearts:
One more query… how to shift the slider and the button towards the center to make it align with primary and secondary info. I used the below code to reduce the height of the slider.
                  ha-card {
                  --control-height: 25px;
Can I place some buttons to cal services where secondary_info normally is?
You can like this:
      .actions {
        align-items: center !important;
Change mush-rgb-disabled for light and dark themes.
    modes:
        light:
            mush-rgb-disabled: 189, 189, 189
        dark:
            mush-rgb-disabled: 111, 111, 111
Thank you,
I have tryied to change those colors, but nothing changed…
It is enought to use the service “reload theme”?
Just tested and works for me with a reload.
I can see that now is not even using the color 111, 111, 111, but pure white.
I will reload HA and come back…
Nothing, I can change theme, update theme, but it not using the color 111, 111, 111,
@rhysb can you shere yout theme yaml?
Thank you
