Hi, after I installed it via HACS and rebooted, the cards donāt show up when I try to customize my dashboard. Is there anything else I need to install?
You can specify an upper_bound
, lower_bound
or min_bound_range
for the primary and secondary Y-axis.
lower_bound | number or string | v0.2.3 | Set a fixed lower bound for the graph Y-axis. String value starting with ~ (e.g. ~50) specifies soft bound. | |
upper_bound | number or string | v0.2.3 | Set a fixed upper bound for the graph Y-axis. String value starting with ~ (e.g. ~50) specifies soft bound. | |
min_bound_range | number | v0.x.x | Applied after everything, makes sure thereās a minimum range that the Y-axis will have. Useful for not making small changes look large because of scale. | |
lower_bound_secondary | number or string | v0.5.0 | Set a fixed lower bound for the graph secondary Y-axis. String value starting with ~ (e.g. ~50) specifies soft bound. | |
upper_bound_secondary | number or string | v0.5.0 | Set a fixed upper bound for the graph secondary Y-axis. String value starting with ~ (e.g. ~50) specifies soft bound. | |
min_bound_range_secondary | number | v0.x.x | Applied after everything, makes sure thereās a minimum range that the secondary Y-axis will have. Useful for not making small changes look large because of scale. |
Like this:
type: custom:vertical-stack-in-card
cards:
- type: grid
square: false
columns: 2
cards:
- type: custom:mushroom-entity-card
entity: sensor.rhys_office_sensor_temperature
primary_info: state
secondary_info: name
icon_color: green
entity: sensor.rhys_office_sensor_humidity
primary_info: state
icon_color: blue
- type: custom:mini-graph-card
entities:
- entity: sensor.rhys_office_sensor_temperature
color: rgb(var(--rgb-green-color))
- entity: sensor.rhys_office_sensor_humidity
color: rgb(var(--rgb-blue-color))
y_axis: secondary
min_bound_range: 10
min_bound_range_secondary: 20
hours_to_show: 24
line_width: 3
font_size: 50
animate: true
show:
icon: false
state: false
legend: false
fill: fade
Full documentation for Mini Graph Card here:
Do you occasionally read this thread? That is evident in quite a few posts.
You can fade in chips permanently or fade them in like other cards depending on conditions.
Just browse through or look only at the posts of Rhys in this thread, then you will definitely find.
Have a look here as an example.
Greetings Moss
Just recently I made the move from the minimalist UI to Mushroom cards.
Redesigned my dashboard and really happy with it.
There is one thing I couldnāt figure out, and that is a chip with 2 values.
Like indoor and outdoor temperature or
Consumed and produced energy, who can give me an example of this?
Like this?
type: custom:mushroom-chips-card
chips:
- type: template
icon: mdi:thermometer
content: |-
Inside {{ states('sensor.your_room') }} | Outside {{
states('sensor.your_town') }}
I used this solution for local files.
How I can make icon as a picture more flat so flag image is rectangle?
flag image size 532x302
type: custom:mushroom-template-card
picture: /local/formula1/flags/United_Arab_Emirates.jpg
primary: ABU DHABI GRAND PRIX 2022
secondary: 18 NOV 2022 - 20 NOV 2022
layout: vertical
card_mod:
style: |
ha-card {
font-family: "Formula1-regular";
--card-primary-font-size: 16px;
--card-secondary-font-size: 12px;
:host {
--mush-icon-border-radius: 6px;
Yeah perfect!,
Hi again,
Is it possible to have a floating card? What I want is to have condition card (alarm, birthdays and so on) floating over de other cards, that you also can dismiss when needed!?
Best regards
Thekholm
Thanks,
I havenāt found a conditional chip that is shown while there is a value and hidden when not.
Yep, added one for you.
You can do it like this:
chips:
- type: conditional
conditions:
- entity: sensor.lounge_sensor_temperature
state_not: 'null'
chip:
type: entity
If you want to use the original aspect ratio, you can do it like this:
layout: vertical
card_mod:
style:
mushroom-shape-avatar$: |
.picture {
height: auto !important;
ha-card {
:host {
A work in progress with Netflix/FireTV-AndroidTV page. It will include :
- A live view of AndroidTV screen
- Fast remote control
- Start Netlix shows
- Tv Usage statistics
- App starting buttons
- Alexa integration of non amazon store contents
- Bypass netflix auth. screen and start show directly
- tv and all other IR controls can be made from the page
This is a work in progress and wiki page will be ready soon.
Thanks for adding the correct Yaml code!
So I created something similar, without changing your config and when I look at my mobileā¦I donāt have the issue youāre experiencing
The only change Iāve made, is that I use the vertical-stack-in-card instead.
Someone who can help to make the slider less in height?
Any advise?
I have 2 side by side in one column in the mobile screen. I think your screenshot is just 1 over the full screen, not?
p.s. strange that you have this bar behind the icons.
Hi, can you explain how create all sensors? thank you
I just took a screenshot of my mobile phone screen.
I donāt have a dashboard made for mobile or whatsoever. I took only your config, changed stack-in-card to vertical-stack-in-card and amended the sensors to my personal sensors. Thatās it
I absolut love this! You have helped me so much and it looks so great. There is just one thing I canāt figure out. I want to have a background color in the card and also animate the Icon. I got both working separately, but I canāt figure out how to get both at the same time.
primary: '{{ state_attr(''binary_sensor.warning_blaubeuren_stadt_1'',''headline'') }}'
secondary: '{{ state_attr(''binary_sensor.warning_blaubeuren_stadt_1'',''description'') }}'
icon: mdi:alert-circle
entity: binary_sensor.warning_blaubeuren_stadt_1
multiline_secondary: true
icon_color: white
card_mod:
style:
mushroom-shape-icon$: |
.shape {
--shape-animation: ping 1.5s infinite, blink 1.5s ease-in-out infinite;;
@keyframes ping {
0% { box-shadow: 0 0 0 0 rgba(var(--rgb-white), 0.7); }
100% { box-shadow: 0 0 5px 15px transparent; }
@keyframes blink {
100% {opacity: 0;}
mushroom-state-info$: |
{% if (states.binary_sensor.warning_blaubeuren_stadt_1.attributes.severity=='Severe')%}
ha-card {
background: red;
--primary-text-color: AliceBlue;
--secondary-text-color: white
This is my current try. Some help would be greatly appreciated
