Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
badge_icon: |-
  {%- set event = as_timestamp(states(config.entity)) %}
  {%- set now = as_timestamp(now()) %}
  {% if (now) > (event) %}
  mdi:exclamation-thick
  {% endif%}
Figured that one out.
Try like this:
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-orange)) {{ ((states(config.entity) | as_datetime | as_local - now()).days + 1) / 30 * 100 }}% 0%, var(--card-background-color) 0% 100%);
      .shape:after {
        content: "";
        height: 100%;
        width: 100%;
        position: absolute;
        border-radius: 50%;
        background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
    mushroom-state-info$: |
      .primary:after {
        content: " (30 Days)";
        color: rgb(var(--card-background-color));
        font-style: bold;
        font-size: 10px
      mushroom-badge-icon {
        top: 30px;
Hey guys,
Is it possible to use animation in mushroom chip cards? I can figure it up…if it is possible can someone please reply here with an example code so I can see how?
Thank you guys!
Have a look here:
How can I add empty line breaks?
If I add two line breaks to get two entities to the same point it only works if I add something like that “\n\n-” if I only add two “\n\n” the line breaks disappear?!
Thanks, Steffen
Awesome… will try :smiling_face_with_three_hearts:
Yepp… Sweden! Winter is coming :sweat_smile:
Edit* Works great! You are best :smiling_face_with_three_hearts:
Hi everyone,
how can i translate this into mushroom.
So from custom buton card to Mushroom template card.
Thanks.
type: custom:button-card
        entity: sensor.deebot_t8_queue_corridor
        icon: mdi:shoe-print
        state:
          - styles:
              icon:
                - color: var(--card-background-color)
              name:
              card:
                - background-color: rgba(77, 163, 100, 0.5)
            operator: '>='
            value: 1
        styles:
          name:
            - font-weight: bold
          card:
            - font-size: 12px
            - width: null
            - height: 60px
            - color: var(--secondary-text-color)
          icon:
          grid:
            - position: relative
          custom_fields:
            notification:
              - display: |
                    if (entity.state == "0")
                      return "none";
                    return "block";
              - position: absolute
              - right: 5%
              - top: 5%
              - height: 20px
              - width: 20px
              - font-size: 15px
              - font-weight: bold
              - line-height: 20px
        custom_fields:
          notification: |
            [[[ return entity.state ]]]
        tap_action:
          action: call-service
          service: script.deebot_room_queue
          service_data:
            queue: deebot_t8_queue
            room: corridor
Hi, I will reduce this space, can you help me?
Which is the custom parameter to modify in YAML file?
Immagine 2022-11-26 193354
Hi!
Could you help me out?
they look like sh*t :frowning:
                    card_mod:
                      style:
                        .entity:nth-child(2)$: |
                          :host {
                            {{ '--paper-item-icon-color: blue ;' if is_state('input_select.washer_status', 'On')}}
                          state-badge {
                            {{ 'animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;' if is_state('input_select.washer_status', 'On') }}
                            transform-origin: 50% 110%;
                          @keyframes shake {
                            0%, 100% { transform: translate(0, 0) rotate(0); }
                            20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
                            40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
                            60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
                            80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
                          @keyframes drum  {
                            50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
                        .entity:nth-child(3)$: |
                          :host {
                            {{ '--paper-item-icon-color: blue ;' if is_state('input_select.dryer_status', 'On')}}
                          state-badge {
                            {{ 'animation: shake 400ms ease-in-out infinite, drum 1s infinite;' if is_state('input_select.dryer_status', 'On') }}
                            transform-origin: 50% 65%;
                          @keyframes shake  {
                            0%, 100% { transform: rotate(4deg); }
                            50%  { transform: rotate(-4deg); }
                          @keyframes drum  {
                            50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
                          ha-card {
                            margin-top: -20px;
                            margin-bottom: -20px;
                            box-shadow: none;
                            background: rgba(0, 0, 0, 0);
What card are you trying to apply it to? Selectors are not from any Mushroom cards.
You can reduce the card margin width by adding masonry-view-card-margin: 2px 2px 4px to your theme. For the Grid Card you add grid-card-gap: 4px to your theme.
Thanks!
Now, is good but not all is good (sorry for my english).
I use mushroom-template-card in vertical-stack-in-card
to a glance card:
                  - show_name: false
                    show_icon: true
                    show_state: false
                    state_color: true
                    theme: mushroom_room
                    type: glance
                    entities:
                      - entity: switch.basement
                        icon: mdi:lightbulb
                        tap_action:
                          action: toggle
                      - entity: input_select.washer_status
                        icon: mdi:washing-machine
                      - entity: input_select.dryer_status
                        icon: mdi:tumble-dryer
Would it be easier to modify it if i use another card?
would kind of like to have minimalistic room card style.
Nobody have a hint to add empty lines?
I have try many things but I always have to add a character or the line is deleted if there is only a line break with a \n.
Thansk, Steffen
Hi there,
I have following code:
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: masonry
    layout: {}
    cards:
        entity: climate.spalna_teplota
        primary: Spálňa
        secondary: >-
          {{ states('sensor.58_2d_34_3a_1f_f3_temperature') }} °C | Ventil
          otvorený na {{ states('sensor.spalna_ventil') }} %
        icon: mdi:bed
        icon_color: |
          {% if is_state('sensor.spalna_ventil', '0.00') %}
          grey
          {% else %}
          red
          {% endif %}
        layout: horizontal
        fill_container: true
        multiline_secondary: true
        card_mod:
          style:
              {%- set sensor = states('sensor.spalna_ventil') %}
              {%- if sensor >= 0.00 %}
                ha-icon {
                  --icon-animation: pulse 2s ease-in-out infinite;
      - type: custom:mushroom-climate-card
        icon_type: none
        primary_info: none
        secondary_info: none
        show_temperature_control: true
        collapsible_controls: true
        card_mod:
          style:
            mushroom-climate-temperature-control$:
              mushroom-input-number$: |
                #container {
                background: none;
                padding: 0px;
                #container .button {
                height: 100%;
                width: 30%;
                #container .button:nth-child(1) {
                background: rgba(var(--rgb-blue), 0.7);
                #container .button:nth-child(3) {
                background: rgba(var(--rgb-red), 0.7);
I want to achieve bigger icon size and working animation, if the senzor value is bigger as 0.00.
Thanks for reply.
Prehľad_–_Home_Assistant
Hello everyone,
Are there any guides on recommended colours to use ?
Hi @rhysb,
Although, used vertical-stack-in-card
but the inner mushroom-template-card still shows the borders.
How to hide it.
Here is my code:
type: custom:vertical-stack-in-card
cards:
    entity: person.admin
    layout: vertical
    picture: /local/img/avatar.png
    primary: '{{- states(''person.admin'') -}}'
    secondary: null
    badge_icon: '{{- state_attr(''person.admin'',''icon'') -}}'
    badge_color: |-
      {% if is_state('person.admin','home') %}
        green
      {% elif is_state('person.admin','nothome') %}
        red
      {% else %}
        orange
      {% endif %}
    tap_action:
      action: more-info
  - type: custom:mushroom-chips-card
    alignment: center
    chips:
      - type: template
        entity: fds_iphone_xr_battery_level
        content_info: none
        icon: >-
          {% set bl = states('sensor.fds_iphone_xr_battery_level') | int %} {%
          if bl < 10 %} mdi:battery-outline {% elif bl < 20 %} mdi:battery-10 {%
          elif bl < 30 %} mdi:battery-20 {% elif bl < 40 %} mdi:battery-30 {%
          elif bl < 50 %} mdi:battery-40 {% elif bl < 60 %} mdi:battery-50 {%
          elif bl < 70 %} mdi:battery-60 {% elif bl < 80 %} mdi:battery-70 {%
          elif bl < 90 %} mdi:battery-80 {% elif bl < 100 %} mdi:battery-90 {%
          elif bl == 100 %} mdi:battery {% else %} mdi:battery-unknown {% endif
        icon_color: >-
          if bl < 10 %} red {% elif bl < 20 %} red {% elif bl < 30 %} orange {%
          elif bl < 40 %} orange {% elif bl < 50 %} yellow {% elif bl < 60 %}
          yellow {% elif bl < 70 %} green {% elif bl < 80 %} green {% elif bl <
          90 %} green {% elif bl < 100 %} green {% elif bl == 100 %} green {%
          else %} grey {% endif %}
        tap_action:
          action: more-info
Share the full code. That snippet doesn’t produce the issue.
I presume you mean Vertical Stack. Try using vertical-stack-card-margin: 2px
I would suggest using Mushroom Chips instead. There is documentation and plenty of examples for applying the animations to Chips.
If you wanted to use them on glance cards, you would need to redo/adjust the clip-path for the state-badge which is slightly larger that the icon.
