Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
  • *I think you are looking for margins. Padding would be on the individual cards.
example settings
margin: 25px 50px 75px;
  • top margin is 25px
  • right and left margins are 50px
  • bottom margin is 75px
type: custom:mod-card
style: |
  ha-card {
    --ha-card-header-color: red;
    --ha-card-header-font-size: 20px;
    --vertical-stack-card-margin: 0px 20px 10px 20px;
card:
  type: vertical-stack
  title: Zeit & Wetter
  cards:
    - type: entity
      entity: sensor.date_time
    - show_current: true
      show_forecast: true
      type: weather-forecast
      entity: weather.forecast_home
      forecast_type: daily
Found a better way
card:
  cards:
    - type: entity
      show_forecast: true
card_mod:
  style: |
    ha-card {
      padding-top:30px;
      color: red !important;
      font-size: 10px;
      --ha-card-header-color: blue  !important;
Nearly… I would like to reduce the spaceing before and after the heading/title. With padding it adds a space only, or I’m wrong?
just use a negative number, -10px for example.
It does not work for me unfortunately. I think to use “custom:mushroom-title-card”. Would it be possible there to reduce the spacing here somehow?
My code
cards:
  - type: custom:mushroom-title-card
    title_tap_action:
      action: navigate
      navigation_path: /dashboard-test/sicherheit
  - type: entity
    show_forecast: true
This should work. I’ll direct message you as well.
cards:
    title_tap_action:
      action: navigate
    card_mod:
      style: |
        ha-card {
        --title-padding: 10px 10px 1px;
        --title-font-size: 15px;
        --primary-text-color: red;
        --title-font-weight: 400;
  - type: entity
    show_forecast: true
Many thanks!!
How to add battery info in the secondary_info of mushroom-cover-card?
type: custom:mushroom-cover-card
entity: cover.cover_first_floor
name: Cover First Floor
show_position_control: true
show_buttons_control: true
primary_info: name
tap_action:
  action: none
hold_action:
  action: more-info
double_tap_action:
  action: none
secondary_info: state
I want the secondary_info shows “Open 50% | battery 97%”.
Anyone can help?
Please use the back tick to post your code. #11
Yes, what you’re looking for is possible if you have card-mod installed.
I do have card_mod installed. @LiQuid_cOOled Can you please share your code?
Thanks.
You could also adjust the % color based on the battery level.
type: custom:stack-in-card
cards:
    title: Bedroom Curtains
  - type: custom:layout-card
    layout_type: custom:grid-layout
    layout:
      grid-template-columns: 1fr
      margin: 0px 0px 0px 0px
    cards:
      - type: custom:mushroom-cover-card
        entity: cover.pc_curtains
        show_tilt_position_control: false
        layout: horizontal
        card_mod:
          style: |
            ha-state-icon:after {
            content: " {{ states('sensor.pc_curtains_battery') }}%";
            background: none;
            font-size: 10px;
            font-weight: 500;
            border-width: 2px;
            border-radius: 50%;
            margin-top: 29px;
            margin-left: 125px;
            position: absolute;
            color: yellow;
card_mod:
  style: |
    ha-card {
     border:none !important;
If you want to change the color based on the battery level add this code to color:
color:  {% if states('sensor.pc_curtains_battery') | int < 15 %}
                     red
                    {% elif states('sensor.pc_curtains_battery') | int < 50 %}
                     yellow
                     lime
Entire card code
cards:
    layout:
    cards:
        layout: horizontal
        card_mod:
          style: |
            background: none;
            font-size: 10px;
            font-weight: 500;
            border-width: 2px;
            border-radius: 50%;
            margin-top: 29px;
            margin-left: 130px;
            position: absolute;
                     red
                     yellow
                     lime
        entity: cover.bed_curtains
        layout: horizontal
        card_mod:
          style: |
            content: " {{ states('sensor.bed_curtains_battery') }}%";
            background: none;
            font-size: 10px;
            font-weight: 500;
            border-width: 2px;
            border-radius: 50%;
            margin-top: 29px;
            margin-left: 130px;
            position: absolute;
            color:  {% if states('sensor.bed_curtains_battery') | int < 15 %}
                     red
                    {% elif states('sensor.bed_curtains_battery') | int < 50 %}
                     yellow
                    lime
        entity: cover.tv_curtains
        layout: horizontal
        card_mod:
          style: |
            content: " {{ states('sensor.tv_curtains_battery') }}%";
            background: none;
            font-size: 10px;
            font-weight: 500;
            border-width: 2px;
            border-radius: 50%;
            margin-top: 29px;
            margin-left: 130px;
            position: absolute;
            color:  {% if states('sensor.tv_curtains_battery') | int < 15 %}
                     red
                    {% elif states('sensor.tv_curtains_battery') | int < 50 %}
                     yellow
                     lime
card_mod:
  style: |
    ha-card {
did you found a solution for the conditial card with numeric condition
edit: solution here
it is done like this. the syntax is wrong for what he posted.
type: custom:mushroom-chips-card
chips:
  - type: conditional
    conditions:
      - condition: numeric_state
        entity: sensor.all_standby_energy
        above: 0
        below: 1000
    chip:
      type: template
      icon: mdi:test-tube
Yes. Thanks. i already found it and posted the solution in the other post
“The other post” ? did you cross post the same question somewhere else? your initial question is not edited with the solution.
sorry. Changed the post …
I need some advise. I have this webrtc cards without grids, but how can I make 2 columns only in mobile? So I can see more cameras?
Thank you
There is a way to size up the circle/shadow behind the icon ?
type: custom:mushroom-light-card
entity: light.light_livingroom
use_light_color: true
show_brightness_control: true
show_color_temp_control: true
layout: horizontal
show_color_control: true
collapsible_controls: false
icon: mdi:coat-rack
fill_container: false
secondary_info: none
card_mod:
          style: |
            :host {
              --mush-icon-symbol-size: 65px;
            ha-card {
               border: none !important;
               box-shadow: none !important;
I can’t use the mush-icon-size because the light control bar don’t align the middle of the logo compared to mush-icon-symbol-size
Take a look at the guide linked in my profile :slight_smile:
