I believe this will get you what you want. @media is used is to apply different styles for different media types/devices.
Adjust the @media screen and (max-width: 400px) {
to your liking
type: custom:mushroom-template-card
primary: Airwick
icon: mdi:spray
icon_color: |-
{% if is_state('switch.toilet_airwick_valve', 'on') %}
red
{% else %}
teal
{% endif %}
layout: vertical
entity: switch.toilet_airwick_valve
card_mod:
style: |
ha-card {
border: none !important;
box-shadow: 0px 0px;
ha-card:after {
content: "{{ states('counter.toilet_airwick_total') }}";
position: absolute;
display: flex;
justify-content: center;
align-items: center;
background: rgb(var(--rgb-orange));
color: var(--card-background-color);
font-weight: bolder;
border-radius: 50%;
top: +10px;
right: +45px;
width: 21px;
height: 21px;
font-size: 11px;
:host {
--icon-size: 64px !important;
perspective: 900px;
ha-card:active {
transform: rotateX(25deg);
transform-origin: center bottom;
transition: 0s;
mushroom-shape-icon {
--shape-color: none !important;
--shape-color-disabled: none !important;}
ha-card:after {
position: absolute;
border-radius: 50%;
top: 10px;
right: 55px;
width: 21px;
height: 21px;
font-size: 11px;
This is amazing homie, thanks
right: +20px;
No problem, happy to help!
wgumaa
(Waleed)
February 12, 2024, 9:07am
10117
Hello everyone,
I am building a custom mushroom-template-card for my washing machine.
It looks like this:
I have the primary info showing “Running” and the secondary info showing time and spin speed.
Is there a way to display the secondary info over 2 lines as opposed to having them on the same line? My current code looks like this:
secondary: >
Time - {{states('sensor.electrolux_sawa_washing_machine_timetoend')}} Min
Spin
{{states('select.electrolux_sawa_washing_machine_userselections_analogspinspeed')}
gbboy
February 12, 2024, 9:29am
10118
I’m sure there is a more elegant way to do it with the custom mushroom cards but using card mod on e.g. a tile card I would do the following using white-space and \A to do a line break:
ha-tile-info$: |
.secondary:after {
visibility: visible;
content: "Time - {{ states('sensor.electrolux_sawa_washing_machine_timetoend') }} Min \A Spin {{ states('select.electrolux_sawa_washing_machine_userselections_analogspinspeed') }} %";
white-space: pre-wrap;
Obviously you would need to adapt to the correct styling but just an example
flrnwrzl
February 12, 2024, 10:09am
10119
Hello I have a problem on mobile with the template cards.
For seome reason it only shows me the text in grey instead of black . but only on mobile.
i have set the color of text in the card mod with:
--primary-text-color: Black;
--secondary-text-color: Black;
what can it be?
Try changing to and avoid capitalizations
--card-primary-color: black;
--card-secondary-color: black;
Clear your web browser’s cache and can you post your full card code?
You also have the ability to set mobile only settings with @media screen and (max-width: 400px) {
flrnwrzl
February 12, 2024, 10:19am
10123
sure
primary: '{{states(''sensor.inverter_1_yield_today'')}} kW'
secondary: Heute
icon: mdi:lightning-bolt
icon_color: none
fill_container: true
entity: sensor.inverter_1_yield_today
tap_action:
action: more-info
card_mod:
style: |
ha-card {
background:
{% if states('sensor.inverter_1_bt2240102870_realtime_power') < '0.001'%}
rgb(255, 255, 190)
{% elif states('sensor.inverter_1_bt2240102870_realtime_power') >'0.001'%}
rgb(255, 255, 80)
{%endif%};
border: none;
border-radius: 25px;
--icon-symbol-size: 35px;
--card-secondary-font-weight: Regular;
transition: 0s;
→ dont want to overcomplicate it
As you are using a mushroom template card, this is what I use:
multiline_secondary: true
secondary: |
{{ ((states('sensor.pv_inverter_pv_dc_power_input') | float(0) ) / 0.1027) | round(0,default=0) }}%
{{ states('sensor.pv_inverter_pv_dc_power_input')| float(0) | round(3) }}kW
{{ ((states('sensor.pv_inverter_pv_dc_power_input') | float(0) * 1000) / 47.306016 ) | round(0,default=0) }}W/m²
{{ ((states('sensor.pv_inverter_dc_current_east') | float(0) + states('sensor.pv_inverter_dc_current_west') | float(0)) / 2) | round(1,default=0) }}A
does this work on both?
primary: |
{{states('sensor.inverter_1_yield_today')}} kW
secondary: Heute
icon_color: none
tap_action:
action: more-info
card_mod:
style: |
ha-card {
background:
rgb(255, 255, 190)
rgb(255, 255, 80)
{%endif%}
border: none;
--card-primary-color: black !important;
--card-secondary-color: black !important;
--card-secondary-font-weight: 400;
transition: 0s;
flrnwrzl
February 12, 2024, 10:28am
10126
unfortunatelly not.
Same result
grey on WEB
grey icon and black text on Mobile
funny thing. it worked before perfectly until update to HA 2024.02
your icon color says none. We have to move your if statement up there. Give me a minute.
flrnwrzl
February 12, 2024, 10:29am
10128
yes because i want it black.
thanks please help
This is what I see with this code.
primary: |
secondary: Heute
icon_color: black
tap_action:
action: more-info
card_mod:
style: |
ha-card {
border: none;
transition: 0s;
background:
rgb(255, 255, 190)
rgb(255, 255, 80)
{%endif%}
SoulAssassin
(Anton Stolov)
February 12, 2024, 10:37am
10130
Guys, 'bout chips, it possible to get animate?
add !important;
after the color black and do you have a theme installed?
