If I change mush-chip-height: 36px
to 60px for example, I get big chips, nothing else needed.
Have you reloaded the theme after making changes?
I had to restart HA to get it working, strange as some template changes are direct visibleā¦ but sorted it outā¦
thanks
What an amazing collection of cards! I rebuilt my entire dashboard, 150+ devices, in just a few hours. I was worried about the lack of customization, but its amazing how flexible the template card is as well as the chip template card. Very, very nice work. Iām also pleased at how much complexity was removed, and how much YAML was eliminated - even if I am very comfortable working with it. And my dashboard is even more beautiful now!
One question - is it possible to use mdi icons in the title card? I inserted unicode icons easily, but would prefer to use MDI for UI consistency.
I will be eagerly following this project
In the inactive state, how to adjust the color of the status bar is not visible in all dark templatesā¦
Going to need some info on that sidebar. It looks great.
Iāve explained the details of the sidebar and shared the code in my other replies. Hope it helps!
Iām experiencing this same issue in my dark theme as well. Anyone have any ideas? Or my guess is there may need to be an adjustment in the code for the slider card in Mushroom.
Is there plans to make the room card from minimalist in mushroom?
would you mind sharing / shwoing your dashboards ?
I;m sure there would be plenty of requests to share the code
hello,
I used header_cards to put chips in it. I changed the size of the chips but itās not aligned
how could i lower the chips to align them?
my code:
header_cards:
cards:
- type: glance
entities:
- entity: alarm_control_panel.54ef44273cc1_alarm
- entity: group.grp_portes
style: |
:host {
--mdc-icon-size: 26px;
- entity: group.grp_fenetres
- entity: sun.sun
- entity: sensor.moon
show_name: false
show_icon: true
show_state: false
style: |
ha-card {
background-color: transparent;
box-shadow: none;
:host {
--mdc-icon-size: 23px;
- type: custom:mushroom-chips-card
chips:
- type: weather
entity: weather.xxxxxxxxx
show_conditions: false
show_temperature: true
style: |
ha-card {
box-shadow: none;
- type: entity
entity: sensor.xxxxxxxxx_wind_speed
style: |
:host {
--card-mod-icon-color: #44739e;
ha-card {
box-shadow: none;
For those who use Card-Mod, hereās a small example how to bypass the limitations of the default Conditional Card in Mushroom Chip Card:
chips:
- type: ā¦
card_mod:
style: |
:host { display:
{% set x = ['unavailable', 'unknown', 'none'] %}
{% set e = states('sensor.mobile_battery_level') %}
{% set b = (e|float(100) <= 35) %}
{{ 'inline' if b or e in x else 'none' }}; }
Again, awesome and beautiful cards! Ive used them extensively and am stuck on three areas:
#1. Iām on HA 2022.3.3 and use HA/Mushroom on a Mac with MacOS 12.3/Safari and on iOS running 15.4. Frequently when returning from a different app Iām unable to activate any of the controls with sliders. A quick refresh solves this and they work again, but it happens dozens of times a day. Thoughts? I can open an issue on Github if necessary.
#2. I looked through the Mushroom Theme documentation and figured out how to change the font and chip sizes easily, but I havenāt been able to figure out how to change the background color on the title card. Running either no theme or the Mushroom theme shows a black background while all other cards are grey. Iām looking too make it match for consistency.
#3 Is it possible to change the icon color in the cards? I see several of the cards have a single icon color setting, but my issue is that Mushroom uses different colors then Home Assistant. For example, an open door in HA is yellow, and a closed door is blue, while an unavailable door is grey. In Mushroom, an open door is blue, and a closed door is grey. Iām finding this very confusing when Iāve been used to the colors for a long time, and of course my entire dashboard isnāt Mushroom (yet) . There doesnāt seem to be any CSS variables for those that I could find. I can, of course, use the template card and have done this successfully, but this requires me to write YAML for every card which I donāt really have the time for. I also tried to look at mushroom.js, but Iām not a javascript guy and wasnāt able to get very far.
Issue 1 also is there on Android 12, one UI 4.0.
Thankās for your message
#1 itās a known issue. Some people reported it. I just pushed a fix with the 1.2.6 version
#2 #3 The documentation and guidelines must be improved.
The rules about the colors are different from HA.
- active state => colored
- unactive state => grey
- unavailable state => grey with a orange badge
We preferred to use a badge instead of just color to better show the difference with a normal state.
If you want custom color, you can look at the template card for now.
Is there a way when using the template card for an input_setect entity to have it a color whin it as a specific option and all other options itās grey?
Yep you can use template to define color.
type: custom:mushroom-template-card
icon: mdi:movie-filter-outline
entity: input_select.movie_mode
secondary: Cinema
icon_color: '{{ iif(is_state(entity, "Cinema"), "deep-purple", "") }}'
Set your primary-text-color to a HEX rather than an RGBA value.
The slider converts the HEX for primrary-text-color and then applies an alpha channel. If you already have RGBA setup for primary-text-color the slider doesnt get a colour.
For the upcoming climate card, hopefully we can get a card background color option like in the Behance and Minimalist UI? It looks super cool. Thank you for your great work
Thank Youā¦
Hello!
Amazing cards! One suggestion I have though is to add a small notification that shows the % you are adjusting to, for brightness, cover position, temperature etcā¦
