Hello, thank you for your work, I am using this card everywhere, I have a question, can you tell me if it is possible to invert this colors in the position slider of a cover card, I am trying with Card-Mod but it nothing, I want the darker color in the place of the light one and vice versa. thanks so much
Thanks for your input. I haven’t had a single failure yet on 1.2.6 regarding the sliders - In addition to no longer experiencing the ‘dead’ controls issue, I find them easier to work now - like it seems you don’t have to be exactly on the edge of the control for them to work - much better!
Thanks for your input on the colors - I actually think that I’m warming to the way you handled it out of the box now. It also helps that instead of 50/50 Mushroom/HA controls my dashboard is more like 90/10 now
How can I Change the icon color based on attribute state?
entity: media_player.home_theater
attr: source
data: Blu-ray
Thank you,
Attribute is source
and what is data
in this context? Is it a nested attribute?
I think I got what you mean. Must be sth like
{{ 'green' if state_attr('media_player.home_theater', 'source') == 'Blu-ray' else 'red' }}
I can give you more details if you post a snapshot of the attributes list.
It works !
Thank you again…
Would love to make the icons slightly bigger, anyone know of an easy way to modify the .js file to make this change for all card icons instead of for each card independently?
Have tried with card-mod as well but my css isn’t up to snuff I guess.
Should be possible with a theme
You can already change the chip size, the border-radius etc… It can be a good idea to add icon size too : GitHub - piitaya/lovelace-mushroom-themes: Additional themes for Lovelace Mushroom Cards 🍄
I’m busy at the moment and I don’t have much time to work on Mushroom but that will change
Were you ever able to figure this out without using layout card? Or care to explain how you do that? Im making a dashboard right now for my tablet and im using badges, however id love to use Chips instead, but cant find a way to center over two grids like yours.
Do you mind sharing how you placed the chips in one row like that? I haven’t been able to figure out a grid with layout card.
@Roflcopterer, @rolfokevin, you can use the Mush Chip Card as badge on top of all other cards:
The only caveat: Editing is done via the raw config (copy & paste)
- theme: Backend-selected
title: []
icon: mdi:toolbox-outline
badges:
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: xxx
- type: entity
entity: xxx
- type: … and so on
alignment: center
Oh that is great, thanks!
can I adjust the font size for the chip card, it is quite small for me. Thanks
Update: I did it by mushroom theme
Is there any way to use this card for an input_number helper just with a slider?
Has anyone found a way to create a shortcut to the Raw Config Editor?
Similar to the way the menu chip works, I would like to click the chip to bring me to edit mode or even better straight to the raw config editor.
Hoping to use something like this:
alignment: center
chips:
- type: action
icon: mdi:dots-vertical
tap_action:
action: navigate
navigation_path: /lovelace-mobile/0?edit=1
In the mobile app on my iphone, this button has not enough space to display the left down button, somehow this needs to be able to cope with less screen space.
Hi. Great HACS Addon
My question, there seems to be no white colour option on the light slider bar for rgb lights ?
My LEDS work no problems but white would be nice as its my main colour and I cant get them back white if I change the colour.
Not possible for now (but you can use the temperature color slider to do this if your light support it).
Mushroom color slider only controls the hue
parameter because the slider a 1 dimensional control.
If you want to control the “saturation” parameter you can use the more-info
popup using a hold_action
or a double_tap_action
Maybe a solution can be to display 2 slider (one for hue, one for saturation). I don’t have the solution in term of design. Mushroom is a minimalist design system, it can be hard to add lot of feature with a minimalistic style.
I think it’s better to use the standard layout instead of horizontal layout if you use 2 controls (buttons and slider).
The horizontal layout only allow 3 buttons instead due to the available space.
