Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Works like a charm! Thanks again for your help!
One last thing though, if you mind.
Do you know why i lose my visual editor when adding card mod background color to chips, but not when i do it to cards?
This is the code i have for my chips, which make me lose the visual editor.
    card_mod:
      style: |
        ha-card {
          --chip-background: rgba(150,150,150,0.1);
Try applying the card_mod to chips instead of the chip. This should not break the visual editor.
Trying to create a popup using a chip card… is this even possible? I’ve not had any success so far…
here’s what I’m working with:
         - type: custom:mushroom-chips-card
            chips:
              - type: template
                content: >-
                  Battery health is {{ states('sensor.sm_f926u1_battery_health')}}
                tap_action:
                  action: fire-dom-event
                  browser_mod:
                    service: browser_mod.popup
                      title: Popup example
                      card:
                        type: entities
                        entities:
                          - sensor.mapinfo
                          - light.bathroom
Any suggestions ideas would be appreciated as to what I’m doing incorrectly here :slight_smile:
Thank you!
This should do the trick:
chips:
  - type: template
    content: Battery health is {{ states('sensor.sm_f926u1_battery_health')}}
    tap_action:
      browser_mod:
        command: popup
        deviceID: this
        card:
          type: entities
          entities:
            - sensor.mapinfo
            - light.bathroom
this code works for me
  - type: template
    icon: mdi:flower
    icon_color: |
      {% if is_state('plant.flower1', 'ok') %}
        green
      {% else %}
        red
      {% endif %}
    entity: plant.flower1
    content: null
    tap_action:
      action: call-service
        title: Włączone
        card:
          type: custom:flower-card
          show_bars:
            - moisture
            - conductivity
            - temperature
            - illuminance
            - dli
            - humidity
Tried that it does nothing just sits there and no response at all. It’s strange!
Strange it doesn’t popup in the main view… it’s popping up in the settings page hahahahahahha
You have browser-mod installed, right? :confused:
Yes I do :slight_smile:
Just checking :grin:
hahahhahahaha I know most times it’s something just simple like that.
Have you turned it off and on again? :rofl:
Worth a try I guess :sweat_smile:
How can i make background image greyscale if no lights or movement detected?
card_mod:
  style: |
    ha-card {
      height: 100px;
      background: url('/local/office-background.jpg') center;
      background-size: cover;
      background-blend-mode: overlay;
This format is better if the deviceID is likely to change.
This allows a pop-up to happen regardless of deviceID it will target whatever the ID is when the pop-up is done rather than having a deviceID in memory that may not be the same if the device changes from wifi to data for example. This allows the deviceID to be loaded each time and won’t break when the deviceID changes. The pop-up only happens on the device that called for it as well. Because of fire-dom-event.
type: custom:mushroom-template-card
entity: light.daniels_bedroom_lights_main
primary: Daniels 🛏️
secondary: '{{ states(''light.daniels_bedroom_lights_main'') | title }}'
picture: >-
  {% set status = states('light.daniels_bedroom_lights_main') %} {% if
  status == 'on' %} local/icons/custom_icons/light-bulb.png {% elif status
  == 'off' %} local/icons/custom_icons/light-bulb-off.png {% endif %}
tap_action:
  browser_mod:
    command: popup
    title: Daniels Bedroom
    card:
      type: entities
      entities:
here you are:
type: vertical-stack
cards:
  - type: custom:layout-card
    layout_type: grid
    layout:
      width: 100%
    cards:
        primary: SYSTEM -  {{(states('sensor.rpi_uptime'))}}
        secondary: Home Assistant - {{(states('sensor.ha_uptime'))}}
        icon: mdi:home-assistant
        icon_color: '#41bdf5'
        layout: horizontal
        tap_action:
          action: navigate
          navigation_path: /config/logs
        card_mod:
          style: |
            :host {
              --mush-icon-size: 60px;
              --mush-card-primary-font-size: 14px;
              --mush-card-secondary-font-size: 12px;
    layout_type: grid
    layout:
      width: 100%
      grid-template-columns: 1fr 1fr 1fr 1fr
    cards:
        entity: update.home_assistant_core_update
        primary: CORE
        secondary: |
          {% if is_state('update.home_assistant_core_update', 'off') %}
            Brak
          {% else %}
            {{ state_attr('update.home_assistant_core_update', 'latest_version') }}
          {% endif %}
        layout: vertical
        fill_container: false
        secondary_info: state
        multiline_secondary: true
        card_mod:
          style: |
            :host {
              margin-top: -10px;
              --mush-card-primary-font-size: 12px;
              --mush-card-secondary-font-size: 10px;
            mushroom-shape-icon {
              --shape-color: none !important;
              {% if is_state('update.home_assistant_core_update', 'on') %}
                 animation: blink 1s linear infinite;
              {% endif %}
            @keyframes blink {
              30% {opacity: 0;}
            ha-card {
              padding-top: 5px !important;
              padding-bottom: 5px !important;
        primary: Supervisor
        secondary: |
          {% if is_state('update.home_assistant_supervisor_update', 'off') %}
            Brak
          {% else %}
            {{ state_attr('update.home_assistant_supervisor_update', 'latest_version') }}
          {% endif %}
        layout: vertical
        card_mod:
          style: |
            :host {
            margin-top: -10px;
              {% if is_state('update.home_assistant_supervisor_update', 'on') %}
              {% endif %}
            @keyframes blink {
              30% {opacity: 0;}
            ha-card {
        primary: HA OS
        secondary: >
          {% if is_state('update.home_assistant_operating_system_update', 'off')
            Brak
          {% else %}
            {{ state_attr('update.home_assistant_operating_system_update', 'latest_version') }}
          {% endif %}
        layout: vertical
        card_mod:
          style: |
            :host {
            margin-top: -10px;
              {% if is_state('update.home_assistant_operating_system_update', 'on') %}
              {% endif %}
            @keyframes blink {
              30% {opacity: 0;}
            ha-card {
      - type: custom:mushroom-update-card
        entity: update.zigbee2mqtt_update
        secondary: |
          {% if is_state('update.zigbee2mqtt_update', 'off') %}
            Brak
          {% else %}
            {{ state_attr('update.zigbee2mqtt_update', 'latest_version') }}
          {% endif %}
        layout: vertical
        use_entity_picture: true
        card_mod:
          style: |
            :host {
            --mush-icon-size: 40px;
            --mush-card-primary-font-size: 11px;
            --mush-card-secondary-font-size: 9px;
              {% if is_state('update.zigbee2mqtt_update', 'on') %}
              {% endif %}
            @keyframes blink {
              30% {opacity: 0;}
            ha-card {
              height: 120px;
    card_mod:
      style: |
        ha-card {
          height: 150px;
    layout_type: grid
    layout:
      width: 100%
      grid-template-columns: 1fr 2fr
      grid-template-rows: auto
      margin: 0px
      padding: 0px
    cards:
      - type: custom:stack-in-card
        cards:
          - type: custom:mushroom-entity-card
            entity: sensor.rpi_cpu_temp
            icon_color: '#0084ff'
            hold_action:
              action: none
            primary_info: name
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-right: -8px;
            entity: sensor.memory_use_percent
            icon_color: '#39539E'
            icon: mdi:memory
            hold_action:
              action: none
            primary_info: name
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-right: -8px;
            entity: sensor.disk_use_percent
            icon_color: '#0077B5'
            icon: mdi:harddisk
            hold_action:
              action: none
            primary_info: name
            card_mod:
              style: |
                ha-card {
                  margin-top: -10px;
                  margin-right: -8px;
        card_mod:
          style: |
            ha-card {
              background: none;
              --ha-card-box-shadow: 0px;
        cards:
          - type: custom:apexcharts-card
            experimental:
              color_threshold: true
            chart_type: radialBar
            show:
              loading: false
            apex_config:
              chart:
                height: 270px
              plotOptions:
                radialBar:
                  offsetY: -25
                  startAngle: -135
                  endAngle: 135
                  hollow:
                  dataLabels:
                    name:
                      show: false
                    value:
                      show: false
              legend:
                show: false
              stroke:
                dashArray: 0
                lineCap: flat
            series:
              - entity: sensor.rpi_cpu_temp
                type: column
                color_threshold:
                  - value: 0
                    color: '#0084ff'
                  - value: 55
                    color: orange
                  - value: 60
                    color: red
              - entity: sensor.memory_use_percent
                type: column
                color_threshold:
                  - value: 0
                    color: '#39539E'
                  - value: 65
                    color: orange
                  - value: 85
                    color: red
              - entity: sensor.disk_use_percent
                type: column
                color: '#0077B5'
            card_mod:
              style: |
                ha-card {
                  background: none;
            entity: sensor.rpi_power_status
            primary: RPI
            icon_color: deep-purple
            icon: mdi:raspberry-pi
            layout: vertical
            card_mod:
              style: |
                :host {
                  --mush-card-primary-font-size: 13px;
                  --mush-icon-border-radius: 50%;
                  --mush-icon-size: 72px;
                ha-card {
                  background: transparent;
                  margin-top: -112px;
                  width: 120px;
                  margin-left: auto;
                  margin-right: auto;
    layout_type: grid
    layout:
      width: 100%
      margin: 0px
      padding: 0px
    cards:
        icon: mdi:home-import-outline
        layout: vertical
        primary: HA Restart
        icon_color: purple
        tap_action:
          confirmation:
            text: Czy na pewno restartujemy Home Assistant ?
          service: homeassistant.restart
        card_mod:
          style: |
            :host {
            --mush-icon-size: 45px;
            ha-card {
        layout: vertical
        primary: RPI Restart
        icon_color: purple
        tap_action:
          confirmation:
            text: Czy na pewno restartujemy RASPBERRY?
          service: hassio.host_reboot
        card_mod:
          style: |
            :host {
            ha-card {
        icon: mdi:robot-excited
        layout: vertical
        primary: Automation
        icon_color: purple
        tap_action:
          confirmation:
            text: Czy na pewno przeładowujemy Automatyzacje ?
          service: automation.reload
        card_mod:
          style: |
            :host {
            ha-card {
    layout_type: grid
    layout:
      width: 100%
      margin: 0px
      padding: 0px
    cards:
        icon: mdi:cog-refresh-outline
        layout: vertical
        primary: Konfiguracja
        icon_color: purple
        tap_action:
          service: script.check_config
        card_mod:
          style: |
            :host {
            ha-card {
      - type: entities
        entities:
          - sensor.config_result
    layout_type: grid
    layout:
      width: 100%
    cards:
      - type: conditional
        conditions:
          - entity: sensor.config_result
            state: invalid
        card:
          type: custom:card-templater
          card:
            type: markdown
            title: Błąd
            content_template: '{{ states.sensor.config_result.attributes.detail }}'
          entities:
Can someone please tell me how to remove or change the plus icons of a grocery list? I don’t know what to call it, I’ve tried right clicking and inspecting. I have card mod. Im using the OurGroceries Card, and trying to make i look as close to mushroom card as possible.
Is there a way to include either album art from a media player to set that as the card background on media player card, and/or have primary info display the media player name always with the secondary info showing the app name and state. If i group together various devices and they are actively playing I cannot tell which room they are in?
cards:
  - type: custom:mushroom-media-player-card
    entity: media_player.lounge_shield
    icon: mdi:play
    use_media_info: true
    fill_container: true
    use_media_atrwork: true
    show_volume_level: false
    media_controls:
      - previous
      - play_pause_stop
      - next
      - on_off
      - shuffle
      - repeat
    volume_controls:
      - volume_set
    collapsible_controls: true
    tap_action:
      action: none
  - type: conditional
    conditions:
      - entity: media_player.lounge_shield
        state_not: 'off'
        state_not: idle
    card:
      hide:
        icon: true
        runtime: true
        source: true
        power: true
        state_label: true
        volume: true
        info: true
        progress: false
        controls: true
      more_info: false
      type: custom:mini-media-player
      toggle_power: false
      group: true
      card_mod:
        style:
          mmp-progress$: |
            paper-progress {
              {{ '--paper-progress-container-color: rgba(63, 81, 181, 0.2) !important;' if is_state(config.entity, 'playing') }}
            ha-card {
              margin: 0px 12px 12px;
              --mmp-progress-height: 42px !important;
              height: var(--mmp-progress-height);
              --mmp-accent-color: rgb(63, 81, 181);
              --ha-card-border-radius: 12px;
thanks for sharing the config of this nice and handy card but I have 1 more question could you share the script of config check and the sensor config result?
It’s wired. Inspired in your code I try to make blink a template card. It blinks on the browser but not in the mobile phone app.
icon: mdi:shield
icon_color: red
card_mod: null
style: |-
  ha-card {
     box-shadow: 0px 0px;
  @keyframes blink {
     50% {opacity: 0;}
What can I do?
