Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Easy to fix, like this:
card_mod:
  style: |
    ha-card {
      {% if not is_state(config.entity, 'off') %}
        background-image: url( '{{ state_attr( config.entity, "entity_picture" ) }}' );
        background-position: center;
        background-repeat: no-repeat;
        background-size: cover;
        background-color: rgba(var(--rgb-card-background-color),0.8);
        background-blend-mode: overlay;
      {% endif %}
      --rgb-state-media-player: var(--rgb-teal);
Worked perfectly thank you very much :smiley:
Ive got another question :smiley: Im trying to call the light.toggle service within a stack-in-card + mushroom person card to a specific light. I tried the following code but that doenst work. Ill just get the normal view to turn on/off the light and change color.
type: custom:stack-in-card
mode: vertical
cards:
  - type: custom:mushroom-person-card
    entity: person.saskia
    icon_type: entity-picture
  - type: custom:mushroom-chips-card
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
    chips:
      - type: entity
        entity: sensor.iphone_13_reni_battery_level
      - type: entity
        entity: lock.320i_xdrive_lock
      - type: entity
      - type: entity
        entity: light.hyperhdr
        service: light.toggle
        data: {}
        entity_id: light.hyperhdr
2
1
which part ? most of the codes were already shared, by i Can point the right post
Yes, I do have card_mod installed.
Here is my code:
cards:
    primary: Office
    secondary: >-
      {{ states('sensor.living_room_thermostat_temperature') }} °C |  {{
      states('sensor.living_room_thermostat_humidity') | int(0) }} %
    icon: mdi:desk
    icon_color: '#e8af10'
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    entity: light.office_ceiling
    tap_action:
      action: toggle
    hold_action:
      action: none
    double_tap_action:
      action: none
    card_mod:
      style: |
        :host {
          --mush-icon-size: 50px;
          height: 70px;
          margin-left: 0px !important;
          --primary-text-color: black;
          --secondary-text-color: black;
    chips:
      - type: template
        icon: |
          {% if is_state(entity, 'on') %}
            mdi:lightbulb-on
          {% else %}
            mdi:lightbulb-outline
          {% endif %}
        icon_color: |
            yellow
          {% else %}
            grey
          {% endif %}
        double_tap_action:
          action: none
        tap_action:
          action: toggle
        hold_action:
          action: none
      - type: template
        entity: binary_sensor.office_motion_sensor
        icon_color: |
            white
          {% else %}
            grey
          {% endif %}
        double_tap_action:
          action: none
        icon: mdi:motion-sensor
        tap_action:
          action: none
        hold_action:
          action: none
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-spacing: 0;
          --chip-icon-size: 20px;
          margin-top: 4px;
          margin-right: 4px;
        :host {
          background-color: rgba(var(--rgb-card-background-color), 0.6);
          position: absolute;
          bottom: 0px;
          left: 0px;
          right: 0px;
          height: 44px;
    chips:
      - type: entity
        entity: sensor.living_room_thermostat_temperature
        hold_action:
          action: none
        double_tap_action:
          action: none
        tap_action:
          action: none
      - type: template
        entity: sensor.living_room_thermostat_humidity
        icon: mdi:water
        icon_color: white
        content: '{{ states(entity) }} {{ state_attr(entity, "unit_of_measurement") }}'
        tap_action:
          action: none
        hold_action:
          action: none
        double_tap_action:
          action: none
    alignment: start
    card_mod:
      style: |
        ha-card {
          --chip-spacing: 0;
          margin-top: 4px;
          margin-left: 4px;
          --text-color: rgb(var(--rgb-green));
          --color: rgb(var(--rgb-red));
        :host {
          position: absolute;
          bottom: 0px;
          left: 0px;
          right: 0px;
          height: 44px;
          --text-color: #ffffff !important;
          --icon-color: #ffffff !important;
card_mod:
  style: |
    ha-card {
      height: 250px;
      background-image: url("/api/image/serve/d66480268b9c0f34de2cc22a77e30dbc/512x512");
      position: relative;
and here is the result:
Screenshot 2022-09-20 080838
I try to change the color of the yellow circled chips.
simpler way: use your sensor definition.
I’ll copy you my code tonight when I’ll at home, quite easy…
I want to change the button background, this one:
(example done in photoshop)
I would like it to match the slider from the fan, for example.
Hi Folks, climate card, is there any way of toggling on/off/auto? It only seems to do on/off by default. I did have a read back but couldn’t find anything obvious? Thanks.
THanks for the code for the card! For some reason, the chip thing worked itself out, maybe because I was using my iPad originally and now I am on the computer? No clue, but thank you for your help!
There it is (sorry for the french…).
Using this, your sensor receive the sentence.
  sensors:
    nbre_fenetres_ouvertes:
      value_template: >
        {% set fenetres = [
          states.binary_sensor.chambre_maelys_detecteur_fenetre,
          states.input_boolean.sdb_fenetre_ouverte,
          states.binary_sensor.annaelle_fenetre,
          states.binary_sensor.bureau_fenetre,
          states.binary_sensor.living_detecteur_fenetre,
          states.binary_sensor.salon_detecteur_fenetre,
          states.binary_sensor.porte_fenetre_salon,
          states.input_boolean.cuisine_fenetre_ouverte,
          states.input_boolean.parents_fenetre_ouverte,
          states.input_boolean.sacha_fenetre_ouverte
        {% set fenetres_ouvertes = fenetres | selectattr('state','eq','on') | list %}
        {% if (fenetres_ouvertes | length ==1)%}
        Une fenêtre ouverte
        {% elif (fenetres_ouvertes | length >1 )%}
        {{ fenetres_ouvertes | length}} fenêtres ouvertes
        {% else %}
        Tout est fermé
        {% endif %}
Did we ever figure out this iOS animation issue? It’s still happening in iOS 16.
It actually happens with the light slider too.
Hi how do i change the primary font family ?
i tried this but no luck
--primary-font-family: SF Text !important;
also this
.mdc-dialog__content {
Hi is this bug in mushroom template card? its does not display 0(zero)…can anyone conform?
{% if is_state('sensor.completed_tasks','0') %}
      0
{% elif not is_state('sensor.completed_tasks','0') %}
      1
 {% endif %}
Here you go!
type: custom:mini-graph-card
animate: true
decimals: 0
hours_to_show: 24
line_width: 1
points: false
points_per_hour: 6
entities:
  - sensor.energy_monitor_power
show:
  labels: true
  icon_adaptive_color: true
  extrema: false
  average: false
color_thresholds:
  - value: 1000
    color: '#0099ff'
  - value: 2000
    color: '#4caf50'
  - value: 4000
    color: '#ff9800'
  - value: 6000
    color: '#f44336'
icon: mdi:transmission-tower
card_mod:
  style:
    .header.flex .icon ha-icon:
        ha-svg-icon {
          animation: blink 1s linear infinite;
          @keyframes blink {
            50% {opacity: 0;}
Hello do you have any github repo?
Congrats on your dashboard! Great ideias
+1 for your code
You will first need to add the font as a stylesheet resource in dashboards. You can then specify the font like this:
Mushroom Fonts
type: custom:mushroom-template-card
icon: mdi:mushroom
icon_color: orange
primary: Mushroom
card_mod:
  style:
    mushroom-state-info$: |
      .primary {
        font-family: 'Nabla', cursive;
        --card-primary-font-size: 30px;
    mushroom-shape-icon$: |
      .shape {
        border-left: 3px solid rgb(var(--rgb-orange));
        transform: rotate(-20deg);
      ha-icon {
        transform: rotate(20deg);
Hey. Im trying to do a pop up within a slider card but cant get it to work/call the service. Any help would be awesome. Im trying to build a slider card (works) where i can press the “picture” i,e “Lights” which shows me a pop up to all my lights/light group. Right now its just showing me a blank pop-up without any text or entities/lights
Thank you :slight_smile:
type: custom:swipe-card
cards:
  - type: horizontal-stack
    cards:
        primary: Licht
        secondary: ''
        icon: mdi:lightbulb
        icon_color: yellow
        layout: vertical
        tap_action:
          action: fire-dom-event
          browser_mod:
            service: browser_mod.popup
              entity: light.alle_lichter
    cards:
        primary: Temperatur
        secondary: ''
        icon: mdi:thermometer
        icon_color: blue
        layout: vertical
        tap_action:
          action: navigate
          navigation_path: temperatur
    cards:
        primary: Jalousie
        secondary: ''
        icon: mdi:window-shutter
        icon_color: green
        layout: vertical
        tap_action:
          action: navigate
          navigation_path: rollos
    cards:
        primary: Media
        secondary: ''
        icon: mdi:cast-variant
        icon_color: teal
        layout: vertical
        tap_action:
          action: navigate
          navigation_path: test
Each card uses different selectors, but for Mushroom Media card you can change the button colors like this:
card_mod:
  style:
    mushroom-media-player-media-control$: |
      mushroom-button {
        --bg-color: rgba(var(--rgb-red), 0.05);
      mushroom-button {
You could maybe create a script to cycle through on/off/auto.
