@rhysb thanks soo far made thisā¦suggest me if you got some better animation ideaā¦
what this animations does is , when my distracting time is more than 1 hr it will alert me with the animation like this
Would it be possible to do the same with sensor while it is active?
Right now it pulses while both being on and off. Goal is to have a more visible style when a sensor is triggered.
This doesnāt work for me sadly. The text color does not change to green or any other color.
I think you can achieve it by
card_mod:
style:
mushroom-shape-icon$: |
.shape {
{% if is_state('vacuum.kazek', 'cleaning') %}
--shape-animation: ping 1s infinite
{% endif %}
@keyframes ping {
0% {
box-shadow: 0 0 5px 1px rgba(var(--rgb-pink), 0.7);
100% {
box-shadow: 0 0 5px 15px transparent;
you need to define if inside card_mod
unless @rhysb has some other solution
I am using mushroom cards with noctis theme, and this buttons are hard to be seeing,
what element on the theme should be changed so I can set a different bg-color
This may be what you are wanting.
Mushroom Inset Ping Animation:
type: custom:mushroom-template-card
icon: mdi:mushroom
icon_color: red
primary: Mushroom
card_mod:
style:
.shape {
--shape-animation: ping 2s infinite;
@keyframes ping {
0% {
box-shadow: 0 0 1px 1px rgba(var(--rgb-red), 0.7) inset;
100% {
box-shadow: 0 0 5px 15px transparent inset;
Should work. Share your code.
Exactly!!! thanks
Add primary-background-color: to your theme file with the color you want.
Hi all!
Does anyone have any problems with animations working in Safari? The animation below works fine in chrome but not in Safari.
Any tips or pointers would be much appreciated!
style: |
ha-card {
padding-top: 25px !important;
padding-bottom: 15px !important;
align-items: center !important;
background-color: rgba(28,28,28,1) !important;
{% set state=states('binary_sensor.test_sensor') %}
{% if state == 'off' %}
mushroom-shape-icon {
animation: fade 4s ease-in-out infinite both;
@keyframes fade {
0%, 50%, 100% {
opacity: 1;
25%, 75% {
opacity: 0.2;
{% endif %}
primary: Test Title Text
icon: |-
{% set mode = states('binary_sensor.test_sensor') %}
{% if mode == 'off' %}
mdi:power-off
{% elif mode == 'on' %}
mdi:power-on
{% else %}
mdi:power
{% endif %}
icon_color: |-
{% set status = states('binary_sensor.test_sensor) %}
{% if status == 'off' %}
red
{% elif status == 'on' %}
green
{% else %}
red
{% endif %}
tap_action: none
Do you have card-mod installed? Can be found in HACS.
Just tested here and next/previous show up correctly for me. Perhaps you could try re-adding the integration.
mind sharing yaml?
I am afraid is not that one:
# Background
background-color: '#242e42'
primary-background-color: red
background-color-2: '#20293c'
secondary-background-color: 'none'
markdown-code-background-color: 'var(--background-color)'
What background did you want? Card background? Try card-background-color:.
Thanks for your fast reply. That actually worked for whatever reason. Really nice card
Thank you!
Is is possible to change the color of the volume bar?
This also changes the volume bar color:
I try not to display anything when there is no light on.
Example: If two lights are on, the text āThere are 2 lights onā is displayed. If no light is on, there should be nothing. Is that possible?
YAML:
primary: Alle Lichter
secondary: >-
Es sind {{ expand(states.light.alle_lichter) | selectattr( 'state', 'eq','on')
| list | count }} Lichter an!
icon: mdi:lightbulb-on-outline
entity: light.alle_lichter
icon_color: |-
{% if is_state('light.alle_lichter', 'on') %}
cyan
{% endif %}
{% if is_state('light.alle_lichter', 'off') %}
grey
{% endif %}
tap_action:
action: toggle
card_mod:
style: |
ha-card:active {
transform: scale(0.975);
transition: 0s;
Yes, with a conditional card.
Thanks it changes the color of the bar but the entity picture/background of the song playing is gone. I tried playing around with placing the code snippet for the volume bar color elsewhere but it stays the same/syntax is completely wrong. No idea if i did it right.
YAML:
type: custom:mushroom-media-player-card
entity: media_player.ytube_music_player
use_media_artwork: false
use_media_info: true
media_controls:
- play_pause_stop
- previous
- next
collapsible_controls: true
volume_controls:
- volume_set
- volume_mute
- volume_buttons
show_volume_level: true
fill_container: false
tap_action:
action: toggle
style: |
ha-card {
{% if is_state('media_player.ytube_music_player', 'off') %}
{% else %}
background-image: url( '{{ state_attr( "media_player.ytube_music_player", "entity_picture" ) }}' );
background-position: center;
background-repeat: no-repeat;
background-size: cover;
background-color: rgba(var(--rgb-card-background-color),0.8);
background-blend-mode: overlay;
position: relative;
{% endif %}
card_mod:
style: |
ha-card {
--rgb-state-media-player: var(--rgb-teal);
