quick question, what does “|-” before template mean?
it’s yaml for multi-line use https://yaml-multiline.info or https://www.w3schools.io/file/yaml-multiline-strings/
hi i Copied exact your code. It seems like coloring the bar is not working. May you can help me
type: custom:stack-in-card
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 42px auto 12px
margin: '-4px -4px -8px -4px;'
cards:
entity: sensor.water_filter_days_remaining
icon: mdi:air-filter
icon_color: |
{% set filter_days = states(entity) | int %}
{% if filter_days < 31 %}
red
{% elif filter_days < 91 %}
orange
{% else %}
green
{% endif %}
card_mod:
style: |
ha-card {
background: none;
--ha-card-box-shadow: 0px;
- type: custom:bar-card
height: 42px
min: '0'
max: '200'
entity_row: true
severity:
- color: rgb(var(--mush-rgb-green))
to: 200
- color: rgb(var(--mush-rgb-orange))
to: 109
- color: rgb(var(--mush-rgb-red))
to: 30
positions:
icon: 'off'
indicator: 'off'
card_mod:
style: |
ha-card {
padding: 12px;
margin-left: 12px;
--bar-card-border-radius: 12px;
bar-card-value {
margin: 12px;
font-size: 12px;
font-weight: bolder;
bar-card-name {
margin: 12px;
font-size: 12px;
bar-card-backgroundbar {
opacity: 0.2;
filter: brightness(1);
entity: input_boolean.water_filter_dropdown
icon: mdi:chevron-down
icon_color: disabled
hold_action:
action: none
card_mod:
style:
mushroom-shape-icon:
.shape ha-icon {
transition: transform 0.14s !important;
{{ 'transform: rotate(-180deg);' if is_state(config.entity, 'on') }}
ha-card {
align-items: flex-end;
box-shadow: none;
mushroom-shape-icon {
--shape-color: none !important;
- type: custom:stack-in-card
mode: horizontal
cards:
- type: custom:mushroom-entity-card
entity: input_datetime.water_filter_replaced
icon: mdi:calendar
layout: vertical
primary_info: state
secondary_info: name
card_mod:
style: |
ha-card {
width: 130px;
margin-left: auto;
margin-right: auto;
entity: sensor.water_filter_days_since_replacement
layout: vertical
primary_info: state
card_mod:
style: |
ha-card {
width: 130px;
margin-left: auto;
margin-right: auto;
entity: input_number.water_filter_threshold
icon: mdi:calendar-edit
layout: vertical
primary_info: state
card_mod:
style: |
ha-card {
width: 130px;
margin-left: auto;
margin-right: auto;
primary: Reset
secondary: ''
icon: mdi:refresh
layout: vertical
tap_action:
action: call-service
service: script.reset_water_filter_date_to_today
data: {}
target: {}
hold_action:
action: none
double_tap_action:
action: none
card_mod:
style: |
ha-card {
margin-top: -14px;
card_mod:
style: |
ha-card {
{{ 'height: 66px;' if is_state('input_boolean.water_filter_dropdown', 'off') }}
Hello the cards I see here are great, but my design skills are beter in Adobe then do the technical stuff :). I was wondering if somebody can build this card. I have an airco which I can turn on/off with a outlet and also show the power. I like to have them bought in one card. Is this possible and how?
Im sure someone else can do it better
cards:
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: switch.solar
icon: mdi:toggle-switch
icon_color: light-green
content_info: none
alignment: end
card_mod:
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
- type: custom:mini-graph-card
entities:
- sensor.solar_energy
label: null
show:
labels: true
icon: false
color_thresholds:
- value: 0
color: '#c5dde3'
- value: 5
color: '#12c2f3'
- value: 8
color: '#b3f312'
Add the mushroom variables to your theme file.
Hey, how have you removed the default dashboard bar at the top? By “default bar” I mean this one:
Your custom one looks really sleek, those are mushroom chips, am I right?
Use the kiosk mode or sidebar-card in HACS. Set the hideTopMenu on True
sidebar:
digitalClock: true
date: true
dateFormat: dddd DD MMMM YYYY
hideTopMenu: false
Thank you for the quick service :). This is a good start.
looking in how to get the on for CCTV working, I can get it working but only for both icons, but want to have it only for one, any idea how to fix that if possible?
type: custom:vertical-stack-in-card
mode: vertical
fill_container: true
cards:
- type: custom:vertical-stack-in-card
horizontal: true
cards:
entity: switch.cctv
layout: vertical
icon: |-
{% if is_state('switch.cctv', 'on') %}
mdi:cctv
{% else %}
mdi:cctv-off
{% endif %}
icon_color: |-
yellow
{% else %}
#6f6f6f
{% endif %}
Just add your if/on to the --icon-animation
like this:
mode: vertical
cards:
horizontal: true
cards:
entity: switch.cctv
layout: vertical
icon: |-
{% if is_state(entity, 'on') %}
mdi:cctv
{% else %}
mdi:cctv-off
{% endif %}
icon_color: |-
yellow
{% else %}
#6f6f6f
{% endif %}
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
{% if is_state(config.entity, 'on') %}
--icon-animation: scan 5s ease-in-out infinite;
{% endif %}
transform-origin: 90% 80%
@keyframes scan {
0%, 100% { transform: rotate(20deg); }
50% { transform: rotate(-15deg); }
Does anybody know how I could add battery levels for my blinds into upper right corner of the cover card? Completely lost here…
type: custom:mushroom-cover-card
entity: cover.living_room_blinds
name: Living Room Blinds
show_position_control: true
show_buttons_control: true
sorry for the late reply i was out of town. Im also using an iphone but i dont have those borders. Neither on an android device.
But i think u already found a solution
great! this part I was missing: {% if is_state(config.entity, ‘on’) %}
keep up the good work!
Mushroom Animations - Part 3
More Mushroom Card Icon Animations
Flash Animation
type: custom:mushroom-template-card
icon: mdi:flash
icon_color: amber
primary: Flash
card_mod:
style:
ha-icon {
--icon-animation: flash 4s linear infinite;
@keyframes flash {
0%, 4%, 8%, 12%, 16%, 20%, 24%, 28%, 32%, 100% { transform: translate(0px,0px); }
2% { transform: translate(-0.3px, 0px); }
6% { transform: translate(0.3px, 0px); }
10% { transform: translate(-0.2px, 0px); }
14% { transform: translate(0.2px, 0px); }
18% { transform: translate(-0.2px, 0px); }
22% { transform: translate(0.5px, 0px); }
26% { transform: translate(-0.5px, 0px); }
34% { transform: translate(-1px, 5px); --icon-color: rgb(var(--rgb-amber)); }
38% { transform: translate(0px, 0px); --icon-color: rgb(var(--rgb-white)); }
40% { --icon-color: rgb(var(--rgb-amber)); }
Charge Animation
icon: mdi:lightning-bolt
icon_color: amber
primary: Charge
card_mod:
style:
ha-icon {
--icon-animation: charge 1s linear infinite;
@keyframes charge {
0%, 10%, 20%, 30%, 40%, 50%, 60%, 70%, 80%, 90%, 100% { transform: translate(0, 0); }
5% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
15% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
25% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
35% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
45% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
55% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
65% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
75% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
85% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
95% { transform: translate({{ range(-10, 10) | random / 10 }}px, {{ range(-10, 10) | random / 10 }}px); }
Double Rainbow Animation
icon: mdi:looks
primary: Double Rainbow
card_mod:
style:
ha-icon {
--icon-animation: double 3s linear infinite alternate;
@keyframes double {
0% { clip-path: inset(0 98% 0 0); transform: rotateY(0deg); }
12.5% { clip-path: polygon(0 22%, 0 75%, 50% 75%); }
25% { clip-path: inset(0 50% 0 0); }
37.5% { clip-path: polygon(0 0, 0 75%, 50% 75%, 100% 0); }
50% { clip-path: inset(0 0 0 0); transform: rotateY(0deg); }
50.1% { transform: rotateY(180deg); }
62.5% { clip-path: polygon(0 0, 0 75%, 50% 75%, 100% 0); }
75% { clip-path: inset(0 50% 0 0); }
87.5% { clip-path: polygon(0 22%, 0 75%, 50% 75%); }
100% { clip-path: inset(0 98% 0 0); transform: rotateY(180deg); }
.shape {
--shape-animation: rainbow 40s linear infinite;
@keyframes rainbow {
0%, 100% {--icon-color: rgb(var(--rgb-red)); --shape-color: rgb(var(--rgb-red), 0.2); }
6.25% { --icon-color: rgb(var(--rgb-deep-orange)); --shape-color: rgb(var(--rgb-deep-orange), 0.2); }
12.5% { --icon-color: rgb(var(--rgb-orange)); --shape-color: rgb(var(--rgb-orange), 0.2); }
18.75% { --icon-color: rgb(var(--rgb-amber)); --shape-color: rgb(var(--rgb-amber), 0.2); }
25% { --icon-color: rgb(var(--rgb-yellow)); --shape-color: rgb(var(--rgb-yellow), 0.2); }
31.25% { --icon-color: rgb(var(--rgb-lime)); --shape-color: rgb(var(--rgb-lime), 0.2); }
37.5% { --icon-color: rgb(var(--rgb-light-green)); --shape-color: rgb(var(--rgb-light-green), 0.2); }
43.75% { --icon-color: rgb(var(--rgb-green)); --shape-color: rgb(var(--rgb-green), 0.2); }
50% { --icon-color: rgb(var(--rgb-teal)); --shape-color: rgb(var(--rgb-teal), 0.2); }
56.25% { --icon-color: rgb(var(--rgb-cyan)); --shape-color: rgb(var(--rgb-cyan), 0.2); }
62.5% { --icon-color: rgb(var(--rgb-light-blue)); --shape-color: rgb(var(--rgb-light-blue), 0.2); }
68.75% { --icon-color: rgb(var(--rgb-blue)); --shape-color: rgb(var(--rgb-blue), 0.2); }
75% { --icon-color: rgb(var(--rgb-indigo)); --shape-color: rgb(var(--rgb-indigo), 0.2); }
81.25% { --icon-color: rgb(var(--rgb-deep-purple)); --shape-color: rgb(var(--rgb-deep-purple), 0.2); }
87.5% { --icon-color: rgb(var(--rgb-purple)); --shape-color: rgb(var(--rgb-purple), 0.2); }
93.75% { --icon-color: rgb(var(--rgb-pink)); --shape-color: rgb(var(--rgb-pink), 0.2); }
Random Animation
icon: none
icon_color: red
primary: Random
card_mod:
style: |
:host {
--card-mod-icon: mdi:dice-{{range(1, 6) | random}};
Sparkle Animation
icon: mdi:shimmer
icon_color: amber
primary: Sparkle
card_mod:
style:
ha-icon {
--icon-animation: stars 4s linear infinite;
.shape {
--shape-color: rgba(var(--rgb-disabled), 0.2);
@keyframes stars {
0%, 3.1%, 14.1%, 40.1%, 55.1% { clip-path: inset(0 0 0 0); }
3%, 40% { clip-path: polygon(48% 100%, 48% 62%, 0 63%, 0 0, 100% 0, 99% 100%); }
14% { clip-path: polygon(49% 45%, 48% 100%, 0 100%, 0 0, 100% 0, 100% 36%); }
55% { clip-path: polygon(0 100%, 0 60%, 41% 65%, 49% 46%, 100% 44%, 100% 100%); }
Eeeew Animation
icon: mdi:bacteria
primary: Eeeew
card_mod:
style:
ha-icon {
--icon-animation: wiggle 0.5s ease infinite;
transform-origin: 80% 80%;
@keyframes wiggle {
0%, 100% { transform: scale(1) rotate(1deg); }
50% { transform: scale(1.04) rotate(-2deg); }
display: flex;
animation: spin 20s infinite;
Sunny Animation
primary: Sunny
icon: mdi:weather-sunny
icon_color: amber
card_mod:
style:
ha-icon {
--icon-animation: sunny 8s ease-in-out infinite alternate;
@keyframes sunny {
70% { transform: rotate(360deg) scale(1); }
80% { transform: scale(1); }
90% { transform: scale(1.15); }
100% { transform: scale(1); }
Cloudy Animation
primary: Cloudy
icon: mdi:weather-cloudy
icon_color: grey
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite;
@keyframes cloudy {
0%, 100% { transform: translateX(3px); }
30% { transform: translateX(-1px); }
45% { transform: translateX(1.5px); }
75% { transform: translateX(-3.2px); }
Rainy Animation
primary: Rainy
icon: mdi:weather-rainy
icon_color: blue
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, rain 1.5s infinite;
@keyframes cloudy {
@keyframes rain {
50% { clip-path: polygon(0 0, 100% 0, 100% 73%, 71% 73%, 50% 39%, 29% 73%, 0 73%); }
Pouring Animation
primary: Pouring
icon: mdi:weather-pouring
icon_color: blue
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, rain 1s infinite;
@keyframes cloudy {
@keyframes rain {
0%, 50%, 100% { clip-path: inset(0 0 0 0); }
25% { clip-path: polygon(0 0, 100% 0, 100% 83%, 54% 83%, 62% 47%, 47% 46%, 38% 83%, 0 83%); }
75% { clip-path: polygon(0 0, 100% 0, 100% 70%, 75% 70%, 80% 48%, 63% 48%, 54% 94%, 32% 94%, 46% 46%, 30% 46%, 23% 72%, 0 72%); }
Tornado Animation
primary: Tornado
icon: mdi:weather-tornado
icon_color: orange
card_mod:
style:
ha-icon {
--icon-animation: tornado 3s ease-in-out infinite;
@keyframes tornado {
0%, 100% { transform: translateX(3px) rotateY(0deg); }
0.1%, 45.1% { transform: rotateY(180deg); }
30% { transform: translateX(-1px) rotateY(180deg); }
30.1%, 75.1% { transform: rotateY(0deg); }
45% { transform: translateX(1.5px) rotateY(0deg); }
75% { transform: translateX(-3.2px) rotateY(180deg); }
Lightning Animation
primary: Lightning
icon: mdi:weather-lightning
icon_color: amber
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, lightning 4s infinite;
@keyframes cloudy {
@keyframes lightning {
10%, 15% { clip-path: polygon(0 0, 100% 0, 100% 100%, 47% 100%, 69% 55%, 66% 40%, 48% 39%, 24% 100%, 0 100%); transform: scale(1.1); }
10.1%, 15.1% { clip-path: inset(0 0 0 0); transform: scale(1); }
Clear Night Animation
icon: mdi:weather-night
icon_color: amber
primary: Clear Night
card_mod:
style:
ha-icon {
--icon-animation: moon 10s linear infinite, stars 5s linear infinite;
@keyframes moon {
0%, 100% { transform: rotate(12deg); }
30% { transform: rotate(-6deg); }
45% { transform: rotate(8deg); }
75% { transform: rotate(-10deg); }
@keyframes stars {
0%, 3.1%, 14.1% { clip-path: inset(0 0 0 0); }
3% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 99% 62%, 68% 62%, 62% 44%, 76% 34%, 100% 34%, 99% 0%); }
14% { clip-path: polygon(1% 1%, 0% 99%, 99% 100%, 100% 25%, 51% 45%, 38% 34%, 36% 0); }
Windy Animation
primary: Windy
icon: mdi:weather-windy
icon_color: blue
card_mod:
style:
ha-icon {
transform-origin: 15% 50%
@keyframes cloudy {
0%, 100% { transform: scaleX(1.2); }
30% { transform: scaleX(0.9); }
45% { transform: scaleX(1.1); }
75% { transform: scaleX(0.8); }
Wind Animation
primary: Wind
icon: mdi:weather-windy-variant
icon_color: blue
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, wind 5s infinite;
@keyframes cloudy {
@keyframes wind {
25% { clip-path: inset(0 0 37% 0); }
Snow Animation
primary: Snow
icon: mdi:weather-snowy
icon_color: grey
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, snow 4s infinite;
@keyframes cloudy {
@keyframes snow {
50% { clip-path: polygon(0 0, 100% 0, 100% 100%, 65% 100%, 76% 73%, 57% 49%, 34% 56%, 26% 79%, 37% 100%, 0 100%); }
51% { clip-path: inset(0 0 0 0); }
Hail Animation
primary: Hail
icon: mdi:weather-hail
icon_color: blue
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, hail 2s infinite;
@keyframes cloudy {
@keyframes hail {
0%, 26%, 51%, 76%, 100% { clip-path: inset(0 0 0 0); }
25% { clip-path: polygon(0 0, 100% 0, 100% 100%, 62% 100%, 47% 69%, 56% 55%, 43% 43%, 31% 58%, 48% 68%, 63% 100%, 0 100%); }
50% { clip-path: polygon(0 0, 100% 0, 100% 100%, 62% 100%, 61% 86%, 74% 74%, 61% 60%, 46% 69%, 60% 87%, 63% 100%, 0 100%); }
75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 47% 100%, 56% 83%, 42% 68%, 27% 81%, 37% 100%, 0 100%); }
Hurricane Animation
primary: Hurricane
icon: mdi:weather-hurricane
icon_color: red
card_mod:
style:
ha-icon {
--icon-animation: spin 1.5s linear infinite reverse;
Dust Animation
primary: Dust
icon: mdi:weather-dust
icon_color: brown
card_mod:
style:
ha-icon {
--icon-animation: wind 10s ease-in-out infinite, dust 1s infinite;
@keyframes wind {
@keyframes dust {
0%, 21%, 41%, 61%, 81%, 100% { clip-path: inset(0 0 0 0); }
20% { clip-path: polygon(0 0, 69% 0, 72% 27%, 100% 30%, 100% 100%, 0 100%); }
40% { clip-path: polygon(0 0, 100% 0, 100% 100%, 57% 100%, 57% 79%, 0 79%); }
60% { clip-path: polygon(30% 0, 100% 0, 100% 100%, 0 100%, 0 28%, 30% 28%); }
80% { clip-path: polygon(0 0, 100% 0, 100% 100%, 0 100%, 0 61%, 32% 62%, 32% 46%, 0 46%); }
Foggy Animation
primary: Foggy
icon: mdi:weather-fog
icon_color: grey
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, fog 4s infinite;
@keyframes cloudy {
@keyframes fog {
0%, 26%, 76%, 100% { clip-path: inset(0 0 0 0); }
25% { clip-path: polygon(0 0, 100% 0, 100% 59%, 60% 59%, 60% 74%, 100% 74%, 100% 100%, 0 100%); }
75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 26% 100%, 26% 76%, 0 76%); }
Partly Cloudy Animation
primary: Cloudy
icon: mdi:weather-partly-cloudy
icon_color: amber
card_mod:
style:
ha-icon {
--icon-animation: cloudy 10s ease-in-out infinite, sun 2s infinite;
@keyframes cloudy {
@keyframes sun {
50% { clip-path: polygon(0 67%, 18% 55%, 16% 31%, 41% 12%, 67% 24%, 77% 59%, 100% 64%, 100% 100%, 0 100%); }
Fireplace Animation
primary: Fireplace
icon: mdi:fireplace
icon_color: red
card_mod:
style:
ha-icon {
--icon-animation: fire 800ms infinite;
transform-origin: 50% 85%;
@keyframes fire {
0%, 19%, 23%, 39%, 43%, 49%, 53%, 69%, 73%, 89%, 93%, 100% { clip-path: polygon(0 0, 100% 0, 100% 100%, 0 100%); }
20%, 40%, 50%, 70%, 90% { clip-path: polygon(0 0, 100% 0, 100% 100%, 65% 99%, 66% 49%, 52% 44%, 33% 48%, 33% 82%, 66% 82%, 69% 100%, 0 100%); }
Washing Machine #2 Animation
cards:
icon: mdi:washing-machine
icon_color: orange
primary: 'Washing Machine #2'
card_mod:
style:
ha-icon {
--icon-animation: shake 400ms ease-in-out infinite;
transform-origin: 50% 58%;
clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
@keyframes shake {
0%, 100% { transform: translate(0, 0) rotate(0); }
20% { transform: translate(0.4px, -0.4px) rotate(-4deg); }
40% { transform: translate(-0.4px, 0.4px) rotate(4deg); }
60% { transform: translate(0.4px, 0.4px) rotate(-4deg); }
80% { transform: translate(-0.4px, -0.4px) rotate(4deg); }
icon_color: orange
card_mod:
style:
ha-icon {
--icon-animation: spin 1s linear infinite;
clip-path: circle(21.7% at 50% 58%);
.shape {
--shape-color: none;
ha-card {
width: 66px;
top: -66px;
card_mod:
style: |
ha-card {
height: 66px;
Pot Animation
icon: mdi:pot-steam
icon_color: grey
primary: Pot
card_mod:
style:
ha-icon {
--icon-animation: steam 2s ease-in-out infinite;
@keyframes steam {
50% { clip-path: inset(39% 0 0 0); }
Serenity Animation
primary: Serenity
icon: mdi:scent
icon_color: green
card_mod:
style:
ha-icon {
--icon-animation: wave 6s ease infinite;
@keyframes wave {
50% { transform: rotatey(180deg); --icon-color: rgb(var(--rgb-cyan)); }
.shape {
--shape-animation: color 6s ease infinite;
@keyframes color {
50% { --shape-color: rgba(var(--rgb-cyan), 0.2); }
Music #1 Animation
primary: 'Music #1'
icon: mdi:music
icon_color: blue
card_mod:
style:
ha-icon {
--icon-animation: music 2s ease-in-out infinite alternate;
transform-origin: 50% 100%
.shape {
perspective: 7px;
@keyframes music {
0%, 100% { transform: translateY(0px) scaleX(1); }
20% { transform: translateY(2px) scaleX(0.9); }
40% { transform: rotateY(10deg) rotateZ(-10deg); }
60% { transform: translateY(-4px) scaleX(1.1); }
80% { transform: rotateY(-10deg) rotateZ(10deg); }
Music #2 Animation
primary: 'Music #2'
icon: mdi:music
icon_color: blue
card_mod:
style:
ha-icon {
--icon-animation: beat 1.3s ease-out infinite both;
transform-origin: 50% 80%;
@keyframes beat {
10% { transform: scale(1.1); }
17% { transform: scale(1.05); }
33% { transform: scale(1.25); }
60% { transform: scale(1); }
Playlist Animation
icon: mdi:format-list-bulleted-square
icon_color: purple
primary: Playlist
card_mod:
style:
ha-icon {
--icon-animation: clip 2s steps(4) infinite;
@keyframes clip {
0% { clip-path: inset(0 0 85% 0); }
100% { clip-path: inset(0 0 -5% 0); }
Grain Animation
icon: mdi:grain
icon_color: brown
primary: Grain
card_mod:
style:
ha-icon {
--icon-animation: flip 1s steps(1) infinite;
@keyframes flip {
50% { transform: rotateY(180deg); }
Focus Animation
icon: mdi:bullseye
icon_color: purple
primary: Focus
card_mod:
style:
ha-icon {
--icon-animation: focus 4s linear infinite alternate;
@keyframes focus {
50% { filter: blur(10px); }
Access Point Animation
icon: mdi:access-point
icon_color: teal
primary: Access Point
card_mod:
style:
ha-icon {
--icon-animation: clip 1.5s infinite;
@keyframes clip {
0% { clip-path: circle(13.0% at 50% 50%); }
100% { clip-path: circle(50.0% at 50% 50%); }
.shape {
--shape-animation: ping 1.5s infinite;
@keyframes ping {
0% { box-shadow: 0 0 1px 1px rgba(var(--rgb-teal), 0.3) inset; }
50% { box-shadow: 0 0 5px 15px transparent inset; }
51% { box-shadow: 0 0 1px 1px rgba(var(--rgb-teal), 0.3); }
100% { box-shadow: 0 0 5px 15px transparent; }
Alert Animation
primary: Alert!
icon: mdi:fire
icon_color: red
card_mod:
style:
.shape {
--shape-animation: ping 1.5s infinite, blink 1.5s ease-in-out infinite;;
@keyframes ping {
0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7); }
@keyframes blink {
100% {opacity: 0;}
Record Animation
icon: mdi:record-circle
icon_color: cyan
primary: Record
card_mod:
style:
.shape {
background: linear-gradient(-45deg, rgba(var(--rgb-black), 0.4) 0%, rgba(var(--rgb-black), 0.6) 50%, rgba(var(--rgb-black), 0.4) 100%);
--shape-animation: spin 400ms linear infinite;
Heart Animation
primary: Heart
icon: mdi:heart
icon_color: red
card_mod:
style:
.shape {
transform-origin: 50% 60%;
--shape-animation: heart 1.3s ease-out infinite both;
@keyframes beat {
@keyframes heart {
0% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.2); }
10% { box-shadow: 0 0 5px 5px transparent; }
17% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.2); }
33% { box-shadow: 0 0 5px 5px transparent; }
60% { box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.2); }
Play Animation
icon: mdi:play
icon_color: orange
primary: Play
card_mod:
style:
ha-icon {
--icon-animation: spin 4s steps(4) infinite;
Christmas Tree Animation
cards:
icon: mdi:pine-tree
icon_color: green
primary: Christmas Tree
icon: mdi:star-four-points
icon_color: yellow
primary: Star
card_mod:
style:
ha-icon {
--icon-animation: star 8s ease infinite alternate;
@keyframes star {
0%, 100% { transform: translateY(-10px) rotate(0deg) scale(0.4); }
50% { transform: translateY(-10px) rotate(360deg) scale(0.6); }
.shape {
ha-card {
width: 66px;
top: -66px;
icon: mdi:gift
icon_color: red
card_mod:
style:
ha-icon {
--icon-animation: surprise 4s ease infinite;
@keyframes surprise {
0%, 20%, 100% { transform: translateY(0); }
2.5% { transform: translateY(-2px) rotate(-27deg); }
5% { transform: translateY(-2px) rotate(21deg); }
7.5% { transform: translateY(-2px) rotate(-15deg); }
10% { transform: translateY(-2px) rotate(9deg); }
12.5% { transform: translateY(0); }
15% { transform: translateY(-1.2px) }
.shape {
--icon-size: 20px;
top: 16px;
left: 18px;
ha-card {
width: 66px;
top: -132px;
card_mod:
style: |
ha-card {
height: 66px;
Doggy Animation
primary: Doggy
icon: mdi:dog
icon_color: brown
card_mod:
style:
ha-icon {
--icon-animation: huh 4s ease infinite;
@keyframes huh {
0%, 10%, 75%, 100% { transform: rotate(0deg); }
15% { transform: rotate(-25deg); }
30%, 35% { transform: rotate(-40deg); }
50% { transform: rotate(12deg); }
65% { transform: rotate(-8deg); }
can we request mdi:fireplace?
Cant really get those animation to work.
What am i doing wrong?
entity: binary_sensor.aqara_motion_stua_motion_1
content_info: none
icon: mdi:eye
card_mod:
style:
ha-icon {
--icon-animation: wink 4s ease-in-out infinite;
@keyframes wink {
0%, 100% { transform: scale(1, 1); }
19% { transform: scale(1.05, 0.6); }
20% { clip-path: polygon(0 100%, 100% 100%, 100% 49%, 86% 51%, 79% 59%, 70% 66%, 57% 71%, 43% 71%, 29% 65%, 21% 57%, 13% 49%, 0 49%); }
25% { transform: scale(1, 1); }
28% { transform: scale(0.95, 1.05); }
30% { clip-path: inset(0 0 0 0); }
try this, modify your entity
entity: switch.adguard_home_filtering
content_info: none
icon: mdi:eye
card_mod:
style:
ha-icon {
@keyframes wink {
Thank you, but it just returns white.
It looks like you are trying to apply the animation to a Mushroom Chip? You can apply it to a Chip like this:
chips:
- type: template
icon: mdi:mushroom
icon_color: red
- type: template
icon: mdi:eye
icon_color: blue
card_mod:
style:
mushroom-template-chip:nth-child(2)$: |
ha-icon {
@keyframes wink {
