Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Only the inner side of the icon stops blinking, but the outside still is…Could you please have a look for me again?"
We have this now so:
type: custom:mushroom-template-card
icon: mdi:radiator
icon_color: '{{ ''red'' if is_state(entity, ''on'') else ''disabled'' }}'
primary: heater
secondary: ''
entity: switch.compressor
tap_action:
  action: toggle
fill_container: true
layout: vertical
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon {
        {{ '--icon-animation: rotation 1s linear infinite;' if is_state(config.entity, 'on') }}
        transform-origin: 29% 88%;
      @keyframes clip {
        0% {
          clip-path: inset(50% 0 0 0);
        100% {
          clip-path: inset(0 0 0 0);
      .shape {
        --shape-animation: ping 2s infinite;
      @keyframes ping {
        0% {
          box-shadow: 0 0 0 0 rgba(var(--rgb-red), 0.7);
        70% {
          box-shadow: 0 0 0 10px transparent;
        100% {
          box-shadow: 0 0 0 0 transparent;
And then do the same for the --shape-animation.
Also replace the example --icon-animation values with the correct ones for your animation.
Oké Thank you i look in the Evening, i hope that we can fix😊
Thanks,
What I mean is the animated speaker icon you did. When I press the on/off button I want it do be animated for 1-2 seconds.
Best regards
Thekholm
Can you explain more about:
input_select.mediaplayer_source
and
input_select.select_option
Can you show me please? can you making for me, I try but it doesn’t work, sorry i feel my stupid
icon: mdi:radiator
primary: heater
secondary: ''
tap_action:
  action: toggle
layout: vertical
card_mod:
style:
      ha-icon {
        --icon-animation: clip 1s linear infinite;' if is_state(config.entity, 'on') }}
      @keyframes clip {
        0% {
        100% {
      .shape {
        --shape-animation: ping 2s infinite;' if is_state(config.entity, 'on') }}
      @keyframes ping {
        0% {
Can you share the final code please?
sure
primary: '{{ states(''sensor.time'') }}'
secondary: '{{ states(''sensor.date'') }}'
tap_action:
  action: fire-dom-event
  browser_mod:
    service: browser_mod.popup
      style: '--popup-background-color: black;'
      content:
        type: custom:weather-card
        entity: weather.dark_sky
        number_of_forecasts: '5'
card_mod:
  style: |
    mushroom-card {
      text-align: center;
      --primary-text-color: orange;
      --primary-text-size: 300%;
      --primary-text-weight: light;
      #background: black
      #center 0px;
      #height: 40px;
      #width:  600px;
      --card-primary-font-size: 40px;
      --primary-font-size: 600px;
      --primary-text-weight: light;}
This includes a pop up for the weather
how can we the machine stopped? whats wrong on the code?
primary: ''
secondary: |2
        {{ states("sensor.wasmachine_electrical_measurement") }} watt |
        {{ states("sensor.wasmachine_smartenergy_metering_summation_delivered") }} kwh
icon: >-
  {{ 'mdi:washing-machine-off'if states('sensor.wasmachine_electrical_measurement') | float(0) > 5 else
  'mdi:washing-machine' }}
entity: input_boolean.wasmachine
layout: vertical
icon_color: yellow
tap_action:
  action: toggle
card_mod:
  style:
      ha-icon {
        --icon-animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;' if states('sensor.wasmachine_electrical_measurement') | float > 5 }}
        transform-origin: 50% 110%;
      @keyframes shake {
        0%, 100% { transform: translate(0, 0) rotate(0); }
        20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
        40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
        60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
        80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
      @keyframes drum {
        50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
stop washing under 5watt start above 5watt
Hello
Using chip card, how could I round the numeric value to only one decimal point?
syntax is wrong on this line:
It should be:
{{ '--icon-animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;' if states('sensor.wasmachine_electrical_measurement') | float > 5 }}
Using a template chip, you could set the content to:
{{ 123.4567 | round(1) }} SEK/kWh
where 123.45… should obviously be replaced with the sensor.
thank you so much and happy now,
I have a script (play.radio) that plays an url/stream depending on the mediaplayer_source entity
So inputselect.mediaplayer_source has a list of the stations, inside the script there are urls to the stations and input_select.select_option is used when I’m tapping the station picture
i know it might sounds complicated but it works :smiley:
send a private message if you want to discuss further
Almost there. Like this:
icon: mdi:radiator
primary: heater
secondary: ''
tap_action:
  action: toggle
layout: vertical
card_mod:
  style:
      ha-icon {
        {{ '--icon-animation: clip 1s linear infinite;' if is_state(config.entity, 'on') }}
      @keyframes clip {
        0% {
        100% {
      .shape {
        {{ '--shape-animation: ping 2s infinite;' if is_state(config.entity, 'on') }}
      @keyframes ping {
        0% { box-shadow: 0 0 1px 1px rgba(var(--rgb-red), 0.7); }
        100% { box-shadow: 0 0 5px 15px transparent; }
Hi. Great idea! How did you make the card for Utilia Terrazzo ? Is this also the climate card ?
thank you,so much but now heater its on and he don,t no flashing outside, whe trying this we remove {{ but no effects i Think we remove that, but i think you need the {{ but we trying,
How can I get a thin divider line in the template card?
Best regards
Thekholm
Does someone can send me the code or example how to use those icons animations with a state
When entity is on then the animation is working with a given color. When entity is off then animation is off and color is different
Im trying and trying but can’t figure it out
Hello, everyone.
why doesn’t it work with the two eties?
The color does not change
can you help me
Thanks.
square: false
columns: 2
type: grid
cards:
    primary: '{{ state_attr(entity, ''friendly_name'') }}'
    secondary: '{{ states(entity) }}dBm'
    icon: |-
      {% set rssi_level = states(entity) | int %}
      {% if -1 > rssi_level >= -50 %}
        mdi:wifi-strength-4
      {% elif -51 >= rssi_level > -61 %}
        mdi:wifi-strength-3
      {% elif -62 >= rssi_level > -72 %}
        mdi:wifi-strength-2
      {% elif -73 >= rssi_level > -83 %}
        mdi:wifi-strength-1
      {% elif -83 >= rssi_level > -94 %}
        mdi:wifi-strength-outline
      {% else %}
        mdi:wifi-strength-off-outline
      {% endif %}
    entity: sensor.shelly1_ba015a_rssi
    fill_container: false
    icon_color: |-
        green
        lime-green
        yelow
        amber
      {% elif -84 >= rssi_level > -94 %}
        red
      {% else %}
        red
      {% endif %}
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    icon: |-
        mdi:wifi-strength-4
        mdi:wifi-strength-3
        mdi:wifi-strength-2
        mdi:wifi-strength-1
      {% else %}
      {% endif %}
    entity: sensor.shellyswitch25_ba7900_rssi
    icon_color: |-
        green
        lime-green
        yelow
        amber
        red
      {% else %}
        red
      {% endif %}
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    badge_color: ''
    icon: |-
        mdi:wifi-strength-4
        mdi:wifi-strength-3
        mdi:wifi-strength-2
        mdi:wifi-strength-1
      {% else %}
      {% endif %}
    entity: sensor.shellyswitch25_ba854b_rssi
    icon_color: |-
        green
        lime-green
        yelow
        amber
        red
      {% else %}
        red
      {% endif %}
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    badge_color: |-
        green
        lime-green
        yelow
        amber
        red
      {% else %}
        red
      {% endif %
    icon: |-
        mdi:wifi-strength-4
        mdi:wifi-strength-3
        mdi:wifi-strength-2
        mdi:wifi-strength-1
      {% else %}
      {% endif %}
    entity: sensor.shelly1_ba2c28_rssi
    icon_color: |-
        green
        lime-green
        yelow
        amber
        red
      {% else %}
        red
      {% endif %}
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    icon: |-
        mdi:wifi-strength-4
        mdi:wifi-strength-3
        mdi:wifi-strength-2
        mdi:wifi-strength-1
      {% else %}
      {% endif %}
    icon_color: |-
        green
        lime-green
        yelow
        amber
        red
      {% else %}
        red
      {% endif %}
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
