burg93
(Adam)
October 14, 2022, 9:46am
3442
rhysb:
Part 3
These are awesome and exactly what I was looking for. Would it be possible to get them and any future ones added to a github page or perhaps a separate thread on here? I’d love to keep up to date with the latest ones but there’s quite a lot to wade through in this thread!
Perhaps a github page with an alphabetically ordered grid of the gifs so you can quickly browse the icons with each hyperlinking to the relevant point in a file of the code. You can create permalinks to any line in a file so could just chuck them all in one big file and grab the permalink for the icon. Excited to see more!
rhysb
(Rhys)
October 14, 2022, 10:13am
3443
I’ve added some documentation to show how to use in your cards.
Mushroom Animations - Part 4
Even More Mushroom Card Icon Animations
[Mushroom HA Animation]
HA Animation type: custom:mushroom-template-card
icon: mdi:home-assistant
icon_color: blue
primary: Home Assistant
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
--icon-animation: boing 3s ease infinite;
transform-origin: 50% 90%;
@keyframes boing {
0% { transform: scale3d(1, 1, 1); }
7% { transform: scale3d(1.25, 0.75, 1); }
rhysb
(Rhys)
October 14, 2022, 10:39am
3444
Use abs (absolute value) filter to convert values to positive. Like this:
{% set rssi_level = states(entity) | int | abs %}
rhysb
(Rhys)
October 14, 2022, 10:52am
3445
You are missing sone @keyframes
on the ping animation. Should be like this:
@keyframes ping {
0% { box-shadow: 0 0 1px 1px rgba(var(--rgb-red), 0.7); }
100% { box-shadow: 0 0 5px 15px transparent; }
The style:
command needs to be indented after card_mod:
like this:
card_mod:
style:
Kabala
(Cata)
October 14, 2022, 11:22am
3447
somehow doesn’t work.
primary: '{{ state_attr(entity, ''friendly_name'') }}'
secondary: '{{ states(entity) }}dBm'
icon: |-
{% if -1 > rssi_level >= -50 %}
mdi:wifi-strength-4
{% elif -51 >= rssi_level > -61 %}
mdi:wifi-strength-3
{% elif -62 >= rssi_level > -72 %}
mdi:wifi-strength-2
{% elif -73 >= rssi_level > -83 %}
mdi:wifi-strength-1
{% elif -83 >= rssi_level > -94 %}
mdi:wifi-strength-outline
{% else %}
mdi:wifi-strength-off-outline
{% endif %}
entity: sensor.shellyswitch25_ba854b_rssi
fill_container: false
icon_color: |-
green
lime-green
yelow
amber
red
{% else %}
red
{% endif %}
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
badge_color: ''
rhysb
(Rhys)
October 14, 2022, 11:38am
3448
You need to change your comparisons to positive values too.
RonOnline
(Ron )
October 14, 2022, 12:11pm
3449
@rhysb Could you help me?
The keyframes drum does not work for me …
This is my card:
- type: custom:stack-in-card
cards:
primary: Zolder
secondary: '{{ states("sensor.zolder_temp_temperature") | round(0) }} °C'
icon: fapro:z
entity: light.lounge_light
tap_action:
action: navigate
navigation_path: zolder
hold_action:
action: toggle
icon_color: '{{ ''yellow'' if is_state(entity, ''on'') else ''disabled'' }}'
fill_container: true
layout: horizontal
multiline_secondary: false
card_mod:
style: |
:host([dark-mode]) {
background-blend-mode: darken;
:host {
background-image: url('/local/zolder.jpg') , linear-gradient(to right, rgba(var(--rgb-card-background-color), 1), rgba(var(--rgb-card-background-color), 0));
background-size: 50% 100%;
background-position: right;
background-repeat: no-repeat;
background-blend-mode: lighten;
--mush-icon-size: 56px;
height: 66px;
margin-left: -10px !important;
- type: custom:mushroom-chips-card
chips:
- type: conditional
conditions:
- entity: sensor.wasmachine_washer_machine_state
state: run
chip:
type: template
icon: mdi:washing-machine
icon_color: |2-
{% if is_state(entity, 'off') %}
grey
{% else %}
blue
{% endif %}
tap_action:
action: more-info
card_mod:
style: >
{% if is_state('sensor.wasmachine_washer_machine_state','run')
ha-card {
animation: shake 500ms ease-in-out infinite, drum 1s infinite;
transform-origin: 100% 100%;
@keyframes shake {
0%, 100% { transform: rotate(4deg); }
50% { transform: rotate(-4deg); }
@keyframes drum {
50% { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
{% else %}
{% endif %}
- type: conditional
conditions:
- entity: sensor.droger
state: 'on'
chip:
type: template
icon: mdi:tumble-dryer
icon_color: |2-
grey
{% else %}
red
{% endif %}
tap_action:
action: more-info
card_mod:
style: |
{% if is_state('sensor.droger','on') %}
ha-card {
animation: shake 800ms ease-in-out infinite, drum 1s infinite;
@keyframes shake {
{% endif %}
- type: conditional
conditions:
- entity: binary_sensor.kleine_zolderraam_contact
state: 'on'
chip:
type: template
double_tap_action:
action: none
entity: cover
icon: >
{% set state=states('binary_sensor.kleine_zolderraam_contact')
{% if state=='off' %}
fapro:door-closed
{% elif state=='on' %}
phu:lift-out-window-open
{% else %}
fapro:door-closed
{% endif %}
icon_color: >-
green
red
{% else %}
yellow
{% endif %}
card_mod:
style: >
{% if is_state('binary_sensor.kleine_zolderraam_contact',
'on') %}
ha-card {
animation: borderPulse 2s ease-out infinite;
@keyframes borderPulse {
50% {
box-shadow: 0 0 20px red;
{% endif %}
content: null
tap_action:
action: toggle
hold_action:
action: none
alignment: end
card_mod:
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
--chip-spacing: 0;
card_mod:
style: |
ha-card {
height: 102px;
Homeotte41
(Jonathan )
October 14, 2022, 12:37pm
3450
Thank you, for all its perfect now
zeltak
(zeltak)
October 14, 2022, 6:24pm
3451
Hi all
is there anyway to make a mushroom button take over 2 spaces ie:
I want to keep the lights and climate card the same size but want to have the alarmo card take double space (I dont need the fans card)
is there anyway at all to define the size a mushroom card takes?
thx alot
Z
burg93
(Adam)
October 14, 2022, 6:58pm
3452
Easiest thing that comes to mind with HA out of the box is a horizontal card with a grid of 2. Then a grid of 2 again in the left cell and just alarmo in the right.
janiv
(Janiv Ratson)
October 14, 2022, 11:43pm
3453
How do I create a template card with last-changed as secondary?
Kabala
(Cata)
October 15, 2022, 4:28am
3454
just doesn’t want to work
icon: |-
{% if 1 > rssi_level >= 50 %}
mdi:wifi-strength-4
{% elif 51 >= rssi_level > 61 %}
mdi:wifi-strength-3
{% elif 62 >= rssi_level > 72 %}
mdi:wifi-strength-2
{% elif 73 >= rssi_level > 83 %}
mdi:wifi-strength-1
{% elif 83 >= rssi_level > 94 %}
{% else %}
{% endif %}
icon_color: |-
green
lime-green
yelow
amber
red
{% else %}
red
{% endif %}
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
badge_color: ''
rhysb
(Rhys)
October 15, 2022, 4:54am
3455
Try like this:
icon: |-
{% if rssi_level > 90 %}
{% elif rssi_level > 80 %}
mdi:wifi-strength-1
{% elif rssi_level > 70 %}
mdi:wifi-strength-2
{% elif rssi_level > 60 %}
mdi:wifi-strength-3
{% elif rssi_level > 1 %}
mdi:wifi-strength-4
{% else %}
{% endif %}
icon_color: |-
red
amber
yellow
light-green
green
{% else %}
red
{% endif %}
tap_action:
action: more-info
hold_action:
action: none
double_tap_action:
action: none
badge_color: ''
rhysb
(Rhys)
October 15, 2022, 5:16am
3457
You can do what you want like this:
square: false
columns: 4
type: grid
cards:
- type: custom:mushroom-light-card
entity: light.office_light
show_brightness_control: false
layout: vertical
- type: custom:mushroom-climate-card
entity: climate.office_air_conditioner
layout: vertical
- type: custom:mushroom-alarm-control-panel-card
entity: alarm_control_panel.downstairs
states:
- armed_home
- armed_away
card_mod:
style: |
:host {
grid-column: 3 / span 2;
zeltak
(zeltak)
October 15, 2022, 5:34am
3458
thx both @rhysb and @burg93 !
appreciate your kind help
Z
rhysb
(Rhys)
October 15, 2022, 5:55am
3459
That animation works by combining the icons from two cards, so won’t work with a chip. You can use the Washing Machine animation from part 1 though.
aeozyalcin
(Anil Ozyalcin)
October 15, 2022, 6:46am
3460
This is awesome stuff! Thank you so much for putting it together!
I am trying to get a spinning “Halo” like effect around a mushroom-chips card as shown in the picture below. Right now, I have only been able to get the Halo to spin along with the icon itself, which is not what I want. I am trying to get the icon to stay stationary while the Halo spins. Any tips?
phairplay
(Phairplay)
October 15, 2022, 7:41am
3461
Morning guys,
I would really like to start using Mushroom and I could really do with some help first my first card.
the alarm panel icon shows blue when disarmed, is it possible to have it green then red when armed
