Hello all, great card Anyone one knows how to place in the chip card the time and date?
thank you in advance
any way to get the unavailable indicator to a template card?
would like to show if a window is open
Loving the new update card.
Any update on the Thermostat card and is there a possibility of a graph card ?
That’s brilliant. All starting to make sense now and looks amazing. Thanks for those code blocks, was really helpful! Looking forward to more updates!
Nice Paul!!!
Fully operational here!!
- type: horizontal-stack
cards:
- type: grid
columns: 2
square: false
cards:
- type: conditional
conditions:
- entity: update.home_assistant_core_update
state: 'on'
card:
type: custom:mushroom-update-card
icon: mdi:home-assistant
name: Home Assistent
show_buttons_control: true
- type: conditional
conditions:
- entity: update.home_assistant_operating_system_update
state: 'on'
card:
name: Home Assistant Operating System
- type: conditional
conditions:
- entity: update.home_assistant_supervisor_update
state: 'on'
card:
name: Home Assistant Supervisor
- type: conditional
conditions:
- entity: sensor.hacs
state_not: '0'
card:
entity: sensor.hacs
icon: hacs:hacs
- type: conditional
conditions:
- entity: update.eufy_security_add_on_update
state: 'on'
card:
icon: phu:ring-doorbell-pro
name: Eufy Security Add-on
- type: conditional
conditions:
- entity: update.rtsp_simple_server_add_on_update
state: 'on'
card:
icon: mdi:cctv
name: RTSP Simple Server Add-on
- type: conditional
conditions:
- entity: update.home_assistant_google_drive_backup_update
state: 'on'
card:
icon: mdi:google
name: Google Drive Backup
- type: conditional
conditions:
- entity: update.file_editor_update
state: 'on'
card:
icon: mdi:file-document-edit
- type: conditional
conditions:
- entity: update.samba_share_update
state: 'on'
card:
icon: ''
- type: conditional
conditions:
- entity: update.terminal_ssh_update
state: 'on'
card:
icon: fas:terminal
- type: conditional
conditions:
- entity: update.studio_code_server_update
state: 'on'
card:
icon: fas:terminal
- type: conditional
conditions:
- entity: update.cloudvdlinden_dsm_update
state: 'on'
card:
icon: mdi:nas
name: CloudvdLinden DSM Update
- type: conditional
conditions:
- entity: binary_sensor.m3_van_leon_update_available_sensor
state: 'on'
card:
icon: phu:tesla-icon
name: Tesla M3 update
Love this! Thank you!
Is there a way to hide the object name so just the icon is visible? Use case: I have a grid set up for a bedroom. There is only one fan in there, so I don’t need a label or status, just the animated icon. Something like show_name: false
. I may be missing it, apologies if I am!
try just setting a space as name, i think it ignores it then and the card gets smaller
Hey,
you can do this by writing “entity” in your template. Like this:
{{ '#ff9800' if is_state(entity, 'on') else '' }}
Isn’t there anyone that can help me get those nice colourful circles around the icon even if the icon calls for a script, shows the alarm status and similar as the example in my post above? The UI looks inconsistent now.
I think there is something wrong with your theme. Which theme do you use ?
I’m using the Mushroom theme. If you add an entity card with a script call, do you get the colour circle?
“Dagens lunch” below launches a script. “Avlarmat” is the status of my home alarm as two examples.
When clicking “Dagens lunch” the script launches and I get the colour circle for a few seconds before disappearing.
The color is only applied when the entity is “active”. Disarmed is considered inactive. Armed state are active so the color will be applied.
The script is also inactive. It go to active a few millisecond when you toggle it. That can explain the color flickering when you toggle it. If you want script always colored. You can do it with a template card if
hey all, is there a way to have all the cards appear they are part of one card. As you can see the from my example, the Solar card has its own shadowed border, i would like to extend this for the whole card??
Would it be possible to align the buttons (Alarmo and Update Card)?
Oh looks like an issue with the update card
Is there a way to customize the text? I’ve only been able to return the code as the text.
tap_action:
confirmation:
text: >-
{{ "Close the Gate?" if
is_state('binary_sensor.front_gate_access_control_window_door_is_open','on')
else "Open the Gate?" }}
Great, then it’s a feature and not a bug
Used a template card instead of entity card and got it to work. Thank you!
Hi there,
Like everyone else I just love the mushroom cards and theming! I have added chip cards to the top of my mobile dashboard, but how can I remove the default home assistant headers? Just for my mobile dashboard having the chip cards at the top is the best look in my opinion. I can sweep right to get to the HA menu items will functionality without the headers is not affected. I tried turning on “full screen” in the companion app settings but it just removed the footer:
I would like to change this view:
To look like something like this:
