iirc you could install any theme and add this to it:
card-mod-root: |
app-toolbar {
display: none;
card-mod-root: |
app-toolbar {
display: none;
This works for me when opening/closing the garage door:
type: custom:mushroom-entity-card
entity: switch.garageporten_template
primary_info: none
layout: vertical
secondary_info: name
tap_action:
action: toggle
confirmation:
text: 'Vill du ƶppna/stƤnga garageporten?'
hold_action:
action: none
Thereās any option to show/hide the upper toolbar?
Thank you @mase
I tried a few different places to put that code but none removed the app toolbarā¦ Any guidance, thank you
on
background: var(--background-image)
resources:
- url: /community_plugin/dual-gauge-card/dual-gauge-card.js
type: js
- url: https://github.com/wowgamr/animated-weather-card
category: Theme
- url: /hacsfiles/simple-thermostat/simple-thermostat.js
type: module
- url: /local/mini-graph-card-bundle.js?v=0.10.0
type: module
card-mod-root: |
app-toolbar {
display: none;
- path: default_view
title: Home
icon: mdi:home-assistant
badges: []
cards:
- type: custom:mushroom-chips-card
chips:
- type: action
double_tap_action:
action: none
for me itĀ“s in a theme.yaml.
try this:
add theme.yaml
in \themes\mytheme
in the theme.yaml
add:
mytheme:
card-mod-root: |
app-toolbar {
display: none;
after a restart apply the theme in your profile
i use the theme that comes with ui-minimalist and thatĀ“s how it works there.
you can install kiosk browser from HACS
then you can add to Raw configuration editor at the first line the following:
(if you want to bring back the header you can add at the and of your HA any page url - ?disable_km)
kiosk_mode:
hide_header: true
Hey everyone.
Is there a chance to modify font size in mushroom-template-card?
Thanks.
You can override some variables with theme variables : GitHub - piitaya/lovelace-mushroom-themes: Additional themes for Lovelace Mushroom Cards š
When using a template card and displaying sensors like my garage door I get the state shown as āonā while it in my normal dashbpard shows as āOpenā. Same with a sensor that tells me when the next mail delivery is, in Mushroom I get ā2ā and in my normal dashboard I get āDay after tomorrowā written.
Is this the correct way to show a sensors value in Mushroom or should I use something else to get the formatted better looking result:
{{states('sensor.postnord_delivery_70150') }}
Same with localizations, in Mushroom I get everything from the template card in English and in my normal dashboard it is in Swedish.
How do the rest of you display sensors in the template card?
Entity card vs. Template card. āĆvermorgonā means āday after tomorrowā, thatās why the ā2ā.
type: custom:mushroom-template-card
secondary: '{{states(''sensor.postnord_delivery_70150'') }}'
icon: mdi:home
entity: sensor.postnord_delivery_70150
primary: Postnord
this looks great! Can you show me, how do you do that ?
Create the card in my example,??
I figured it out
Iām looking to embed a site like Windy using an iframe. Is this possible using any of the existing Mushroom cards?
Hereās what it looks like in my current Lovelace dashboard:
If thereās just the one weather condition that you need to fix you can just use a replace()
Currently it is {{ state_attr('weather.home', 'temperature') }}ĀŗC
and {{ (states('weather.home')).replace("partlycloudy", "partly cloudy") }} outside.
If there are more than that you can use a dictionary:
{%- set con = states('weather.home') -%}
{%- set fix = {
"partlycloudy":"partly cloudy",
"scatteredshowers":"scattered showers"} -%}
and {{ fix.get(con) if con in fix.keys() else con }} outside.
Iām here once to again to show the appreciation !!!
It was never so clean!
My dashboard for HA maintenance in General
And the vacuum cardā¦ i just canāt wait for it!
Iām trying to use mdi icons in the template card to display devices that are currently on. I am trying to add the following code in Secondary Information. Is it possible to alter this so the icon will properly display?
{% if is_state('fan.living_room_fan', 'on') %}
mdi:fan
{% endif %}
Thanks for the response - I was hoping to get dynamic that is state based. In the meantime Iām using state agnostic text.
This may have already been asked but I cant find it in the thread but everyoneās corners on the cards seem to have a much more pronounced roundness to the corners in comparison to mine.
Did yours round that much with a basic install or have to edited the config to do this? My cards donāt look as rounded as they do in the demo pictures on the github page for this project.
See photo below, my cards on the left and the Demo cards on the right from the github project. Am I missing something?
I tried this on my original HA install and on a brand new install just in case I had something in my main install that was causing it however it does it on a brand new install of HA as well.
You need to download the mushroom themes, itāll give you the nice rounded corners.
Thats better thank you!
