Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Here is the wisdom you seek:
I t think it would make more sense to put this on the share your protest forum, this looks like a whole new project. Nice!
I have developed my mushroom dashboard frm my mobile first, then I used layout-card (vertical) so I can move my cards around to fill the space with this:
view_layout:
  column: 1
I think it works quite well
Please understand that it is very straining on the eye and difficult to fast read code, if not formatted in a standard way. Please use the Preformatted text-function. In your post, press and hold ctrl and then “E”.
Then just paste your code. Done. Super, thanks!
This is exactly what I was looking for. I’ll give it a shot. Thanks much!
Please share the code.
How to add the power consumption into a light card?
Everything is done via UI, and is quite simple. I divided the dashboard in variuous block
I use the vertical layout, and if needed, the grid layout. For example, the “Luci” block:
type: vertical-stack
cards:
  - type: custom:mushroom-title-card
    title: Luci
  - type: grid
    cards:
      - type: custom:mushroom-light-card
        entity: light.barra_est_knx
        entity: light.barra_ovest_knx
        entity: light.disbrigo_knx
        entity: light.tavolo_knx
        icon: ''
        entity: light.soggiorno_knx
        icon: ''
        entity: light.divano_knx
        icon: ''
        entity: light.isola_knx
        entity: light.sottopensile_knx
        entity: light.ingresso_knx
        icon: ''
        entity: light.corridoio_ingresso_knx
    columns: 2
    square: false
view_layout:
  column: 1
I also use the top left image to go back home
show_state: false
show_name: false
camera_view: auto
type: picture-entity
entity: weather.openweathermap
image: local/immaginistanze/soggiorno.jpg
tap_action:
  action: navigate
  navigation_path: home
hold_action:
  action: none
aspect_ratio: '3:1'
view_layout:
  column: 1
@KaherdinTristan Did you ever have a chance to figure out how to “link” the color + temperature button to the vertical slider?
Hi
Is it possible that the inside of the icon on the icon pump can rotation?
  1. Has anyone managed to animate the air purifier icon? I’d like to use that instead of the standard fan icon (for air purifiers).
  2. Is it possible to add a badge to the icon on the Mushroom Fan card? I tried using some of the card_mod code (mushroom-badge-icon) in previous posts, but those were all for Template cards, so not sure if the Fan card supports badges at all.
That should be done by fiddling with “track” and “progress”, and knowing how to reference the current entity state and color. I guess this, and I know its the logical thing to do. But help me all hedonistic gods, I have not a clue in the world who designed css and left all the documentation undone.
 - type: custom:my-slider-v2
        entity: light.bella_ledlight
        vertical: true
        styles:
          card:
            - width: 35px
          container:
            - border-radius: 12px
          track:
            - background: >
                [[[ if (entity.state == "off") return
                "rgba(var(--mush-rgb-disabled), 0.2)";
                 else return "rgba(var(--mush-rgb-amber), 0.2)";
          progress:
            - background: >
                "rgb(var(--mush-rgb-disabled))";
                 else return "rgb(var(--mush-rgb-amber))";
          thumb:
            - width: 0px
yes. place two icons on top of each other, rotate one.
i dont know how to do this, but I know the answer is already in this thread.
@rhysb can you please tell me how to add the shadow effect to the climate card ? so that when the A/C is the icon animates like yours but also produces this shadow animation similar to alert animation.
i tried the following code but the shadow animations creates a square instead of circle.
@keyframes cool {
      60% { box-shadow: 0 0 0 0 rgba(var(--rgb-cyan), 0.7); }
      100% { box-shadow: 0 0 5px 15px transparent; }
      0%, 100% { transform: rotate(25deg); }
      25% { transform: rotate(-25deg); }
      50% { transform: rotate(50deg); }
      75% { transform: rotate(-50deg); }
Screen Shot 2022-10-20 at 3.18.27 PM
haha, I know what you mean. This is where I’m at right now. The right slider only controls brightness level and not color temperature or color control. This is a workaround but simplifying the design I want to get rid of the horizontal line.
Anyone know how to do this magic trick?
type: horizontal-stack
cards:
  - type: vertical-stack
    cards:
        entity: light.lr_light_group
        use_light_color: true
        show_brightness_control: true
        show_color_temp_control: true
        show_color_control: true
        name: Living Room Lights
        collapsible_controls: true
      - type: custom:mushroom-entity-card
        fill_container: false
        tap_action:
          action: toggle
        icon: ''
        primary_info: name
        name: Living Room Switches
        layout: horizontal
        secondary_info: state
    vertical: true
    styles:
      card:
        - height: 150px
        - width: 35px
      container:
      track:
        - background: >
      progress:
        - background: >
      thumb:
        - width: 0px
    card_mod:
      style: |
        ha-card {
          padding: 12px 12px 12px;
      card_mod:
        style: |
          ha-card {
            height: 140x;
Nice! I also got it working by using the layout-card (in vertical) and just a layout break card to create new columns. Works great!
Question, what card did you use for the breaks? e.g. -----Area Lights-----
It is hard to see the rotation, but I have added one for you:
I’ve added one for Air Purifier too :grinning_face_with_smiling_eyes:
Hm still unable to get either of these 2 to work.
