did something change with the theme again after the 2022.11 HA update? borders around chips again after just removing them again haha.
would these have reverted some how after the update? I made this change a few days ago and all was well until today.
This change has been reverted, so you will need to change this back to --chip-box-shadow
. Unfortunately you will not be able to do a āReplace Allā as --ha-card-box-shadow
is used by Mushroom Cards.
If you would like to remove the new border, you can add ha-card-border-width: 0
to your theme.
It is nice to see some being added to HA with the new Tile Card.
and what if Iām not using theme and I want to remove borders (that appeared) in every card ?
shall I add --ha-card-border-width: 0
to every single card ?
Do you have an example please?
I did that to my themes but doesnt change anything
This is what I have in mine
Mushroom:
# Nothing here as it's the default HA theme since 2022.11
modes:
light: {}
dark: {}
Odd choice to add those large borders when itās known that people are already happy with the way mushroom looks (due to its popularity). Anyway it looks terrible with them so thanks for the tips on removing it here. One liner worked a charm in the now empty mushroom theme file.
Remove the double dash perhaps. This is working in mine, nothing else in the file. Obviously with it set as current theme in the user settings.
Mushroom:
modes:
light: {}
dark: {}
ha-card-border-width: '0px'
Didnt work for me for some reason
Tried a new browser and cleared my cache, but still there
Are you using stack in card or vertical stack in card ?
There is an open PR to solve this problem with stack in card : Home Assistant 2022.11 compatibility by ov1d1u Ā· Pull Request #47 Ā· custom-cards/stack-in-card Ā· GitHub
yes I am, Ok then that explains it thanks
This also works in my system, so there is no border.
Mushroom:
modes:
light: {}
dark: {}
ha-card-border-width: "0px"
@cowboysdude
Did u get error or know what could be the reason ?
Visual editor is not supported for this configuration:
At path: card_mod -- Expected a value of type `never`, but received: `[object Object]`
You can still edit your config in YAML.
Wellā¦!
After the latest update my cards look like this now
So I tried to change stuff, but it didnāt work! Then I tried to change my theme to Mushroom Shadow and got this.
Not right yet, so now I tried to change this line in my card --ha-card-box-shadow: none;
to this --chip-box-shadow: 0px; Then it all worked again.
Is Mushroom Shadow the one too use from now on? I have used the Mushroom original from day one.
Best regards
Thekholm
Uhmmmmm not really sure I never got that errorā¦
This is what is in my configuration.yaml file for card mod
extra_module_url:
- /local/card-mod.js
as well as this
- url: /hacsfiles/lovelace-card-mod/card-mod.js
type: module
While card-mod can be installed as a lovelace resource, some functionality will benefit greatly from it being installed as a frontend module instead.
To do that, add the following to your
configuration.yaml
file and restart Home Assistant:frontend: extra_module_url: - /local/card-mod.js
Youāll need to adjust that path according to where you have installed
card-mod.js
. If you installed through HACS, this is probably/hacsfiles/lovelace-card-mod/card-mod.js
.Any resource definitions automatically added by HACS can be kept as is even after adding
extra_module_url
Mushroom doesnāt need themes. Itās built to work with the default Home Assistant theme. If you use other custom cards (vertical-stack-in-card, stack-in-card, etcā¦), it can requires some tweaks. So you can use Mushroom without themes and just add --chip-box-shadow: none
if you donāt want the border in chips.
I try to keep Mushroom as close as possible to the Home Assistant default design to avoid issues during updates.
Thanks,
Then I have to work out a solution to get cards using Stack-in-card and others.
Best regards
Thekholm
Ps: Great work with the Mushroom cards and hope everything works out great at Nabu-casa
Is it possible to flashing mushroom chips card?
with the release of ha 2022.11 i have a line between cards if i use the custom:stack-in-card:
How can i get rid of it?
There is a PR on stack-in-card to fix that behavior but there is no update since 2 years.
The vertical-stack-in-card has been fixed, you can try this one if you want.
