Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
I’m sure you can apply the border to the stack in card but I’m not sure what css variable to use so I add a template card just for the border line. Not the simplest code but it works
type: custom:stack-in-card
mode: vertical
cards:
  - type: horizontal-stack
    cards:
        primary: AAPL
        secondary: Apple
        icon: mdi:apple
        icon_color: disabled
        primary: '121.35'
        secondary: +0.12%
        card_mod:
          style:
            mushroom-state-info$: |
                text-align: end;
              ha-card {
                margin: 3px 8px 0px 0px;
                --secondary-text-color: rgb(var(--rgb-green));
    card_mod:
      style: |
        ha-card {
          margin: -25px 0px 0px 66px;
          border-bottom: solid 2px rgba(var(--rgb-disabled), 0.2);
    cards:
        primary: GOOG
        secondary: Alphabet Inc.
        icon: mdi:google
        primary: 2,041.04
        secondary: +0.27%
        card_mod:
          style:
                text-align: end;
              ha-card {
Awesome. Just what i was looking for. Could you please share the code? :slight_smile:
Amazing, exactly what I was looking for! Your code is much more neat as well.
Heads up!
There is one breaking change for the chips. --chip-box-shadow has changed to --ha-card-box-shadow. You can do a find and replace all to fix.
In case anyone does a copy/paste from @rhysb’s last post, the --chips-box-shadow is meant to be --chip-box-shadow. There is no ‘S’ after chip.
I have an air purifier that has 3 preset speeds and wanted a button card to set those instead of the percentage slider of the fan card. Here’s the code incase anyone wants it
ezgif-5-3dbe075939
cards:
    entity: fan.andrews_air_purifier
    icon: mdi:fan
    primary: Air Purifier
    secondary: |-
      {% set fanspeed = state_attr(config.entity, 'percentage') %}
      {% if is_state_attr(config.entity, "mode", "auto") %}
        Auto
      {% elif is_state_attr(config.entity, "mode", "sleep") %}
        Sleep
      {% elif fanspeed == 100 %}
        High
      {% elif fanspeed == 66 %}
        Medium
      {% elif fanspeed == 33 %}
        Low
    icon_color: green
    card_mod:
      style:
        mushroom-shape-icon$: |
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
          ha-icon {
            box-shadow: 0px 0px;
            animation: rotation linear infinite !important;
            {% set fanspeed = state_attr(config.entity, 'percentage') |float %}
              animation-duration: 2s !important;
              animation-duration: 6s !important;
              animation-duration: 0.5s !important;
              animation-duration: 1.5s !important;
              animation-duration: 3s !important;
            {%- else -%}
            animation-duration: ;
            {%- endif %}
          ha-card {
            margin-bottom: -9px;
    cards:
      - type: custom:layout-card
        layout_type: grid
        cards:
            layout: vertical
            primary: Low
            tap_action:
              action: call-service
              service: fan.set_percentage
                percentage: 33
                entity_id: fan.andrews_air_purifier
            view_layout:
              grid-area: button1
            card_mod:
              style: |
                ha-card {
                  height: 44px !important;
                  box-shadow: none;
                  --card-primary-font-weight: normal;
            layout: vertical
            primary: Medium
            tap_action:
                percentage: 66
            view_layout:
              grid-area: button2
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
            layout: vertical
            primary: High
            tap_action:
                percentage: 100
            view_layout:
              grid-area: button3
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
            layout: vertical
            icon: mdi:fan-auto
            icon_color: white
            tap_action:
              service: fan.set_preset_mode
                preset_mode: auto
            double_tap_action:
                preset_mode: sleep
            view_layout:
              grid-area: button4
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
                mushroom-shape-icon {
                  --shape-color: none !important;
                  --icon-symbol-size: 20px;
        layout:
          grid-template-columns: 29% 29% 29% 13%
          grid-template-rows: auto
          grid-template-areas: |
            "button1 button2 button3 button4"
card_mod:
  style: |
    ha-card {
      {% if is_state('fan.andrews_air_purifier', 'on') %}
          background: rgba(101,170,91,0.1);
Many thanks for this important note. Maybe it’s because I’m running 2022.11.0b0, but when selecting the chip card in a standard view without any theme, I get this:
Super-awkward rookie mistake: forgot to clear cache. Shouldn’t have updated at 2 AM.
We have an iPad in the basement, primarily for guest use to control just that area. This is still a WIP, but I was able to fill my iPad screen perfectly. I used a custom grid layout card, defined below. The playlists on the right are displayed when nothing is playing, and that section is swipeable to view more. When Spotify is playing, it shows the current track and speaker volume controls.
max_cols: 6
grid-template-columns: 16% 16% 32% 36%
grid-template-rows: 16.7% 16.7% 16.7% 16.7% 16.7%
  "info info light-1 climate"
  "info info light-2 spotify"
  "info info light-3 spotify"
  "button-1 button-2 light-4 spotify"
  "button-3 button-4 light-5 volume-1"
  "button-5 button-6 master volume-2"
justify-items: stretch
height: calc(100vh - 5px);
card_margin: 0
Has anyone added icons or custom buttons to light cards? Several of the lights in our home have timers (automations to turn off the light after X minutes), to avoid lights being left on. I’d love an elegant way to toggle the timer automation from the light card. Maybe using the existing button style on the card for swapping between color/temp/brightness, or adding a tappable icon like the attached example. It needs to have a way to tell if the timer is on or off; in this case the icon would be a color when on, or disabled when off.
Screen Shot 2022-10-26 at 5.18.31 PM
And another question: has anyone modified the secondary text style in a mushroom card? I love the style of Feltron reports (e.g. Feltron: 2011 Annual Report), and it would be awesome to have a mushroom card with giant numbers. In the meantime, I’ve been using standard “entity” cards for larger data.
Screen Shot 2022-10-26 at 5.26.34 PM
Hi
How do I create a custom button that looks like the mushroom default button look and feel in its regular state, and when the states changes, I’d like to customize it, when it gets back to the default state, again show the mushroom default theme button.
very nicely done may i ask how you did the part of spotify that when something is playing the card shrinks and volume controls come up ?
any chance you can animate mdi:calendar-clock?
Custom buttons on light card:
Change title font size/style:
I like your code and ideas, any chance you could share your dashboard look?
And on we go… :partying_face:
Sorry for the probably noob question, but how do I do a find and replace all?
mush-chip-box-shadow is back, see the newest release notes.
New variables for themes :
  • --mush-chip-border-color
  • --mush-chip-border-width
  • --mush-chip-box-shadow
