Hi, Iāve installed both mushroom and mushroom theme but when I canāt see to find any custom mushroom card when after creating a new dashboard. Tried clearing cache but still dont see any mushroom cards =(
I had the same issue, problem was that there was no reference to Mushroom under Configuration > Control Panel (might be called Dashboards in English) > Resources.
Add a reference as a JavaScript module to: local/community/lovelace-mushroom/mushroom.js.
Thanks!!! finally got it working!
For some reason im unable to use the mushroom vacuum card. Iāve got 1.4 installed. Ive tried redownloading, removing and readding, ive checked that thereās references to vacuums in the installed js file, but it doesnt show up as a card to add in lovelace, nor can i manually type in ācustom:mushroom-vacuum-cardā as the card type. This persists after browser reloads/server restarts.
Not had a problem like this before - any ideas for how to fix it?
Thereās no Vacuum Card yet as I knowā¦
Itās listed as availabe in Github and thereās documentation for it
That PR has only recently been approved, so it may become available in the next release.
Yep, the vacuum card is coming in the release (just few adjustments and fixes to do )
Great stuff. Any news on when the temp/thermostat card will be available ?
Keep up the good work
i got a custom card which i show when a condition is 0 like this:
type: conditional
conditions:
- entity: sensor.seventeentrack_packages_in_transit
state_not: '0'
card:
type: custom:seventeen-track-card
title: Unterwegs
but when i use the chip card with a condition the custom card is not shown:
type: custom:mushroom-chips-card
chips:
- type: conditional
conditions:
state_not: '0'
chip:
title: Unterwegs
what am i doing wrong?
Anyone have any ideas on how to include MDI icons in the template field?
Can you tell me how you got 2/3 of the with for the ledstrip and 1/3 for the āPokoj Dā light?
Or mind sharing the code? I cant seem to find how to divide the with in unequal pieces.
Sure thing!
It is layout card with Grid view
please see the code below, it is bigger because I use conditional cards to hide brightness, color temp and temperature when lights are off or unavailable
hope this helps
grid-template-columns: 2fr 1fr
2fr represents 2/3 , 1fr 1/3
type: vertical-stack
cards:
- type: custom:text-divider-row
text: Lights
- type: custom:layout-card
layout_type: grid
layout:
width: 100%
grid-template-rows: auto
cards:
- type: conditional
conditions:
- entity: light.tasma_led_rgbww
state_not: 'on'
card:
type: custom:mushroom-light-card
icon: mdi:led-strip-variant
hide_state: true
- type: conditional
conditions:
state: 'on'
card:
show_color_temp_control: true
show_brightness_control: true
hide_state: true
use_light_color: true
show_color_control: true
- type: conditional
conditions:
- entity: light.yeelight_edison_style
state_not: 'on'
card:
hide_state: true
icon: mdi:lightbulb-variant-outline
- type: conditional
conditions:
state: 'on'
card:
hide_state: true
layout_type: grid
layout:
width: 100%
grid-template-columns: 1fr 1fr
cards:
- type: conditional
conditions:
- entity: light.xiaomi_mi_desk_lamp
state_not: 'on'
card:
hide_state: true
name: Lampka Sypialnia
icon: mdi:desk-lamp
- type: conditional
conditions:
state: 'on'
card:
hide_state: true
icon: mdi:desk-lamp
- type: conditional
conditions:
- entity: light.yeelight_white
state_not: 'on'
card:
icon: mdi:floor-lamp
hide_state: true
- type: conditional
conditions:
state: 'on'
card:
hide_state: true
layout_type: grid
layout:
width: 100%
cards:
- type: conditional
conditions:
- entity: light.kitchen_led
state_not: 'on'
card:
hide_state: true
- type: conditional
conditions:
state: 'on'
card:
hide_state: true
Hello, am I the only having issue with colors using binary sensor in mushroom chip ?
Using this
chips:
- type: entity
entity: binary_sensor.annaelle_fenetre
icon_color: purple
icon: mdi:account
- type: entity
entity: person.eric
icon_color: blue
binary sensor is always black, but entity sensor is using color.
I think that for the binary_sensor your sensor has to be On
indeed this is a z-wave fibaro window sensor, so itās sending open/close.
but Iāve no idea how to change this to on/off ??
Iāve just tried this, but not working eitherā¦
chips:
- type: entity
icon_color: '{{ is_state(entity, ''Closed'') | iif(''green'', ''red'') }}'
icon: mdi:account
Guess I need a template, but I canāt see some chips-template-card
Does anyone know a way to center align the text in the Mushroom Title Card? Iād imagine it can be done with card-mod but I donāt really know how to set it up properly.
I was thinking long time to redesign my dashboard and then I found mushroom - Thats really the design which I was looking for and its very easy to configure. @piitaya Thanks for the great JOB!!!
In my setup I use some WLED with SK6812 RGBW LEDs.
With using light card I found out that its not possible to choose a white color and also canĀ“t control the color temperature. No control elements available.
Does anybody know a solution, or should a raise a ticket on github?
You can search on GitHub. The problem is already known. We are focused on new cards for now. Itās hard to response on all issues on our free time
Itās not a tech issue but a UX issue. For now you can use the more info popup as a workaround
