alnavasa
(A)
November 27, 2022, 10:00pm
4124
I am having some trouble templating a Hacs update card , anyone can help me with this one out, I managed to template color properly, but I canât get to work on the secondary info
type: custom:mushroom-template-card
primary: HACS
secondary: >-
{{ "Up to date" if states("sensor.hacs") | float < 1 else
(states("sensor.hacs") | float | round(0) }} " pending updates" }}
icon: hacs:hacs
layout: vertical
fill_container: true
multiline_secondary: false
entity: sensor.hacs
icon_color: '{{ "green" if states("sensor.hacs") | float < 1 else "amber" }}'
picture: ''
I use this code for my HACS updates card, maybe it helps.
Edit : updated to go to HACS when clicked
entity: ''
icon: mdi:store
icon_color: |-
{% if states('sensor.hacs') == "0" %}
green
{% else %}
orange
{% endif %}
primary: HACS
secondary: |-
Up-to-date
{% else %}
{% for item in state_attr('sensor.hacs', 'repositories') -%}
{%- if loop.first %}{{states('sensor.hacs')}} update(s): {% elif loop.last %} en {% else %}, {% endif -%}
'{{ item.display_name | lower }}'
{%- endfor %}
{% endif %}
multiline_secondary: true
fill_container: false
tap_action:
action: navigate
navigation_path: ../hacs/entry
Sylwester
(Sylwester Olik)
November 28, 2022, 1:59am
4126
I created 2 additional buttons to climate card using vertical stack and - top margin. It looks ok but I can not press Thermostat icon to toggle thermostat on and off. I think that is because chip card with buttons is on top of climate card. Any solution for that?
type: custom:stack-in-card
cards:
- type: vertical-stack
cards:
- type: custom:mushroom-climate-card
entity: climate.hallway
show_temperature_control: true
- type: custom:mushroom-chips-card
chips:
- type: template
content: >-
{% set time = state_attr('timer.heating_boost_timer',
'finishes_at') %} {{ 'BOOST' if time == None else
(as_datetime(time) - now()).total_seconds() |
timestamp_custom('%H:%M', false) }}
tap_action:
action: call-service
service: input_boolean.toggle
data: {}
entity_id: input_boolean.heating_boost
entity: input_boolean.heating_boost
card_mod:
style: |
ha-card {
{% if is_state('input_boolean.heating_boost', 'on') %}
--chip-background: rgba(var(--rgb-orange), 0.2);
{% else %}
--chip-background: rgba(var(--rgb-disabled), 0.15);
{% endif %}
--chip-box-shadow: none;
--chip-border-radius: 10px;
--chip-height: 42px;
--chip-padding:10px 38px 10px 38px;
margin-bottom: 12px;
- type: template
icon: mdi:leaf
tap_action:
service: script.turn_on
data: {}
entity_id: script.heating_eco
entity: input_boolean.heating_eco
card_mod:
style: |
ha-card {
{% if is_state('input_boolean.heating_eco', 'on') %}
--chip-background: rgba(var(--rgb-green), 0.2);
{% else %}
{% endif %}
--chip-padding:10px;
margin-right: 12px;
alignment: end
card_mod:
style: |
ha-card {
margin-top: -108px;
--chip-spacing: 12px;
Different idea is to move buttons on bottom but I do not know how to make chip auto wider or how to make fixed width.
cards:
cards:
layout: horizontal
- type: horizontal-stack
cards:
cards:
chips:
- type: template
content: >-
tap_action:
data: {}
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-orange), 0.5);
{% else %}
{% endif %}
alignment: center
chips:
- type: template
icon: mdi:leaf
tap_action:
data: {}
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-green), 0.5);
{% else %}
{% endif %}
alignment: center
theandouz
(Theandouz)
November 28, 2022, 5:00am
4127
Hey @rhysb , I think the math in the Christmas countdown is off I noticed it hasnât moved. I believe this works now but only calculates for 30 days, not the year
{{ (((states('input_datetime.christmas') | as_datetime | as_local - now()).days + 1) / 31 * 100 - 100) * -1 }}
Card Code
icon: mdi:pine-tree
primary: Days to Christmas
icon_color: green
secondary: >-
{{ (states('input_datetime.christmas') | as_datetime | as_local - now()).days + 1 }} days
card_mod:
style:
mushroom-shape-icon$: |
.shape {
background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-red)) {{ (((states('input_datetime.christmas') | as_datetime | as_local - now()).days + 1) / 31 * 100 - 100) * -1 }}% 0%, var(--card-background-color) 0% 100%);
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
border-radius: 50%;
background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
FireDragon
(Nguyen Dac Manh)
November 28, 2022, 1:19pm
4129
Hi @rhysb ,
Still the same code.
With theme Mushroom or default theme
With theme Mushroom Shadow:
berkans
(Berkan Sezer)
November 28, 2022, 1:31pm
4130
Home Assistant Spotify Button
Page Properties:
Start Spotify song on your media player. Designed for Amazon Alexa but you can change it from (tap_action:) part.
Displays spotify artwork when music is being played.
Spotify logo disappears while music is being played.
Stop spotify music with double tap
You can find all the codes and png on :
alnavasa
(A)
November 28, 2022, 3:37pm
4131
I am trying to reduce top or bottom spacing in Px,
Both not working, I am trying to bring up spacing of the top of the bottom group or reduce bottom margin of the header
square: false
columns: 1
type: grid
cards:
- type: custom:mushroom-title-card
title: Jaxxxx
- square: false
columns: 3
type: grid
cards:
- type: custom:mushroom-light-card
entity: light.xxxxxx
secondary_info: none
use_light_color: true
show_brightness_control: true
entity: light.xxxxx
entity: light.xxxxx
use_light_color: false
show_brightness_control: false
entity: light.pxxxa
show_color_control: false
show_color_temp_control: true
entity: light.xxxxx
icon: ''
icon: ''
entity: light.xxxxxxx
icon: ''
entity: light.sxxxxxxx
entity: light.sonoff_10012209cd_2
entity: light.xxxxx
entity: light.xxxxx
entity: light.xxxxx
title: ''
subtitle: Riego
card_mod:
style: |
ha-card {
margin-top: -50px;
- square: false
columns: 5
type: grid
cards:
- type: custom:mushroom-entity-card
entity: switch.netro_zone_1
layout: vertical
tap_action:
action: toggle
entity: switch.netro_zone_2
layout: vertical
tap_action:
action: toggle
entity: switch.netro_zone_3
layout: vertical
tap_action:
action: toggle
entity: switch.netro_zone_4
layout: vertical
tap_action:
action: toggle
entity: switch.netro_zone_5
layout: vertical
tap_action:
action: toggle
@rhysb this is not about mushroom, but as you are a css expert, do you know how I can achiev this inverted rounded bordes, in a image (picture-elements)
Im designing an mobile version and wanted to do it in a picture-elements with a image
This is what I have so far, but did it on PS with help of some friends, since I dont know shit about PS I wanted a way to do it natively on HA.
alexdelprete
(Alessandro Del Prete)
November 28, 2022, 4:16pm
4133
this Input Select card is perfect for the card that @uvjim created for Logitech Harmony dynamic activities here: Mushroom Cards - Build a beautiful dashboard easily đ - #1632 by uvjim
Iâll try to merge them as a mushroom excercise.
A big thank to both of you for sharing all this, I never thought Iâd love mushrooms so much.
This thread is amazingâŚitâs a big box full of candiesâŚand it never ends!
Hello, good afternoon,
First thank you for your great work.
Second, ask you how I can make the images of the people have a larger size and the color circle remains thin.
I have tried the following way, the image grows, but the color margin grows gradually and it is not pretty, I would like it to be like an alo, something fine
chips:
- type: conditional
conditions:
- entity: person.vero
state: home
chip:
type: entity
entity: person.vero
content_info: none
use_entity_picture: true
mush-chip-height: 60px
card_mod:
style: |
ha-card {
âchip-background: rgba(var(ârgb-state-person-home), 0.4);
margin-top: 5px;
margin-bottom: 10px;
âchip-height: 68px;
- type: conditional
conditions:
- entity: person.jordi
state: home
chip:
type: entity
content_info: none
card_mod:
style: |
ha-card {
âchip-background: rgba(var(ârgb-state-person-home), 0.9);
margin-top: 5px;
âchip-height: 68px;
- type: conditional
conditions:
- entity: person.jan
state: home
chip:
type: entity
entity: person.jan
content_info: none
card_mod:
style: |
ha-card {
margin-top: 5px;
âchip-height: 68px;
- type: conditional
conditions:
- entity: person.marti
state: home
chip:
type: entity
content_info: none
card_mod:
style: |
ha-card {
margin-top: 5px;
âchip-height: 68px;
alignment: start
card_mod:
style: |
ha-card {
margin-left: 8px;
cards:
chips:
- type: conditional
conditions:
state_not: home
chip:
type: entity
entity: person.vero
content_info: none
card_mod:
style: |
ha-card {
{% if is_state(âperson.veroâ, ânot_homeâ) %}
âchip-background: rgba(var(ârgb-state-person-not-home), 0.4);
{% elif is_state(âperson.veroâ, âunknownâ) %}
âchip-background: rgba(var(ârgb-state-person-unknown), 0.4);
{% else %}
âchip-background: rgba(var(ârgb-state-person-zone), 0.4);
{% endif %}
margin-top: 5px;
âchip-height: 68px;
- type: conditional
conditions:
state_not: home
chip:
type: entity
content_info: none
card_mod:
style: |
ha-card {
{% if is_state(âperson.jordiâ, ânot_homeâ) %}
{% elif is_state(âperson.jordiâ, âunknownâ) %}
{% else %}
{% endif %}
margin-top: 5px;
âchip-height: 68px;
- type: conditional
conditions:
state_not: home
chip:
type: entity
entity: person.jan
content_info: none
card_mod:
style: |
ha-card {
{% if is_state(âperson.janâ, ânot_homeâ) %}
{% elif is_state(âperson.janâ, âunknownâ) %}
{% else %}
{% endif %}
margin-top: 5px;
âchip-height: 68px;
- type: conditional
conditions:
state_not: home
chip:
type: entity
content_info: none
mush-chip-height: 100px
card_mod:
style: |
ha-card {
{% if is_state(âperson.martiâ, ânot_homeâ) %}
{% elif is_state(âperson.martiâ, âunknownâ) %}
{% else %}
{% endif %}
margin-top: 5px;
âchip-height: 100px;
alignment: end
card_mod:
style: |
ha-card {
margin-right: 8px;
rhysb
(Rhys)
November 28, 2022, 8:45pm
4135
The Mushroom Title Card does not have any âha-cardâ, so you canât use âcard-modâ directly on it. Have a look at this post and --title-padding
in particular:
If anyone needs to modify the Mushroom Title card, it can be done with card_mod like this:
[Mushroom Title Card]
type: custom:mod-card
card:
title: I'd rather be picking
subtitle: Mushrooms
card_mod:
style:
mushroom-title-card$: |
.title {
--primary-text-color: rgb(var(--rgb-grey));
--title-font-size: 20px;
--title-font-weight: lighter;
.subtitle {
--secondary-text-color: rgb(var(--rgb-red)); âŚ
rhysb
(Rhys)
November 28, 2022, 8:54pm
4136
Is your vertical-stack-in-card
up-to-date? This is how it looks for me with âdefaultâ theme:
rhysb
(Rhys)
November 28, 2022, 9:02pm
4137
Seems to be working correctly for me
((Christmas_Day - Current_Day + 1) / 365 * 100) = % days to Christmas from last Christmas
The +1 is a hack because now()
gives days + time of partial day.
alnavasa
(A)
November 28, 2022, 9:37pm
4138
I am not getting it to work:
I want to remove the space below âriegoâ subtitle to be smaller, I tried multiple padding values with no effect
title: ''
subtitle: Riego
card_mod:
style:
.header {
--title-padding: -68px -524px -88px;
rayzorben
(Rayzorben)
November 28, 2022, 9:48pm
4139
Hi, just trying this out for the first time. When installing I got a popup that said something about lovelace not being in storage mode and I had to add something somewhere. But the screen closed quickly and I couldnât see what it said and I canât get it back.
Any advice on what I put and where to get mushroom working would be appreciated.
alnavasa
(A)
November 28, 2022, 11:01pm
4140
I am currently developing an energy card, based on stack, apex and mushroom cards.
Any input would be appreciated, I will share the code when done, I just donât feel itâs properly designed yet.
(values are wrong)
rhysb
(Rhys)
November 28, 2022, 11:02pm
4141
When posting code make sure you use formatted text option.
Post it again and we can have a look.
rhysb
(Rhys)
November 28, 2022, 11:04pm
4142
No, you need to wrap it in mod-card
as in the example. Like this:
card:
subtitle: Riego
card_mod:
style:
.header {
--title-padding: 8px 24px 8px;
rhysb
(Rhys)
November 29, 2022, 1:44am
4143
You could try something like this.
Picture Element Inverted Border:
type: picture-elements
elements:
- type: state-icon
tap_action:
action: toggle
entity: light.office_light
icon: mdi:snail
style:
top: 15%
left: 70%
image: /local/mushroom.png
card_mod:
style: |
ha-card {
border-bottom-left-radius: 0;
border-bottom-right-radius: 0;
box-shadow: none;
--ha-card-border-width: 0;
margin-bottom: calc(-1 * var(--ha-card-border-radius, 12px));
--paper-item-icon-active-color: rgb(var(--rgb-brown-color));
--mdc-icon-size: 120%;
ha-card:after {
content: "";
position: absolute;
background-color: var(--primary-background-color);
height: calc(2 * var(--ha-card-border-radius, 12px));
width: 100%;
left: 0px;
border-top-left-radius: var(--ha-card-border-radius, 12px);
border-top-right-radius: var(--ha-card-border-radius, 12px);
box-shadow: var(--ha-card-box-shadow) inset;
