Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Try like this:
        {% if states('sensor.valve_opening') | float > 0 %}
          content: "{{ states('sensor.valve_opening') }}";
        {% endif %}
Your selector is not correct. Should be something like this:
card_mod:
  style: |
    mushroom-badge-icon:after {
Have a look here:
Just use the attribute media_album_name for the content.
Iā€™m trying to get this to work for me with no luck, Iā€™m trying to make my chips bigger, current code is:
type: custom:mushroom-chips-card
chips:
  - type: weather
    entity: weather.forecast_smithhouse
    show_conditions: true
    show_temperature: true
  - type: light
    entity: light.scott_s_bedroom
    content_info: name
when I add in the card_mod lines, it just does nothing. Any advice @rhysb ?
This will enlarge all the Chips:
chips:
  - type: weather
  - type: light
    content_info: name
card_mod:
  style: |
    ha-card {
      --chip-height: 48px;
      --chip-border-radius: 20px;
Make sure you have card-mod installed.
Hello, can someone help with code? My animation is not working:
type: custom:stack-in-card
cards:
  - type: custom:layout-card
    layout_type: masonry
    columns: 2
    layout: {}
    cards:
        primary: ā˜• KĆ”vovar
        secondary: null
        icon: mdi:coffee-maker
        icon_color: |
          {% if is_state('switch.kavovar_power', 'on') %}
          brown
          {% else %}
          disabled
          {% endif %}
        fill_container: true
        multiline_secondary: true
        layout: horizontal
        card_mod:
          style:
            mushroom-shape-icon$: |
              {% if is_state('sensor.kavovar_operation_state', 'run') %}
                ha-icon {
                  --icon-animation: java 2s linear infinite;
              {% endif %}
              @keyframes rotating {
                0%, 80%, 100% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 0 100%); }
                10% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 79%, 63% 76%, 67% 70%, 66% 54%, 42% 55%, 42% 70%, 47% 77%, 55% 80%, 57% 100%, 0 100%); }
                15% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 79%, 63% 76%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 47% 77%, 55% 80%, 55% 100%, 0 100%); }
                20% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 76%, 63% 76%, 67% 70%, 66% 54%, 42% 55%, 42% 70%, 47% 76%, 55% 76%, 57% 100%, 0 100%); }
                25% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 76%, 63% 76%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 47% 76%, 55% 76%, 56% 100%, 0 100%); }
                30% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 73%, 64% 73%, 66% 70%, 66% 55%, 42% 55%, 42% 69%, 44% 73%, 55% 73%, 57% 100%, 0 100%); }
                35% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 73%, 64% 73%, 66% 70%, 66% 55%, 42% 54%, 42% 69%, 44% 73%, 55% 73%, 56% 100%, 0 100%); }
                40% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 70%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 57% 70%, 57% 100%, 0 100%); }
                45% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 70%, 67% 70%, 66% 54%, 42% 54%, 42% 70%, 55% 70%, 56% 100%, 0 100%); }
                50% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 66%, 67% 65%, 66% 54%, 42% 54%, 42% 65%, 57% 65%, 57% 100%, 0 100%); }
                55% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 66%, 67% 65%, 66% 54%, 42% 54%, 42% 65%, 55% 65%, 56% 100%, 0 100%); }
                60% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 60%, 66% 60%, 66% 54%, 42% 54%, 42% 60%, 57% 60%, 57% 100%, 0 100%); }
                65% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 60%, 66% 60%, 66% 54%, 42% 54%, 42% 60%, 55% 60%, 56% 100%, 0 100%); }
                70% { clip-path: polygon(0 0, 100% 0, 100% 32%, 47% 32%, 47% 43%, 100% 43%, 100% 100%, 55% 100%, 55% 56%, 66% 56%, 66% 54%, 42% 54%, 42% 56%, 57% 56%, 57% 100%, 0 100%); }
                75% { clip-path: polygon(0 0, 100% 0, 100% 100%, 55% 100%, 55% 56%, 66% 56%, 66% 54%, 42% 54%, 42% 56%, 55% 56%, 55% 100%, 0 100%); }
              ha-card {
                --card-primary-font-size: 24px;
                --card-secondary-font-size: 18px;
                --icon-size: 96px;
Thanks @rhysb !
This removes the badge content, but there is still an idle badge icon visible. Is it possible to remove that also? So that there is no badge visible at all (for that specific condition off course)?
I have this code to show when my car is charging, but I canā€™t seem to remove the badge_icon when it is not charging. Any ideas?
type: custom:mushroom-template-card
primary: Tesla
secondary: '{{states(''sensor.tess_battery'')}}% '
icon: |-
  {% set value = states('sensor.tess_battery')|float %}
  {% if value < 10 %} mdi:battery-10
  {% elif value < 20 %} mdi:battery-20
  {% elif value < 30 %} mdi:battery-30
  {% elif value < 40 %} mdi:battery-40
  {% elif value < 50 %} mdi:battery-50
  {% elif value < 60 %} mdi:battery-60
  {% elif value < 70 %} mdi:battery-70
  {% elif value < 80 %} mdi:battery-80
  {% elif value < 90 %} mdi:battery-90
  {% else %} mdi:battery-50
  {% endif %}
icon_color: |-
  {% if value < 10 %} #990000
  {% elif value < 20 %} #FF0000
  {% elif value < 30 %} #FF6600
  {% elif value < 40 %} #FFCC00
  {% elif value < 50 %} #FFFF00
  {% elif value < 60 %} #99CC00
  {% elif value < 70 %} #66FF33
  {% elif value < 80 %} #99CC00
  {% elif value < 90 %} #00CC00
  {% else %} grey
  {% endif %}
layout: vertical
entity: sensor.tess_battery
multiline_secondary: false
badge_icon: |-
  {% if is_state('binary_sensor.tess_charging', 'on') %}
  mdi:lightning-bolt
  {% else %}
  {% endif %}
badge_color: orange
card_mod:
  style: |
    ha-card {
      border: 0px;
      margin: 0px 0px 0px 0px;
      -webkit-border-radius: 0px;
      background-color: hsla(0, 0%, 0%, 0);
      text-align: left;
      justify-self: left;
      box-shadow: none;
Your animation name and keyframes name do not match.
You can do it like this:
    mushroom-badge-icon$: |
      .badge {
        {{ 'display: none !important;' if state_attr(config.entity, 'hvac_action') == 'idle' }}
Check the value of binary_sensor.tess_charging because your code works fine for me.
Hero :star_struck:
Working like a charm ā€¦
Once again thanks for your continuous support for the community! Well appreciated!
@tvds could you post the complete code pls? Thx
Sure ā€¦
type: custom:mushroom-climate-card
entity: climate.living
icon: none
show_temperature_control: true
layout: horizontal
card_mod:
  style:
      .shape:after {
        content: "{{ state_attr(config.entity, 'current_temperature')|replace('.', ',') }}Ā°";
        font-size: 14px;
        font-weight: bolder;
        color: white;
        position: absolute;
      .shape {
        {% set mode = state_attr(config.entity, 'hvac_action') %}
        --shape-color: rgba(var(--rgb-
        {%- if mode == 'heating' -%}
          orange
        {%- elif mode == 'cooling' -%}
          blue
        {%- else -%}
          grey
        {% endif %}));
        position: absolute;
        display: flex;
        justify-content: center;
        align-items: center;
        background: rgb(var(--rgb-green));
        color: rgb(var(--rgb-white));
        border-radius: 50%;
        top: 0;
        width: 100%;
        height: 100%;
        font-size: 0.7em;
      .badge {
Thank you, realized a few minutes after I posted that card-mod was a plugin, after I installed that I was all good.
Hello, this my code without color control:
           - type: custom:stack-in-card
             cards:
               - type: custom:mushroom-light-card
                 entity: group.natale
                 icon: mdi:pine-tree
                 use_light_color: false
                 icon: mdi:pine-tree
                 icon_color: green
                 card_mod:
                   style:
                       .shape {
                         --shape-color: none;
                       ha-card {
                         width: 66px;
                         top: -66px;
                 icon: mdi:star-four-points
                 icon_color: yellow
                 card_mod:
                   style:
                       ha-icon {
                         --icon-animation: star 8s ease infinite alternate;
                       @keyframes star {
                         0%, 100% { transform: translateY(-10px) rotate(0deg) scale(0.4); }
                         50% { transform: translateY(-10px) rotate(360deg) scale(0.6); }
                       .shape {
                       ha-card {
                         width: 66px;
                         top: -133px;
                 icon: mdi:grain
                 icon_color: red
                 card_mod:
                   style:
                       ha-icon {
                         --icon-animation: flash 2s steps(1) infinite, lights 2s infinite;
                         clip-path: polygon(51% 15%, 24% 74%, 74% 74%);
                       @keyframes flash {
                         50% { transform: rotateY(180deg); }
                       @keyframes lights {
                         0%, 100% {--icon-color: rgb(var(--rgb-red)); }
                         6.25% { --icon-color: rgb(var(--rgb-deep-orange)); }
                         12.5% { --icon-color: rgb(var(--rgb-orange)); }
                         18.75% { --icon-color: rgb(var(--rgb-amber)); }
                         25% { --icon-color: rgb(var(--rgb-yellow)); }
                         31.25% { --icon-color: rgb(var(--rgb-lime)); }
                         37.5% { --icon-color: rgb(var(--rgb-light-green)); }
                         43.75% { --icon-color: rgb(var(--rgb-green)); }
                         50% { --icon-color: rgb(var(--rgb-teal)); }
                         56.25% { --icon-color: rgb(var(--rgb-cyan)); }
                         62.5% { --icon-color: rgb(var(--rgb-light-blue)); }
                         68.75% { --icon-color: rgb(var(--rgb-blue)); }
                         75% { --icon-color: rgb(var(--rgb-indigo)); }
                         81.25% { --icon-color: rgb(var(--rgb-deep-purple)); }
                         87.5% { --icon-color: rgb(var(--rgb-purple)); }
                         93.75% { --icon-color: rgb(var(--rgb-pink)); }
                       .shape {
                       ha-card {
                         width: 66px;
                         top: -200px;
                 icon: mdi:gift
                 icon_color: red
                 tap_action:
                   action: toggle
                 card_mod:
                   style:
                       ha-icon {
                         --icon-animation: surprise 4s ease infinite;
                       @keyframes surprise {
                         0%, 20%, 100% { transform: translateY(0); }
                         2.5% { transform: translateY(-2px) rotate(-27deg); }
                         5% { transform: translateY(-2px) rotate(21deg); }
                         7.5% { transform: translateY(-2px) rotate(-15deg); }
                         10% { transform: translateY(-2px) rotate(9deg); }
                         12.5% { transform: translateY(0); }
                         15% { transform: translateY(-1.2px) }
                       .shape {
                         --icon-size: 18px;
                         top: 18px;
                         left: 18px;
                       ha-card {
                         width: 66px;
                         top: -262px;
             card_mod:
               style: |
                 ha-card {
                   height: 66px;
                   {% set r = state_attr('group.natale', 'rgb_color')[0] %}
                   {% set g = state_attr('group.natale', 'rgb_color')[1] %}
                   {% set b = state_attr('group.natale', 'rgb_color')[2] %}
                   background-color: rgba( {{r}}, {{g}}, {{b}}, 0.1 );
this is result for ON:
and OFF:
Can I remove colors and animation when entity is OFF?
Thank you
is it too difficult?
I think I did something wrong. but my UI looks inconsistent.
When I first load the page everything looks great:
However when I refresh I see borders:
Nothing changes, as far as I can see. How is this possible?
I am trying to implement something that I have seen done with buttons. Basically, they have a row of buttons or chips, and each button/chip causes a different page view to load below the row of chips/buttons not navigate to another view. So you would have:
and each one would load a card below it, for instance a room card, based on the button you pushed. I have tried conditional card, but it will not load the card correctly. Then there is the scenario were you push another button and you already have a button pressed. You would need the old button to be turned off. Has anyone accomplished this and if so is anyone willing to share their code. I hope that this is clear enough.
A few weeks back I saw the great work on a minimalist inspired room card by @theandouz and had the same thoughts as @PatrickJanson for a smaller version to be able to fit more cards on the screen at once.
I re-worked things a bit to make it smaller and added a few extra ā€œfeaturesā€.
  • The secondary text displays temp and humidity, color is based on the roomā€™s climate devices hvac state (heating, cooling) as well as an icon to quickly display the state.
  • The light chip is constant and supports the light entityā€™s color or a default color if there isnā€™t one. Single tap brings up a quick popup to show all light entities in that room.
  • Can display up to 4 conditional chips at a time (You can add as many as you like but only 4 display) with certain chips bringing up a popup including the beautiful media card from @rhysb. I personally preferred the conditional chips to just display the icon without the circle around it. I found it easier to notice.
minimalist-style-card
Hereā€™s the code. Certainly open to any additional ideas or tweaks.
Minimalist Room Card
type: custom:vertical-stack-in-card
cards:
    entity: group.master_bedroom
    icon: mdi:bed
    icon_color: |
      {% if is_state(entity, 'on') %}
        #03A9F4
      {% else %}
        grey
      {% endif %}
    primary: Master Bedroom
    secondary: >-
      {{ states('sensor.thermostat_master_bedroom_local_temperature') | round(0)
      }}Ā°C | {{ states('sensor.thermostat_master_bedroom_humidity') |
      round(0) }}%
    layout: horizontal
    tap_action:
      action: navigate
      navigation_path: /mobile-dashboard/master-bedroom
    double_tap_action:
      action: navigate
    hold_action:
      action: toggle
    badge_icon: >
      {% if is_state_attr('climate.thermostat_master_bedroom', 'hvac_action',
      'heating') %}
        mdi:radiator
      {% elif is_state_attr('climate.thermostat_master_bedroom', 'hvac_action',
      'cooling') %}
        mdi:snowflake
      {% else %}  {% endif %}
    badge_color: >
      'heating') %}
        red
      'cooling') %}
        #03A9F4
    card_mod:
      style:
        mushroom-state-info$: |
          .primary {
            font-size: 16px !important;
            position: relative;
            top: -50px;
            left: -155px;
            overflow: visible !important;
            white-space: normal !important;
          .secondary {
            position: relative;
            top: -52px;
            left: -155px;
          .shape {
            position: relative;
            left: -43px;
            top: 55px;
          :host {
            --mush-icon-size: 146px;
            --secondary-text-color:
              {% if is_state_attr('climate.thermostat_master_bedroom', 'hvac_action', 'heating') %}
                red
              {% elif is_state_attr('climate.thermostat_master_bedroom', 'hvac_action', 'cooling') %}
                #03A9F4
              {% else %}
                #6c6c75
              {% endif %}
        style: |
          mushroom-badge-icon {
            left: 69px;
            top: 25px;
    primary: none
    icon_color: disabled
    icon: mdi:lightbulb
    secondary: none
    entity: light.master_bedroom_light
    tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.popup
          title: Master Bedroom Lights
          content:
            type: vertical-stack
            cards:
                name: Master Bedroom Light
                use_light_color: true
                show_brightness_control: true
                show_color_temp_control: false
                show_color_control: false
                collapsible_controls: true
                card_mod:
                  style: |
                    ha-card {
                      --ha-card-border-width: 0;
                entity: light.closet_light
                card_mod:
                  style: |
                    ha-card {
            card_mod:
              style: |
                ha-card {
    hold_action:
      action: toggle
    double_tap_action:
      action: more-info
    card_mod:
      style:
          .shape {
            {% if is_state(config.entity, 'on') %}
              {% if state_attr(config.entity, 'rgb_color') == none %}
                --icon-color: rgb(255,190,137) !important;
                --shape-color: rgb(255,190,137, 0.2 ) !important;
              {% else %}
                {% set r = state_attr(config.entity, 'rgb_color')[0] %}
                {% set g = state_attr(config.entity, 'rgb_color')[1] %}
                {% set b = state_attr(config.entity, 'rgb_color')[2] %}
                --icon-color: rgb( {{r}}, {{g}}, {{b}} ) !important;
                --shape-color: rgba( {{r}}, {{g}}, {{b}}, 0.2 ) !important;
              {% endif %}
            {% endif %}
          ha-card {
            width: 66px;
            margin-left: 68%;
            top: -178px;
            background: none;
          :host {
            --mush-icon-size: 38px;
  - type: custom:mushroom-chips-card
    chips:
      - type: conditional
        conditions:
          - entity: input_boolean.in_bed
            state: 'on'
        chip:
          type: entity
          icon: mdi:bed
          icon_color: blue
          content_info: none
      - type: conditional
        conditions:
          - entity: binary_sensor.motion_master_bedroom_occupancy
            state: 'on'
        chip:
          type: entity
          icon: mdi:motion-sensor
          icon_color: blue
          content_info: none
      - type: conditional
        conditions:
          - entity: fan.master_bedroom_fan
            state: 'on'
        chip:
          type: entity
          icon: mdi:fan
          icon_color: blue
          content_info: none
          tap_action:
            browser_mod:
                title: Master Bedroom Fan
                content:
                  type: custom:mushroom-fan-card
                  name: Master Bedroom Fan
                  icon_animation: true
                  fill_container: false
                  show_percentage_control: true
                  show_oscillate_control: false
                  card_mod:
                    style: |
                      ha-card {
      - type: conditional
        conditions:
          - entity: switch.plug_master_bedroom
            state: 'on'
        chip:
          type: entity
          icon: mdi:power-plug
          icon_color: blue
          content_info: none
          tap_action:
            browser_mod:
                title: Master Bedroom Plugs
                content:
                  type: custom:mushroom-entity-card
                  name: Master Bedroom Plug
                  icon_color: '#03A9F4'
                  tap_action:
                    action: toggle
                  card_mod:
                    style: |
                      ha-card {
      - type: conditional
        conditions:
          - entity: media_player.emby_bedroom
            state: playing
        chip:
          type: entity
          icon: mdi:play-pause
          icon_color: blue
          content_info: none
          tap_action:
            browser_mod:
                title: Master Bedroom Media Player
                content:
                  cards:
                    - type: custom:mushroom-media-player-card
                      icon: mdi:play
                      use_media_info: true
                      use_media_artwork: false
                      show_volume_level: false
                      media_controls:
                        - play_pause_stop
                        - previous
                        - next
                      volume_controls:
                        - volume_buttons
                        - volume_set
                      card_mod:
                        style: |
                          mushroom-shape-icon {
                            display: flex;
                            {% set media_type = state_attr(config.entity, 'media_content_type') %}
                            {% if media_type == 'tvshow' %}
                              --card-mod-icon: mdi:television-classic;
                              animation: flicker 1s linear infinite alternate;
                            {% elif media_type == 'movie' %}
                              --card-mod-icon: mdi:movie-roll;
                              animation: spin 2s linear infinite reverse;
                            {% elif media_type == 'music' %}
                              --card-mod-icon: mdi:music;
                              animation: beat 1.3s ease-out infinite both;
                            {% elif media_type == 'playlist' %}
                            {% else %}
                              --card-mod-icon: mdi:play;
                            {% endif %}
                          @keyframes flicker {
                            0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--rgb-indigo), 1); }
                            32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--rgb-indigo), 0.6); }
                          @keyframes beat {
                            0%, 60% { --icon-symbol-size: 21px; }
                            5%, 17%, 57% { --icon-symbol-size: 22px; }
                            10%, 20%, 51% { --icon-symbol-size: 23px; }
                            25%, 45% { --icon-symbol-size: 24px; }
                            30%, 39% { --icon-symbol-size: 25px; }
                            33% { --icon-symbol-size: 26px; }
                          ha-card {
                          ha-card:before {
                            transform: translate3d(0,0,0);
                            -webkit-transform: translate3d(0,0,0);
                            content: "";
                            background: url('/local/idle_art.png') center no-repeat;
                            {% if not is_state(config.entity, 'idle') %}
                              background: url( '{{ state_attr(config.entity, "entity_picture") }}') center no-repeat;
                            {% endif %}
                            background-size: contain;
                            margin: 4px 4px 16px;
                            filter: drop-shadow(4px 4px 6px rgba(0, 0, 0, 0.5));
                            border-radius: var(--control-border-radius);
                              aspect-ratio: 16 / 9;
                              aspect-ratio: 2 / 3;
                            {% else %}
                              aspect-ratio: 1 / 1;
                            {% endif %}
                    - type: conditional
                      conditions:
                          state_not: 'off'
                          state_not: idle
                      card:
                        hide:
                          icon: true
                          runtime: true
                          source: true
                          power: true
                          state_label: true
                          volume: true
                          info: true
                          progress: false
                          controls: true
                        more_info: false
                        type: custom:mini-media-player
                        toggle_power: false
                        group: true
                        card_mod:
                          style:
                            mmp-progress$: |
                              paper-progress {
                                {{ '--paper-progress-container-color: rgba(var(--rgb-indigo-color), 0.2) !important;' if is_state(config.entity, 'playing') }}
                              ha-card {
                                margin: 0px 12px 12px;
                                --mmp-progress-height: 12px !important;
                                height: var(--mmp-progress-height);
                                --mmp-accent-color: rgb(var(--rgb-indigo-color));
                                --mmp-border-radius: 12px !important;
                  card_mod:
                    style: |
                      ha-card:before {
                        content: "";
                        position: absolute;
                        height: 100%;
                        width: 100%;
                        {% if not is_state('media_player.emby_bedroom', 'idle') %}
                          background: url( '{{ state_attr('media_player.emby_bedroom', "entity_picture") }}' ) center no-repeat;
                        {% endif %}
                        filter: blur(150px) saturate(200%);
                        background-size: 100% 100%;
                      ha-card {
    card_mod:
      style:
          ha-card {
            width: 66px;
            margin-left: 76%;
            top: -186px;
            background: none;
            --chip-border-width: 0;
          :host {
            --mush-icon-size: 20px;
            --mush-chip-spacing: -2.9px
card_mod:
  style: |
    ha-card {
      height: 178px !important;
      width: 178px !important;
Hi, just saw your card and i like itā€¦ try to take the things i need for my setup.
I want to have it like this:
But now i wanna hide the graphs by default like you did, but it doesnā€™t work for me.
keep:
  margin: false
  box_shadow: false
  background: false
cards:
  - type: custom:simple-thermostat
    entity: climate.wohnzimmer
    layout:
      step: row
    header: false
    control: false
- type: conditional
  conditions:
    - entity: input_boolean.thermostat_dropdown
      state: 'on'
  card:
    keep:
      margin: false
      box_shadow: false
      background: false
    cards:
      - type: custom:mini-graph-card
        entities:
          - entity: sensor.temp_wohnzimmer
            color: blue
          - entity: sensor.targettemp_wohnzimmer
            color: lightblue
        line_color: blue
        line_width: 4
        font_size: 75
        hours_to_show: 24
        hour24: true
        animate: true
        icon: mdi:thermometer
        unit: Ā°C
        lower_bound: 12
        upper_bound: 28
        show:
          legend: false
          state: true
          icon: false
          fill: fade
        entities:
          - entity: sensor.valve_wohnzimmer
        line_color: red
        line_width: 4
        font_size: 75
        hours_to_show: 24
        hour24: true
        animate: true
        icon: mdi:valve
        unit: '%'
        lower_bound: 0
        upper_bound: 100
        show:
          legend: false
          state: true
          icon: false
          fill: fade
I tried it like this, but as i donā€™t really understand the contidional type (or have not installed that type). Do you have any hint, why this doesnā€™t work for me.
This is the error code
end of the stream or a document separator is expected (13:1)
- type: conditional
