Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Probably using browser mod and a combo of conditional cards. You can add a drop down select to any card using card mod and layout card and then create helpers for all your sources.
Txs. I’ll try this as I have all the helpers already.
Have you been able to disable the 'more page dialogue?
Also @rolfokevin this may answer another query I had. Where do you add this code to? A blank YAML card or a particular mushroom card?
Might be obvious but how are refreshing?
Have your seen this post?
it was already here, but wanted to share the FINAL dashboard of mine, i spent days and nights to work on the shadowing, borders, backgrounds etc, and I hope this is the final one!
PS please stop sharing new ideas in this topic :smiley: !!! (joking of course)
Sure, it is not mine. I saw it in this thread (I believe) but cannot remember who did this. Thus credits go to John “Mushroom” Doe, kudos man (or woman :smiley: )
type: custom:stack-in-card
cards:
    primary: Front Door
    secondary: >-
      {% if is_state('sensor.nuki_frontdoor_door_security_state','Opened &
      Unlocked')%}
        Open and Unlocked
      {% elif is_state('binary_sensor.nuki_frontdoor_door_open','on') %}
        Door Open
      {% elif is_state('lock.nuki_frontdoor_lock','unlocked') %}
        Unlocked
        Closed & Locked
      {% endif%}
    icon: >-
      Unlocked')%}
        mdi:door-open
        mdi:door-open
        mdi:lock-open
        mdi:door-closed-lock
      {% endif%}
    layout: vertical
    icon_color: >-
      {% if is_state('sensor.nuki_frontdoor_door_security_state','Closed &
      Locked')%}
        green
        red
      {% endif%}
    badge_icon: >
      {% set battery_level = (states(entity) | int / 10) | round(0) | int * 10
      %} {% if battery_level == 100 %}
        mdi:battery
      {% elif battery_level > 0 %}
        mdi:battery-{{ battery_level }}
        mdi:battery-alert-variant-outline
    badge_color: |-
      {% set battery_level = states(entity) | int %}
      {% if battery_level > 90 %}
        green
      {% elif battery_level > 60 %}
        light-green
      {% elif battery_level > 50 %}
        lime
      {% elif battery_level > 40 %}
        yellow
      {% elif battery_level > 30 %}
        amber
      {% elif battery_level > 20 %}
        orange
      {% elif battery_level > 10 %}
        deep-orange
        red
    tap_action:
      action: more-info
    entity: sensor.nuki_frontdoor_battery
    hold_action:
      action: toggle
  - type: custom:mushroom-lock-card
    entity: lock.nuki_frontdoor_lock
    primary_info: none
    secondary_info: none
    icon_type: none
    layout: vertical
card_mod:
  style: |
    ha-card {
      {% if is_state('sensor.nuki_frontdoor_door_security_state','Closed & Locked')%}
          background: rgba(101,170,91,0.2);
          background: rgba(226,84,66,0.2);
I use Nuki lock which have the door and lock status in one sensor but it should work with two sensors too.
You can add the player name to the Mushroom Media Card like this:
type: custom:mushroom-media-player-card
entity: media_player.currently_playing
use_media_info: true
icon_type: icon
collapsible_controls: true
show_volume_level: false
volume_controls:
  - volume_set
  - volume_buttons
media_controls:
  - previous
  - play_pause_stop
  - next
icon: mdi:play
card_mod:
  style:
    mushroom-state-info$: |
      .primary:before {
        content: "{{ state_attr(state_attr(config.entity, "active_child"), "friendly_name") }} - ";
This example is based on a Universal Media Player and displays the active players name.
I’ve been tinkering with this. You can blend the album art like this:
Mushroom Media Card with faded album art:
icon: mdi:play
media_controls:
  - play_pause_stop
  - previous
  - next
volume_controls:
  - volume_buttons
  - volume_set
fill_container: false
card_mod:
  style: |
    mushroom-shape-icon {
      {% set media_type = state_attr(config.entity, 'media_content_type') %}
      --card-mod-icon:
      {% if media_type == 'tvshow' %}
        mdi:television-classic
      {% elif media_type == 'movie' %}
        mdi:movie-open
      {% elif media_type == 'music' %}
        mdi:music
      {% elif media_type == 'playlist' %}
        mdi:music
        mdi:play
      {% endif %};
    ha-card {
      {% if not is_state(config.entity, 'off') and not is_state(config.entity, 'idle') %}
        background: url( '{{ state_attr(config.entity, "entity_picture") }}' ), linear-gradient(to left, transparent, rgb(var(--rgb-card-background-color)) 50%);
        background-size: 50%, cover;
        background-position: right;
        background-repeat: no-repeat;
        background-blend-mode: saturation;
Update: Change background-blend-mode to saturation. This looks a bit nicer and allows me to remove the stack-in-card.
Just a little tweak to the Mushroom Climate Card to animate the fan icon:
Mushroom Climate Card - Animated Fan
    type: custom:mushroom-climate-card
    entity: climate.air_conditioner
    name: Air Conditioner
    show_temperature_control: true
    hvac_modes:
      - heat_cool
      - heat
      - cool
      - dry
      - fan_only
    card_mod:
      style: |
          --card-mod-icon:
          {% if is_state(config.entity, 'heat_cool') %}
            mdi:autorenew
          {% elif is_state(config.entity, 'heat') %}
            mdi:fire
          {% elif is_state(config.entity, 'cool') %}
            mdi:snowflake
          {% elif is_state(config.entity, 'dry') %}
            mdi:water-percent
          {% elif is_state(config.entity, 'fan_only') %}
            mdi:fan
            mdi:air-conditioner
          {% endif %};
          display: flex;
          {% if is_state(config.entity, 'fan_only') %}
            animation: rotation 1s linear infinite;
        @keyframes rotation {
          100% {
             transform: rotate(360deg);
Great how the albumart fades across the card. Noticed the entity media_player.currently_playing. You mind elaborating on this as this doesn’t look familiar?
Thank you. Most of this has been done, but I’ll give the remaining ideas a try.
Looks great. Out of curiosity is that a slider of sorts on the right? What does it do?
it is only sound / voice slider from my phone . while taking the screenshot :smiley:
Hi everyone, this is a great thread to get new ideas. I wanted to show a feature I made for my CCT LED strips. I wanted to have the ability to turn on/off, as well as select the colour temperature without fiddling with a slider. This is what I came up with. Uses a combination of stack-in card, grid cards, and mushroom templates.
Happy to share the YAML if someone is interested.
great!! yes, please YAML. :slight_smile:
Here’s the code for the first entity, the others are a copy-paste with just the entity id changed.
          - type: custom:layout-card
            layout_type: custom:vertical-layout
            layout: {}
            cards:
              - type: custom:stack-in-card
                card_mod:
                  style: |
                    ha-card {
                      background: rgba(28,28,28,0.6)
                cards:
                    layout_type: custom:grid-layout
                    layout:
                      grid-template-columns: 90% 10%
                    cards:
                      - type: custom:mushroom-light-card
                        entity: light.living_room_strip
                        fill_container: true
                        show_brightness_control: true
                        show_color_control: false
                        show_color_temp_control: false
                        use_light_color: true
                        card_mod:
                          style: |
                            ha-card {
                              box-shadow: none;
                              background: none;
                      - type: vertical-stack
                        cards:
                            chips:
                              - type: action
                                icon_color: blue
                                tap_action:
                                  action: call-service
                                  service: light.turn_on
                                    color_temp: 154
                                    entity_id: light.living_room_strip
                                icon: mdi:lightbulb
                                card_mod:
                                  style: |
                                    ha-card {
                                      --chip-background: rgba(var(--rgb-blue), 0.2);
                            chips:
                              - type: action
                                icon_color: amber
                                icon: mdi:lightbulb
                                tap_action:
                                    color_temp: 267
                                card_mod:
                                  style: |
                                    ha-card {
                                      --chip-background: rgba(var(--rgb-amber), 0.2);
                            chips:
                              - type: action
                                icon_color: orange
                                icon: mdi:lightbulb
                                tap_action:
                                    color_temp: 500
                                card_mod:
                                  style: |
                                    ha-card {
                                      --chip-background: rgba(var(--rgb-orange), 0.2);
Here is a visualization to understand the sections of the card:
If my fan has 6 speeds. Is there a way to use the slider on the fan card to choose which speed I want?
I currently have 6 seperate buttons on card
for example 1-16% would be speed 1
17-33% woudl be speed 2
and so on.
Another option is to use the template card and media card (whiteout icon, primary info and secondary info) and use the stack card. Than you don’t need to use card mod and are flexible where what info is presented.
for example:
keep:
  margin: true
cards:
  - square: false
    columns: 1
    type: grid
    cards:
        primary: |-
          {% set s = state_attr(entity, 'source') %}
          {% if s %} Spotify - {{s}}
          {% else %} Spotify
        secondary: |-
          {% set a = state_attr(entity, 'media_artist') %}
          {% set t = state_attr(entity, 'media_title') %}
          {% if a %} {{a}} - {{t}}
          {% else %} Beschikbaar
        icon: mdi:spotify
        entity: media_player.spotify_secondary
        icon_color: |-
          {% if s %} deep-orange
          {% else %} disabled
        tap_action:
          action: more-info
      - type: custom:mushroom-media-player-card
        media_controls:
          - shuffle
          - previous
          - play_pause_stop
          - next
          - repeat
        icon_type: none
        primary_info: none
Hey I know your one of the coding experts on here . I’m trying to use the mushroom fan card slider to control my 6 speeds on fan . Currently I have 6 seperate buttons set as scripts for the RF BroadLink hub
I found entity-row-slider but my issue is I need it to look like a mushroom card and mushroom slider. Am this be done with fan or template card?
HA and Mushroom should automatically take care of it. I have a tuya based fan controller and I didn’t have to do anything special in Mushroom to get the slider on the fan card to work.
I feel like I still might have trouble because I had to manually program each speed button as a script for this fan. The fan itself is in a smart fan I had to use an RF hub. Good to know though for future fans I might set up. Thanks
