Just set this up today for my cell, and it is fantastic. Also followed along with Zack to fine tune. Great work man!
disable the other tap actions for that card
How on earth do you get these iconās ? I have been searching a lot for this, but canāt seem to find it. Iām using Afvalwijzer too.
The new 1.6.1 Mushroom version is out with Media player card and the Lock card
Already integrated the media card in my dashboards, and love it! Much cleaner than other options.
One request (Iāll post this on the GH as well): Would it be possible to add TTS entry to the card?
That works great - but is it possible to evaulate the state of an entity thats matched in the entity list of the auto_entities card based on rules in the mushroom card?
So if I created a singlw mushroom template card, i could set the icon color to be:
{{ (states('sensor.bedroom_thermometer_power') |int(0) < 80 ) | iif('orange', 'green') }}
If I have an auto_entities card that shows several batteries, is it possible to pass the entity name to evaluate them all?
edit: Found the answer - need to use āthis.entity_idā in the template.
Awesome, that helped quite a bit. Thanks!
found a solution for the covers?
Isnāt fixed with the last release ?
oh nice, it is fixed! thanks!
The new cards donāt seem to work on mobile app - I can see them in the web but not using home assistant mobile app, any idea? All other mushroom cards work as expected. I have HA docker and Iāve downloaded the js from the latest release. Thanks and great work
Have you tried closing the app completely and re-opening it? could be a caching issue.
Is it only me that on Alarm chip I canāt do anything? Disarm, Arm is greyed out.
On HA default all is good.
Yes I tried refresh, remove the JS from resources and add back again, logout login⦠it doesnāt seem to work - Iām using iOS app, any clue?
everything has been working fine installing Mushroom.js ( 1.4.0 ) threw resources but I tried to update to the latest by deleting mushroom from my www folder and uploaded the latest version also rebooted do I need to do something else? no media card no vaccum card. or maybe I am confusedā¦tried updating to 1.6.0. ( Scratch this post after reading otherās comments I cleared cache on my windows Chrome browser and they are there )
not sure, I would think its a cache issue forsure. The new cards show up fine on my iphone
Yes it was a cache issue - on the mobile app Iāve selected the option Reset Frontend Cache and now all works fine ( App Configuration > Debugging ) thanks all for the support - this is a great project.
Iām getting this error with the new media card if I select something in the dropdown menu of volume control or media controls.
If I make manually a array in yaml it works.
I am working on automating my ceiling fan using a broadlink rm pro. I have on/off and change direction working and I want to use the mushroom fan card. Unfortunately it has an oscillating option, but no way of changing the direction. Will the card be updated to include changing direction?
Whatās your HA version? I think 2022.4 is needed to have the editor works great
