Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
This works for me
card_mod:
  style: |
    ha-card {
      border-radius: 30px;
      width: 70px;
      margin-left: auto;
      margin-right: auto;
      --card-primary-font-size: 10px;
Schermafbeelding 2023-01-01 124957
Worked perfectly. Thank you!
Dang that looks great! Question, how did you made those buttons (2nd row) in that particular shape?
is it normal if the card not reduce when nothing is playing ?
I use this
card_mod:
  style: |
    ha-card {
      background: var(--card-background-color);
      width: 66px;
      margin-left: auto;
      margin-right: auto;
      margin-bottom: 2px;
You can do this with layout card, specifically the custom:grid-layout.
For the page layout you have to select ‘Grid’ and then add some code below, for example:
grid-template-columns: 0.5em 22em 22em 22em 0.5em
grid-template-rows: 9em auto auto
grid-gap: 0.7em
grid-template-areas: |
  "welcome welcome welcome . ."
  ". left1 center1 right1 ."
  ". left2 center2 right2 ."
mediaquery:
  '(max-width: 400px)':
    grid-template-columns: 3% 94% 3%
    grid-template-rows: auto
    grid-gap: 0em
      ". welcome ."
      ". left1 ."
      ". left2 ."
      ". center1 ."
      ". center2 ."
      ". right1 ."
      ". right2 ."
This code creates 3 main columns for tablets/desktop, which you can fill with vertical stacks. For phones (less than 400px wide) it stacks the columns instead. All with a certain column width and row height.
Hello guys, have my dashboard almost with mushroom cards and it is lovely.
Is there anyway to have a light entity with a timer? Basically when the light is on it goes off after x time and a timer to see how may time is remaining?
thank you
@rhysb would you help me with this? I got this icon that i want to ‘boink’ (animate) on a specific state. No clue what im missing here.
type: custom:mushroom-chips-card
chips:
  - type: template
    icon: mdi:nas
    icon_color: green
    content: '{{ states(entity) }}'
    entity: sensor.sabnzbd_status
    tap_action:
      action: more-info
card_mod:
  style:
    mushroom-template-chip:nth-child(1)$: |
      ha-icon {
        {% if is_state('sensor.sabnzbd_status', 'idle') %}
          animation: boing 3s ease infinite;
          transform-origin: 50% 90%;
      @keyframes boing {
        0% { transform: scale3d(1, 1, 1); }
        7% { transform: scale3d(1.25, 0.75, 1); }
        10% { transform: scale3d(0.75, 1.25, 1); }
        12% { transform: scale3d(1.15, 0.85, 1); }
        16% { transform: scale3d(0.95, 1.05, 1); }
        19% { transform: scale3d(1.05, 0.95, 1); }
        25% { transform: scale3d(1, 1, 1); }
Refer to this post.
https://community.home-assistant.io/t/mushroom-cards-build-a-beautiful-dashboard-easily/388590/1046?u=boostin4hp
type: custom:stack-in-card
cards:
    primary: Garage Door
    secondary: >-
      {% if is_state('cover.garage_door','open') and
      is_state('binary_sensor.garage_door_open','on') %}
        Open and Unlocked
      {% elif is_state('binary_sensor.garage_door_open','on') %}
        Door Open
      {% elif is_state('cover.garage_door','open') %}
        Unlocked
      {% else %}
        Closed
      {% endif%}
    icon: >-
        mdi:garage-open-variant
        mdi:garage-alert-variant
      {% else %}
        mdi:garage-variant-lock
      {% endif%}
    icon_color: >-
      {% if is_state('cover.garage_door','closed') and
      is_state('binary_sensor.garage_door_open','off') %}
        green
      {% else %}
        red
      {% endif%}
    badge_icon: |-
      {% set bl = states('sensor.garage_door_sensor_battery_level') | int %}
      {% if bl < 10 %} mdi:battery-outline
      {% elif bl < 20 %} mdi:battery-10
      {% elif bl < 30 %} mdi:battery-20
      {% elif bl < 40 %} mdi:battery-30
      {% elif bl < 50 %} mdi:battery-40
      {% elif bl < 60 %} mdi:battery-50
      {% elif bl < 70 %} mdi:battery-60
      {% elif bl < 80 %} mdi:battery-70
      {% elif bl < 90 %} mdi:battery-80
      {% elif bl < 100 %} mdi:battery-90
      {% elif bl == 100 %} mdi:battery
      {% else %} mdi:battery-unknown
      {% endif %}
    badge_color: |-
      {% if bl < 10 %} red
      {% elif bl < 20 %} red
      {% elif bl < 30 %} red
      {% elif bl < 40 %} orange
      {% elif bl < 50 %} orange
      {% elif bl < 60 %} green
      {% elif bl < 70 %} green
      {% elif bl < 80 %} green
      {% elif bl < 90 %} green
      {% elif bl < 100 %} green
      {% elif bl == 100 %} green
      {% else %} disabled
      {% endif %}
    tap_action:
      action: none
    card_mod:
      style: |
        mushroom-badge-icon {
          left: -3px;
  - type: custom:mushroom-cover-card
    entity: cover.garage_door
    primary_info: none
    secondary_info: none
    icon_type: none
    tap_action:
      action: none
    show_buttons_control: true
    card_mod:
      style: |
        ha-card {
          margin-top: -12px;
card_mod:
  style: |
    ha-card {
          background: rgba(101,170,91,0.2);
      {% else %}
          background: rgba(226,84,66,0.2);
      {% endif %}
Ok, i found a solution
with ha-card, just add this :
        --primary-text-color: transparent;
        --secondary-text-color: transparent;
Complete style code :
    card_mod:
      style: |
        :host {
          --mush-icon-size: 65px;
        ha-card {
          {% if not is_state(config.entity, 'unavailable') %}
            background-image: url( '{{ state_attr( config.entity, "entity_picture" ) }}' );
            background-position: center;
            background-repeat: no-repeat;
            background-size: cover;
            background-color: rgba(var(--rgb-card-background-color)0.5);
            background-blend-mode: overlay;
          {% endif %}
          --rgb-state-media-player: var(--rgb-teal);
Example with my computer card :
Capture
missing endif after animation
 {% endif %}
@Tyfoon @Guizmos @Tehlo
I am using unifi_status to get all the UDM stats and the official unifi Protect integration to get the CPU temperature.
I have created extra sensors from the unifi_status attributes to make things easier.
unifi_status
- platform: unifi_status
    host: [UDM_IP]
    port: 8443
    username:[USER]
    password: *********
    verify_ssl: false
    version: UDMP-unifiOS
    monitored_conditions:
      - wan
      - www
      - lan
      - wlan
      - firmware
    sensors:
      unifi_status_wan_cpu:
        friendly_name: "CPU"
        unit_of_measurement: "%"
        value_template: "{{ states.sensor.unifi_status_wan.attributes['gw_system-stats']['cpu'] }}"
      unifi_status_wan_mem:
        friendly_name: "Memory"
        value_template: "{{ states.sensor.unifi_status_wan.attributes['gw_system-stats']['mem'] }}"
      unifi_status_wan_ip:
        friendly_name: "WAN IP"
        value_template: "{{ states.sensor.unifi_status_wan.attributes.wan_ip }}"
      unifi_status_wan_download:
        friendly_name: "WAN Download"
        unit_of_measurement: Kbps
        icon_template: "mdi:progress-download"
        value_template: "{{ (states.sensor.unifi_status_wan.attributes['rx_bytes-r'] / 1024) | int }}"
      unifi_status_wan_upload:
        friendly_name: "WAN Upload"
        icon_template: "mdi:progress-upload"
        value_template: "{{ (states.sensor.unifi_status_wan.attributes['tx_bytes-r'] / 1024) | int }}"
      unifi_status_firmware_version:
        friendly_name: "UDM Firmware Version"
        icon_template: "mdi:database-plus"
        value_template: "{{ states.sensor.unifi_status_wan.attributes.gw_version }}"
      unifi_status_www_speedtest_down:
        friendly_name: "UDM Speedtest Download"
        unit_of_measurement: Mbps
        value_template: "{{ states.sensor.unifi_status_www.attributes.xput_down | int }}"
      unifi_status_www_speedtest_up:
        friendly_name: "UDM Speedtest Upload"
        value_template: "{{ states.sensor.unifi_status_www.attributes.xput_up | int }}"
      unifi_status_www_speedtest_ping:
        friendly_name: "UDM Speedtest Ping"
        unit_of_measurement: ms
        icon_template: "mdi:progress-clock"
        value_template: "{{ states.sensor.unifi_status_www.attributes.speedtest_ping }}"
The cards are all using using decluttering_templates
decluttering_templates:
  graph_template:
    default:
      - name: ''
      - icon: ''
      - unit: ''
      - color: '#2196f3'
      - hours: 24
    card:
      cards:
          entity: '[[entity]]'
          secondary: |
            {{ '[[name]]' or state_attr('[[entity]]', 'friendly_name') }}
          primary: >
            {{ states('[[entity]]') }} {{ '[[unit]]' or state_attr('[[entity]]',
            'unit_of_measurement') or '' }}
          icon: >
            {{ '[[icon]]' or state_attr('[[entity]]', 'icon') or
            'mdi:chart-line' }}
          icon_color: '[[color]]'
          card_mod:
            style: |
              :host {
                --mush-icon-size: 42px;
          tap_action:
            action: more-info
        - type: custom:mini-graph-card
          entities:
            - entity: '[[entity]]'
              color: '[[color]]'
          hours_to_show: '[[hours]]'
          line_width: 3
          animate: true
          show:
            icon: false
            state: false
            legend: false
  entity_chips:
    default:
      - name: ''
      - icon: ''
      - unit: ''
      - color: '#2196f3'
      - state: ''
    card:
      mode: horizontal
      card_mod:
        style:
          hui-horizontal-stack-card$: |
            #root {
              align-items: center;
      cards:
          primary: |
          secondary: >
            {{ [[state]] or states('[[entity]]') }} {{ '[[unit]]' or
            state_attr('[[entity]]', 'unit_of_measurement') or '' }}
          icon: >
            'mdi:progress-question' }}
          tap_action:
            action: more-info
        - type: custom:mushroom-chips-card
          card_mod:
            style: |
              ha-card {
                --chip-box-shadow: none;
                --chip-spacing: 12px;
                --chip-background: transparent;
                --chip-padding: 0 0px;
              .chip-container {
                justify-content: end !important;
                padding-right: 12px;
          chips: '[[chips]]'
The code for the device and graph cards
device
type: custom:decluttering-card
template: entity_chips
variables:
  - entity: sensor.unifi_status_wan
  - name: UDM-SE
  - state: states('sensor.unifi_status_firmware_version')
  - color: >-
      {{ 'orange' if states('sensor.unifi_status_firmware_upgradable') != '0'
      else 'green' if is_state(entity, 'OK') else 'red' }}
  - chips:
      - type: entity
        entity: sensor.unifi_status_www_speedtest_down
      - type: entity
        entity: sensor.unifi_status_www_speedtest_up
      - type: entity
        entity: sensor.unifi_status_www_speedtest_ping
graphs
type: grid
square: false
columns: 3
cards:
  - type: custom:decluttering-card
    template: graph_template
    variables:
      - entity: sensor.udm_se_cpu_utilization
      - name: Processor
      - icon: mdi:cpu-64-bit
      - hours: 24
    variables:
      - entity: sensor.udm_se_cpu_temperature
      - color: orange
      - name: Temperature
      - icon: mdi:thermometer
    variables:
      - entity: sensor.udm_se_memory_utilization
      - color: teal
      - name: Memory
Hi
Thank you for the info.
It was enough to activate the temperature entity in Unifi Protect integration.
Here is my card:
Capture
With dynamic change of icon colors
Hi, thanks for your reply @Kollisionskurs, however your suggestion doesn’t seem to work out the problem :frowning:
hi together,
after several month break i started from scratch with my Dashboard.
At the moment i am experimenting with some cards an try to test so ideas
One Questions, where i think its possible… but how
01
For the color of the icon i want to use the theme variable.
If i use orange, red, yellow it works - so the error is on my side, how i try to use the variable of the theme
@Kollisionskurs
I rechecked every line now. Could it be the case that animated icons dont work with mushroom chips?
      - type: template
        icon: mdi:robot-vacuum
        icon_color: |-
          {% if is_state('vacuum.roborock_s5_max', 'docked') %}
          blue
          {% else %} green
          {% endif %}
        entity: vacuum.roborock_s5_max
        card_mod:
          style:
            mushroom-shape-icon$: |
              ha-icon {
                {{ '--icon-animation: boing 3s ease infinite;' if is_state(vacuum.roborock_s5_max, 'cleaning') }}
              @keyframes boing {
Try with this :
- type: template
        icon_color: |-
          blue
          {% else %} green
          {% endif %}
        card_mod:
          style:
              ha-icon {
                {% if is_state('vacuum.roborock_s5_max', 'cleaning') %}
                {% endif %}
              @keyframes boing {
Hey there, sadly this didn’t work. Im al out of idea’s, something tells me this is a very minor thing that im overlooking. :smiley:
try :
        type: custom:mushroom-template-card
        icon_color: |-
          blue
          {% else %} green
          {% endif %}
        card_mod:
          style:
              ha-icon {
                {% endif %}
              @keyframes boing {
Type is not “template” but “custom:mushroom-template-card”
Works for me :wink:
