Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Go to Settings->People, select the person and add a picture.
Edit the Mushroom Person Card and change the Icon Type to Entity Picture.
Add !important, like this:
height: 100px !important;
A better option would be to change the padding. You can add mush-spacing: 4px to your theme file and it will change it for all Mushroom Cards.
Could You do me a favour and could You share with configuration.yaml for open windows goup? Ive tried copied from battery config but its not working:/
Thank You in advance!
Hello bro, I would like to add a photo instead of an icon in this.
type: custom:mushroom-chips-card
chips:
  - type: template
    entity: input_number.lounge_pc_volume
    icon: mdi:volume-high
    icon_color: blue
    content: >-
      {{ (states(entity) | float * 100) | round(0) }}%
      Volume
    card_mod:
      style: |
        ha-card:before {
          content: "";
          position: absolute;
          height: var(--chip-height);
          width: var(--chip-height);
          border-radius: 50%;
          background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-cyan)) {{ (states(config.entity) |float * 100) | round(0) }}% 0%, var(--card-background-color) 0% 100%);
        ::slotted(ha-icon) {
          margin-right: 0.4em !important;
Ah, my bad :rofl:.
You can replace the icon with a picture like this.
Mushroom Chip Progress Bar with Picture:
chips:
  - type: template
    icon: none
    content: '{{ (states(entity) | float * 100) | round(0) }}% Volume'
    card_mod:
      style: |
        ha-card:before {
          content: "";
          position: absolute;
          border-radius: 50%;
          background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-orange)) {{ (states(config.entity) | float * 100) | round(0) }}% 0%, var(--card-background-color) 0% 100%);
          background: url( '/local/ls50.png' ) no-repeat  center center;
          background-size: 0.7em;
          border-radius: 50%;
          z-index: 1;
        .content {
         --chip-padding: 0 0.25em 0 0;
Yes, sure. It looks like this:
all_windows:
  entities:
    - binary_sensor.rhys_office_left_window_contact
    - binary_sensor.rhys_office_right_window_contact
    - binary_sensor.michaelas_bedroom_left_window_contact
    - binary_sensor.michaelas_bedroom_top_right_window_contact
    - binary_sensor.michaelas_bedroom_bottom_right_window_contact
    - binary_sensor.elijahs_bedroom_left_window_contact
    - binary_sensor.elijahs_bedroom_right_window_contact
    - binary_sensor.family_room_left_window_contact
    - binary_sensor.family_room_right_window_contact
    - binary_sensor.dining_room_left_window_contact
    - binary_sensor.dining_room_right_window_contact
    - binary_sensor.lounge_top_left_window_contact
    - binary_sensor.lounge_top_right_window_contact
    - binary_sensor.lounge_bottom_left_window_contact
    - binary_sensor.lounge_bottom_right_window_contact
    - binary_sensor.garage_left_window_contact
    - binary_sensor.garage_right_window_contact
    - binary_sensor.kitchen_window_contact
    - binary_sensor.toilet_window_contact
    - binary_sensor.master_bedroom_left_window_contact
    - binary_sensor.master_bedroom_top_left_window_contact
    - binary_sensor.master_bedroom_top_right_window_contact
    - binary_sensor.sarahs_office_left_window_contact
    - binary_sensor.sarahs_office_right_window_contact
    - binary_sensor.sarahs_office_top_left_window_contact
    - binary_sensor.ensuite_window_contact
    - binary_sensor.bathroom_left_window_contact
    - binary_sensor.bathroom_right_window_contact
Damn! i wrote bad question:D i`m sorry:)
What i mean, are You able to send me configuration for sensor which You created for all windows group? In past You sent that sensor config for devices with batteries, here:
    sensors:
      devices_with_low_battery:
        friendly_name: 'Devices with Low Battery'
        unit_of_measurement: devices
        value_template: >-
          {% set ignore_entities = [] %}
          {{ states.sensor
            | selectattr('attributes.device_class', 'eq', 'battery')
            | rejectattr('entity_id', 'in', ignore_entities)
            | map(attribute='state')
            | reject('in', ['unknown', 'unavailable'])
            | map('int', -1) | select('le', 30)
            | select('ge', 0)
            | list | count
        icon_template: >-
          {% if is_state('sensor.devices_with_low_battery', '0') %}
            mdi:battery-check
          {% else %}
            mdi:battery-alert
          {% endif %}
Thank You!:slight_smile:
A separate sensor template is not required. Just template it in the Chip like this:
content: >-
  {{ expand(states.group.all_windows) | selectattr( 'state', 'eq', 'on') | list | count }}
Have a look here:
Ohh, gotcha. Thank You, gonan combine it;)
For your first question, have a look here:
You are the master ! Respectfully kneeling…
Many thanks.
Sure, here is a variation with volume button.
Mushroom Media Player with Volume:
type: custom:stack-in-card
cards:
  - type: custom:mushroom-media-player-card
    entity: media_player.currently_playing
    icon: mdi:play
    use_media_info: true
    use_media_artwork: false
    show_volume_level: false
    media_controls:
      - next
      - play_pause_stop
      - previous
      - shuffle
    fill_container: false
    card_mod:
      style: |
        mushroom-shape-icon {
          display: flex;
          {% set media_type = state_attr(config.entity, 'media_content_type') %}
          {% if media_type == 'tvshow' %}
            --card-mod-icon: mdi:television-classic;
            animation: flicker 1s linear infinite alternate;
          {% elif media_type == 'movie' %}
            --card-mod-icon: mdi:movie-roll;
            animation: spin 2s linear infinite reverse;
          {% elif media_type == 'music' %}
            --card-mod-icon: mdi:music;
            animation: beat 1.3s ease-out infinite both;
          {% elif media_type == 'playlist' %}
          {% else %}
            --card-mod-icon: mdi:play;
          {% endif %}
          {{ 'animation: none;' if not is_state(config.entity, 'playing') }}
        @keyframes flicker {
          0%, 31.98%, 32.98%, 34.98%, 36.98%, 39.98%, 67.98%, 68.98%, 95.98%, 96.98%, 97.98%, 98.98%, 100% { --icon-color: rgba(var(--album-art-color), 1); }
          32%, 33%, 35%, 36%, 37%, 40%, 68%, 69%, 96%, 97%, 98%, 99% { --icon-color: rgba(var(--album-art-color), 0.6); }
        @keyframes beat {
          0%, 60% { --icon-symbol-size: 21px; }
          5%, 17%, 57% { --icon-symbol-size: 22px; }
          10%, 20%, 51% { --icon-symbol-size: 23px; }
          25%, 45% { --icon-symbol-size: 24px; }
          30%, 39% { --icon-symbol-size: 25px; }
          33% { --icon-symbol-size: 26px; }
        ha-card {
          --ha-card-border-width: 0;
          --rgb-state-media-player: var(--album-art-color);
        .actions {
          --rgb-primary-text-color: var(--album-art-color);
          --primary-text-color: rgb(var(--album-art-color));
        ha-card:before {
          transform: translate3d(0,0,0);
          -webkit-transform: translate3d(0,0,0);
          content: "";
          background: url('/local/idle_art.png') center no-repeat;
          {% if not is_state(config.entity, 'idle') and not is_state(config.entity, 'off') %}
            background: url( '{{ state_attr(config.entity, "entity_picture") }}') center no-repeat;
          {% endif %}
          background-size: contain;
          margin: 4px 4px 16px;
          filter: drop-shadow(4px 4px 6px rgba(0, 0, 0, 0.5));
          border-radius: var(--control-border-radius);
            aspect-ratio: 16 / 9;
            aspect-ratio: 2 / 3;
          {% else %}
            aspect-ratio: 1 / 1;
          {% endif %}
  - type: conditional
    conditions:
      - entity: media_player.currently_playing
        state_not: 'off'
        state_not: idle
    card:
      type: custom:mushroom-template-card
      entity: input_boolean.volume_visible
      layout: horizontal
      card_mod:
        style: |
          ha-card {
            height: var(--control-height) !important;
            width: calc((100% / 3) - var(--spacing));
            border-radius: var(--control-border-radius) !important;
            background: rgba(var(--album-art-color), 0.05) !important;
            margin-left: auto;
            margin-right: auto;
            --shape-color: none !important;
            --shape-color-disabled: none !important;
            --icon-color: rgb(var(--album-art-color)) !important;
  - type: conditional
    conditions:
      - entity: input_boolean.volume_visible
        state_not: 'off'
        state_not: 'off'
        state_not: idle
    card:
      secondary_info: none
      primary_info: none
      icon_type: none
      use_media_info: false
      volume_controls:
        - volume_set
      card_mod:
        style: |
          ha-card {
            padding-bottom: 0px !important;
            background: none;
  - type: conditional
    conditions:
        state_not: 'off'
        state_not: idle
    card:
      hide:
        icon: true
        runtime: true
        source: true
        power: true
        state_label: true
        volume: true
        info: true
        progress: false
        controls: true
      more_info: false
      type: custom:mini-media-player
      toggle_power: false
      group: true
      card_mod:
        style:
          mmp-progress$: |
            paper-progress {
              {% if is_state(config.entity, 'playing') %}
                --paper-progress-container-color: rgba(var(--album-art-color), 0.2) !important;
              {% endif %}
            ha-card {
              margin: 12px 12px 12px;
              --mmp-progress-height: 12px !important;
              height: var(--mmp-progress-height);
              --mmp-accent-color: rgb(var(--album-art-color));
              --mmp-border-radius: 12px !important;
card_mod:
  style: |
    ha-card:before {
      content: "";
      position: absolute;
      height: 100%;
      width: 100%;
      {% if not is_state('media_player.currently_playing', 'idle') and not is_state('media_player.currently_playing', 'off') %}
        background: url( '{{ state_attr('media_player.currently_playing', "entity_picture") }}' ) center no-repeat;
      {% endif %}
      filter: blur(150px) saturate(200%);
      background-size: 100% 100%;
    ha-card {
    :host {
      --album-art-color:
        {{ states('sensor.muted_color') }}
      {% else %}
        var(--rgb-indigo-color)
      {% endif %};
Hi, Maybe I did something completely wrong here. Should I be using the cofiguration file?
And not trying to edit the code here?
How should I define the card I want in the configuration file and how then can I call it?
You have spelt ‘height’ incorrectly.
thank you very much :smiling_face_with_three_hearts:
These seem like shadow to me, not borders… :thinking:
But even still;
For removing borders you can do either of the following:
border: none;
# or
border-width: 0;
if it’s actually shadow you can do:
box-shadow: none;
# or
box-shadow: 0 0 0 0;
You might have to add a
!important
# for example:
box-shadow: none !important;
To the end of them.
So for example, with your code:
Did you figure out how to do this using stack-in-card?
Excuse me if this has been answered somewhere already (I’ve been searching for two days without luck) but is there any way to change the icon color on a mushroom entity card based on state? I’ve actually been able to get it to once, but not in conjunction with the animation I’d also like:
type: custom:mushroom-entity-card
icon: mdi:sprinkler-variant
tap_action:
  action: toggle
layout: vertical
entity: switch.closet
icon_color: '{{ ''yellow'' if(is_state(switch.closet, ''on'')) else ''red'' }}'
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon {
        {{ '--icon-animation: spray 4s ease-in infinite;' if(is_state('switch.closet', 'on')) }}
      @keyframes spray {
        0%, 50%, 100% { clip-path: polygon(0 0, 60% 0, 61% 100%, 0% 100%); }
        25%, 75% { clip-path: polygon(41% 1%, 100% 0, 100% 100%, 39% 100%); }
thank you, bro!
