Hassio
(Hassio)
January 12, 2023, 8:04pm
4885
Does anyone no if you can change the background of an card/button?
I have some scene cards, and some room cards like this:
But I really want to change the background for some cards. I also try to add some dividers to the cards, but with no luck.
type: custom:mushroom-template-card
primary: Home
secondary: ''
icon: mdi:home
layout: vertical
tap_action:
action: navigate
navigation_path: Woonkamer
icon_color: '#E38B29'
It’s a simple conditional card: when Spotify is playing, display the media player (aspect ratio square to make it look like the album art) and any speakers that are playing. When Spotify isn’t playing, it displays a collection of playlist buttons (which I manually created using my playlist artwork).
Yeah, I know we can customize individual instances — it would be nice to have a reusable template so the customizations don’t need to be repeated on every card.
rhysb
(Rhys)
January 12, 2023, 8:56pm
4888
I’ve updated the original post to remove the lines .
I thought I would give back and share my Mushroom graph card. It uses stack-in-card to combine mushroom-entity-card with mini-graph-card. This is the dual version, but it is easy to modify for a single graph.
[Mushroom Graph]
type: custom:vertical-stack-in-card
cards:
- type: grid
square: false
columns: 2
cards:
- type: custom:mushroom-entity-card
entity: sensor.family_room_sensor_temperature
primary_info: state
secondary_info: name
rhysb
(Rhys)
January 12, 2023, 9:02pm
4889
You can target specific card types in your theme using card_mod
. Have a look here:
You can target a specific type of card by specifying the class instead of ha-card. For the Mushroom Template Card the class is .type-custom-mushroom-template-card, so we would add it like this to our theme:
card-mod-card: |
.type-custom-mushroom-template-card:active {
transform: scale(1.02);
transition: 0s;
Let me know if you need any help identifying the classes.
rhysb
(Rhys)
January 12, 2023, 9:19pm
4890
You cannot use templating in an entity card. Try using a Mushroom Template Card instead:
icon: mdi:sprinkler-variant
fill_container: false
tap_action:
action: toggle
layout: vertical
entity: switch.closet
icon_color: '{{ ''yellow'' if(is_state(entity, ''on'')) else ''red'' }}'
primary: Front Yard
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
{{ '--icon-animation: spray 4s ease-in infinite;' if(is_state(config.entity, 'on')) }}
@keyframes spray {
0%, 50%, 100% { clip-path: polygon(0 0, 60% 0, 61% 100%, 0% 100%); }
25%, 75% { clip-path: polygon(41% 1%, 100% 0, 100% 100%, 39% 100%); }
Posreg
(Daros)
January 12, 2023, 9:35pm
4891
This is just outstanding! We are implementing it with @Matjum , thank you!
Can I give you a challenge :D?
Do you think it is possible to add second progress bar with different entity?
Let’s say we would like to add mobile battery AND smartwatch battery
looking forward to your reply!
yorknh
January 12, 2023, 9:59pm
4892
I’ve tried a few things with no luck to change the color of the slider in the media player card. Is there a way that I just wasn’t able to figure out? Regardless, it might make sense to add color choices for any kind of slider like what you did with the light cards. Thanks in advance.
bkr1969
(Brian)
January 12, 2023, 11:12pm
4893
That was the problem. Changed to template card and it works perfectly. Thanks!
rhysb
(Rhys)
January 12, 2023, 11:33pm
4894
Sure, here you go:
Mushroom Dual Progress Bar:
icon: mdi:battery-high
primary: Battery Level
icon_color: green
secondary: >-
{{ states('sensor.rhys_phone_battery_level') | round(0) }}% Phone |
{{ states('sensor.rhys_tablet_battery_level') | round(0) }}% Tablet
card_mod:
style:
.shape {
background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-{{ config.icon_color }})) {{ states('sensor.rhys_phone_battery_level') }}% 0%, var(--card-background-color) 0% 100%);
.shape:before {
content: "";
background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-teal)) {{ states('sensor.rhys_tablet_battery_level') }}% 0%, var(--card-background-color) 0% 100%);
position: absolute;
border-radius: var(--icon-border-radius);
width: 81%;
height: 81%;
.shape:after {
content: "";
height: 100%;
width: 100%;
position: absolute;
background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
Implementing with @Matjum ?
I’ll add one for Chips tonight
sebbaT
January 12, 2023, 11:34pm
4895
Amazing! didn’t think of doing like that.
One lasssst question
How I can target the mushroom-state-info
container for the song name and artist to apply white-space: normal;
as the text pushes everything out the page with a long string of text.
e.g:
xbmcnut
(xbmcnut)
January 13, 2023, 1:59am
4896
Looking good. Any chance you could share the full code for either your UPS or NAS chip card?
sparkydave
(🇦🇺 Dave)
January 13, 2023, 2:05am
4897
Sure thing. Here are the final results:
NAS Card
type: custom:stack-in-card
cards:
primary: NAS
secondary: 'Online since: {{ states(''sensor.synology_nas_uptime'') }}'
icon: mdi:nas
icon_color: |
{% if is_state('sensor.synology_status_volume_1', 'normal') %}
green
{% else %}
red
{% endif %}
- type: custom:mushroom-chips-card
chips:
- type: template
entity: sensor.synology_average_disk_temp_volume_1
content: '{{ states(entity) }} °C'
icon: mdi:thermometer
icon_color: >
{% if states('sensor.synology_average_disk_temp_volume_1') | int > 80
red
{% elif states('sensor.synology_average_disk_temp_volume_1') | int >
70 %}
orange
60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
- type: template
entity: sensor.synology_cpu_load_total
content: '{{ states(entity) }} %'
icon_color: |
{% if states('sensor.synology_cpu_load_total') | int > 80 %}
red
{% elif states('sensor.synology_cpu_load_total') | int > 70 %}
orange
{% elif states('sensor.synology_cpu_load_total') | int > 60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
icon: mdi:cpu-64-bit
- type: template
entity: sensor.synology_memory_usage_real
icon: mdi:memory
icon_color: |
{% if states('sensor.synology_memory_usage_real') | int > 80 %}
red
{% elif states('sensor.synology_memory_usage_real') | int > 70 %}
orange
{% elif states('sensor.synology_memory_usage_real') | int > 60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
- type: template
entity: sensor.synology_volume_used_volume_1
icon: mdi:harddisk
icon_color: |
{% if states('sensor.synology_volume_used_volume_1') | int > 80 %}
red
{% elif states('sensor.synology_volume_used_volume_1') | int > 70 %}
orange
{% elif states('sensor.synology_volume_used_volume_1') | int > 60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
alignment: end
UPS Card
cards:
primary: UPS
secondary: ' {{ states(''sensor.ups_status'') }}'
icon: mdi:nas
icon_color: |
{% if is_state('sensor.ups_status', 'Online') %}
green
{% else %}
red
{% endif %}
chips:
- type: template
entity: sensor.ups_input_voltage
content: 'Input: {{ states(entity) }} V'
icon: mdi:power
icon_color: |
{% if states('sensor.ups_input_voltage') | int < 230 %}
red
{% elif states('sensor.ups_input_voltage') | int < 235 %}
orange
{% elif states('sensor.ups_input_voltage') | int > 235 %}
green
{% elif states('sensor.ups_input_voltage') | int > 242 %}
red
{% else %}
red
{% endif %}
tap_action: none
- type: template
entity: sensor.ups_output_voltage
content: 'Output: {{ states(entity) }} V'
icon: mdi:power
icon_color: |
{% if states('sensor.ups_output_voltage') | int < 230
red
{% elif states('sensor.ups_output_voltage') | int < 235
orange
{% elif states('sensor.ups_output_voltage') | int >
235 %}
green
242 %}
red
{% else %}
red
{% endif %}
tap_action: none
- type: template
entity: sensor.ups_load
content: 'Load: {{ states(entity) }} %'
icon: mdi:weight-lifter
icon_color: |
{% if states('sensor.ups_load') | int > 80 %}
red
{% elif states('sensor.ups_load') | int > 70 %}
orange
{% elif states('sensor.ups_load') | int > 60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
- type: template
entity: sensor.ups_battery_charge
icon: |
{% if states(entity) | int < 30 %}
mdi:battery-30
{% elif states(entity) | int < 50 %}
mdi:battery-50
{% elif states(entity) | int < 70 %}
mdi:battery-70
{% elif states(entity) | int > 70 %}
mdi:battery
{% else %}
mdi:battery-alert
{% endif %}
icon_color: |
{% if states('sensor.ups_battery_charge') | int < 30 %}
red
{% elif states('sensor.ups_battery_charge') | int < 50 %}
orange
{% elif states('sensor.ups_battery_charge') | int < 70 %}
yellow
{% elif states('sensor.ups_battery_charge') | int > 70 %}
green
{% else %}
red
{% endif %}
tap_action: none
alignment: end
What I like is that I can see if there are any issues at a very quick glance based on seeing the colours, all green = all good.
xbmcnut
(xbmcnut)
January 13, 2023, 2:08am
4898
That’s brilliant (and fast!), thank you.
viper80
(Robert)
January 13, 2023, 6:25am
4899
What ups do you have? model?
Posreg
(Daros)
January 13, 2023, 7:46am
4900
super awesome again! you are just unbeliavable
by implementing with @Matjum I meant that we are your fans and trying the animations and different options you present
ArveVM
(ArveVM)
January 13, 2023, 8:32am
4901
wow, just wow!!!
Have been looking for some good visualization of timer-status, and then stumbled upon this goldmine
I’m actually moving to a version of your “Room-Card” and have been looking for a way to visualize time left on timer for smart-clocks (the kids!!)
so is there a way to “turn the dial” - so when timer is lets say
- 75% of something, then the “right upper quadrant” is blank and the rest is colored
- 50% of something, then the "left side " is colored and the rest is blank
- 25% of something, then the "left upper quadrant " is colored and the rest is blank
(ofcourse all levels should work as in your config, only the dial is “mirrored” ? (really bad explenation - i know - not natively english speaking/writing )
Anyway, apriciate you sharing ! - great work!
l0ghan
(L0ghan)
January 13, 2023, 9:29am
4902
Tank you all for your commitment and kindness, here is what I ended with all your help
Home :
Salon:
Cuisine:
Bureau:
Nurserie:
Chambre:
Salle de bain:
Toilettes:
Couloir:
Server:
Garage:
There is also a lot of conditional card and dynamic layout.
I can share code if you want to, you just have to ask for it and I will be glad.
Have you all a good day.
julien
rhysb
(Rhys)
January 13, 2023, 9:57am
4903
Mushroom Chip Dual Progress Bar:
chips:
- type: template
icon_color: purple
content: >
{{ states('sensor.rhys_phone_battery_level') | round(0) }}% Phone | {{
card_mod:
style: |
ha-card:before {
content: "";
position: absolute;
height: var(--chip-height);
width: var(--chip-height);
border-radius: 50%;
background: radial-gradient(var(--card-background-color) 63%, transparent 0%), conic-gradient(rgb(var(--rgb-{{ config.icon_color }})) {{ states('sensor.rhys_phone_battery_level') }}% 0%, var(--card-background-color) 0% 100%);
ha-card:after {
content: "";
position: absolute;
left: 3px;
top: 3px;
height: calc(var(--chip-height) * 0.83);
width: calc(var(--chip-height) * 0.83);
border-radius: 50%;
background: radial-gradient(var(--card-background-color) 63%, transparent 0%), conic-gradient(rgb(var(--rgb-pink)) {{ states('sensor.rhys_tablet_battery_level') }}% 0%, var(--card-background-color) 0% 100%);
::slotted(ha-icon) {
margin-right: 0.45em !important;
z-index: 1;
Mushroom Chip Dual Progress Bar with Picture Icon:
chips:
- type: template
icon: none
content: >
card_mod:
style: |
ha-card:before {
content: "";
position: absolute;
border-radius: 50%;
background: radial-gradient(var(--card-background-color) 63%, transparent 0%), conic-gradient(rgb(var(--rgb-teal)) {{ states('sensor.rhys_phone_battery_level') }}% 0%, var(--card-background-color) 0% 100%);
ha-card:after {
content: "";
position: absolute;
left: 3px;
border-radius: 50%;
background: radial-gradient(var(--card-background-color) 63%, transparent 0%), conic-gradient(rgb(var(--rgb-light-green)) {{ states('sensor.rhys_tablet_battery_level') }}% 0%, var(--card-background-color) 0% 100%);
background: url( '/local/battery2.svg' ) no-repeat center center;
background-size: 0.7em;
border-radius: 50%;
z-index: 1;
.content {
--chip-padding: 0 0.25em 0 0;
rhysb
(Rhys)
January 13, 2023, 10:24am
4904
The conic-gradient
works in a clock-wise direction, but we can rotate of reverse it with a transform
Mushroom Chip Progress Bar Reversed:
chips:
- type: template
entity: input_number.lounge_pc_volume
icon: mdi:volume-high
icon_color: blue
content: '{{ (states(entity) | float * 100) | round(0) }}% Volume'
card_mod:
style: |
ha-card:before {
content: "";
position: absolute;
border-radius: 50%;
background: radial-gradient(var(--card-background-color) 60%, transparent 0%), conic-gradient(rgb(var(--rgb-cyan)) {{ (states(config.entity) |float * 100) | round(0) }}% 0%, var(--card-background-color) 0% 100%);
transform: rotateY(180deg);
margin-right: 0.4em !important;
