Can I change the color around a icon somehow without changing icon color?
you can use card mod
After initial installation my Pi4 (8 GB) is around 5% with 2022.4.4 as before. I also use Mushroom.
This is the default “Area Card”, I’ve used Cardmod to adjust the height. The current Area Card isn’t super useful, but for now it works okay. The card links to a “room” page with more control options, graphs and so on.
I’m waiting for something like Room summary card · Issue #55 · piitaya/lovelace-mushroom · GitHub
Any idea how to use icon_color: for entity ? It’s work for template, but then i don’t have information about numbers of lights on.
Im guessing this is all of them, along with RGB values (which ive used when adding in non-mushroom cards)
Thank you!
This is for my question ? i know colors but can’t use them for entity like for template.
Use template chip instead of entity chip. Only template chip, template card and title properties allow template usage
How can I display “number of lights on” in template card ? When I use template icon can change colours, but numbers of light is gone…
Primary is not working for me or I don’t know how to implement.
Btw, thank you for your work, is great add-on and really game changer for me. THX.
type: custom:mushroom-chips-card
chips:
- type: template
entity: sensor.number_of_lights_on
icon: mdi:lightbulb
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon_color: |-
{% set state=states(‘sensor.number_of_lights_on’) %}
{% if state==‘0’ %}
black
{% elif state!=‘0’ %}
yellow
{% endif %}
That is my code for counting lights on with color change
{% set count = namespace(value=0) %}
{% for state in states.light %}
{%if state.state == "on" and 'ug' in state.entity_id | string%}
{% set count.value = count.value + 1 %}
{%endif%}
{%endfor%}
{% if count.value > 0%}
amber
{%else%}
grey
{%endif%}
How did you get the postnord sensor?
In template card is working.
but in template chip is not…
what im doing wrong ?
Now I know :), in template chip i have to use content: instead primary:
Using this one:
Another question, why i cant put ‘0’ as text in content templete chip ?
any diferent text string is working ok, i want display 0 when all lights off…
type: entity
entity: sensor.current_lights_on
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
icon_color: amber
icon: mdi:lightbulb-group
and sensor for counting lights on (you could probably combine these to drop the sensor-entity)
current_lights_on:
friendly_name: All Lights Currently On
value_template: >-
{{ expand('light.alle_lys_lamper')|selectattr('state','eq','on')|list|count }}
Ah great, thanks! I’ve also got the banner card working with a picture background, that does the job for now.
That Room summary card looks also amazing!
I have the same problem, when no light is on, I don’t have the 0 displayed next to my icon, if I turn on one or more lights, the correct number is displayed next to the icon.
How can I have the 0 displayed next to my icon even if no light is on?
chips:
- type: template
entity: sensor.lights_on_count
content: '{{states(''sensor.lights_on_count'') }}'
icon_color: |-
{% set nbr= states('sensor.lights_on_count') | float %}
{% if nbr> 0 %}
orange
{% endif %}
tap_action:
action: navigate
navigation_path: lights
alignment: center
How can i delete background from mushroom-template-card?
Hi.
Can someone help me. I try to create a area button. It should look like this:
But it looks like this:
My Question is, why this CSS is not working:
card_mod:
style: |
.chip-container.align-end {
justify-content: space-evenly;
this is the css after reload:
