cosimop
January 26, 2023, 12:00pm
5169
Hello to everyone.
Is there any way to have the secondary_info: last-changed
displayed in a template card?
Right now this is what I have:
On the left, I use an entity card and I have as secondary info the last changed in the format “x minutes ago”. On the right, I use a template card because I customized the icon colour but cannot work out how to set the secondary info as the card on the left. I was only able to get the time but I need the format “x minutes ago”
This is the code of the card on the right:
type: custom:mushroom-template-card
primary: Bagno
secondary: >-
{{(as_timestamp(states.binary_sensor.luce_bagno_ping.last_changed) |
timestamp_custom('%I:%M %p'))}}
icon: mdi:toilet
icon_color: |2-
{% if is_state('binary_sensor.luce_bagno_ping', 'off') %}
green
{% else %}
red
{% endif %}
layout: vertical
hold_action:
action: none
double_tap_action:
action: none
tap_action:
action: none
Any help is appreciated, thank you!
Fantastic, thats great! Having some troubles with the icon colour though, using this template, it just sets the icon to a white/grey colour with no circle around the icon itself.
"{{ 'green' if is_state(entity, 'off') else 'red' }}"
jetolu
(Jetolu)
January 26, 2023, 2:30pm
5171
Here’s two working samples I’m using to change icon colors based on something:
{% set temp = int(states('sensor.outside_temperature')) %}
{% set color = 'red' if temp >= 20 else 'green' if temp >= 10 else 'light-blue' %}
{{ color }}
Simpler one:
{% if (states('light.living_room') == 'on') %}orange{% endif %}
Robbi-Ho
(Rob)
January 26, 2023, 3:12pm
5172
Maybe this can be a start:
secondary: >
{% if states('binary_sensor.luce_bagno_ping.last_changed') == 'unavailable' %}
indisponibile
{% elif (as_timestamp(states('binary_sensor.luce_bagno_ping.last_changed'))) > 0 %}
{% set sec = as_timestamp(states('binary_sensor.luce_bagno_ping.last_changed')) as_timestamp(now()) %}
{% set hr = (sec / 3600) | int %}
{% set min = sec / 60 - hr * 60 %}
{% if hr > 0 and min > 1 %}
{{"%d" % (hr)}} ora e {{"%2d" % (min)}} minuto
{% elif hr > 0 %}
{% elif min > 1 %}
{{min | int}} minuto
{% endif %}
{% endif %}
cosimop
January 26, 2023, 4:28pm
5173
Thank you @Robbi-Ho , but unfortunately it does not work.
In the dev tools I get this error:
TemplateSyntaxError: expected token 'end of statement block', got 'as_timestamp'
Is there any way to fix this? I think it’s precisely what I need
Thank you for that.
This is possible to change the position of the primary or secondary text in the card?
Use auto entities and filter them
I have CSS styling issues with it. It removes the “3d” float look from cards
kbrown01
(Kbrown01)
January 26, 2023, 8:26pm
5177
Thanks @Holdestmade , I thought I had tried that. Now onto some creating construction. Going to have to build my own media_player source selection card I guess. Getting there with your help!
sparkydave
(🇦🇺 Dave)
January 26, 2023, 10:12pm
5178
Thought I should post the final outcome. The last chip is showing the database file size.
HA Server card
type: custom:stack-in-card
cards:
primary: HA Server
secondary: 'Uptime: {{ states(''sensor.ha_uptime_phrase'') }}'
icon: mdi:server-network
tap_action: none
icon_color: |
{% if states('sensor.cpu_temperature') | int > 80 %}
red
{% elif states('sensor.cpu_temperature') | int > 70 %}
orange
{% elif states('sensor.cpu_temperature') | int > 60 %}
yellow
{% else %}
green
{% endif %}
- type: custom:mushroom-chips-card
chips:
- type: template
entity: sensor.cpu_temperature
content: '{{ states(entity) }} °C'
icon: mdi:thermometer
icon_color: |
red
orange
yellow
{% else %}
green
{% endif %}
tap_action: none
- type: template
entity: sensor.processor_use
content: '{{ states(entity) }} %'
icon_color: |
{% if states('sensor.processor_use') | int > 80 %}
red
{% elif states('sensor.processor_use') | int > 70 %}
orange
{% elif states('sensor.processor_use') | int > 60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
icon: mdi:cpu-64-bit
- type: template
entity: sensor.memory_use_percent
icon: mdi:memory
icon_color: |
{% if states('sensor.memory_use_percent') | int > 80 %}
red
{% elif states('sensor.memory_use_percent') | int > 70 %}
orange
{% elif states('sensor.memory_use_percent') | int > 60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
- type: template
entity: sensor.disk_use_percent
icon: mdi:harddisk
icon_color: |
{% if states('sensor.disk_use_percent') | int > 80 %}
red
{% elif states('sensor.disk_use_percent') | int > 70 %}
orange
{% elif states('sensor.disk_use_percent') | int > 60 %}
yellow
{% else %}
green
{% endif %}
tap_action: none
- type: entity
entity: sensor.db_size
alignment: end
Mrcuddles
(Jelle Smits)
January 26, 2023, 10:20pm
5179
I have created somewhat of a tabcontroller using mushroom cards. I use a input_select helper to change the active tab, but that changes the tabs for everyone. Does anyone have a idea on how to fix this to a per user base?
Would be nice if mushroom had something like this out-of-the-box btw.
Would you mind sharing the code for this card?
You could do it on a user basis by having input helpers for each person, but that would take it quite far. There’s also a tab card in HACS, but it doesn’t really have the mushroom feel.
aarnaegg
(Aaron)
January 27, 2023, 2:40am
5181
Would love to see the code/requirements for this!
Thanks, this ended up working for me
{{ 'green' if is_state('binary_sensor.home_assistant_versions_update_available', 'off') else 'red' }}
queerco
January 27, 2023, 6:03am
5183
happy to share the code but it will be embarrassing, as I’m sure its not elegant and is a total mess! I will have a final look over it and post it up
queerco
January 27, 2023, 6:05am
5184
Yes, I have HAcast linked, but I have an automation that basically ‘resets’ it every 12 hours by telling the cast device to disconnect then playing media > dashboard again (otherwise I found it can be a bit buggy, esp. when you leave the house)
queerco
January 27, 2023, 6:30am
5185
Please be kind haha. Because I have no idea really how to use styles etc, I’ve essentially used stack in cards within stack in cards to bold headers
type: custom:layout-card
mode: grid
cards:
- type: custom:stack-in-card
mode: horizontal
view_layout:
grid-area: top
cards:
mode: horizontal
cards:
- type: custom:simple-clock-card
use_military: true
hide_seconds: true
font_size: 1.5rem
padding_size: 33px
- type: gauge
entity: sensor.the_breville_airactive_3dtm_temperature
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.den_table_strio_socket_4
icon: mdi:fire-circle
show_state: false
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: fan.the_breville_airactive_3dtm
show_state: false
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:air-filter
show_state: false
entity: switch.kitchen_strip_socket_1
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:clouds
entity: scene.den_all_whiite
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:dance-pole
entity: scene.den_hard
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:rocket-launch
entity: scene.den_scene
- type: vertical-stack
cards:
cards:
mode: vertical
cards:
- type: custom:mushroom-light-card
entity: light.dresden_elektronik_conbee_ii_den_lights_zha_group_0x0002
secondary_info: none
primary_info: name
use_light_color: true
show_brightness_control: true
icon: mdi:spotlight-beam
fill_container: false
icon_type: icon
layout: horizontal
mode: vertical
cards:
entity: light.ambient
primary_info: name
icon: mdi:owl
icon_type: icon
layout: horizontal
- square: true
columns: 4
type: grid
cards:
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:dog
entity: switch.kitchen_strip_socket_2
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:led-strip-variant
entity: light.lobby_floor_group
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.table
icon: mdi:table-furniture
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.couch
icon: mdi:sofa-outline
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:panorama-outline
entity: switch.den_table_strio_socket_5
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:pine-tree
entity: light.xmqs
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.send_ramen_light_socket_1
icon: mdi:noodles
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.kitchen_strip_socket_5
icon: mdi:shoe-heel
view_layout:
grid-area: main1
- type: custom:layout-card
layout_type: custom:grid-layout
cards:
- type: media-control
entity: media_player.den
view_layout:
grid-area: SUB1
- square: true
columns: 1
type: grid
cards:
- type: picture
image: https://i.scdn.co/image/ab67706c0000da84ea3ed42af3b7a87d9cfda357
tap_action:
action: call-service
service: media_player.play_media
media_content_id: FV:2/9
enqueue: replace
entity_id: media_player.den
hold_action:
action: none
- type: picture
image: https://i.scdn.co/image/ab67706f00000003296dfaca9d08da66ad668073
tap_action:
media_content_id: FV:2/17
enqueue: replace
hold_action:
action: none
- type: picture
image: https://i.scdn.co/image/ab67616d0000b2737a67ab6d2ae75ae2093447d1
tap_action:
media_content_id: FV:2/15
enqueue: replace
hold_action:
action: none
layout:
grid-template-columns: 84% 16%
grid-template-rows: auto
grid-template-areas: |
"SUB1 SUB2"
view_layout:
grid-area: main2
mode: vertical
view_layout:
grid-area: foot2
cards:
mode: horizontal
cards:
- type: horizontal-stack
cards:
- type: custom:mushroom-entity-card
entity: light.bathroom_group
layout: horizontal
primary_info: none
icon: mdi:bathtub-outline
- type: entities
entities:
- type: custom:paper-buttons-row
buttons:
- entity: binary_sensor.bathroom_motion_6029abfe_ias_zone
layout: state
state_icons:
'off': mdi:lock-open
'on': mdi:lock
state_text:
'off': Vacant
'on': Occupied
styles:
button:
justify-content: flex-start
font-size: 15px
state_styles:
'off':
button:
color: green
'on':
button:
color: red
layout: horizontal
primary_info: none
hide_icon: true
show_color_temp_control: false
show_color_control: false
- square: true
columns: 4
type: grid
cards:
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.bathroom_window
icon: mdi:mirror
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:bathtub
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.kawaii_switch_1
icon: mdi:currency-gbp
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:exit-run
mode: vertical
view_layout:
grid-area: foot3
cards:
mode: horizontal
cards:
cards:
entity: binary_sensor.tuyatec_zn9wyqtr_rh3040_iaszone
icon: mdi:bed
primary_info: none
entity: switch.den_heater_socket
- type: custom:mushroom-fan-card
entity: light.bedroom
layout: horizontal
primary_info: none
hide_icon: true
- square: true
columns: 4
type: grid
cards:
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: switch.wi_fi_power_strip_2_socket_5
icon: mdi:gender-male
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.bedwallgrp
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.desksling
icon: mdi:lamps
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.bedlamps_groip
icon: mdi:arm-flex
mode: vertical
view_layout:
grid-area: foot1
cards:
mode: vertical
cards:
entity: light.greenhouse_group
icon: mdi:blinds-vertical-closed
layout: horizontal
- square: true
columns: 4
type: grid
cards:
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
icon: mdi:syllabary-hiragana
entity: switch.greenhouse_power_socket_5
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.cage_lights
icon: mdi:greenhouse
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.grindr_redux_socket
icon: mdi:drama-masks
- show_name: false
show_icon: true
type: button
tap_action:
action: toggle
entity: light.trion
layout:
grid-template-columns: 34% 33% 33%
"top top top"
"main1 main2 main2"
"foot1 foot2 foot3"
MartinG
(Martin)
January 27, 2023, 9:04am
5186
I have reaf this long topic and I am still not able to figure out such a simple thing.
I am using chip cards in horizontal stack and I need to make the second and fourth chip to occupy only as much space as is the size of icon, so the first and third can use more space.
But I am getting this instead
Is it possible to force size of a chip card?
jono
(Jono)
January 27, 2023, 9:59am
5187
When animating (for example) a fan is it possible to speed up from start, and slow down when turning off like it does in Apple’s Home app?
Existing code that turns on and off ↓
card_mod:
style:
mushroom-shape-icon$: |
ha-icon {
{{ '--icon-animation: spin 1s linear infinite;' if is_state('switch.fan_heater', 'on') }}
LGO44
(LE GALLO)
January 27, 2023, 10:35am
5188
Is it possible to use a mushroom_template_card in a custom:auto-entities?
I try this:
filter:
include:
- domain: sensor
entity_id: sensor.wiser_heating signal
- entity_id: sensor.wiser roomstat _signal
sort:
ignore_case: true
method: entity_id
numeric: false
reverse: false
type: custom:auto-entities
card:
primary: Qualite liaison = {{states(entity_id) }}
secondary: >-
Chemin box = {{state_attr(‘entity_id’,‘hub_route’)}}
