Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
This is how I do it (based on a post in here)
 - type: custom:auto-entities
   card:
     type: grid
     columns: 2
     square: false
   card_param: cards
   sort:
     method: name
   filter:
     include:
       - state: "unavailable"
         options:
           type: custom:mushroom-entity-card
           secondary_info: none
       - state: "Unavailable"
         options:
     exclude:
       - integration: ibeacon
Loved the roborock interface.
Can you share the code for it?
Also, how did you make the Mop Intensity and Route selections?
Sorry, I’m not very good at Node-RED. :sweat_smile: Can you explain how to do this?
Hi
I have a problem, my wife is home all day, what to do…
He he
I have a Person.card showing Home/Not Home, from the mobile… But i thing i’m missing something…
bc. if my wife is out, it still shows her as ā€œHomeā€.
Can someone guide/help me, so when my wife is out, then I can see her as ā€œNot Homeā€?
I do have these sensors:
zone.home
sensor.oneplust8_geocoded_location and sensor.oneplust8_wifi_connection (but both is not updating, these are 6 hours old and don’t track correct in history)
type: custom:mushroom-person-card
entity: person.linda
primary_info: none
use_entity_picture: true
icon_type: entity-picture
entity_picture: /local/......png
card_mod:
  style: |
    mushroom-shape-avatar {
      {{ 'filter: grayscale(100%);' if is_state('device_tracker.oneplust8', 'not_home') }}
you can do s.th like this if this is helpful
filter:
  include:
    - domain: device_tracker
      state: 'home'
      attributes:
        is_wired: false
      options:
        type: custom:mushroom-template-card
        primary: "{{ state_attr(entity , 'friendly_name') }}"
        secondary: >-
          {{ state_attr(entity , 'ip') }} ,
          {{ state_attr(entity , 'essid') }}
        icon: "{{ state_attr(entity , 'icon') }}"
        icon_color: blue
        multiline_secondary: true
        tap_action:
          action: more-info
        badge_icon: mdi:wifi
        badge_color: green
@fellipute, thanks! I will post the whole collective on Github. That is where I keep many of the things I have put together that folks would like to look at. Reason is it’s too much code for here (cards, YAML + Automations + input_selects and such).
The mop intensity, route and vacuum speed are just helpers with the defined set of speeds.You can figure them out from this which is an automation that triggers when one of them changes to set the proper vacuum mode.
alias: Set Vacuum Mode
description: ""
  - platform: state
    entity_id:
      - input_select.vac_mop_intensity
      - input_select.vac_speed
      - input_select.vac_mop_route
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: "{{trigger.entity_id == 'input_select.vac_mop_intensity'}}"
        sequence:
          - service: vacuum.send_command
              command: set_water_box_custom_mode
              params: |
                {% if states("input_select.vac_mop_intensity") == "Off" %}
                  {{ 200 }}
                {% elif states("input_select.vac_mop_intensity") == "Low" %}
                  {{ 201 }}
                {% elif states("input_select.vac_mop_intensity") == "Medium" %}
                  {{ 202 }}
                {% elif states("input_select.vac_mop_intensity") == "High" %}
                  {{ 203}}
                {% endif %}
              entity_id: vacuum.roborock_s7
      - conditions:
            value_template: "{{trigger.entity_id == 'input_select.vac_mop_route'}}"
        sequence:
              command: set_mop_mode
              params: |
                {% if states("input_select.vac_mop_route") == "Standard" %}
                  {{ 300 }}
                {% elif states("input_select.vac_mop_route") == "Deep" %}
                  {{ 301 }}
                {% elif states("input_select.vac_mop_route") == "Deep+" %}
                  {{ 303 }}
                {% endif %}
      - conditions:
            value_template: "{{trigger.entity_id == 'input_select.vac_speed'}}"
        sequence:
            data_template:
              command: set_custom_mode
              params: |
                {% if states("input_select.vac_speed") == "Silent" %}
                  {{ 101 }}
                {% elif states("input_select.vac_speed") == "Balanced" %}
                  {{ 102 }}
                {% elif states("input_select.vac_speed") == "Turbo" %}
                  {{ 103 }}
                {% elif states("input_select.vac_speed") == "Max" %}
                  {{ 104 }}
                {% endif %}
mode: single
I probably could have used trigger.entity_id in the params but that would not save much code.
Try this
card_mod:
  style: |
    {% if not is_state(config.entity, "home") %}
    {% endif %}
I love this thread! So many great ideas and such a helpful community - Rhys you need the Mushroom equivalent of a Nobel Prize good sir :slight_smile:
Hopefully you all might be able to assist me in this one:
I’m trying to build this button here (mocked up)
intended
However the bes I’ve managed to do is this:
original
I’ve built the above using the following yaml:
type: custom:stack-in-card
mode: horizontal
cards:
    primary: Master Bedroom
    secondary: |-
      Current {{states ('sensor.master_bedroom_current_temp')}} °C
      Target {{states ('sensor.master_bedroom_target_temp')}} °C
    icon: mdi:bed-king
    layout: vertical
    icon_color: yellow
    fill_container: false
    card_mod:
      style: |
        :host {
          --ha-card-border-color: rgba(0,0,0,0);
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        double_tap_action:
          action: none
        entity: sensor.master_bedroom_faults
        icon: |-
          {% set state=states('sensor.master_bedroom_faults') %}
          {% if state=='Nil' %}
          mdi:check
          {% else %}
          mdi:exclamation-thick
          {% endif %}
        icon_color: |-
          green
          {% else %}
          red
          {% endif %}
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        entity: sensor.master_bedroom_mode
        icon: |-
          {% set state=states('sensor.master_bedroom_mode') %}
          {% if state=='FollowSchedule' %}
          mdi:calendar-check
          {% else %}
          mdi:calendar-alert
          {% endif %}
        icon_color: |-
          green
          {% else %}
          red
          {% endif %}
        tap_action:
          action: none
        hold_action:
          action: none
    card_mod:
      style: |
        .chip-container {
          flex-flow: column !important;
What I can’t work out is how to essentially adjust the column sizes on the stack-in-card so that the mushroom template card takes up 3/4 of the space and the chip cards only take up the necessary portion.
Is it that even the right method to achieve it?
I’m not sure if it’s relevant but the button will be part of a 2x2 grid of the same buttons for the different rooms in my house.
I’ve trawled this topic and fiddled around plenty so my apologies for any frustration caused if it’s an easy answer. I just can’t seem to figure it out! Many thanks guys
I styled about 9 chips on a chip card that are all warnings, ie outdoor motion, water leaks, garbage day, etc, but when I converted them to conditional chips, the styling stopped working. I currently have the card_mod at the parent level, so not sure if there is mushroom-conditional-chip, option or if I have to switch to styling the child method.
@rhsyb you bloody legend. Is there a way to clean up the pixelation in the radial?
Windows (Edge):
Printer
iOS:
Or is depending on the browser?
You can add a slight blur between the colors to reduce the jaggies, like this:
background: radial-gradient(var(--card-background-color) 60%, transparent calc(60% + 1px)), conic-gradient(rgb(var(--rgb-{{ config.icon_color }})) {{ (states(config.entity) |float * 100) | round(0) }}% 0%, var(--card-background-color) 0% 100%);
Adding a Conditional Chip changes the selector. Have a look here:
@rhysb Perfect! Cheers legend!
Can you share your code ?
Sure.
mode: horizontal
cards:
    icon: mdi:water
    icon_color: blue
    layout: vertical
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    secondary: '{{states((entity))}} %'
    multiline_secondary: false
    entity: sensor.mfc_9340cdw_cyan_toner_remaining
    card_mod:
      style:
        mushroom-shape-icon$: |
          .shape {
              background: radial-gradient(var(--card-background-color) 60%, transparent calc(60% + 1px)), conic-gradient(rgb(var(--rgb-{{ config.icon_color }})) {{ (states(config.entity)) }}% 0%, var(--card-background-color) 0% 100%);
          .shape:after {
            content: "";
            height: 100%;
            width: 100%;
            position: absolute;
            border-radius: var(--icon-border-radius);
            background: rgba(var(--rgb-{{ config.icon_color }}), 0.2);
    icon: mdi:water
    icon_color: red
    layout: vertical
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    entity: sensor.mfc_9340cdw_magenta_toner_remaining
    card_mod:
      style:
          .shape {
          .shape:after {
            content: "";
            height: 100%;
            width: 100%;
            position: absolute;
    icon: mdi:water
    icon_color: yellow
    layout: vertical
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    entity: sensor.mfc_9340cdw_yellow_toner_remaining
    card_mod:
      style:
          .shape {
          .shape:after {
            content: "";
            height: 100%;
            width: 100%;
            position: absolute;
    icon: mdi:water
    icon_color: disabled
    layout: vertical
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    entity: sensor.mfc_9340cdw_black_toner_remaining
    card_mod:
      style:
          .shape {
          .shape:after {
            content: "";
            height: 100%;
            width: 100%;
            position: absolute;
    icon: mdi:printer-3d-nozzle
    icon_color: green
    layout: vertical
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    entity: sensor.mfc_9340cdw_fuser_remaining_life
    card_mod:
      style:
          .shape {
          .shape:after {
            content: "";
            height: 100%;
            width: 100%;
            position: absolute;
Try something like this:
mode: horizontal
cards:
    secondary: |-
    icon: mdi:bed-king
    layout: vertical
    icon_color: yellow
    card_mod:
      style: |
        ha-card {
          width: 200%;
          --ha-card-border-width: 0;
    chips:
      - type: template
        double_tap_action:
          action: none
        icon: |-
          mdi:check
          {% else %}
          {% endif %}
        icon_color: |-
          green
          {% else %}
          red
          {% endif %}
        tap_action:
          action: none
        hold_action:
          action: none
      - type: template
        icon: |-
          mdi:calendar-check
          {% else %}
          mdi:calendar-alert
          {% endif %}
        icon_color: |-
          green
          {% else %}
          red
          {% endif %}
        tap_action:
          action: none
        hold_action:
          action: none
    card_mod:
      style: |
        ha-card {
          position: absolute;
          right: 4px;
          top: calc(25% - 6px);
        .chip-container {
Could you kindly tell me how to set the measurements of a person card?
you probably have to look at ease-in and ease-out
or check what the great Another take author did:
icon_fan2:
  styles:
    custom_fields:
      icon:
        - width: 75%
        - margin-left: -3%
  custom_fields:
    icon: >
        const path = `
          <circle cx="25" cy="25" r="6.6"/>
          <path d="M31.9 30.4c-.5.6-1.1 1.1-1.7 1.5-1.4 1.1-3.2 1.7-5.2 1.7-2.3 0-4.5-.9-6-2.4-.9 1.1-1.6 2.3-2.3 3.2l-4.9 5.4c-1.8 2.7.3 5.6 2.5 7 3.9 2.4 9.8 3.1 14.1 1.9 4.6-1.3 7.9-4.7 7.4-9.7-.2-3.4-1.9-6-3.9-8.6zM17 28.3c-.4-1-.6-2.1-.6-3.3a8.7 8.7 0 0 1 6.4-8.4l-1.6-3.5L19 6.2c-1.5-2.8-5-2.5-7.3-1.2-4 2.2-7.5 6.9-8.7 11.3-1.2 4.6.2 9.2 4.7 11.3 3.1 1.3 6.1 1.2 9.3.7zm26.9-17.6c-3.3-3.4-8-4.6-12.1-1.8-2.8 1.8-4.2 4.6-5.5 7.5 4.2.6 7.4 4.2 7.4 8.6 0 .9-.1 1.7-.4 2.5 1.3.2 2.8.3 3.8.4 2.3.4 4.7 1.3 7.1 1.7 3.2.3 4.7-3 4.8-5.6.3-4.6-1.9-10.1-5.1-13.3z"/>
        const style = `
          <svg viewBox="0 0 50 50">
            <style>
              @keyframes rotate {
                0% {
                  visibility: visible;
                  transform: rotate(0deg) translateZ(0);
                100% {
                  transform: rotate(1080deg) translateZ(0);
              .start {
                animation: rotate 2.8s ease-in;
                transform-origin: center;
                fill: #5daeea;
                visibility: hidden;
                will-change: transform;
              .on {
                animation: rotate 1.8s linear infinite;
                fill: #5daeea;
                animation-delay: 2.8s;
                visibility: hidden;
              .end {
                animation: rotate 2.8s;
                fill: #9ca2a5;
                animation-timing-function: cubic-bezier(0.61, 1, 0.88, 1);
              .start_timeout {
                fill: #5daeea;
                visibility: hidden;
              .end_timeout {
                fill: #9ca2a5;
            </style>
        if (variables.state === 'on' && variables.timeout < 2000) {
          return `${style}<g class="start">${path}</g><g class="on">${path}</g></svg>`;
        if (variables.state === 'off' && variables.timeout < 2000) {
          return `${style}<g class="end">${path}</g></svg>`;
        if (variables.state === 'on' && variables.timeout > 2000) {
          return `${style}<g class="start_timeout">${path}</g></svg>`;
        } else {
          return `${style}<g class="end_timeout">${path}</g></svg>`;
oh that is nice! thanks for sharing.
I anchored it a bit (and took out some superflous () ):
type: custom:hui-element
card_type: horizontal-stack
cards:
  - entity: sensor.epson_ink_level_black
    icon_color: black
    <<: &card
      icon: mdi:water
      layout: vertical
      tap_action:
        action: more-info
      hold_action:
        action: none
      double_tap_action:
        action: none
      secondary: >
        {{states(entity)}} %
      card_mod:
        style:
            .shape {
                            conic-gradient(rgb(var(--rgb-{{config.icon_color}})) {{states(config.entity)}}% 0%,
            .shape:after {
              content: "";
              height: 100%;
              width: 100%;
              position: absolute;
              background: rgba(var(--rgb-{{config.icon_color}}), 0.2);
  - entity: sensor.epson_ink_level_cyan
    icon_color: cyan
    <<: *card
  - entity: sensor.epson_ink_level_magenta
    icon_color: pink
    <<: *card
  - entity: sensor.epson_ink_level_yellow
    icon_color: yellow
    <<: *card
  - entity: sensor.epson_ink_level_waste
    <<: *card
Didnt yet set the box shadow to none because for testing purposes I want it to stick out still (I dont want to use stack-in-card)
Note I had to use ā€˜pink’ for my magenta cartridge. Which was a bit of a surprise since magenta is an official htmlcolor name.
btw, look what’s happening, its flashing constantly
Jan-28-2023 16-46-07
now trying to do the same for regular tile card, but that hasn’t been my luck yet. not sure how to find the correct dom on that.
      type: tile
      icon: mdi:water
      vertical: true
      tap_action:
        action: more-info
      hold_action:
        action: none
      double_tap_action:
        action: none
      card_mod:
        style:
          ha-tile-icon$: |
            .shape {
            .shape:after {
              content: "";
              height: 100%;
              width: 100%;
              position: absolute;
This is the neatest room card I’ve personally seen so far with the left icon linking to the room page and the light button turning on the room lights, perhaps with the light % changed to the room temp would be good too. I’ve seen this image posted a few times in this thread but for the life of me I can’t find if anyone has posted any yaml for it! If anyone has then I’d appreciate a link! Thanks.
