Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Did you try setting a blank character as secondary info (other than space, just google and copy)?
that worked, thanks! I ended up copying from here: https://emptycharacter.com/
I would like to reduce this distance, can someone help me do this?
Schermafbeelding 2023-02-07 000304
type: custom:stack-in-card
keep:
  box_shadow: false
  border_radius: true
  margin: false
  outer_padding: false
  background: true
cards:
	entity: weather.buienradar
	icon: mdi:weather-night
	icon_color: '#03A9F4'
	layout: vertical
	card_mod:
	  style: |
		:host {
		  --mush-icon-size: 90px;
  - type: custom:mushroom-title-card
	title: '{{ states.weather.buienradar.attributes["temperature"] }} Ā°C'
	subtitle: '{{ states.weather.buienradar.attributes["humidity"] }} %'
	alignment: center
I am looking for mushroom card examples where people are using it to represent a room with inset buttons for multiple devices.
Iā€™ve seen a few like these, but they are good for only maybe 2 buttons while maintaining proper spacing:
So would love to see example cards others have created for this purpose as I think this could help me avoid making different dashboards per room when most of my rooms have <=4 device toggles.
Try like this:
type: entities
entities:
  - type: custom:fold-entity-row
    head:
      type: custom:mushroom-entity-card
      entity: group.nuvole_giorno
      icon: mdi:script-outline
      icon_color: light-blue
    padding: 0
    entities:
      - type: custom:auto-entities
        filter:
          include:
            - group: group.nuvole_giorno
              options:
                tap_action: null
        card:
          type: custom:layout-card
          cards: []
          layout_type: masonry
        sort:
          method: first
    card_mod:
      style: |
        :host {
          --masonry-view-card-margin: -12px 8px 0px 8px;
          --ha-card-border-width: 0;
          --ha-card-background: none;
          --ha-card-box-shadow: 0;
card_mod:
  style:
    fold-entity-row$: |
      ha-icon {
        background: none !important;
        margin-right: 24px !important;
        --toggle-icon-width: 21px !important;
        color: rgb(var(--rgb-disabled-color));
      .card-content {
        padding: 0;
        margin: 0 !important;
You can do away with the stack-in-card and achieve the same look like this:
type: custom:mushroom-template-card
layout: vertical
primary: >-
  {{ state_attr(entity, "temperature")
  }} Ā°C
secondary: >-
  {{ state_attr(entity, "humidity") }}
card_mod:
  style: |
    :host {
      --mush-card-primary-font-size: 24px;
      --mush-card-primary-font-weight: normal;
      --mush-card-secondary-font-size: 16px;
      --mush-card-secondary-font-weight: normal;
Please would you share your code for these room cards?
They arenā€™t room cards per se, but here is my room light card, hot tub, and vacuum card. They have multiple buttons. I pretty much only use mobile so to have multiple pieces of info and still be readable I had to go full width of a card.
When i change the temperature it will change to ā€œheatingā€. I need this button to put it back to the automatic scheme again.
Would you mind sharing your code? It looks really nice.
Thank you!
A quick question. How do I remove the background ā€˜discā€™ behind the icon?
Schermafbeelding 2023-02-07 131201
I like this shows the entire artwork. I copied it and tested but though I see no errors I am only seeing this -
Not sure what I am missing.
Hello!!! Very simple for some I wold guess. How can I make a widther room for the left card and reduce the space for the right one?
Instead of 50%-50% something like 60%-40%.
vent
mode: horizontal
cards:
    primary: Ventilador Techo
    secondary: >-
      {% if is_state('fan.fan_1', 'on') %}
      {{state_attr('fan.fan_1','percentage')}}% - Timer:
      {% set timer = 'timer.fan_1_runing_timer' %}
      {% set ct =
      ((as_timestamp(state_attr(timer,'finishes_at'))-as_timestamp(now()))/60)|int|round(0)%}
      {% if ct > 60 %}{{ ct // 60 }}:{{ '{:0>2d}'.format(ct%60) }}{% else %}
      {{ct}}{% endif %} min.
      {% else %}
      Apagado
      {% endif %}
    icon: mdi:fan
    entity: fan.fan_1
    icon_color: |-
      green
      {% else %}
      grey
      {% endif %}
    fill_container: true
  - type: custom:stack-in-card
    mode: vertical
    cards:
        mode: horizontal
        cards:
            primary: ''
            secondary: ''
            icon: |-
                mdi:sun-thermometer
              {% endif %}
            entity: input_select.fan_1_direction
            icon_color: |-
              {% if is_state('input_select.fan_1_direction', 'forward') %}
                orange
              {% endif %}
            layout: vertical
            tap_action:
              action: call-service
              service: fan.set_direction
                direction: forward
                entity_id: fan.fan_1
            primary: ''
            secondary: ''
            icon: |-
                mdi:snowflake-thermometer
              {% endif %}
            icon_color: |-
              {% if is_state('input_select.fan_1_direction', 'reverse') %}
                blue
              {% endif %}
            layout: vertical
            tap_action:
                direction: reverse
            multiline_secondary: false
card_mod:
  style: |
    ha-card {
      --ha-card-border-width: 1;
Well, fixed the cover art issue. Was missing the setting for the mini media player.
I followed your changings but nothing changedā€¦ i still have the icons outside the margins of the card, just like the screenshot i quotedā€¦
Awsome!
Could i request i animation for a car when in use.
Perhaps: mdi:car-hatchback, so its in profile.
How do you develop theses animations?
For my cards that I want 60%/40% I use the custom layout card:
Basic:
layout_type: custom:grid-layout
layout:
  grid-template-columns: 60% 40%
  margin: 0px
  padding: 0px
cards:
    stuff...
    stuff...
Here is my complete card that has a 60/40 split and then has inside the second one more stuff. I wrap everything in a vertical stack in card so the background and border goes around everything
Example Card 2
type: custom:vertical-stack-in-card
cards:
  - type: custom:layout-card
    layout:
      margin: 0px
      padding: 0px
    cards:
        primary: Garage
        entity: group.all_garage_doors
        icon: mdi:garage
        icon_color: grey
        tap_action:
          action: none
        hold_action:
          action: none
        double_tap_action:
          action: none
        secondary: ''
        card_mod:
          style:
              ha-card {
                border:0px;
                box-shadow: none;
      - type: custom:mushroom-chips-card
        alignment: end
        chips:
          - type: template
            entity: cover.garage1_door
            tap_action:
              service: cover.toggle
              data: {}
                entity_id: cover.garage1_door
            icon: |
              {% if is_state(config.entity, "open") -%}
                 mdi:garage-open
              {%- else -%}
                mdi:garage
              {%- endif %}
            icon_color: |
                 deep-orange
              {%- else -%}
                grey
              {%- endif %}
            content: Garage 1
            card_mod:
              style:
                  ha-card {
                    {% if is_state(config.entity,'open') %}
                      --text-color: rgb(var(--rgb-white));
                      --icon-color:  rgb(var(--rgb-white));
                      background-color: rgba(var(--rgb-red), 0.2) !important;
                    {% else %}
                      --text-color: rgb(var(--rgb-grey));
                      --icon-color: rgb(var(--rgb-grey));
                      background-color: rgba(var(--rgb-disabled),0.10) !important;
                    {% endif %}
                    border: 0px;
          - type: template
            entity: cover.garage2_door
            tap_action:
              data: {}
                entity_id: cover.garage2_door
            icon: |
                 mdi:garage-open
              {%- else -%}
                mdi:garage
              {%- endif %}
            icon_color: |
                 deep-orange
              {%- else -%}
                grey
              {%- endif %}
            content: Garage 2
            card_mod:
              style:
                  ha-card {
                    {% else %}
                    {% endif %}
                    border: 0px;
        style: |
          .chip-container {
                  padding-right: 08px;
                  padding-top: 15px;
                  padding-bottom: 4px;
I was wondering if it is possible to add an effects control to the light card with a dropdown list. All of my lights are configured with numerous scenes and it would be great to be able to access them from the light card. If this is not possible, how do you create an input select card with a dropdown list of the input select options similar to the home assistant default (and very clunky) entities card? Iā€™m guessing it is possible with the template card but I canā€™t determine how to do so.
Thereā€™s probably a better way, but hereā€™s how I did an effects list for my WLED strip.
If you need to create the effects list as an entity, this goes in configuration.yaml and reference your light with the effects.
template:
  select:
    - name: "Example select: WLED effect"
      state: "{{ state_attr('light.wled', 'effect') }}"
      options: "{{ state_attr('light.wled', 'effect_list') }}"
      select_option:
        service: light.turn_on
          entity_id: light.wled
          effect: "{{ option }}"
Example Card with the light card and select card
cards:
  - type: custom:mushroom-light-card
    entity: light.wled
    show_brightness_control: true
    show_color_control: true
    use_light_color: true
    layout: horizontal
    show_color_temp_control: false
    primary_info: name
    collapsible_controls: true
    icon: mdi:led-strip-variant
  - type: custom:mushroom-select-card
    entity: select.example_select_wled_effect
    icon: none
    primary_info: none
    secondary_info: none
    icon_type: none
please share the code for this
