Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Something like this:
      - type: custom:mushroom-chips-card
        chips:
          - type: template
            icon: mdi:washing-machine
            icon_color: orange
            entity: switch.washing_machine
          - type: template
            icon_color: orange
        card_mod:
          style:
            mushroom-template-chip:nth-child(2)$: |
              ha-icon {
                {{ 'animation: shake 400ms ease-in-out infinite;' if is_state('sensor.washing_machine', 'on') }}
                transform-origin: 50% 58%;
                clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
              @keyframes shake {
                0%, 100% { transform: translate(0, 0) rotate(0); }
                20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
                40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
                60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
                80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
            mushroom-template-chip:nth-child(3)$: |
              mushroom-chip {
                cursor: default !important;
              ha-icon {
                position: absolute;
                left: -35px;
                {{ 'animation: spin 1s linear infinite;' if is_state('sensor.washing_machine', 'on') }}
                clip-path: circle(21.7% at 50% 58%);
              @keyframes spin {
                100% { transform: rotate(360deg); }
              ha-card {
                --chip-box-shadow: none;
        alignment: center
Can you try and explain a bit more what you are wanting here?
Need some help with a template card.
Have a template card, that shuts down and power on (wol) my unRAID server.
In general the card works.
When pushing the button, it takes around 30 seconds until its powered down and the state changes. Is it possible to have the secondary info showing in that time, that the server gets powered off until the state changes to powered off? And also, when its powered off the other way?
Actually my state change is:
{% if is_state(‘switch.unraid’, ‘on’) %}
Powered On
{% else %}
Powered Off
{% endif %}
Hope you can help. :slight_smile:
Hey. I`ve copied my question once again. Maybe someone will have solution for it?
Hoping someone can help with a browser_mod.popup issue, interestingly I’m sure the following code use to work but a recent release broke it.
When I add the following code directly on a dashboard its formatted as I want it:
type: vertical-stack
cards:
  - square: false
    columns: 2
    type: grid
    cards:
      - type: custom:vertical-stack-in-card
        style: |
          ha-card {
             margin: 20px 0px 0px 20px;
             padding-left: 20px;
             padding-right: 20px;
        cards:
            style: |
              ha-card {
                 background: transparent;
                 margin: 0px -10px 0px;
            primary: Open
            secondary: >-
              {% if is_state('switch.nodered_blinds_livingroom_morning', 'on')
               Enabled
              {% else %}
                Disabled
              {% endif %}
            icon: mdi:alarm
            entity: ''
            icon_color: >-
               blue
              {% else %}
                grey
              {% endif %}
            tap_action:
              action: call-service
              service: switch.toggle
              data: {}
                entity_id: switch.nodered_blinds_livingroom_morning
          - type: custom:layout-card
            layout_type: masonry
            layout:
              width: 221
              max_cols: 1
              height: auto
              padding: 0px
              card_margin: var(--masonry-view-card-margin, 0px 0px 0px)
            chips:
              - type: template
                card_mod:
                  style: |
                    ha-card {
                icon: mdi:minus
                tap_action:
                  service: script.automation_livingroom_blinds_morning_decrease
              - type: template
                card_mod:
                  style: |
                    ha-card {
                      --chip-background: transparent;
                entity: input_datetime.automation_blind_evening_livingroom
                content: >-
                  {{(state_attr('input_datetime.automation_blind_morning_livingroom','timestamp'))
                  | timestamp_custom('%H:%M', false) }}
                tap_action:
                  action: more-info
              - type: template
                card_mod:
                  style: |
                    ha-card {
                icon: mdi:plus
                tap_action:
                  service: script.automation_livingroom_blinds_morning_increase
            alignment: center
            card_mod:
              style: |
                ha-card {
                  margin: -2px 0px 12px;
                  --chip-border-width: 0;
                  --chip-border-radius: 12px;
                  --chip-height: 40px;
                  --chip-padding: 12px;
                  --chip-spacing: 1px;
        style: |
          ha-card {
             margin: 20px 20px 0px 0px;
             padding-left: 20px;
        cards:
            style: |
              ha-card {
            primary: Close
            secondary: >-
              {% if is_state('switch.nodered_blinds_livingroom_evening', 'on')
               Enabled
              {% else %}
                Disabled
              {% endif %}
            icon: mdi:alarm
            entity: ''
            icon_color: >-
               blue
              {% else %}
                grey
              {% endif %}
            tap_action:
              data: {}
                entity_id: switch.nodered_blinds_livingroom_evening
            layout:
              width: 221
              max_cols: 1
              height: auto
              padding: 0px
            chips:
              - type: template
                card_mod:
                  style: |
                    ha-card {
                icon: mdi:minus
                tap_action:
                  service: script.automation_livingroom_blinds_evening_decrease
              - type: template
                card_mod:
                  style: |
                    ha-card {
                content: >-
                  {{(state_attr('input_datetime.automation_blind_evening_livingroom','timestamp'))
                tap_action:
                  action: more-info
              - type: template
                card_mod:
                  style: |
                    ha-card {
                icon: mdi:plus
                tap_action:
                  service: script.automation_livingroom_blinds_evening_increase
            alignment: center
            card_mod:
              style: |
                ha-card {
However, if I use the same code in a browser_mod.popup it comes out like this:
It seems to be the popup doesn’t like the first vertical-stack?
You can combine the Mushroom Light and Select cards like this.
Mushroom Light Preset Card:
type: custom:stack-in-card
cards:
  - type: custom:mushroom-light-card
    entity: light.led_matrix
    show_brightness_control: true
    use_light_color: true
    show_color_control: true
    card_mod:
      style: |
        ha-card {
          --ha-card-border-width: 0;
  - type: custom:mushroom-select-card
    entity: select.led_matrix_preset
    icon_type: none
    secondary_info: none
    primary_info: none
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 0px;
          right: 0px;
          width: 50%;
card_mod:
  style: |
    :host {
      border-radius: var(--ha-card-border-radius, 12px);
      background: var(--card-background-color);
    ha-card {
      overflow: visible !important;
      {% if is_state('light.led_matrix', 'on') %}
        background: {{ '#%02x%02x%02x13' % state_attr('light.led_matrix', 'rgb_color') }};
      {% endif %}
It is mostly documented in the Mushroom Themes Github. Additional variables can be discovered by digging in to the code or CSS.
I would like to have an animation like this when I press the button to open the gate
N.B. The switch is configured at 300ms but I would like the animation to last 2/3 seconds
This gif is the animation of the home assistant widget
Screen_Recording_20230220_121508_One-UI-Home_1
Any way to change the primary and secondary text color? I tried:
--primary-text-color: "FF0000"
--secondary-text-color: "00FF00"
But, that doesn’t have any effect:
Try:
--primary-text-color: #FF0000;
--secondary-text-color: #00FF00;
or something like this:
card_mod:
  style: |
    mushroom-card {
      --primary-text-color: red;
      --card-primary-font-size: 40px;
I wonder if anyone can help me troubleshoot a difference between Firefox on Windows and iOS Companion app displaying the same card differently? On Firefox the card displays correctly but on iOS the circle that should surround the kitchen icon is squased. The same problem happens on iOS Safari…
Capture
ios
cards:
    chips:
      - type: template
        icon: mdi:door
        icon_color: >-
          {% if is_state('binary_sensor.back_door_sensor_magnet_on_off','on') %}
            red
          {% elif is_state('binary_sensor.back_door_sensor_magnet_on_off','off')
            green
          {% else %}
            disabled
          {% endif %}
      - type: template
        icon: |-
          {% if is_state('binary_sensor.kitchen_motion_group','on') %}
            mdi:motion-sensor
          {% else %}
            mdi:walk
          {% endif %}
        icon_color: |-
            red
          {% elif is_state('binary_sensor.kitchen_motion_group','off') %}
            green
          {% else %}
            disabled
          {% endif%}
      - type: template
        icon: mdi:thermometer
        icon_color: orange
        use_entity_picture: false
        content: '{{ states("sensor.kitchen_sensor_temperature")  |round(1) }}C'
        entity: sensor.kitchen_sensor_temperature
      - type: template
        icon: mdi:water-percent
        icon_color: light-blue
        content: '{{ states("sensor.kitchen_sensor_humidity")  |round() }}%'
        entity: sensor.kitchen_sensor_humidity
    alignment: center
    card_mod:
      style:
        mushroom-template-chip:nth-child(1)$: |
          ha-icon {
            {{ 'animation: open 6s ease-in-out infinite;' if is_state('binary_sensor.back_door_sensor_magnet_on_off', 'on') }}
            transform-origin: 30%;
          @keyframes open {
            0%, 66% { transform: rotateY(0deg); }
            33% { transform: rotateY(-120deg); }
          .shape {
            perspective: 45px;
          ha-icon {
            {{ 'animation: clip 2s infinite;' if is_state('binary_sensor.kitchen_motion_group', 'on') }}
          {% if is_state('binary_sensor.kitchen_motion_group', 'on') %}
            @keyframes clip {
              50% { clip-path: polygon(0 0, 55% 0, 100% 100%, 0 100%); }
            .shape {
              animation: motion 2s linear infinite;
            @keyframes motion {
              0%, 100% { --shape-color: rgba(var(--rgb-red), 0.3); }
              50% { --shape-color: rgba(var(--rgb-red), 0.2); }
          {% endif %}
          ha-card {
            --chip-background: none;
            --chip-spacing: 0;
            padding-top: 5px;
    primary: Kitchen
    icon: mdi:countertop-outline
    tap_action:
      action: navigate
      navigation_path: /lovelace/kitchen
    card_mod:
      style:
        mushroom-state-info$: |
          .primary {
            font-size: 20px !important;
            position: absolute;
            top: 0px;
            left: 75px;
            white-space: normal !important;
        mushroom-shape-icon$: |
          .shape {
            position: relative;
            left: -30px;
            top: -0px;
            height: 20px;
            {% if is_state('light.kitchen_light_group', 'on') %}
               --shape-color: rgba(var(--rgb-orange), 0.25);
               --icon-color: rgba(var(--rgb-white), 1);
            {% endif %}
          :host {
            --mush-icon-size: 120px;
            --primary-text-color: #a0a0a0
          ha-card {
            height: 75px !important;
  - type: custom:stack-in-card
    cards:
      - type: grid
        square: false
        columns: 3
        cards:
            entity: cover.kitchen_blind
            icon: |-
              {%  if is_state ('cover.kitchen_blind', 'open') %}
                mdi:blinds-open
              {% else %}
                mdi:blinds
               {% endif %}
            icon_color: |-
                grey
              {% else %}
               purple
               {% endif %}
            primary_info: none
            layout: vertical
            tap_action:
              action: toggle
            entity: input_select.dishwasher_state_machine
            icon: mdi:dishwasher
            icon_color: '{{ ''light-blue'' if is_state(entity, ''job_ongoing'') else '''' }}'
            primary_info: none
            layout: vertical
            card_mod:
              style:
                  ha-icon {
                    {{ '--icon-animation: bounce 1.5s ease-in-out infinite, wash 1s ease-in-out infinite;' if states('sensor.dishwasher_powee') | int > 5 }}
                    transform-origin: 50% 75%;
                  @keyframes bounce {
                    0%, 20%, 50%, 80%, 100% {transform: translateY(0); }
                    40% { transform: translateY(-1.2px) rotate(5deg); }
                    60% { transform: translateY(-1.1px) rotate(-4deg); }
                  @keyframes wash {
                    50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
                  ha-card:active {
                    background: rgba(var(--rgb-disabled), 0.1);
                    transform: scale(0.975);
                    transition: 0s;
            icon: mdi:speaker
            entity: media_player.kitchen_sonos
            icon_color: '{{ ''green'' if is_state(entity, ''playing'') else ''disabled'' }}'
            primary_info: none
            layout: vertical
            card_mod:
              style:
                  .shape {
                    --icon-animation: beat 1.3s ease-out infinite both;
                    transform-origin: 50% 60%;
                  @keyframes beat {
                    0% { transform: scale(1); }
                    10% { transform: scale(1.1); }
                    17% { transform: scale(1.05); }
                    33% { transform: scale(1.25); }
                    60% { transform: scale(1); }
      - type: grid
        square: false
        columns: 1
        cards:
            cards:
                layout_type: custom:grid-layout
                layout:
                  grid-template-columns: auto 33px
                  margin: '-4px -4px -8px -4px;'
                cards:
                    primary: Kitchen
                    icon: mdi:toggle-switch-outline
                    entity: light.kitchen_light_group
                    icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''disabled'' }}'
                    fill_container: false
                    multiline_secondary: false
                    card_mod:
                      style: |
                        ha-card {
                          background: none;
                          --ha-card-box-shadow: 0px;
                    entity: input_boolean.kitchen_lights
                    primary: ''
                    secondary: ''
                    icon: >-
                      {{ 'mdi:chevron-up' if is_state(entity, 'on') else
                      'mdi:chevron-down' }}
                    icon_color: disabled
                    hold_action:
                      action: none
                    card_mod:
                      style: |
                        ha-card {
                          align-items: flex-end;
                          background: none;
                        mushroom-shape-icon {
                          --shape-color: none !important;
              - type: conditional
                conditions:
                  - entity: input_boolean.kitchen_lights
                    state: 'on'
                card:
                  columns: 4
                  mode: horizontal
                  keep:
                    background: true
                    border_radius: true
                    margin: true
                  cards:
                      entity: light.kitchen_spotlights
                      icon: mdi:lightbulb-spot
                      primary_info: none
                      layout: vertical
                      card_mod: null
                      style: |
                        ha-card {
                          box-shadow: 0px 0px;
                      entity: light.kitchen_leds
                      icon: |-
                        {% if is_state('light.kitchen_leds','on') %}
                          mdi:led-strip-variant
                        {% else %}
                          mdi:led-strip-variant-off
                        {% endif %}
                      show_brightness_control: false
                      show_color_control: false
                      collapsible_controls: false
                      primary_info: none
                      layout: vertical
                      card_mod:
                        style: |
                          ha-card:active {
                            transition: 0s;
                            {% if is_state(config.entity, 'on') %}
                              --card-mod-icon: mdi:led-strip-variant;
                            {% else %}
                              --card-mod-icon: mdi:led-strip-variant-off;
                            {% endif %}
                      entity: light.kitchen_wall_leds
                      collapsible_controls: true
                      primary_info: none
                      layout: vertical
                      card_mod:
                        style: |
                              --card-mod-icon:
                              {% set light_level = ((state_attr(config.entity, "brightness") / 255) * 10) | round(0) * 10 %}
                              {% if light_level == 100 %}
                                mdi:lightbulb-on
                              {% elif light_level > 0 %}
                                mdi:lightbulb-on-{{ light_level }}
                              {% else %}
                                mdi:lightbulb-on-outline
                              {% endif %};
                            {% else %}
                              --card-mod-icon: mdi:lightbulb-outline;
                            {% endif %}
                          ha-card {
                      entity: light.kitchen_ceiling_leds
                      primary_info: none
                      layout: vertical
                      card_mod:
                        style: |
                              --card-mod-icon:
                                mdi:lightbulb-on
                              {% else %}
                              {% endif %};
                            {% else %}
                            {% endif %}
                          ha-card {
                state_color: true
                show_header_toggle: false
Credit for the card goes to @danwooller
Thanks! It works :slight_smile:
That is perfect! Thank you!
EDIT: Actually, this is not working for me. The select card is still showing below the light card and the select options are still constrained. I copied your code exactly and replaced with my own entities. Thoughts?
EDIT 2: Nevermind. I just needed to add card-mod to my frontend. Thanks again!
2023-02-20 08_44_01-Window
cards:
    entity: light.office_light
    card_mod:
      style: |
        ha-card {
    entity: input_select.office_light
    icon_type: none
    primary_info: none
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 0px;
          right: 0px;
          width: 50%;
card_mod:
  style: |
    :host {
    ha-card {
      {% if is_state('light.office_light', 'on') %}
        background: {{ '#%02x%02x%02x13' % state_attr('light.office_light', 'rgb_color') }};
      {% endif %}
When using the humidity card, is there a way to offset the output value?
I have a small zigbee humidifier inside of my cigar humidor that works great but it reads 3% higher than what the humidity actually is.
This is actually really great. It is exactly what I was looking for with my lights. The background color is a nice touch.
I was also able to use the same technique to modify the fan card with fan presets. Of course I’m not skilled enough to quickly modify the fancy backround css but it is exactly what I needed.
2023-02-20 09_55_13-Window
cards:
  - type: custom:mushroom-fan-card
    entity: fan.living_room_fan
    icon_animation: true
    show_percentage_control: false
    show_oscillate_control: false
    card_mod:
      style: |
        ha-card {
    entity: input_select.living_room_fan_preset_mode
    icon_type: none
    primary_info: none
    card_mod:
      style: |
        ha-card {
          position: absolute;
          top: 0px;
          right: 0px;
          width: 50%;
card_mod:
  style: |
    :host {
    ha-card {
Pasted complete and only the entity: changed to a sensor from my system :upside_down_face:
Do you have card-mod installed?
No :upside_down_face:
Remove the height: 20px like this:
          .shape {
            position: relative;
            left: -30px;
            top: 0px;
            {% endif %}
Try using stack-in-card instead of vertical-stack-in-card.
