Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
hi.
i have done this card.
everything fine!
what did i have to change in this code to have NO number in the Chip.
i`ll have only the icon!
Screenshot 2023-02-20 211147
- type: conditional
            conditions:
              - entity: cover.shellyswitch25_10521c072531
                state: closed
            chip:
              type: template
              icon_color: amber
              icon: mdi:window-shutter
              content: >-
                {{ expand(states.cover.shellyswitch25_10521c072531) |
                selectattr( 'state', 'eq', 'closed')  | list | count  }}
              tap_action:
                action: navigate
                navigation_path: /dashboard-mobile/wohnzimmer
              card_mod: null
              style: "ha-card {\nborder: none;\n  --icon-size: 30px;\n}\t\t\n"
content: ''
good be a good idea to do
Unfortunately, the exact same, displays correctly when on a dashboard but the bottom half of the card is hidden when in a popup.
Can someone help me canter text in title card? Blank symbol at the end breaks it
Code
type: custom:mod-card
card:
  type: custom:mushroom-title-card
  title: '{{states("sensor.time")}}'
  alignment: center
  subtitle: |-
    {% set time = now().hour %}
    {% if (time >= 18) %}
    Добрый вечер, {{user}}!
    {% elif (time >= 12) %}
    Добрый день, {{user}}!
    {% elif (time >= 5) %}
    Доброе утро, {{user}}!
    {% else %}
    Доброй ночи, {{user}}!
    {% endif %}
card_mod:
  style:
    mushroom-title-card$: |
      h1 {
        --title-font-size: 49px;
      .header {
        --title-padding: 0px 0px 10px 0px;
My mistake, that did work. Thank you!
Your code works ok for me, but you could try {{ states("sensor.time") | trim }}
It’s mostly minimalist off memory, its been a while since I have looked at it :slight_smile: I’ll update my code and share in the next few days so you can take a look!
Looking for advice on the best way to build this mock-up card below. I essentially want to build room cards for my tablet layout that will be within a slider card, so I can slide between them. I want to be able to either click on the title or the main picture as I would a button card to go to the next screen. Not sure whether to build it as one entire button card or as a stack?
can you share your code
Something like this perhaps?
type: vertical-stack
cards:
    primary: Lounge Room
    icon: mdi:sofa
    icon_color: blue
    card_mod:
      style: |
        ha-card {
          --ha-card-background: none;
          padding: 0px !important;
          margin-left: -2px !important;
          --ha-card-box-shadow: none;
          transition: all 0s;
        :host {
          --mush-icon-border-radius: 12px;
  - type: custom:stack-in-card
    cards:
        card_mod:
          style: |
            ha-card {
              height: 200px !important;
              background: url('/local/lounge_room.jpg') center / cover no-repeat !important;
              --ha-card-border-radius: 12px;
              margin: -4px;
              transition: all 0s;
        cards:
          - type: custom:mushroom-chips-card
            chips:
              - type: entity
                entity: sensor.lounge_sensor_temperature
                icon_color: red
              - type: entity
                entity: sensor.lounge_sensor_humidity
                icon_color: indigo
              - type: entity
                entity: sensor.dryer_energy
                icon_color: orange
            card_mod:
              style: |
                .chip-container {
                  flex-flow: column !important;
                  --chip-spacing: 0px;
                  --chip-background: none;
                  --chip-box-shadow: none;
                  transition: all 0s;
        card_mod:
          style: |
            ha-card {
              position: absolute;
              right: 8px;
              top: 8px;
              background: rgba(var(--rgb-card-background-color), 0.7);
              box-shadow: none;
              transition: all 0s;
    card_mod:
      style: |
        ha-card {
  - type: horizontal-stack
    cards:
        icon: mdi:lightbulb-group-outline
        icon_color: amber
        layout: vertical
        card_mod:
          style: |
            ha-card {
        icon: mdi:door-closed
        icon_color: blue
        layout: vertical
        card_mod:
          style: |
            ha-card {
        icon: mdi:blinds-open
        icon_color: grey
        layout: vertical
        card_mod:
          style: |
            ha-card {
        icon: mdi:hvac
        icon_color: deep-orange
        layout: vertical
        card_mod:
          style: |
            ha-card {
        icon: mdi:speaker
        icon_color: grey
        layout: vertical
        card_mod:
          style: |
            ha-card {
No code yet, all done in Powerpoint :slight_smile:
That’s doesn’t work. :pensive:
I have this bug in all my mush title cards in primary and secondary text strings.
I don’t know what can affect.
This is cool. Would be even cooler if it would work on light mode in reverse.
How did you get that bottom navigation bar?
@rhysb how do make it so the white card is smaller, as i want to then apply this to the other cards to the right?
cards:
  - type: custom:mushroom-title-card
    title: Common Devices
    subtitle: null
    cards:
        cards:
            primary: ''
            secondary: Garage Door
            icon: >-
              {% set
              state=states('binary_sensor.garage_door_garage_door_contact') %}
              {% if state=='on' %}
              mdi:garage-open
              {% elif state=='off' %}
              mdi:garage-variant-lock
              {% endif %}
            entity: cover.garage_door_trigger
            icon_color: >-
              {% set
              red
              disabled
              {% endif %}
            tap_action:
              action: toggle
            layout: vertical
            multiline_secondary: true
            badge_icon: ''
            card_mod: null
            style:
              mushroom-shape-icon$: |
                .shape {
                  box-shadow: 0px 2px 2px 0px rgba(0,0,0,0.15) !important;
                  mush-chip-background: rgba(159, 212, 166, 0.3);
      - type: vertical-stack
        cards:
            primary: ''
            secondary: Brads Lamp
            icon: |-
              {% set state=states('light.master_bedroom_bedside_lamp_brads') %}
              mdi:lamp
              mdi:lamp
              {% endif %}
            entity: climate.master
            icon_color: |-
              orange
              disabled
              {% endif %}
            tap_action:
              action: call-service
              service: light.toggle
                color_temp: 500
                brightness_pct: 25
                entity_id: light.master_bedroom_bedside_lamp_brads
            layout: vertical
            hold_action:
              action: more-info
            badge_icon: mdi:face-man-profile
            card_mod: null
            style:
                .shape {
        cards:
            primary: ''
            secondary: Laurens Lamp
            icon: >-
              {% set state=states('light.master_bedroom_bedside_lamp_laurens')
              mdi:lamp
              mdi:lamp
              {% endif %}
            entity: light.master_bedroom_bedside_lamp_laurens
            icon_color: >-
              orange
              disabled
              {% endif %}
            tap_action:
                color_temp: 500
                brightness_pct: 23
                entity_id: light.master_bedroom_bedside_lamp_laurens
            layout: vertical
            hold_action:
              action: more-info
            badge_icon: mdi:face-woman-shimmer
            card_mod: null
            style:
                .shape {
        cards:
            primary: ''
            secondary: Master Zone
            icon: |-
              {% set state=states('climate.master') %}
              {% if state=='heat_cool' %}
              mdi:air-conditioner
              mdi:air-conditioner
              {% endif %}
            icon_color: |-
              blue
              disabled
              {% endif %}
            tap_action:
              action: toggle
            layout: vertical
            badge_icon: mdi:chess-king
            card_mod: null
            style:
                .shape {
        cards:
            primary: ''
            secondary: Master Fan
            icon: |-
              {% set state=states('fan.master_bedrom_ceiling_fan') %}
              mdi:ceiling-fan
              mdi:ceiling-fan
              {% endif %}
            entity: fan.master_bedrom_ceiling_fan
            icon_color: |-
              {% if state=='open' %}
              green
              {% elif state=='closed' %}
              disabled
              {% endif %}
            tap_action:
              service: fan.set_percentage
                percentage: 66
                entity_id: fan.master_bedrom_ceiling_fan
            layout: vertical
            badge_color: ''
            card_mod: null
            style:
                .shape {
        cards:
            primary: ''
            secondary: Frontyard Tap
            layout: vertical
            icon: |-
              {% set state=states('switch.frontyard_tap_state') %}
              mdi:sprinkler
              mdi:sprinkler
              {% endif %}
            entity: switch.frontyard_tap_state
            icon_color: |-
              blue
              disabled
              {% endif %}
            badge_icon: ''
            badge_color: ''
            tap_action:
              action: toggle
            hold_action:
              action: navigate
              navigation_path: /lovelace/pool-and-garden
            double_tap_action:
              action: more-info
            card_mod: null
            style:
                .shape {
        cards:
            primary: ''
            secondary: iZone Hub
            icon: |-
              {% set state=states('climate.izone_controller') %}
              {% if state=='cool' %}
              mdi:hvac
              {% elif state=='dry' %}
              mdi:hvac
              mdi:hvac
              {% endif %}
            entity: climate.izone_controller
            icon_color: |-
              blue
              green
              disabled
              {% endif %}
            tap_action:
              action: toggle
            layout: vertical
            badge_icon: |-
              mdi:snowflake
              mdi:water-percent
              mdi:hvac
              {% endif %}
            badge_color: |-
              blue
              green
              disabled
              {% endif %}
            card_mod: null
            style:
                .shape {
        cards:
            primary: ''
            secondary: Pool Heater
            icon: |-
              {% set state=states('switch.pool_heater_switch') %}
              mdi:pool-thermometer
              {% endif %}
            entity: climate.pool_heater
            icon_color: |-
              {% if state=='heat' %}
              amber
              disabled
              {% endif %}
            tap_action:
              action: toggle
            layout: vertical
            badge_icon: |-
              {% set state=states('binary_sensor.zodiac_exo_pool_pump') %}
              mdi:pump
              mdi:pump
              {% endif %}
            badge_color: |-
              green
              disabled
              {% endif %}
            hold_action:
              action: navigate
            card_mod: null
            style:
                .shape {
card_mod:
  style: |
    ha-card {
      background-size: cover;
      background-color: rgba(159, 212, 166, 0.3);
Is it me, or is it impossible to have icon_color working with a template value?
what doesn’t work? pretty straight forward to define icon_colour within various cards. there are plenty of examples in this topic. like this.
type: custom:mushroom-template-card
primary: Lights
secondary: |-
  {%set lights = states.light
            | selectattr('state', 'eq', 'on')
            | list | count %}
  {% set d1 = '' if lights == 1 else 's' %}
  {{lights}} Light{{d1}} on
icon: mdi:lightbulb
icon_color: |-
  {% set icon = states.light
            | list | count %}
   {% if icon==0 %}
        grey
        {% else %}
        yellow
        {% endif %}
hold_action:
  service: script.turn_of_all_lights
  service_data: {}
  target: {}
double_tap_action:
  action: none
tap_action:
  action: navigate
  navigation_path: lights
fill_container: true
Forgot to mention, but i’m using a Chips Action card. Maybe it’s that?
When i use your code (or mine), and i’ll inspect it’s just echoeing the template code in Chrome Inspector instead of parsing it.
results in:
I do not have the picture element in my setup, nor the swiping. You might want to use this code as a starting point.
One of those room cards is represented by this code:
cards:
    entity: light.kuche
    primary: Küche
    tap_action:
      action: toggle
    icon_color: |-
      {% if states.light.kuche.state == 'on' %}
      orange
      {% else %}
      grey
      {% endif %}
    secondary: >-
      {{ '%0.1f°C' | format(state_attr('climate.temperatur_kuche',
      'current_temperature')) }} ({{ '%0.0f%%' |
      format(states.sensor.heizen_kuche.state | int ) }})
      {{  state_attr('climate.temperatur_kuche', 'preset_mode')
            | replace('away', 'Reduziert')
            | replace('eco', 'Frostschutz')
            | replace('sleep', 'Schlafen')
            | replace('comfort', 'Komfort') }} - {{ '%0.0f°C' |
      format(state_attr('climate.temperatur_kuche', 'temperature')) }}
    icon: mdi:stove
    card_mod:
      style:
          .shape {
            box-shadow: 0px 2px 2px 0px rgba(0,0,0,0.16) !important;
          mushroom-shape-icon {
            position: absolute;
            --icon-size: 80px;
            top: -60px;
            left: -30px;
          mushroom-state-item {
            text-align: right;
            transform: translateX(0%);
    alignment: justify
    chips:
      - type: light
        entity: light.kuchenschrank
        content_info: none
        use_light_color: false
      - type: entity
        entity: sensor.window_kueche
        content_info: none
        icon_color: grey
      - type: action
        icon: mdi:dots-horizontal
        tap_action:
          action: navigate
          navigation_path: /lovelace-details/kuche
