Unfortunately, it isnāt sticking for me :/, here is my code if you wanna see
The card shows but instead of overlaying on top it gets pushed down when I scroll, not overlayed.
- type: custom:gap-card
height: 1000
- type: custom:mushroom-media-player-card
entity: media_player.currently_playing
icon: mdi:play
use_media_info: true
icon_type: entity-picture
show_volume_level: false
media_controls:
- play_pause_stop
- next
volume_controls:
- volume_set
fill_container: false
layout: horizontal
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Currently Playing
content:
type: custom:stack-in-card
cards:
icon_type: none
layout: vertical
media_controls:
- previous
- play_pause_stop
- next
volume_controls:
- volume_set
- volume_buttons
collapsible_controls: false
card_mod:
style:
mushroom-state-info$: |
/* CSS for Mushroom Popup Media Player */
.secondary:before {
/* Add album name between song title and artist name */
{% if state_attr(config.entity, 'media_album_name') != none %}
content: "{{ state_attr(config.entity, 'media_album_name')}}\A";
{% endif %}
/* Format title to fit on seperate line */
white-space: pre;
text-overflow: ellipsis;
ha-card {
/* Remove border from media player */
--ha-card-border-width: 0;
/* Apply album art color to media player icon & volume bar */
--rgb-state-media-player: var(--album-art-color);
/* Disable transitions */
transition: all 0s;
.actions {
/* Apply album art color to media player controls */
--rgb-primary-text-color: var(--album-art-color);
--primary-text-color: rgb(var(--album-art-color));
/* Move volume button to seperate row */
display: block !important;
ha-card:before {
content: "";
/* Show album art above media player when active and default image when idle */
{% if is_state(config.entity, ['playing', 'paused']) %}
background: url( '{{ state_attr(config.entity, "entity_picture") }}') center no-repeat;
{% else %}
background: url('/local/idle_art.png') center no-repeat;
{% endif %}
/* Add padding around album art */
margin: 0px 4px 16px;
/* Add drop shadow to album art */
filter: drop-shadow(4px 4px 6px rgba(var(--album-art-color), 0.3));
/* Round borders of album art */
border-radius: var(--control-border-radius);
/* Adjust the album art aspect ratio based on media type */
{% set media_type = state_attr(config.entity, 'media_content_type') %}
{% if media_type == 'tvshow' %}
aspect-ratio: 16 / 9;
{% elif media_type == 'movie' %}
aspect-ratio: 2 / 3;
{% else %}
aspect-ratio: 1 / 1;
{% endif %}
/* Stretch album art to fit box. Fix for if album art is not sized correctly */
background-size: 100% 100%;
mushroom-button {
/* Size volume button to match other controls and center */
display: flex;
width: calc((100% / 3) - (var(--spacing) / 3) * 2);
margin: auto;
mushroom-media-player-media-control,
mushroom-media-player-volume-control {
/* Correct margins for volume button on second row */
display: flex;
margin-right: 0px !important;
/* Check if PLAY|STOP are supported and adjust margin accordingly */
{% if state_attr(config.entity, 'supported_features') | int | bitwise_and(20480) > 0 %}
margin-bottom: var(--spacing) !important;
{% endif %}
- entity: media_player.currently_playing
hide:
icon: true
runtime: true
source: true
power: true
state_label: true
volume: true
info: true
progress: false
controls: true
more_info: false
type: custom:mini-media-player
toggle_power: false
group: true
card_mod:
style:
mmp-progress$: |
paper-progress {
/* Apply album art color to progress bar when paused */
--paper-progress-container-color: rgba(var(--album-art-color), 0.2) !important;
/* Apply album art color to progress bar when playing */
--paper-progress-active-color: rgb(var(--album-art-color)) !important;
ha-card {
/* Move progress bar up into gap. Check if PLAY|STOP are supported */
--base-offset: calc(4 * var(--mush-spacing, 12px)
+ 1.33 * var(--mush-spacing, 12px)
+ var(--mush-card-primary-line-height, 1.5) * var(--mush-card-primary-font-size, 14px)
+ var(--mush-card-secondary-line-height, 1.5) * var(--mush-card-secondary-font-size, 12px)
+ var(--mush-control-height, 42px));
/* Check if Play (16385) or Stop (4096) are supported and add control button height if they are */
--control-offset: calc(var(--mush-spacing, 12px) + var(--mush-control-height, 42px));
{% else %}
--control-offset: 0px;
{% endif %}
/* Check if album name is present and add to height if it is */
{% set album_name = state_attr(config.entity, 'media_album_name') %}
{% if album_name == None or album_name == "" %}
--album-offset: 0px;
{% else %}
--album-offset: calc(var(--mush-card-secondary-line-height, 1.5) * var(--mush-card-secondary-font-size, 12px));
{% endif %}
bottom: calc(var(--base-offset) + var(--control-offset) + var(--album-offset));
/* Correct margins for progress bar */
margin: 0px 28px -12px;
/* Set height of card to match pregress bar height */
height: var(--mmp-progress-height);
/* Remove border outline */
/* Round corners of progress bar */
--mmp-border-radius: var(--control-border-radius, 12px) !important;
/* Set height of progress bar */
--mmp-progress-height: 12px !important;
/* Remove transitions to prevent progress bar floating in */
transition: all 0s;
card_mod:
style: |
:host {
/* Assign album art color to variable used in popup */
--album-art-color:
{% if is_state('media_player.currently_playing', ['playing', 'paused']) %}
{{ states('sensor.muted_color') }}
{% else %}
141, 117, 238
{% endif %};
/* Remove background because it is applied to popup */
--ha-card-background: none;
card_mod:
style:
ha-dialog$: |
.mdc-dialog__surface {
/* Apply gradient background to popup using album art colors. Set to default colors when idle */
background: linear-gradient(305deg, transparent 50%, rgba({{ states('sensor.dark_vibrant_color') }}, 0.4)),
linear-gradient(55deg, transparent 50%, rgba({{ states('sensor.vibrant_color') }}, 0.2)),
linear-gradient(180deg, transparent 40%, rgba({{ states('sensor.dark_muted_color') }}, 0.3));
{% else %}
background: linear-gradient(0deg, transparent 40%, rgba(192, 127, 190, 0.3)),
linear-gradient(240deg, transparent 40%, rgba(143, 119, 237, 0.3)),
linear-gradient(120deg, transparent 40%, rgba(122, 181, 239, 0.3));
{% endif %}
ha-header-bar$: |
.mdc-top-app-bar {
/* Remove header background so that popup background is visible */
--mdc-theme-primary: none;
/* Reduced the gap between header and album art */
margin-bottom: -16px;
:host {
/* Set width of popup */
--popup-min-width: 450px;
card_mod:
style: |
/* CSS for Mushroom Mini Media Player */
ha-card {
/* Apply album art color to volume bar */
/* Apply gradient background to sticky media player using album art colors */
--ha-card-background: linear-gradient(135deg, rgba({{ states('sensor.dark_vibrant_color') }}, 0.3),
{% endif %}
.actions {
/* Apply album art color to sticky media player controls */
/* Allow the album info to display more text */
max-width: fit-content;
/* Fix the width of the volume bar */
width: 200px;
:host {
/* Add background to host to prevent transparent card */
border-radius: var(--ha-card-border-radius, 12px);
background: var(--card-background-color);
/* Assign album art color to variable used in sticky media player */
--album-art-color: {{ states('sensor.muted_color') }};
{% else %}
/* Hide the sticky media player when it is idle */
display: none !important;
{% endif %}
/* Make the media player sticky at the bottom of the page */
z-index: 9;
position: sticky;
position: -webkit-sticky;
bottom: 12px;
