Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Hi Mario,
new here?
can actually be found quite easily if you search.
I hope Rhys will not be scared away, meanwhile he is written to for a lot of trivial stuff.
Universal Media Player - Home Assistant (home-assistant.io)
Have a look here:
Do you mean make a Grid sticky? Like this:
type: custom:mod-card
card:
  type: grid
  square: false
  columns: 3
  cards:
      primary: Mushroom
      icon: mdi:mushroom
      icon_color: red
      primary: Mushroom
      icon: mdi:mushroom
      icon_color: red
      primary: Mushroom
      icon: mdi:mushroom
      icon_color: red
card_mod:
  style: |
    :host {
      position: sticky;
      bottom: 12px;
Probably something to do with your theme. Try default theme and see if it works then.
It doesn’t work for me either.
Tested with several themes
A big thumbs up for your work!
Try like this:
type: custom:stack-in-card
mode: horizontal
cards:
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        icon: mdi:home
        tap_action:
          action: navigate
          navigation_path: /homekit-infused/main_room
      - type: template
        icon: mdi:alpha-d-circle
        icon_color: blue
        tap_action:
          action: navigate
          navigation_path: /homekit-infused/home
      - type: template
        icon: mdi:alpha-v-circle
        icon_color: purple
        tap_action:
          action: navigate
          navigation_path: /homekit-infused/vally_esther_room
      - type: template
        icon: mdi:robot-vacuum
        icon_color: |-
          {% set state=states('vacuum.nestico_robot_vacuum') %}
          {% if state=='docked' %}
          grey
          {% elif state=='cleaning' %}
          blue
          {% elif state=='error' %}
          red
          {% elif state=='paused' %}
          pink
          {% elif state=='returning' %}
          purple
          {% endif %}
        tap_action:
          action: navigate
          navigation_path: /homekit-infused/vacuum
      - type: template
        icon: mdi:speaker
        icon_color: green
        tap_action:
          action: navigate
          navigation_path: /homekit-infused/media
      - type: template
        icon: mdi:dog
        icon_color: red
        tap_action:
          action: navigate
          navigation_path: /homekit-infused/luna
      - type: template
        entity: climate.3family_room
        icon_color: |-
          {% set status = state_attr('climate.3family_room','hvac_action') %}
          {% if status == 'off' %}
          grey
          {% elif status == 'cooling' %}
          blue
          {% elif status == 'heating' %}
          red
          {% else %}
          grey
          {% endif %}
        icon: mdi:thermostat
        tap_action:
          action: fire-dom-event
          browser_mod:
            service: browser_mod.popup
              content:
                mode: vertical
                cards:
                  - type: custom:mushroom-climate-card
                    fill_container: false
                    show_temperature_control: true
                    collapsible_controls: false
                    hvac_modes:
                      - heat
                      - cool
                      - fan_only
                    layout: horizontal
                  - type: custom:thermostat-dark-card
                    hvac:
                      states:
                        idle: idle
                        cooling: cooling
                        heating: heating
                    step: '0.5'
                    chevron_size: '100'
                    pending: '3'
                    idle_zone: '2'
                    highlight_tap: true
                card_mod:
                  style: |
                    ha-card {
                       background: #111111;
      - type: action
        icon_color: white
        icon: mdi:magnify
        tap_action:
          action: call-service
            content:
              type: custom:search-card
              max_results: 10
              actions:
                - matches: ^toggle (.+\..+)
                  service: homeassistant.toggle
                  service_data: null
                  entity_id:
                    '1': null
              excluded_domains:
                - alarm_control_panel
                - automation
                - binary_sensor
                - button
                - camera
                - device_tracker
                - govee
                - group
                - input_boolean
                - input_number
                - input_select
                - input_text
                - number
                - script
                - select
                - siren
                - update
                - zone
            dismissable: true
            autoclose: false
            right_button: MEDIA
            left_button: HOME
            left_button_action:
              service: browser_mod.navigate
            right_button_action:
          target: {}
        card_mod:
          style: |
            ha-card {
              --chip-background: #11224D;
            .content {
              animation: boing 3s ease infinite;
              transform-origin: 50% 90%;
            @keyframes boing {
              0% { transform: scale3d(1, 1, 1); }
              7% { transform: scale3d(1.25, 0.75, 1); }
              10% { transform: scale3d(0.75, 1.25, 1); }
              12% { transform: scale3d(1.15, 0.85, 1); }
              16% { transform: scale3d(0.95, 1.05, 1); }
              19% { transform: scale3d(1.05, 0.95, 1); }
              25% { transform: scale3d(1, 1, 1); }
    alignment: justify
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 0;
          --chip-font-size: 0.3em;
          --chip-height: 50px
style: |
  ha-card {
    border-radius: 30px;
    z-index: 999 !important;
    position: sticky !important;
    position: -webkit-sticky !important;
    top: 0 !important;
You can combine animations like this:
card_mod:
  style:
    mushroom-template-chip:nth-child(3)$: |
        ha-icon {
          {{ 'animation: illumination 2s infinite, shine 2s infinite;' if is_state('binary_sensor.ruch_kuchnia_occupancy', 'on') }};
        @keyframes illumination {
          0%, 100% { clip-path: inset(0 0 0 0); }
          80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
        @keyframes shine {
          0% {
            opacity: 0.5;
            filter: brightness(10%);
          50% {
            opacity: 1;
            filter: brightness(100%);
          100% {
            opacity: 0.5;
On a new View with default theme, does this work for you?
type: custom:mushroom-template-card
primary: Sticky Mushrooms
icon: mdi:mushroom
icon_color: red
card_mod:
  style: |
    :host {
      position: sticky;
      bottom: 12px;
      z-index: 99;
    ha-card {
      margin-top: 2000px;
It works with a new dashboard!
With the original theme as well as with the minimalist-desktop theme that I use it’s ok
But I do not understand why it does not work on my other dashboards
How do i add other card mod details to the below card please. I want to chaneg the padding as well as margin??
type: custom:mushroom-light-card
entity: light.master_bedroom_bedside_lamp_brads
use_light_color: true
show_brightness_control: true
show_color_temp_control: false
layout: default
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape {
        box-shadow: 0px 2px 2px 0px rgba(0,0,0,0.20) !important;
      ha-card {
        padding: 20px;
You can add the progress bar to a Mushroom Card with entity picture like this.
Mushroom Person Card with Battery Bar:
type: custom:mushroom-person-card
entity: person.rhys
icon_type: entity-picture
card_mod:
  style:
    mushroom-shape-avatar$: |
      .container:before {
        content: "";
        height: 100%;
        width: 100%;
        background: radial-gradient(rgb(var(--rgb-white)) 60%, transparent calc(60% + 1px)), conic-gradient(rgb(var(--rgb-green)) {{ states('sensor.rhys_phone_battery_level') }}% 0%, transparent 0% 100%);
        border-radius: var(--icon-border-radius);
        position: absolute;
        -webkit-mask-image: radial-gradient(circle calc(var(--icon-size) / 2 - 2px) at 50% 50%, transparent 100%, black 0);
Like this:
entity: light.office_light
layout: default
card_mod:
  style:
      .shape {
      ha-card {
        --spacing: 20px;
Try adding things into the new dash to see what is breaking it.
Cheers mate!
no I use the custom layout-card with grid, here an example
type: "custom:layout-card"
layout_type: "custom:grid-layout"
layout:
  mediaquery:
    # Mobile
    "(max-width: 800px)":
      grid-template-rows: "auto"
      grid-template-columns: "1fr"
      overflow: auto;
      grid-template-areas: |
        "header"
        "main"
        "footer"
my idea was trying s.th like that for footer but it does not work
  - view_layout:
      grid-area: "footer"
      show:
        mediaquery: "(max-width: 800px)"
    type: "mushroom-template-card"
    icon: mdi:mushroom
    icon_color: red
    card_mod:
     style: |
       :host {
         position: sticky;
         bottom: 12px;
Of course I know the documentation for Universal Media Player. I thought Rhys had used templates to determine which player was used last.
Legend. Ta.
Hey guys,
I struggle with the mushroom theme and its ‘lines/borders’. Normally i would mask them using the following code;
                      card_mod:
                        style: |
                          ha-card {
                             background: none;
                            --ha-card-box-shadow: 0px;
however, i can’t seem to get rid of these lines/borders (image below). Can someone take a look at my code to see what im doing wrong?
code:
      - type: conditional
        conditions:
          - entity: sensor.plex_dc_nashost
            state_not: '0'
        chip:
          type: template
          icon: mdi:plex
          icon_color: orange
          tap_action:
            browser_mod:
                title: Plex monitor
                content:
                  type: horizontal-stack
                  cards:
                    - type: custom:vertical-stack-in-card
                      cards:
                        - type: custom:stack-in-card
                          mode: vertical
                          cards:
                            - type: custom:mushroom-entity-card
                              icon: mdi:plex
                              icon_color: '#e5a00d'
                              entity: sensor.tautulli_total_bandwidth
                              icon: mdi:lan
                              entity: sensor.tautulli_top_movie
                              icon: mdi:movie-filter
                              entity: sensor.tautulli_top_tv_show
                              icon: mdi:filmstrip
                      card_mod:
                        style: |
                          ha-card {
                             background: none;
                            theme: Mushroom Shadow
                          - type: entity-filter
                            entities:
                                media_player.plex_plex_for_samsung_tv_ue55f8000
                              - media_player.plex_plex_for_ios_tims_ipad
                              - media_player.plex_plex_web_chrome_osx
                              - media_player.plex_plex_web_chrome_windows
                              - media_player.plex_plex_for_lg_lg_43uj670v_zd
                              - media_player.plex_plex_web_chrome_windows_2
                                media_player.plex_jorritroom12_live_nl_plex_for_lg_lg_55un71006lb
                                media_player.plex_shoq_value_plex_for_lg_lg_oled83c14la
                              - media_player.plex_plex_web_chrome_windows_4
                                media_player.plex_plex_for_playstation_5_ps5_825
                              - media_player.plex_plex_for_ios_tims_iphone
                              - media_player.plex_plex_web_chrome_windows_6
                            state_filter:
                              - playing
                              - paused
                            card:
                              type: entities
          card_mod:
            style: |
              ha-card:after {
                content: "{{ (states.sensor.plex_dc_nashost.state | int) }}";
                position: absolute;
                display: flex;
                justify-content: center;
                align-items: center;
                background: rgb(255, 191, 0);
                color: var(--card-background-color);
                font-weight: bolder;
                border-radius: 50%;
                top: -5px;
                right: -5px;
                width: 16px;
                height: 16px;
                font-size: 11px;
    alignment: center
Works great, may try a new animation now that I know it works, thanks!
Changing my theme did nothing but changed my colors, don’t think the theme has anything to do with it. It shows up but just doesn’t overlay on top of the other cards.
Tried with and without gap-card on default theme and nothing changed, it won’t overlay just gets pushed down. I have kiosk mode btw if that makes a difference.
