Would you mind sharing your chip top bar code? I cannot get the bar to span across the whole width (only a column wide) and I really like your weather and person chips.
You need to add the code to the badges section of the dashboard to have it span the whole page.
Thatâs the mini graph card: GitHub - kalkih/mini-graph-card: Minimalistic graph card for Home Assistant Lovelace UI
Oh, thanks. Actually have that installed and using it in one view. But when I configured it, it only had the single view and I never looked for updatesđ¤Śââď¸
@gfandrea or others, Iâm willing to use the vertical-stack-in-card resource for the first time but Iâm not able to load this into my frontend. Even after I restarted home assistant, it doesnât show up. If I check my resources, Iâm able to find the vertical-stack-in-card resource:
I deleted and reinstalled already 3 times but without any success. Could you help me out? Thanks in advance.
Hi
I want to make a custom card based on one of the cards in this Hacs.
Where can I find the code for the included cards?
Ex. I want to mod the entities cards to by default show the icon in color x (green).
Peace
Awesome, worked like a charm. Thanks a lot!
Hi Leon, did you use your own icons to display the waste collection info?
In the latest release, I feel a delay between clicking on the card and the action. In the minimalist-ui there is no such delay. This is true?
Set your âHold Actionâ and âDouble Tap Actionâ to âNo Actionâ
Yes I use my own icons.
Iâll try and add the code to this comment later. But Iâm using a mixture of vertical and horizontal stacks to make everything work. So over her I have a vertical stack card that has the chip card as the first card and then a horizontal stack for the two columns and in each card of the horizontal stack I have vertical stack so that everything stays aligned.
Is there a way to label conditional Chip cards? I have a bunch of conditional chips in a horizontal layout that only display if theyâre on (think âleak detectedâ or âwindows openâ or âvacation mode is onâ). The problem is that I have 10 of these conditional chips and in the visual editor, theyâre all just labeled as âconditionalâ. So if I want to edit one or rearrange, I have to click into each one and then go back and remember that âthe 3rd one down is window alerts, and the 4th one down is a door is openedâ. See example below:
How can I display a chip (or more then one) for a specific user? Is this also possible for a entity?
I with ya on this one. I have an area just for a series of conditional chips between my users and the rest of my cards and figuring out which is which can be a PITA.
Not sure if itâs your issue, but I was using the documentation from stack-in card and it started with "- type: " and I had to remove the dash to get it working. Messed with me for about an hour before I found it lol
Check out the state switch card and use it with you mushroom cards.
It should be fixed in the next release Improve chips list display in editor by piitaya ¡ Pull Request #404 ¡ piitaya/lovelace-mushroom ¡ GitHub
