Hey Rhys,
been meaning to ask you before, but forgot, and now you got me triggered again
is there a reason you use these somewhat unconventional quotes?
according to Ha styleguides we best use double outer en single inner quotes on a single line:
icon_color: "{{ 'green' if is_state(entity,'home') else 'blue' }}"
or, forget about the outer quotes when using multi-line notation:
icon_color: >
seems much cleaner than these double single quotes to my eyes, but maybe there is another reason I am not aware of?
reypm
March 21, 2023, 6:55pm
6036
Can I get some help animating the icon if the fan is on
- type: custom:stack-in-card
cards:
- type: template
entity: fan.office
content: '{{state_attr(''fan.office'', ''percentage'')}}%'
icon: '{{ ''mdi:fan'' if is_state(entity, ''on'') else ''mdi:fan-off'' }}'
icon_color: '{{ ''green'' if is_state(entity, ''on'') else ''grey'' }}'
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Office Fan
content:
cards:
- type: custom:mushroom-fan-card
entity: fan.office
icon_animation: true
show_percentage_control: true
collapsible_controls: true
fill_container: true
card_mod:
style: |
.content {
card_mod:
style: |
@keyframes rotation {
0% {
transform: rotate(0deg);
100% {
transform: rotate(360deg);
alignment: end
@rhysb
I have tried to add a second icon in the top, but there is a lot of spacing, anyway to pull the together at the end of the line ?
rhysb
(Rhys)
March 21, 2023, 7:25pm
6038
Hi Marius, Mushroom Template Cards change this when you enter the Visual Editor. Even if you use the double quotes it gets changed back. We will have to take this up with Paul.
johnbull
(Johan Forsgard)
March 21, 2023, 7:30pm
6039
I’m really found of the Mushroom cards and my dashboards contain almost only mushroom cards.
But today I ran into an issue.
I have defined a sensor from Node Red that contains a timer HH.mm.ss and that looks to be impossible to get displayed by any mushroom card. I have tried mushroom entity card and mushroom chips card etc, but I can’t get them to display this sensor/timer.
A standard Entity card can show it.
However, standard entities card on the other looks to have the same issue as mushroom cards.
The drawback of the standard Entity card is that it takes so much space…
Why isn’t it possible to display a sensor that is a running timer by mushroom cards, or is there something I have missed?
Edit:
The entity looks like this:
and when using the standard Entity card, it displays like this:
and says “timer stopped” when it runs out.
But with for example with the mushroom chips card it looks like this:
even when timer is running
reypm
March 21, 2023, 7:31pm
6040
Yea, the reason why is because @rhysb original version for the first custom:mushroom-chips-card
is using alignment: justify
if you want to change that behavior you have to play a little bit. I am playing with this right now because I want the back chip aligned to the left while the rest, aligned to the right but I am not getting the expected result:
NIce.
I’d like the “menu” on the left, “date” in the middle, but 2 icons on the right…
But I have no idea where to begin
Use a horizontal stack with separate chip sections, each aligned differently
reypm
March 21, 2023, 7:43pm
6043
Got mine working as I wanted:
- type: custom:layout-card
layout_type: custom:vertical-layout
cards:
layout_type: custom:grid-layout
layout:
grid-template-columns: auto auto
margin: 8px 4px 4px 4px;
cards:
- type: custom:mushroom-chips-card
chips:
- type: back
chips:
- type: template
entity: light.office
icon: '{{ ''mdi:lightbulb-on'' if is_state(entity, ''on'') else ''mdi:lightbulb'' }}'
icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''grey'' }}'
- type: template
entity: fan.office
alignment: end
I am missing only one thing and I will wait for some help: animate the icons.
As I said you have to play a little bit with @rhysb code and “destroy” your dashboard to get what you want!
rhysb
(Rhys)
March 21, 2023, 7:49pm
6044
Yes, you can do like this:
cards:
chips:
- type: menu
- type: template
content: '{{ now().strftime("%A, %-d %B") }}'
card_mod:
style: |
/* Style date & time */
ha-card {
--chip-box-shadow: none;
--chip-background: none;
--chip-border-width: 0;
/* Center date & time */
position: absolute;
left: 50%;
transform: translateX(-50%);
- type: template
icon: mdi:alert-circle
card_mod:
style: |
ha-card {
/* Position on right */
position: absolute;
right: calc(var(--chip-height) + var(--chip-spacing));
reypm
March 21, 2023, 7:50pm
6045
oh this solution is even nicer did not know you could style chips independently
ffm777
(Carlo)
March 21, 2023, 7:57pm
6046
Sorry if this has been asked before. But is it possible to use conditional chip cards with a numerical condition? Let’s say, a chip only displays if the humidity is above a certain threshold. Of course, I could use helpers in HA, but I would like to avoid that.
reypm
March 21, 2023, 8:09pm
6047
@rhysb is it possible to animate the chips icon based on a condition? ie: animate the fan icon only if it is on couldn’t get it working
rhysb
(Rhys)
March 21, 2023, 8:19pm
6048
You can do like this:
chips:
- type: template
entity: fan.office
tap_action:
browser_mod:
title: Office Fan
content:
cards:
entity: fan.office
alignment: end
card_mod:
style:
.chip-container :nth-child(1)$: |
ha-icon {
{{ 'animation: spin 1s linear infinite;' if is_state('fan.office', 'on') }}
@keyframes spin {
100% { transform: rotate(360deg); }
A that explains it. I never use the Ui and write it all in yaml mode…
Yeah, this really should be adjusted. Hope Paul is open to that.
reypm
March 21, 2023, 8:32pm
6050
I must say: you are a crack! exactly what I was looking for. Where do you get the animation params from? is there a guide?
rhysb
(Rhys)
March 21, 2023, 9:14pm
6052
You do that in CSS like this:
chips:
- type: template
icon: mdi:mushroom
icon_color: red
- type: entity
entity: sensor.bathroom_sensor_humidity
icon: mdi:water-percent
icon_color: blue
- type: template
icon: mdi:mushroom
icon_color: red
card_mod:
style: |
.chip-container :nth-child(2) {
{{ 'display: none;' if states('sensor.bathroom_sensor_humidity') | float < 80 }}
When I use this on the desktop, it looks strange, as the top shows on all columns, anyway to fix that ?
Or it single colum only ?
rhysb
(Rhys)
March 21, 2023, 9:32pm
6054
It is intended for single column only. Sticky headers don’t really work for a multi column layout .
