Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Oki, so phone only…
Would be nice, to be able to turn off the “Sticky headers” when on a device with multi column (Tablets and web)
Good idea, I’ll look to add that.
Try using a Template Chip:
type: custom:mushroom-chips-card
chips:
  - type: template
    entity: sensor.countdown
    content: '{{ states(entity) }}'
    icon: mdi:timer-outline
@rhysb hhhmm seems that I cannot mix styles for two different things or did I am missing something? In the below code I am trying to remove the borders from all chips but also to animate the fan but is not working, any advice? :thinking:
  - type: custom:stack-in-card
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: back
            card_mod:
                style: |
                  ha-card {
                    position: absolute;
                    left: 0%;
                    transform: translateX(-0%);
          - type: template
            entity: light.office
            icon: '{{ ''mdi:lightbulb-on'' if is_state(entity, ''on'') else ''mdi:lightbulb'' }}'
            icon_color: '{{ ''orange'' if is_state(entity, ''on'') else ''grey'' }}'
            tap_action:
              action: toggle
          - type: template
            entity: fan.office
            content: >
              {% if is_state('fan.office', 'on') %}
                {{ state_attr('fan.office', 'percentage') }}%
              {% endif %}
            icon: '{{ ''mdi:fan'' if is_state(entity, ''on'') else ''mdi:fan-off'' }}'
            icon_color: '{{ ''green'' if is_state(entity, ''on'') else ''grey'' }}'
          - type: template
            entity: input_boolean.firewall_status
            icon: mdi:network
            tap_action:
              action: toggle
            hold_action:
              action: none
        alignment: end
        card_mod:
          style: |
            ha-card {
              --chip-box-shadow: none;
              --chip-background: none;
              --chip-border-width: 0;
            .chip-container :nth-child(3)$: |
              ha-icon {
                {{ 'animation: spin 1s linear infinite;' if is_state('fan.office', 'on') }}
              @keyframes spin {
                100% { transform: rotate(360deg); }
Hey, do I get a badge or something for triggering Marius? :joy:
You will need to use .: to navigate up from the shadow root $.
        card_mod:
          style:
              ha-icon {
              @keyframes spin {
              ha-card {
If it’s Mushroom related, then yep, ask away. Otherwise, send me a message :grinning_face_with_smiling_eyes:.
here you go:
Снимок экрана 2023-03-22 в 09.18.40
Hi, why doesn’t I show the borders of the card at the top?
The suggestion of @rhysb I’m replying to goes back a long way, but I’m having trouble getting the following to work. It’s at the beginning of my theme file, and I want all the Mushroom entity cards to “pop” when tapped. I had the appropriate card-mod code embedded in the yaml of every Mushroom entity card, but would rather this be handled by the theme. Can anyone spot what might be wrong? The “pop” just isn’t happening.
Also, I want all my Title card text to always be white, hence the code in my theme. But this also requires custom code in the yaml of every Title card, and I’d like this handled by the theme too, if possible.
steve_theme:
  card-mod-theme: "steve_theme"
  card-mod-card: |
    .type-custom-mushroom-entity-card:active {
      transform: scale(0.85);
      transition: 0s;
  card-mod-card-yaml: |
    mushroom-title-card$: |
      h1 {
        --primary-text-color: white;
      h2 {
        --secondary-text-color: white;
Cannot figure out how to do this. I have the general theme settings done for removing borders But I would really like to remove the chip borders in this stacked card. (eg. around Casa). Does someone know how to do this?
type: custom:vertical-stack-in-card
horizontal: true
view_layout:
  grid-area: header
cards:
    alignment: justify
    chips:
      - type: menu
        card_mod:
          style: |
            ha-card {
              padding-top: 8px;
              --chip-height: 60px;
      - type: template
        content: Casa
        card_mod:
          style: |
            ha-card {
              padding-top: -15px;
              --chip-height: 80px;
              --chip-background: rgba(var(--rgb-green), 0.0);
      - type: entity
        entity: input_button.dummy
        icon: mdi:magnify
        tap_action:
          action: fire-dom-event
          browser_mod:
            service: browser_mod.popup
              title: ' '
              content:
                type: custom:search-card
                max_results: 50
        hold_action:
          browser_mod:
            service: browser_mod.sequence
              sequence:
                - service: browser_mod.navigate
                    path: '?disable_km'
                - service: browser_mod.refresh
              browser_id: THIS
        content_info: none
        card_mod:
          style: |
            ha-card {
              padding-top: 8px;
card_mod:
  style: |
    ha-card {
      --ha-card-border-radius: 0px;
      margin-right: -10px;
      margin-left: -10px;
      margin-top: -10px;
      height: 70px !important;
    :host {
      z-index: 999;
      position: sticky;
      position: -webkit-sticky;
      top: 0;
–-chip-border-width: 0px; does not seem to work
Use Mushroom Shadows on the device and this will sort it
I am using that, but as you can see, it works on my menu cards on the left. However the cards on top (for menu and icons on the right, it is not working.
Not sure where to post this, but I finally got sticky headers working around a custom:layout-card in grid mode. (And the grid does masonry!), quick overview here: GitHub - tbrasser/config
Use layout-card and set the max-width.
I think you need to add it in a vertical stack card like below as it works in this
Start it like this
square: false
columns: 1
cards:
  - type: vertical-stack
    cards:
        chips:
          - type: template
            icon_color: ''
            icon: mdi:menu
You can change the --primary-text-color and --secondary-text-color in your theme like this:
Unfortunately you won’t be able to target mushroom-title-card using card-mod in your theme as it needs mod-card.
Your other Mushroom Entity card-mod theme looks ok and works for me.
unfortunatly cannot get it to work
Try this:
          style: |
            ha-card {
              border: 0px !important;
              box-shadow: none !important;
              padding-top: 8px;
That did the trick! Thank you!
