Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Thanks for the code, the cards look awesome.
all thanks to @rhysb :slight_smile: :slight_smile: :slight_smile:
Awesome work.
I wish to have another part more in part 2.
There is Spotify and TV.
I wish to have a home page and 3 button
One home, one Spotify, one TV.
If i select home it will replace the dog.
Can you point me to where put that code and wich part to copy.
Thanks in advance
Continuing the discussion from Mushroom Cards - Build a beautiful dashboard easily :mushroom::
any help is welcome, i am not able to change background-blend-mode from lighten to darken when is set dark mode, i know that is the second time when i ask but iā€™m lostā€¦
type: custom:mushroom-template-card
primary: |-
  {% set time = now().hour %}
  {% if (time >= 18) %}
    Bună Seara, {{user}}!
  {% elif (time >= 12) %}
    Bună Ziua, {{user}}!
  {% elif (time >= 5) %}
    Bună Dimineața, {{user}}!
  {% else %}
    Salut, {{user}} !
  {% endif %}
secondary: >-
  Afară sunt {{states("sensor.familia_vlad_outdoor_temperature")| round(1)}}Ā°C
  și este{% set condition = states('sensor.aemet_condition') %}  {% set
  conditions = {'clear-night': 'o noapte senină', 'cloudy': 'Ʈnnourat',
  'exceptional': 'exceptionellt', 'fog': 'ceață', 'hail': 'hagel', 'lightning':
  'fulgere', 'lightning-rainy': 'ploaie cu fulgere', 'partlycloudy': 'parțial
  noros', 'pouring': 'ƶsregn', 'rainy': 'ploie', 'snowy': 'ninsoare',
  'snowy-rainy': 'lapoviță', 'sunny': 'soare', 'windy': 'vĆ¢nt', 'windy-variant':
  'blƄsigt'} %} {{ conditions[condition] }}
  Ǝn casă sunt {{states('sensor.temperatura_medie')}}Ā°C
icon: ''
fill_container: true
multiline_secondary: true
card_mod:
  style: |
    {%if is_state('sensor.aemet_condition','cloudy')%}
     ha-card {
     height: 100px !important;
     border: solid #A9A9A9;
     box-shadow: 0px 0px 9px 1px #808080;
     background-image: url('/local/cloudy.webp'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
     background-size: 50%, 100%;
     background-color: rgba(0, 0, 0, 0.1);
     background-position: right;
     background-repeat: no-repeat;
     background-blend-mode: lighten;
     --primary-text-color: #447FA6;
     --secondary-text-color: #447FA6;
     --card-primary-font-size: 20px;
     --card-secondary-font-size: 11px
    {% elif is_state('sensor.aemet_condition','partlycloudy')%}
    ha-card {
     background-image: url('/local/partlycloudy.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','sunny')%}
    ha-card {
     background-image: url('/local/sunny.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','clear-night')%}
    ha-card {
     background-image: url('/local/clearnight.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','fog')%}
    ha-card {
     background-image: url('/local/fog.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','lightning-rainy')%}
    ha-card {
     background-image: url('/local/heavy-rain-thunderstorm.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','lightning')%}
    ha-card {
     background-image: url('/local/lightning.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','rainy')%}
    ha-card {
     background-image: url('/local/rainny.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','snowy')%}
    ha-card {
     background-image: url('/local/snowy.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','snowy-rainy')%}
    ha-card {
     background-image: url('/local/snowyrain.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% elif is_state('sensor.aemet_condition','windy')%}
    ha-card {
     background-image: url('/local/windy.jpg'),linear-gradient(to left, transparent, rgba(var(--rgb-card-background-color)) 50% );
    {% endif %}
Have a look here:
Have a look here:
https://nodered.org/docs/user-guide/editor/palette/manager
Thank youā€¦it work flawlessly
@rhysb ā€¦ you are one of those people i have seen who can solve most of the css queriesā€¦almost all of themā€¦ can you help me on thisā€¦
not that the gap affects somethingā€¦ but looks better if the gap is uniform all roundā€¦ and i found it can be achieved with the display: none optionā€¦ but i dont know how to apply this onto the yaml code. Not able to understand how to point onto the correct item. (layout-card)
Your room card is great!
If it is possible, I would like to add a light chip to the room card that will always be displayed.
Could you please assist me?
oh thanks @rhysb, I finally got it!
Now I have a big problem:
  • I use the minimalist theme to hide the top navigation bar, but that doesnā€™t make the sticky player work for me.
    I also tried to change the theme but to no avail :frowning:
Can some one suggest some article / post / website ā€¦
  1. Where I can learn how to navigate webpage & get the selectors
  2. Use them to manipulate items using CSS
  3. How to implement that in the YAML code in home assistantā€¦
I need to get the above query doneā€¦
hey lads,
quick question, Iā€™m using the numbers card a bit ā€˜out of the boxā€™ to display some percentages
iā€™ve disabled all the tap actions, but is there a way to ā€˜disableā€™ the slider too? so itā€™s a purely visual thing?
Is it possible to do a dual text chip somehow? Like iOS is doing it signal-2023-04-14-114810
Try here:
Someday I need to compile a searchable list of all the tweaks you share on here. Absolutely fantastic! Thanks!
Hi, Iā€™d like to center horizontally the number of lights on in this element created using chip card, but without sucess. Any advice? Thanx
- type: custom:stack-in-card
    mode: horizontal
    card_mod:
      style: |
        ha-card {
          background-color: var(--nav-link-background);
          margin: 0px 0px -4px -4px;
    cards:
        primary: Lights
        secondary: ''
        icon: mdi:lightbulb-group
        layout: horizontal
        tap_action:
          action: navigate
          navigation_path: /main-control/lights
        hold_action:
          action: none
        double_tap_action:
          action: none
        card_mod:
          style: |
            ha-card {
              margin: 0px -100px 0px 0px;
            mushroom-shape-icon {
              --icon-color: var(--light-icon-color) !important;
      - type: custom:mushroom-chips-card
        alignment: end
        chips:
          - type: conditional
            conditions:
              - entity: sensor.lights_on_all
                state_not: '0'
            chip:
              type: template
              content: '{{states(entity)}}'
              tap_action:
                action: none
              hold_action:
                action: none
              double_tap_action:
                action: none
              style: |
                ha-card {
                  --chip-height: 20px;
                  --chip-border-radius: 0.3em;
                  --chip-padding: 0.2em 0.2em !important;
                  margin: 22px 12px 0px 0px;
                  --text-color: var(--button-on-background-secondary);
                  --chip-background: var(--button-background-secondary);
                  --chip-font-size: 12px;
                  --chip-font-weight: 600;
                  justify-self: center !important;
Anyone have a chance to look at this?
Can someone help me center the +/- buttons pls?
Here is my code I tried but it ainā€™t working.
  - type: custom:mushroom-climate-card
    entity: climate.3family_room
    show_temperature_control: true
    hvac_modes:
      - heat_cool
      - heat
      - cool
      - fan_only
    layout: horizontal
    primary_info: none
    secondary_info: none
    collapsible_controls: false
    card_mod:
      style: |
        mushroom-climate-temperature-control$:
          mushroom-input-number$: |
            #container {
              background: none;
              padding: 0px;
              flex-direction: row !important;
              justify-content: center !important;
            #container .button {
              height: 100%;
              width: 30%;
            #container .button:nth-child(1) {
              background: rgba(var(--rgb-blue), 0.2);
            #container .button:nth-child(3) {
              background: rgba(var(--rgb-red), 0.2);
          --card-mod-icon:
          {% if is_state(config.entity, 'heat_cool') %}
            mdi:autorenew
          {% elif is_state(config.entity, 'heat') %}
            mdi:fire
          {% elif is_state(config.entity, 'cool') %}
            mdi:snowflake
          {% elif is_state(config.entity, 'dry') %}
            mdi:water-percent
          {% elif is_state(config.entity, 'fan_only') %}
            mdi:fan
          {% else %}
            mdi:air-conditioner
          {% endif %};
          display: flex;
          {% if is_state(config.entity, 'fan_only') %}
            animation: rotation 1s linear infinite;
          {% endif %}
        @keyframes rotation {
          100% {
             transform: rotate(360deg);
You can center the temperature controls like this:
card_mod:
  style:
      mushroom-button-group$: |
        .container {
