Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
Is it possible to have the light slider with the name or text inside the slider? To make the slider wider and cover the whole width…
icon_color: '{{ ''green'' if is_state(config.entity, ''on'') else ''red'' }}'
I will try like that…
Thank you
Is something like this possible with title and chips?
For some reason this code doesn’t seem to run the animation, but it does work with “sunny” animation, also of your animations, in the same exact style. What’s broken here?
      - type: conditional
        conditions:
          - entity: input_boolean.cycle_day
            state: 'on'
          - entity: binary_sensor.luz_kitchen
            state: 'on'
        chip:
          type: template
          icon_color: amber
          icon: mdi:lightbulb-on
          tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              .content {
                animation: illumination 2s infinite;
              @keyframes illumination {
                0%, 100% { clip-path: inset(0 0 0 0); }
                80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
Thank you so much
@edit: I feel like the above could’ve been a little too vague, so below I linked the entire card.
Full card for context:
type: custom:stack-in-card
cards:
    entity: input_boolean.room_kitchen
    primary: Cozinha
    secondary: '{{ states("sensor.temp_kitchen") | round(0) }} °C'
    icon: mdi:fridge-outline
    tap_action:
      action: navigate
      navigation_path: cozinha
    hold_action:
      action: call-service
      service: light.turn_off
        transition: 3
        area_id: kitchen
    double_tap_action:
      action: toggle
    icon_color: |-
      {% if states('light.candeeiro_cozinha') == 'on' %}
      #F5C02F
      {% elif states('light.lightstrip_kitchen_light') == 'on' %}
      white
      {% endif %}
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 76px;
          height: 66px;
          margin-left: -18px !important;
  - type: custom:mushroom-chips-card
    chips:
      - type: conditional
        conditions:
          - entity: input_boolean.vacuum_kitchen
            state: 'on'
        chip:
          type: template
          icon_color: pink
          icon: mdi:robot-vacuum
          tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              .content {
                animation: spin 6s ease 1.5s infinite;
              @keyframes spin {
                100% { transform: rotate(360deg); }
      - type: conditional
        conditions:
          - entity: media_player.mitv_kitchen
            state_not: 'off'
            state_not: unavailable
        chip:
          type: template
          icon_color: disabled
          icon: |-
            {% set media_type = state_attr('media_player.mitv_kitchen',
            'media_content_type') %}
            {% if media_type == 'tvshow' %}
              mdi:television-classic
            {% elif media_type == 'movie' %}
              mdi:movie-open
            {% elif media_type == 'music' %}
              mdi:music
            {% elif media_type == 'playlist' %}
              mdi:music
            {% else %}
              mdi:television
            {% endif %}
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
            state: 'on'
            state: 'on'
        chip:
          type: template
          icon_color: amber
          icon: mdi:weather-sunny
          tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              .content {
                animation: sunny 8s ease-in-out infinite alternate;
              @keyframes sunny {
                70% { transform: rotate(360deg) scale(1); }
                80% { transform: scale(1); }
                90% { transform: scale(1.15); }
                100% { transform: scale(1); }
      - type: conditional
        conditions:
            state: 'on'
            state: 'on'
        chip:
          type: template
          icon_color: amber
          tap_action:
            action: none
          hold_action:
            action: none
          card_mod:
            style: |
              .content {
      - type: conditional
        conditions:
          - entity: binary_sensor.occupancy_kitchen
            state: 'on'
        chip:
          type: template
          icon: mdi:transition
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: binary_sensor.window_kt_contact
            state: 'on'
        chip:
          type: template
          icon: mdi:window-open-variant
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: timer.kitchen_ceiling
            state: active
        chip:
          type: template
          icon: mdi:timer
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: timer.kitchen_daytime
            state: active
        chip:
          type: template
          icon: mdi:timer-outline
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: timer.kitchen_extra
            state: active
        chip:
          type: template
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: timer.kitchen_noble
            state: active
        chip:
          type: template
          tap_action:
            action: none
          hold_action:
            action: none
      - type: conditional
        conditions:
          - entity: timer.kitchen_late
            state: active
        chip:
          type: template
          tap_action:
            action: none
          hold_action:
            action: none
    alignment: end
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-background: none;
          --chip-spacing: 0;
card_mod:
  style: |
    ha-card {
      height: 102px;
      {% if is_state('light.candeeiro_cozinha', 'on') %}
        background: rgba(245, 192, 47, 0.1);
      {% endif %}
    :host {
      background: var(--card-background-color);
      border-radius: var(--ha-card-border-radius);
I really can’t get this to work :frowning:
Use a layout-card, grid layout with two grid elements, markdown for title and your mushroom chips or you could use a Stack-in-Card I guess.
Another day, another thing to learn :slight_smile:
At the Moment i try different ideas to setup my “ServerView”. For that i made a very crap mockup, to show the route where i want to got
I tried, with different Stacks - but where i got real Problems are the bars for CPU, Temp and so on
Perhaps anybody from you, can give me a hint or a small example - from where i can go further
@rhysb perhaps you have an example, from where i can start?
thx in advance
-primary: Door
-secondary:…
multiline_secondary: true
-primary: Person Home
-secondary:…
Or
secondary: …
Primary: Persons Home
secondary: … Persons
primary: Home
Looks great thanks!
Just need to figure out how to stop the “# Persons” from being bolder then the other text but other then that it’s nice
well you already use “bolder” in card_mod, try “normal” or lighter"
–mush-card-primary-font-weight: lighter;
… thou i think it’s the font-size you should reduce !
Doesn’t work
really like your work and working on a nice dashboard with lot of your work. Will share once finished.
Is it possible to have an animated printer icon, just normal printing?
Many thanks.
Neither of these worked, weird. Maybe Im putting them in the wrong spot.
type: custom:mushroom-template-card
secondary: Home
primary: |-
  {{ states(config.entity) }}
    Persons
icon: mdi:account-supervisor-circle
entity: zone.home
layout: vertical
icon_color: orange
tap_action:
  service: browser_mod.popup
  target: {}
    dismissable: true
    autoclose: false
    content:
      type: grid
      square: false
      cards:
        - type: custom:mushroom-person-card
          entity: person.davidnestico
          icon_type: entity-picture
          hold_action:
            action: none
          double_tap_action:
            action: none
          entity: person.dad
          hold_action:
            action: none
          double_tap_action:
            action: none
          entity: person.vally
          hold_action:
            action: none
          double_tap_action:
            action: none
          fill_container: false
          entity: person.esther
          hold_action:
            action: none
          double_tap_action:
            action: none
          entity: person.mom
          hold_action:
            action: none
          double_tap_action:
            action: none
        - type: custom:mushroom-entity-card
          entity: zone.home
          layout: horizontal
          hold_action:
            action: none
          double_tap_action:
            action: none
      columns: 2
    style: >-
      background-color: {{ states('input_text.dark_nav_bar_color') }}
      !important;
card_mod:
  style:
    mushroom-shape-icon$: |
      .shape:after {
        position: absolute;
        font-size: var(--card-primary-font-size);
        font-weight: bolder;
      .shape {
        box-shadow: var(--ha-card-box-shadow) !important;
      ha-card {
        --ha-card-background: none;
        box-shadow: none;
        --ha-card-border-width: 0;
      mushroom-shape-icon {
        --shape-color: white !important;
Try to put !important behind lighter
First, im not sure you should have .: | , but just
card_mod;
   style
      ha-card {
... and for the font-weight, try this
:host {
   --mush-card-primary-font-weight: lighter;
   --mush-card-secondary-font-weight: lighter;
Latest at the bottom, (in line with cards: in your grid/stack) ,or if under the specific card , as above “style | ha-card” or host :slight_smile:
Hi @rhysb, I am still struggling with creating an animated conditional card. Any help would be appreciated.
primary: >-
  {% set ct = states('sensor.ev_car_remaining_charging_time') | int %}
  {% if ct > 60 %}{{ ct // 60 }}:{{ '{:0>2d}'.format(ct%60) }} Hours{% else
  %}{{ct}} Minutes{% endif %}
secondary: Charge Time
icon: |
  {% set state=states(entity) %}
  {% if state<='1' %}
  mdi:battery
  {% elif state>='1' %}
  mdi:battery-clock
  {% else %}
  mdi:battery
  {% endif %}
entity: sensor.ev_car_remaining_charging_time
icon_color: |-
  {% set state = states(entity) %}
  {% if state >= '1' %}
  green
  {% else %}
  grey
  {% endif %}
hold_action:
  action: none
double_tap_action:
  action: none
tap_action:
  action: none
So bascially when the car is charging I would like it display the animation you called battery 2:
icon: mdi:battery-high
icon_color: green
primary: 'Batterye #2'
card_mod:
  style:
      ha-icon {
        --icon-animation: charge 3s steps(1) infinite;
      @keyframes charge {
        0% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 84%, 34% 84%, 34% 100%, 100% 100%, 100% 0%); }
        20% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 64%, 34% 64%, 34% 100%, 100% 100%, 100% 0%); }
        40% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 44%, 34% 44%, 34% 100%, 100% 100%, 100% 0%); }
        60% { clip-path: polygon(0% 0%, 0% 100%, 34% 100%, 34% 24%, 67% 24%, 67% 24%, 34% 24%, 34% 100%, 100% 100%, 100% 0%); }
So any help showing me how to integrate that into my button code would be great! At the moment it displays the battery clock icon in green if the time is greater than 1 minute. I would like it to have the animated battery 2 icon.
How would I change the background color of a vertical-stack card?
This works for a vertical-stack-in-card, but not the vertical-stack
  - type: vertical-stack
    style: |
      ha-card {
        {{ '--ha-card-background: color-mix(in srgb, var(--indigo-color) 10%, var(--card-background-color));'}}
Did you follow my previous post?
vertical-stack and horizontal-stack do not have a ha-card element, so you would need to use mod-card.
type: custom:mod-card
card:
  cards:
      primary: Mushroom
      icon: mdi:mushroom
      icon_color: red
      primary: Mushroom
      icon: mdi:mushroom
      icon_color: red
card_mod:
  style: |
    ha-card {
      background: color-mix(in srgb, var(--green-color) 10%, var(--card-background-color));
    :host {
      /* Remove styling from Mushroom Cards */
      --ha-card-box-shadow: none;
The dimensions of the icon within .content are smaller, so you would need to modify the clip-path to suit.
          card_mod:
            style: |
              .content {
                80% { clip-path: polygon(0% 100%, 35% 60%, 35% 43%, 43% 35%, 65% 40%, 70% 75%, 100% 100%); }
