Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Please tell me how to make a chip with a condition? When I add the condition, my chip doesnā€™t show up when triggered
  - type: conditional
    conditions:
      - entity: binary_sensor.lumi_lumi_sensor_motion_aq2_iaszone
        state: 'on'
Thank you.
The animation is still frozen my friend.
Canā€™t seem to make it play. Somehow, the animations from your part 1 do work, the animations from part 3 I canā€™t make them run on that condition / custom chip card.
It shows, but itā€™s a static icon.
:thinking: working hereā€¦
Chip Animation
type: custom:mushroom-chips-card
chips:
  - type: conditional
    conditions:
      - entity: input_boolean.cycle_day
        state: 'on'
      - entity: binary_sensor.luz_kitchen
        state: 'on'
    chip:
      type: template
      icon_color: amber
      icon: mdi:lightbulb-on
      tap_action:
        action: none
      hold_action:
        action: none
      card_mod:
        style: |
          .content {
            animation: illumination 2s infinite;
          @keyframes illumination {
            0%, 100% { clip-path: inset(0 0 0 0); }
            80% { clip-path: polygon(0% 100%, 35% 60%, 35% 43%, 43% 35%, 65% 40%, 70% 75%, 100% 100%); }
Use dev tools to check the state of your binary_sensor.
Post your code and someone will help out.
I think whatā€™s breaking it all is the background removal. Cus individually it works, but not on the complete card setting. No issue, Iā€™ll rebuild them with the proper code, specifically with the " mushroom-template-chip:nth-child(1)$: |" options.
Thank you.
Another one for you, Iā€™m able to make the background follow the state with this bit of code:
      {% if is_state('light.lightstrip_kitchen_light', 'on') %}
         background: rgba({{ (state_attr('light.lightstrip_kitchen_light', 'rgb_color') | join(',')) }},0.1)
How would this work for ā€œicon_colorā€ inside a custom:mushroom-template-card?
    icon_color: >-
      {% if states('light.candeeiro_cozinha') == 'on' %}
      #F5C02F
      {% elif states('light.lightstrip_kitchen_light') == 'on' %}
      'rgba({{ (state_attr('light.lightstrip_kitchen_light', 'rgb_color') |
      join(',')) }},0.1)'
      {% endif %}
This is returning me a white icon. Would be pretty cool if I was able to make the icon follow the LED RBG Color IF on. Thank you again.
You canā€™t use CSS there. It can only be used in card_mod.
Oh, I see.
So thereā€™s no way to change the icon color dynamically?
Or thereā€™s a different template to be added in the card_mod part?
Yes, something like this:
type: custom:mushroom-template-card
primary: Desk Light
icon: mdi:led-strip-variant
entity: light.office_desk_light
card_mod:
  style: |
    mushroom-shape-icon {
      {% if is_state(config.entity, 'on') %}
        {% set light_color = (state_attr(config.entity, 'rgb_color') | join(',')) %}
        --icon-color: rgb({{ light_color }}) !important;
        --shape-color: rgba({{ light_color }}, 0.1) !important;
      {% endif %}
Does anyone know if this card has been adapted for the switch from Polymer to Lit?
Canā€™t find anything in the release notes.
Thank you again.
Unfortunetely, still doesnā€™t work, in fact, itā€™s breaking all the other code with it.
The background ā€œdivisorā€ stopped showing, the icon size reduced size instead of being a little bigger too. Iā€™m sorry for being so annoying, but this is harder than it seemed lol.
type: custom:stack-in-card
cards:
    entity: input_boolean.room_kitchen
    primary: Cozinha
    secondary: >-
      {{ states('sensor.temp_kitchen') | round(1) }}Ā°C | {{
      states('sensor.humd_kitchen') | round(0) }}%
    icon: mdi:fridge-outline
    icon_color: blue
    fill_container: true
    layout: horizontal
    multiline_secondary: false
    tap_action:
      action: navigate
      navigation_path: cozinha
    hold_action:
      action: call-service
      service: light.turn_off
        transition: 3
        area_id: kitchen
    double_tap_action:
      action: toggle
    card_mod:
      style: |
        :host([dark-mode]) {
          background: rgba(var(--rgb-primary-background-color), 0.2);
        :host {
          background: rgba(var(--rgb-primary-text-color), 0.025);
          --mush-icon-size: 80px;
          height: 65px;
          margin-left: -18px !important;
          {% endif %}
  - type: custom:mushroom-chips-card
    chips:
      - type: template
        icon: |-
          {% if states('input_boolean.vacuum_kitchen') == 'off' %}
          mdi:sprout-outline
          {% endif %}
        icon_color: pink
        tap_action:
          action: none
        hold_action:
          action: none
        content_info: none
      - type: template
        icon_color: red
        icon: |-
          mdi:sprout-outline
          {% endif %}
        entity: sensor.washing_machine
      - type: template
        icon_color: red
        icon: |-
          mdi:sprout-outline
          {% endif %}
        entity: sensor.trockner
    alignment: end
    card_mod:
      style:
          ha-icon {
            animation: spin 6s ease 1.5s infinite;
          @keyframes spin {
            100% { transform: rotate(360deg); }
        mushroom-template-chip:nth-child(2)$: |
          ha-icon {
            animation: shake 400ms ease-in-out infinite, drum 2s ease infinite;
            transform-origin: 50% 110%;
          @keyframes shake {
            0%, 100% { transform: translate(0, 0) rotate(0); }
            20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
            40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
            60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
            80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
          @keyframes drum {
            50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
        mushroom-template-chip:nth-child(3)$: |
          ha-icon {
            animation: shake 400ms ease-in-out infinite, drum 1s infinite;
            transform-origin: 50% 65%;
          @keyframes shake {
            0%, 100% { transform: rotate(4deg); }
            50%  { transform: rotate(-4deg); }
          @keyframes drum {
            50%  { clip-path: polygon(0 0, 0 100%, 35% 100%, 36% 74%, 31% 43%, 61% 40%, 71% 69%, 62% 78%, 36% 73%, 35% 100%, 100% 100%, 100% 0); }
          ha-card {
            --chip-box-shadow: none;
            --chip-background: none;
            --chip-spacing: 0;
            margin-right: 6px;
card_mod:
  style: |
    ha-card {
      height: 100px;
      {% elif is_state('light.candeeiro_cozinha', 'on') %}
         background: rgba(245, 192, 47, 0.1);
      {% endif %}
@EDIT:
I managed to fix the ā€œconditionalā€ part. Instead of using conditions, Iā€™m using ā€œtemplatesā€ with states on the icons to show. It works. And letā€™s me animate.
I just really need the Icon State thing to work if thatā€™s possible. ALMOST THERE. :smiley:
After a long time away Iā€™m back to further improving my dashboard - still the best looking one out there in my mind.
A simple request I canā€™t find the answer to. For the various rooms I only show temp and humidity on the home page (and eventually light the icon if the light in the room is on.
The code to show this is šŸŒ”ļø{{ states('sensor.atc_9c32_temperature') | round(1) }}Ā°C šŸ’§{{ states('sensor.atc_9c32_humidity') | round(0) }}%
Where can I find the library of the icons (thermometer and water drop in this case) as Iā€™m adding the battery level as well. I had a look at the mdi website but can only find the code to display the icons. I need the actual icons to copyā€¦
https://emojipedia.org
Exactly what I was looking for
Thanks :slight_smile:
Can you tell me what exactly I need to check? Which developer tools tab should I use?
You should go to Developer Tools > States > Search for binary_sensor.lumi_lumi_sensor_motion_aq2_iaszone and check what does it list.
Youā€™re looking for itā€™s state. So whatā€™s under the State Column, is the ā€œOnā€ youā€™re looking for. If it isnā€™t on, you can see what it is there, and thatā€™s what you need to type on the conditional.
Thanks for the quick reply. Its state is off, but when motion is detected, it changes to on. Tell me if Iā€™m doing everything right? I choose the condition chip, and then in the condition tab I choose the required entity and specify the state on
If you intend that to only show if itā€™s ON that exactly what you should be doing, yes.
When itā€™s OFF isnā€™t gonna show anything. When itā€™s ON itā€™ll pass the condition.
The same would work for any other state. Imagine it was an alarm - for example - and you wanted it to show when you were away, youā€™d put away there, so it would only show when the alarm state is away. If youā€™re home it doesnā€™t show cus the state is another.
You can even complicate it (I do that with some stuff), you can add states of TWO different entities. ā€œIf lights AND motion onā€ for example, will show something, but both need to be on, otherwise it doesnā€™t show cus not all conditions are met.
Thanks for your advice. What you said is very interesting. This worked for me. The only thing I will add in the chip tab is to add the same entity as in the condition tab
Hi @rhysb, I did and it works. However trying to use the same logic for a washing machine card and its not working.
Here is the code; where am I going wrong?
type: horizontal-stack
cards:
    icon: |-
      {% set state=states(entity) %}
      {% if state=='Running' %}
      mdi:washing-machine
      {% elif state== 'Delayed start' %}
      mdi:washing-machine
      {% elif state== 'Cycle is finished' %}
      mdi:washing-machine
      {% else %}
      mdi:washing-machine-off
      {% endif %}
    secondary: |
      Washing Machine
    icon_color: |-
      green
      orange
      purple
      {% else %}
      grey
      {% endif %}
    primary: |2-
       {% set d ={
        'Delayed start': 'Delayed Start',
        'Running': 'Running',
        'Cycle is finished': 'Cycle Ended',
        'Off': 'Off'
        {{ d.get(states(entity)) }}
    tap_action:
      action: more-info
    hold_action:
      action: none
    double_tap_action:
      action: none
    entity: sensor.electrolux_sawa_washing_machine_wm1_appliancestate_2
card_mod:
  style:
    mushroom-shape-icon$: |
      ha-icon {
          {{ '--icon-animation: shake 400ms ease-in-out infinite, drum 2s ease infinite' if is_state(config.entity, 'Running') }}
       transform-origin: 50% 110%;}
       @keyframes shake {
       @keyframes drum {
Also would want to create weather button with multiple animations based on condition.
