jata
May 1, 2023, 6:20am
6720
Hey community, this is a great project and a long thread. I have searched but havenāt found a clear answer. Here goes my question.
I want to use a card (entity or template) to show WAN status (connected) in the primary info slot and IP in secondary. The IP is an attribute of the entity WAN - a binary_sensor.
If I use an entity card, I can show āconnectedā as primary but canāt find a way to get the attribute in the secondary. If I use a template card, I can get the state to show as āonā in primary info and ip in the secondary - so using a template card seems to work best for this use case.
Can someone explain why the state is āonā it is displayed as āconnectedā when using the entity card? Is there a way to expose the āconnectedā state/value using a template?
how can i check 2 sensor value in one āifā condition? this ist not working
{% if is_state('sensor.smart_state_of_charge', '100') && is_state('binary_sensor.openwb_cp1_autoladestatus', 'off')%}
not charging
sarruman
(Stratos)
May 1, 2023, 9:51am
6723
First of all, Iād like to state that I admire your work! U consist an inspiration to me, though Iām totally new to home assistant and your dashboard and views are something totally unreachable to meā¦!
However, I try to learn from your examples!
Having said that, could you please share (an example of) the yaml of your dashboard ? Iāve read your posts about individual cards, but Iād like to copy- imitate your (ideal!) structureā¦!
I hope I donāt ask for much!
Thank you so much in advance!
Sylwester
(Sylwester Olik)
May 1, 2023, 10:21am
6724
Hi @rhysb . Is it possible to do wider Chips card so will auto match screen size. Just now I have used padding to make it a little more wider.
type: custom:mushroom-chips-card
chips:
- type: template
tap_action:
action: none;
hold_action:
action: call-service
service: notify.mobile_app_sylwester_s_s21
message: Ringing
title: Find Phone
ttl: 0
importance: high
priority: high
tag: Find
channel: alarm_stream
timeout: 60
icon: mdi:target
icon_color: red
content: Find Phone
alignment: center
card_mod:
style: |
ha-card {
--chip-background: rgba(var(--rgb-red), 0.2);
--chip-border-radius: var(--mush-control-border-radius, 12px);
--chip-height: var(--mush-control-height, 36px);
--chip-box-shadow: none;
user-select: none;
--chip-padding: 80px;
ha-card:active {
--chip-background: rgba(var(--rgb-red), 0.4);
tfmeier
(Thomas Meier)
May 1, 2023, 1:25pm
6725
Iām considering 3 columns for my mushroom dashboard by removing the icon to create more screen real estate - see tile Lounge below. However at the moment the icon turns orange when the light in the room is on. Could I instead turn the whole tile orange if the light in the room is on? Or if thatās not possible could I ad least add a batch and change batch color accordingly?
This is my code with the icon
type: horizontal-stack
cards:
primary: Lounge
secondary: >-
š”ļø{{ states('sensor.atc_f3d3_temperature') | round(1) }}Ā°C š{{
states('sensor.atc_f3d3_battery') | round(0) }}%
icon: ''
entity: light.controller_rgbw_22854b
tap_action:
action: navigate
navigation_path: lounge
hold_action:
action: toggle
icon_color: |-
{% if is_state('switch.kogan01', 'on') %}
orange
{% endif %}
picture: ''
badge_icon: mdi:home
primary: Kitchen
secondary: >-
š”ļø{{ states('sensor.atc_b49c_temperature') | round(1) }}Ā°C š{{
states('sensor.atc_b49c_battery') | round(0) }}%
icon: mdi:home
tap_action:
action: navigate
navigation_path: kitchen
hold_action:
action: toggle
icon_color: |-
{% if is_state('light.controller_rgbw_22854b', 'on') %}
orange
{% endif %}
badge_icon: ''
primary: Hello, {{user}}
secondary: How are you?
icon: mdi:home
it doesnāt work for me
- type: tile
entity: sensor.10_battery_level
card_mod:
style: |
.background {
background: color-mix(in srgb, var(--tile-color) 10%, var(--card-background-color));
weppa
May 1, 2023, 7:57pm
6727
Morning @rhysb , long time no speak brother, what transform property are you using on the mushroom-shape-iconās in your example? Thanks in advance.
rhysb
(Rhys)
May 2, 2023, 7:35am
6728
Those ones are Tiles but you can replicate the effect like this:
type: custom:mushroom-light-card
entity: light.office_light
card_mod:
style:
mushroom-shape-icon$: |
.shape:active {
transform: scale(1.2);
rhysb
(Rhys)
May 2, 2023, 7:42am
6729
Does your browser support color-mix
https://caniuse.com/?search=color-mix
wgumaa
(Waleed)
May 2, 2023, 7:46am
6730
Morning guys!
First I would like to extend my thanks to @rhysb and @Mattia2399 for their input and help!
I have designed a stack-in-card card for my washing machine.
I was wondering if i can add another entity on the card but not as a chip. The possible areas would be here in red:
I already have an entity in the red space above the ā66 Minā
Here is my code:
type: custom:stack-in-card
title: null
mode: vertical
cards:
icon: |-
{% set state=states(entity) %}
{% if state=='Pre-Washing' %}
mdi:washing-machine
{% elif state== 'Washing' %}
mdi:washing-machine
{% elif state== 'Rinsing' %}
mdi:washing-machine
{% elif state== 'Spinning' %}
mdi:washing-machine
{% else %}
mdi:washing-machine-off
{% endif %}
icon_color: |-
purple
blue
light-blue
orange
{% else %}
grey
{% endif %}
primary: |2-
{% set d ={
'Pre-Washing': 'Pre Wash',
'Washing': 'Washing',
'Rinsing': 'Rinsing',
'Spinning': 'Spinning'
{{ d.get(states(entity)) }}
secondary: |
{{states('sensor.electrolux_sawa_washing_machine_wm1_timetoend_2')}} Min
tap_action:
action: none
hold_action:
action: none
double_tap_action:
action: none
fill_container: true
multiline_secondary: false
entity: sensor.electrolux_sawa_washing_machine_wm1_cyclephase_2
card_mod:
style: null
ha-icon {
{{ '--icon-animation: shake 400ms ease-in-out infinite, drum 2s ease infinite; transform-origin: 50% 110%;' if is_state(config.entity, 'Running') }}
@keyframes shake {
0%, 100% { transform: translate(0, 0) rotate(0); }
20% { transform: translate(0.4px, -0.4px) rotate(-4deg); }
40% { transform: translate(-0.4px, 0.4px) rotate(4deg); }
60% { transform: translate(0.4px, 0.4px) rotate(-4deg); }
80% { transform: translate(-0.4px, -0.4px) rotate(4deg); }
@keyframes drum {
50% { clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0); }
- type: custom:mushroom-chips-card
alignment: center
chips:
- type: template
icon: mdi:tshirt-crew-outline
entity: sensor.electrolux_sawa_washing_machine_wm1_programuid
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
content: '{{states(''sensor.electrolux_sawa_washing_machine_wm1_programuid'') }} '
- type: template
icon: mdi:thermometer
entity: sensor.electrolux_sawa_washing_machine_wm1_analogtemperature
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
content: >-
{{states('sensor.electrolux_sawa_washing_machine_wm1_analogtemperature')
}}Ā°C
- type: template
icon: mdi:alpha-s-circle-outline
entity: sensor.electrolux_sawa_washing_machine_wm1_analogspinspeed
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
content: >-
{{states('sensor.electrolux_sawa_washing_machine_wm1_analogspinspeed')
- type: template
entity: binary_sensor.electrolux_sawa_washing_machine_wm1_doorlock_2
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
content: >-
{% set d ={ 'off': 'Locked', 'on': 'Unlocked', } %} {{
icon: |-
{% if state=='off' %}
mdi:lock
{% else %}
mdi:lock-open-outline
{% endif %}
Any tips or help appreciated!
Thank you very much! Updated Chrome
rhysb
(Rhys)
May 2, 2023, 8:28am
6732
You can make full-width Mushroom Chips like this:
chips:
- type: template
icon: mdi:mushroom
icon_color: red
content: Mushroom
card_mod:
style: |
ha-card {
justify-content: center;
alignment: center
card_mod:
style: |
.chip-container * {
width: 100%;
margin-right: 0px !important;
Multiple Chips will stack vertically.
wgumaa
(Waleed)
May 2, 2023, 11:19am
6733
Update:
So I have managed to add the other entity
How can reduce the white space in the card?
maniac365
(maniac365)
May 3, 2023, 12:35am
6736
Thank you very much. It looks amazing now.
akkaria
(Adam)
May 3, 2023, 3:08am
6737
After doing some further reading in the card_mod documentation iāve managed to work it out.
For anyone interested you need to do the following:
card_mod:
style:
mushroom-cover-buttons-control$: |
mushroom-button {
--bg-color: red;
wgumaa
(Waleed)
May 3, 2023, 6:33am
6738
Iāll post the code in a bit
Hey @rhysb , can we create a footer similar to this?
maybe using sticky cards.
wgumaa
(Waleed)
May 3, 2023, 1:18pm
6741
@Mattia2399 Hi,
Here is my code but the animation is running despite the condition I put. Any ideas?
Should i put the animation in the icon section?
cards:
icon: |-
{% if state=='Running' %}
mdi:washing-machine
{% elif state== 'Delayed start' %}
mdi:washing-machine
{% elif state== 'Cycle is finished' %}
mdi:washing-machine-alert
{% else %}
{% endif %}
icon_color: blue
entity: sensor.electrolux_sawa_washing_machine_wm1_appliancestate_2
primary: |2-
{% set d ={
'Delayed start': 'Delayed Start',
'Running': 'Running',
'Cycle is finished': 'Cycle Ended',
'Off': 'Off'
secondary: |
card_mod:
style:
icon: |-
mdi:washing-machine
{% else %}
{% endif %}
ha-icon {
{{ '--icon-animation: shake 400ms ease-in-out infinite;' if is_state(config.entity, 'Running') }}
transform-origin: 50% 58%;
@keyframes shake {
icon: mdi:washing-machine
icon_color: red
card_mod:
style:
ha-icon {
--icon-animation: spin 1s linear infinite;
clip-path: circle(21.7% at 50% 58%);
.shape {
--shape-color: none;
ha-card {
width: 80px;
top: -82px;
alignment: center
chips:
- type: template
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
- type: template
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
content: >-
}}Ā°C
- type: template
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
content: >-
- type: template
double_tap_action:
action: none
tap_action:
action: none
hold_action:
action: none
content: >-
{{d.get(states(entity)) }}
icon: |-
mdi:lock
{% else %}
{% endif %}
I think the icon: is wrong. I have a similar card and here is my part withe the animation:
card_mod:
style:
{% if is_state('sensor.miele_waschmaschine_status', 'running') %}
ha-icon {
@keyframes shake {
@keyframes drum {
{% endif %}
entity: sensor.miele_waschmaschine_status
You do not need the different on off icons because they are at the icon part already.
Steffen
