Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Hey there, how do you get the temperature to show up in your livingroom button?
Hey there, would you mind sharing the code with us?
Thanks for the great work on these cards! Keep up the great work! I love them in my Dwains Dashboard v3!
Sure.
type: custom:stack-in-card
cards:
    icon: mdi:shower
    icon_color: blue
    layout: vertical
    tap_action: null
    action: navigate
    navigation_path: pokoje
    primary: Łazienka
    multiline_secondary: true
    secondary: >-
      Temp: {{
      state_attr('climate.hmip_wth_2_000a9be9a3e3ae','current_temperature')|float}}°C
      Wilgotność: {{
      state_attr('climate.hmip_wth_2_000a9be9a3e3ae','current_humidity')|float}}%
    style: |
      ha-card {
        box-shadow: 0px 0px;
  - type: custom:mushroom-chips-card
    chips:
      - type: light
        entity: light.lazienka_swiatlo
        content_info: none
        use_light_color: false
        card_mod: null
        style: |
          ha-card {
      - type: light
        entity: light.lazienka_led
        content_info: none
        card_mod: null
        style: |
          ha-card {
      - type: template
        content_info: none
        card_mod: null
        icon: mdi:fan
        icon_color: |2-
              {% set state=states('light.lazienka_led') %}
              {% if state=='on' %}
              green
              {% elif state=='off' %}
              black
              {% endif %}
        style: |
          @keyframes rotation {
            0% {
              transform: rotate(0deg);
            100% {
              transform: rotate(360deg);
          ha-card {
            animation: rotation linear infinite;
            {% if states('light.lazienka_led') == 'on' %}
             animation-duration: 3s;
            {%- else -%}
            {%- endif %}
      - type: light
        content_info: none
        card_mod: null
        icon: mdi:radiator
        style: |
          ha-card {
    alignment: center
Thank you a ton!!
The horizontal and vertical stacks are the cards I’m using all the time, I;m not so good at card-mod therefore I used your option with no borders.
Finally, I think my Mobile dashboard is ready !
The buttons on top navigates to Power, Network, Weather etc, I removed names to have clear mobile view
Great, glad I could help! :+1:
Hi, this is the title and the first card
type: vertical-stack
cards:
  - type: custom:mushroom-title-card
    title: Riepilogo
  - square: false
    columns: 2
    type: grid
    cards:
      - type: custom:vertical-stack-in-card
        cards:
            secondary: Cucina e soggiorno
            icon: mdi:sofa
            tap_action:
              action: navigate
              navigation_path: soggiorno
            icon_color: blue
            primary: Zona giorno
            card_mod: null
            style: |
              ha-card {
            chips:
              - type: entity
                entity: sensor.temperatura_soggiorno
                icon_color: blue
                card_mod: null
                style: |
                  ha-card {
              - type: entity
                entity: sensor.umidita
                icon_color: blue
                card_mod: null
                style: |
                  ha-card {
        alignment: center
Mushroom 1.7.3 is out!
Fastest Mushwroooom ever, thank you so much, @piitaya and collaborators!
What are those room cards made of? Is that stack-in-card with chips on top and then a mushroom-template-card?
For inspiration…
stack-in-card + (mushroom-template-card + custom:mushroom-chips-card) + box-shadow: 0px 0px and animation blink and rotation
20220502_132702
cards:
    icon: mdi:shower
    icon_color: blue
    layout: vertical
    tap_action: null
    action: navigate
    primary: Łazienka
    secondary: >-
      Temp: {{
      Wilgotność: {{
    style: |
      ha-card {
    chips:
      - type: light
        content_info: none
        card_mod: null
        style: |
          ha-card {
      - type: light
        content_info: none
        card_mod: null
        style: |
          ha-card {
      - type: template
        content_info: none
        card_mod: null
        icon: mdi:fan
        icon_color: |2-
              green
              black
              {% endif %}
        style: |
            0% {
            100% {
          ha-card {
            {%- else -%}
            {%- endif %}
            template
      - type: template
        content_info: none
        card_mod: null
        icon: |2-
              mdi:radiator
              mdi:radiator-disabled
              {% endif %}
        icon_color: |2-
              red
              black
              {% endif %}
        style: |
          ha-card {
            animation: blink 0.1s linear infinite;
            @keyframes blink {
              50% {opacity: 0;}
            {%- else -%}
            {%- endif %}
          ha-card {
    alignment: center
please share your yaml code…
Thanks for your wonderful work. I see some users are able to add temperatures under their buttons/rooms, do you have an example of how to do this?
To just add text, use a template card and then you can use templates in the primary and secondary text. I’m using this for temp and humidity. This can be done with just one card.
{{ states("sensor.ble_temperature_sensor") }} °C - {{states("sensor.ble_humidity_sensor") }}%
Some other people are using stack-in-card and vertical-stack-in-card to put chips instead.
Nice work @RodgerDodger
Could you please share the whole code :grinning:
Thank you, but I’m only a fan :innocent:
Please have a look at xisio’s code: #675 by xisio
Thanks for getting me somewhere. Right now i have this as result;
    primary: light.kitchen
    show_brightness_control: true
    use_light_color: true
    icon: mdi:spotlight-beam
    layout: vertical
    secondary: >
      {{ states("sensor.philips_sml001_c6710202_temperature") }} °C -
      {{states("sensor.philips_sml001_fde90002_illuminance") }} lux
However, brightness control, color control and name ā€˜Kitchen’ wont get applied, am i missing something?
You are using a mushroom-template-card but values that is from the light card.
https://github.com/piitaya/lovelace-mushroom/blob/4a65c3946c1ce7422805784a60e7b72458a60ec7/docs/cards/template.md
Bummer, i can’t have the slider + the addition information(?) temp, lux etc etc?
Thank you and yes. It’s the first card and as I mentioned I’ve a room specific view behind every room and person card.
All uppercase words are based on my personal entities or gusto.
kiosk_mode:
  mobile_settings:
    hide_header: true
    ignore_entity_settings: true
    custom_width: 812
  - theme: Google Theme
    title: Home
    icon: mdi:home
    visible:
      - user: PERSON_1
      - user: PERSON_!
    badges: []
    cards:
      - type: custom:swipe-card
        cards: []
        chips:
          - type: weather
            entity: weather.home
            show_conditions: true
            show_temperature: true
          - type: entity
            entity: sensor.count_LIGHTS_ON
            icon: mdi:lightbulb-alert
            icon_color: amber
            hold_action:
              action: call-service
              service: light.turn_off
              service_data: {}
                entity_id: light.WHOLE_HOUSE
        alignment: center
        primary: |-
          {% set time = now().hour %}
          {% if (time >= 18) %}
            EVENING_GREETING, {{user}}!
          {% elif (time >= 12) %}
            DAY_GREETING, {{user}}!
          {% elif (time >= 5) %}
            MORNING_GREETING, {{user}}!
          {% endif %}
        secondary: |-
            MOTIVATIONAL_EVENING_QUESTION
            MOTIVATIONAL_DAY_QUESTION
            MOTIVATIONAL_MORNING_SAYING
          {% endif %}
        tap_action:
          action: none
        hold_action:
          action: none
        double_tap_action:
          action: none
        layout: horizontal
        multiline_secondary: false
      - type: custom:state-switch
        entity: user
        default: default
        states:
          PERSON_!:
            type: conditional
            conditions:
              - entity: calendar.GOOGLE_BIRTHDAY_CALENDAR
                state: 'on'
            card:
              type: custom:mushroom-template-card
              layout: horizontal
              tap_action:
                action: none
              hold_action:
                action: none
              double_tap_action:
                action: none
              icon: mdi:cake
              primary: '{{ state_attr(''calendar.GOOGLE_BIRTHDAY_CALENDAR'', ''message'') }}'
      - type: conditional
        conditions:
          - entity: sensor.ORGANIC_WASTE
            state: TOMORROW
        card:
          subtitle: INFORMATIONS
      - type: horizontal-stack
        cards:
          - type: conditional
            conditions:
                state: TOMORROW
            card:
              chips:
                - type: entity
                  icon_color: deep-orange
                  content_info: name
                  tap_action:
                    action: none
                  hold_action:
                    action: none
                  double_tap_action:
                    action: none
                  icon: mdi:delete-circle-outline
              alignment: justify
            cards:
              - type: conditional
                conditions:
                  - entity: sensor.YELLOW_BAG
                    state: TOMORROW
                card:
                  chips:
                    - type: entity
                      icon_color: yellow
                      icon: mdi:delete-empty
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                        target: {}
                      double_tap_action:
                        action: none
                      content_info: none
                  alignment: center
              - type: conditional
                conditions:
                  - entity: sensor.PAPER_WASTE
                    state: TOMORROW
                card:
                  chips:
                    - type: entity
                      icon_color: blue
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      content_info: none
                  alignment: center
              - type: conditional
                conditions:
                    state: TOMORROW
                card:
                  chips:
                    - type: entity
                      icon_color: green
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      content_info: none
                  alignment: center
              - type: conditional
                conditions:
                  - entity: sensor.RESIDUAL_WASTE
                    state: TOMORROW
                card:
                  chips:
                    - type: entity
                      icon_color: grey
                      tap_action:
                        action: none
                      hold_action:
                        action: none
                      double_tap_action:
                        action: none
                      content_info: none
                  alignment: center
        subtitle: FAMILY
        cards:
          - type: custom:mushroom-person-card
            entity: person.PERSON_1
            use_entity_picture: true
            layout: vertical
            hold_action:
              action: navigate
              navigation_path: PERSON_1
            entity: person.PERSON_2
            layout: vertical
            hold_action:
              action: navigate
              navigation_path: PERSON_2
            hide_name: false
            entity: device_tracker.MY_CAR
            layout: vertical
            hold_action:
              action: navigate
              navigation_path: car
            hide_state: false
            hide_name: false
        subtitle: ROOMS
        cards:
          - type: custom:mushroom-entity-card
            entity: light.OFFICE
            tap_action:
              action: navigate
              navigation_path: OFFICE
            icon_color: amber
            layout: horizontal
            hold_action:
              action: toggle
            primary_info: name
            secondary_info: none
            icon: hue:room-office
            entity: light.BATHROOM
            icon_color: amber
            layout: horizontal
            tap_action:
              action: navigate
              navigation_path: BATHROOM
            icon: mdi:bathtub
            hold_action:
              action: toggle
            primary_info: name
        cards:
            entity: light.BEDROOM
            icon_color: amber
            tap_action:
              action: navigate
              navigation_path: BEDROOM
            hold_action:
              action: toggle
            layout: horizontal
            entity: light.NURSERY
            icon_color: amber
            layout: horizontal
            tap_action:
              action: navigate
              navigation_path: NURSERY
            hold_action:
              action: toggle
        cards:
            icon: mdi:sofa
            entity: light.LIVING_ROOM
            icon_color: |-
              {% if is_state('light.LIVING_ROOM', 'on') %}
                amber
              {% else %}
                 #646464
              {% endif %}
            primary: LIVING_ROOM
            secondary: |-
              {% if is_state('select.HARMONY_HUB_activities', 'PowerOff') %}
                        {% elif is_state('select.HARMONY_HUB_activities', 'HARMONY_ACTIVITY_1') %}
                          HARMONY_ACTIVITY_1
                        {% elif is_state('select.HARMONY_HUB_activities', 'HARMONY_ACTIVITY_2') %}
                          HARMONY_ACTIVITY_2
                        {% elif is_state('select.HARMONY_HUB_activities', 'HARMONY_ACTIVITY_3') %}
                          HARMONY_ACTIVITY_3
                        {% else %}
                        {% endif %}
            hold_action:
              service: light.toggle
              service_data: {}
                entity_id: light.LIVING_ROOM
            double_tap_action:
              action: none
            tap_action:
              action: navigate
              navigation_path: LIVING_ROOM
            entity: light.DINING_ROOM
            icon_color: amber
            layout: horizontal
            tap_action:
              action: navigate
              navigation_path: DINING_ROOM
            icon: hue:room-dining
            hold_action:
              action: toggle
        cards:
            entity: light.KITCHEN
            icon_color: amber
            layout: horizontal
            tap_action:
              action: navigate
              navigation_path: KITCHEN
            icon: ''
            primary_info: name
            hold_action:
              action: toggle
            entity: light.decke_PANTRY
            secondary: " {% if is_state('vacuum.VACCUM_NAME', 'docked') %}
                                 {% elif is_state('vacuum.VACCUM_NAME', 'cleaning') %}
                                   VACUUM IS CLEANING
                                 {% elif is_state('vacuum.VACCUM_NAME', 'returning') %}
                                   VACUUM IS RETURNING
                                 {% elif is_state('vacuum.VACCUM_NAME', 'error') %}
                                    VACUUM ERROR
                                 {% elif is_state('vacuum.VACCUM_NAME', 'paused') %}
                                   VACUUM IS PAUSED
                                 {% else %}
                                 {% endif %}
            primary: PANTRY
            tap_action:
              action: navigate
              navigation_path: PANTRY
            hold_action:
              action: toggle
            double_tap_action:
              action: none
            icon_color: |-
              {% if is_state('light.PANTRY', 'on') %}
                amber
              {% else %}
                 #646464
              {% endif %}
            icon: mdi:food
            card_mod:
              style: |
                ha-card {
                  --secondary-text-color:  {{ 'red' if is_state('vacuum.VACUUM_NAME', 'error') else '' }};;
        cards:
            icon: hue:room-laundry
            entity: light.UTILITY_ROOM
            icon_color: >-
              {% if is_state('input_select.washing_machine_state', 'ready') and
              is_state('input_select.dryer_state', 'ready') %}
                          #646464
                        {% elif is_state('input_select.washing_machine_state', 'washing') and is_state('input_select.dryer_state', 'drying') %}
                          blue
                        {% elif is_state('input_select.dryer_state', 'ready') and is_state('input_select.washing_machine_state', 'washing') %}
                          green
                        {% elif is_state('input_select.washing_machine_state', 'ready') and is_state('input_select.dryer_state', 'drying') %}
                          purple
                        {% else %}
                          none
                        {% endif %}
            primary: UTILITY_ROOM
            secondary: >-
                          WASHING & DRYING
                          WASHING
                          DRYING
                        {% else %}
                          none
                        {% endif %}
            hold_action:
              action: none
            double_tap_action:
              action: none
            tap_action:
              action: navigate
              navigation_path: UTILITY_ROOM
            icon: |-
              {% if is_state('cover.GARAGE_DOOR', 'closed') %}
                mdi:garage-variant-lock
              {% elif is_state('cover.GARAGE_DOOR', 'open') %}
                mdi:garage-open-variant
              {% elif is_state('cover.GARAGE_DOOR', 'opening') %}
                mdi:garage-alert-variant
              {% elif is_state('cover.GARAGE_DOOR', 'closing') %}
              {% else %}
              {% endif %}
            entity: cover.GARAGE_DOOR
            icon_color: |-
                #646464
                red
                yellow
                yellow
              {% else %}
              {% endif %}
            primary: GARAGE
            secondary: |-
                OPEN
                IS OPENING
                IS CLOSING
              {% else %}
              {% endif %}
            tap_action:
              action: navigate
              navigation_path: GARAGE
            hold_action:
              action: none
            double_tap_action:
              action: none
Can you share your person card code please? It it just a stack-in card with no border? Looks great!
