@piitaya do any of the cards support the header/footer options like the lovelace cards to add buttons at the bottom? Didnāt seem to like it for me on the light card
Hi, I have a TADO binary sensor which is created by the integration and shows in HA as window open or closed but in developer tab itās classed as on or off. In my mushroom card, it shows binary sensor as off.
How can I get it to show window as open or closed in the mushroom card as it should as device class is window ?
I tried adding a customization but it already knows itās a window ? I donāt want to duplicate the entity
Martyn
I use this for my door sensors to convert from on/off to open/close. Thereās probably a better way to do it but this works in a mushroom template card. I use it as my secondary info line
{% set state=states(entity) %}
{% if state=='on' %}
open
{% elif state=='off' %}
closed
{% endif %}
Great work! Do you mind sharing your sidebar code?
what does fill_container do?
check my post history. im not at a pc to be able to share right now
You can check this if you want the card to take the full height (useful when you use it in a grid layout
Itās not supported. But you can combine card with vertical stack in card.
Interesting thanks, any plans to support it?
There is plan to add custom buttons on entity card but no footer, header.
I prefer to keep mushroom card simple for now
- one icon
- one name
- one state
- one line of control
Advanced things can be done with card_mod, vertical stack in card, etcā¦
Yeah but they donāt look as pretty as yours
How did you create the buttons on the room cards?
this is based on the example provided by @dunner
It is a combination of stack-in-card, horizontal stacks + chips (templates and lights) + no borders
Salon example:
type: custom:stack-in-card
mode: vertical
cards:
- type: custom:mushroom-chips-card
chips:
- type: template
icon: |
{% if is_state('media_player.sony_bravia_tv', 'off') %}
mdi:television-classic
{% else %}
mdi:television-classic-off
{% endif %}
icon_color: |
grey
{% else %}
indigo
{% endif %}
entity: light.kitchen_led
content_info: none
card_mod: null
style: |
ha-card {
box-shadow: 0px 0px;
tap_action:
action: more-info
- type: template
icon: |
{% if is_state('light.kitchen_led', 'on') %}
mdi:lightbulb-spot
{% else %}
mdi:lightbulb-spot-off
{% endif %}
icon_color: |
yellow
{% else %}
grey
{% endif %}
content_info: none
card_mod: null
style: |
ha-card {
tap_action:
action: more-info
- type: template
entity: climate.saswell_gtz03
icon: |
{% if is_state('climate.saswell_gtz03', 'off') %}
mdi:radiator-off
{% elif is_state('climate.saswell_gtz03', 'auto') %}
mdi:radiator-disabled
{% else %}
mdi:radiator
{% endif %}
icon_color: |
grey
orange
{% else %}
red
{% endif %}
content: '{{ states(''climate.saswell_gtz03'',) }} '
style: |
ha-card {
alignment: center
- type: horizontal-stack
cards:
primary: Salon
layout: vertical
icon: mdi:sofa
icon_color: '#a37208'
tap_action:
action: navigate
navigation_path: salon
hold_action:
action: more-info
style: |
ha-card {
cards:
chips:
- type: template
entity: sensor.ble_temperature_salon
icon: mdi:thermometer
icon_color: yellow
content: '{{ states(''sensor.ble_temperature_salon'',) }} °C '
card_mod: null
style: |
ha-card {
- type: template
icon: mdi:water-percent
icon_color: teal
content: '{{ states(''sensor.ble_humidity_salon'',) }} % '
card_mod: null
style: |
ha-card {
alignment: center
Does anyone else have an issue where mushroom cards wont render on a google nest hub?
indeed!
I think the that by default stack-in-card does not have borders
here I have condidational cards as well, showing different if phone is charging or not.
I shall change this simply to the different Icon by state⦠
mode: horizontal
cards:
- type: custom:mushroom-person-card
entity: device_tracker.sg21
use_entity_picture: true
hide_name: true
layout: vertical
- type: conditional
conditions:
- entity: binary_sensor.sg21_is_charging
state: 'on'
card:
type: custom:mushroom-entity-card
entity: sensor.sg21_battery_level
layout: vertical
icon_color: light-green
icon: mdi:battery-charging-medium
- type: conditional
conditions:
state: 'off'
card:
layout: vertical
icon_color: green
icon: mdi:battery-arrow-down
Hi all,
I have got a problem handling the color of an entities icon, depending on its state.
In my case, I have a sensor for waste collection indicating, if waste has to be put for collection. But itās not working. It defaults to blackā¦
Here is the code for that:
cards:
- type: custom:mushroom-entity-card
entity: sensor.gcoll_bio
icon_color: >-
{% if is_state('sensor.gcoll_bio.state', 'HEUTE') %} red {% elif
is_state('sensor.gcoll_bio.state', 'MORGEN') %} orange {% else %} green {%
endif %}
entity: sensor.gcoll_paper
Itās basically a horizontal-stack which holds two of those entities:
Any idea, whatās wrong with the code? Already a lot of variantsā¦
Maybe itās because of the spaces before and after the color ?
That only works in the template card, doesnāt it?
missing the
at the end of your {% elif statement after āredā
But also I donāt believe this works in entity card, youāll need to use a template card if Iām not mistaken.
Does that change dynamically (without refreshing the page) if the state has been changed?
