Sorry, been busy with work. Will try to get back into it
Try like this:
type: vertical-stack
view_layout:
grid-area: chips
cards:
- type: custom:mushroom-chips-card
chips:
- type: conditional
conditions:
- entity: sensor.dryer_operation_state
state: Run
chip:
type: template
icon: mdi:washing-machine
icon_color: |
{% if is_state('sensor.dryer_operation_state', 'Run') %}
blue
{% else %}
disabled
{% endif %}
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
title: Dryer
content:
type: custom:vertical-stack-in-card
cards:
- type: entities
entities:
- entity: sensor.dryer_runtime
secondary_info: last-updated
show_header_toggle: false
state_color: false
- type: custom:mini-graph-card
entities:
- sensor.dryer_power
card_mod:
style: |
.content {
animation: shake 400ms ease-in-out infinite, drum 1s infinite;
@keyframes shake {
0%, 100% { transform: rotate(4deg); }
50% { transform: rotate(-4deg); }
@keyframes drum {
50% { clip-path: polygon(0 0, 0 100%, 100% 100%, 100% 0, 58% 47%, 62% 54%, 60% 61%, 54% 66%, 47% 65%, 42% 58%, 58% 47%, 100% 0); }
Do you have some code for a sticky card ?
I want two buttons in a horizontal stack centered en 5px from the bottom, on every screen . Same place.
I have something with position: sticky and bottom:x px but indont get it workingā¦
You can sticky on the bottom like this:
type: custom:mod-card
card:
type: horizontal-stack
cards:
icon: mdi:chevron-left
icon_color: blue
layout: vertical
card_mod:
style: |
ha-card {
width: fit-content;
padding: 0px !important;
margin-left: auto;
transition: all 0s;
icon: mdi:chevron-right
icon_color: blue
layout: vertical
card_mod:
style: |
ha-card {
width: fit-content;
margin-right: auto;
transition: all 0s;
card_mod:
style: |
:host {
position: sticky;
bottom: 5px;
ha-card {
margin: 0px 0px -12px 0px;
background: none;
--ha-card-border-width: 0px;
--ha-card-box-shadow: none;
I should think so, this place has been a shambles
Thanks. And how do I get them centered ?
hey guys
Iām creating a card that I can reuse without having to change many things, I just need to be able to get the entityās default icon, does anyone know if thereās a way? Iāve tried '{{ states[config.entity].icon }}'
, '{{ states[icon.entity]}}'
among other ways but it didnāt work
This should work
icon: '{{ state_attr(config.entity,''icon'') }}'
It worked
thanks
They should already be centered. Are they not for you?
its about the 4 icons at the bottom. It looks like nothing is happing, so I think i did something wrong
- type: horizontal-stack
cards:
- type: 'custom:button-card'
template: chip_navigate
variables:
ulm_chip_navigate_path: verbruikgisteren
ulm_chip_navigate_icon: mdi:flash
ulm_chip_navigate_icon_color : rgb(30,227,137)
card_mod:
style: |
ha-card {
width: fit-content;
margin-left: auto;
transition: all 0s;
variables:
ulm_chip_navigate_path: status
ulm_chip_navigate_icon: mdi:battery-70
ulm_chip_navigate_icon_color : rgb(212,128,61)
card_mod:
style: |
ha-card {
width: fit-content;
margin-left: auto;
transition: all 0s;
variables:
ulm_chip_navigate_path: recycle
ulm_chip_navigate_icon: mdi:recycle
ulm_chip_navigate_icon_color : rgb(69,124,97)
card_mod:
style: |
ha-card {
width: fit-content;
margin-left: auto;
transition: all 0s;
variables:
ulm_chip_navigate_path: updates
ulm_chip_navigate_icon: mdi:update
ulm_chip_navigate_icon_color : purple
card_mod:
style: |
ha-card {
width: fit-content;
margin-left: auto;
transition: all 0s;
card_mod:
style: |
:host {
position: sticky;
bottom: 5px;
ha-card {
background: none;
Iām also interested in knowing if we could use a slider instead of the + and - buttons for thermostats. It makes changing temperatures really inconvenientā¦ any way to achieve this?
I would like to ask for a little help, too many decimal places are displayed for the temperature value
chips:
- type: template
entity: sensor.bedroom_thermal_comfort_humidex_perception
content: >-
{{ states('sensor.bedroom_thermal_comfort_humidex') }} Ā°C {{
states('sensor.bedroom_thermal_comfort_humidex_perception') }}
I have a question. In mushroom-select-card is it possible to change the length of the drop-down list?
can you please share the code.
Big thanks, works for other chips as well
Hmm they are aligned over the whole width ā¦ And they are much bigger dan my chips. Can I make them smaller ? En less space in between ? And the space on the right even big as the space on the left ? Too much questions probably š«£
You can do it with Mushroom Cards like this:
card:
cards:
icon: mdi:numeric-1-circle
icon_color: red
layout: vertical
card_mod:
style: |
ha-card {
width: fit-content;
transition: all 0s;
icon: mdi:numeric-2-circle
icon_color: orange
layout: vertical
card_mod:
style: |
ha-card {
width: fit-content;
transition: all 0s;
icon: mdi:numeric-3-circle
icon_color: yellow
layout: vertical
card_mod:
style: |
ha-card {
width: fit-content;
transition: all 0s;
icon: mdi:numeric-4-circle
icon_color: green
layout: vertical
card_mod:
style: |
ha-card {
width: fit-content;
transition: all 0s;
card_mod:
style: |
:host {
position: sticky;
bottom: 5px;
ha-card {
display: flex;
background: none;
justify-content: center;
--mush-icon-size: 32px;
ok thanks. Iāll try
