Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
You can set the height of the Mushroom Select List like this:
type: custom:mushroom-select-card
entity: select.butterfly_preset
layout: horizontal
card_mod:
  style:
    mushroom-select-option-control$:
      mushroom-select$:
        mwc-menu$:
          mwc-list$: |
            .mdc-deprecated-list {
              --height-multiplier: 1.12;
              --select-visible-items: 5;
              height: calc(var(--select-visible-items) * var(--height-multiplier) * var(--select-height));
          mwc-menu-surface$: |
            .mdc-menu-surface {
              --scrollbar-width: 8px;
            .mdc-menu-surface::-webkit-scrollbar {
              width: var(--scrollbar-width);
            .mdc-menu-surface::-webkit-scrollbar-thumb {
              background: var(--mdc-theme-primary);
              border-radius: calc(var(--scrollbar-width) / 2);
You can round it like this:
{{ states('sensor.bedroom_thermal_comfort_humidex') | round(1) }}
Thank you very much. You are amazing. :+1:
The seekbar only appears when the music is paused, it disappears when music is playing, also seekbar is grey in color, any odea on how to fix it?
Hello!
Why do I have pop-ups displayed in the background and not in the foreground?
Even the system ones.
ehi @rhysb, take a look at the footer I created above :slight_smile:
How do I change the height and font size of the encircled part?
Kindly guide
I have a button that when pressed, the icon has to blink until a binary sensor is “on”. when it is not pressed it has to be mdi.wifi-off. when binary sensor is on, the blinking has to stop and icon has just to be green…
How can I do this ?
Hi
fixing only works if I have enough cards. If there are too few boxes, the bar slides back up. Is there a way to do that too?
EDIT: I’ve solved it for already. Thank you.
@WW983 can you tell me how you built the selection-card for the rooms and how you built the “title” cards regarding the used font and colors. In general my setup is a little bit similiar :slight_smile: but i want to improve styling and usability…
greetings from germany :slight_smile:
WOW, love the bar card!
Could you please share the bar card? please!!!
@tobiasfrank87 @madir
Sure. here’s the code. But look at the code from the @Mattia2399 . It’s much more professional. The code is specifically balanced for my case. If you have any questions, you can write me a message
type: custom:stack-in-card
mode: horizontal
card_mod:
  style: |
    ha-card { border-radius: 50px;
              background: rgb(45, 45, 45);}
    :host {
      position: sticky;
      bottom: 5px;
cards:
  - type: custom:layout-card
    layout_type: grid
    layout:
      grid-template-columns: 60% 40%
      grid-template-rows: auto
      grid-template-areas: |
        "eins1 zwei2"
    cards:
      - type: custom:stack-in-card
        mode: horizontal
        view_layout:
          grid-area: eins1
        card_mod:
          style: |
            background: rgb(208, 208, 208);
            box-shadow: none;
        cards:
            layout_type: grid
            layout:
              grid-template-columns: 90% 10%
                "eins zwei"
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
            cards:
                view_layout:
                  grid-area: eins
                icon_color: black
                icon: mdi:home
                primary: Home
                entity: input_boolean.menu
                tap_action:
                  action: more-info
                hold_action:
                  action: more-info
                card_mod:
                  style: |
                    ha-card {
                      box-shadow: none;
                      --spacing: 8px;
                      --icon-size: 35px;
                      --primary-text-color: rgb(var(--rgb-black));
                    mushroom-shape-icon {
                        --shape-color: none !important;
              - type: custom:mushroom-chips-card
                view_layout:
                  grid-area: zwei
                chips:
                  - type: template
                    card_mod:
                      style: |
                        ha-card {
                          position: absolute;
                          right: 0px;
                          top: 10px;
                          background: green;
                          box-shadow: none;
                    double_tap_action:
                      action: none
                    icon_color: white
                    icon: mdi:chevron-up
                    tap_action:
                      action: more-info
                    hold_action:
                      action: more-info
        mode: horizontal
        view_layout:
          grid-area: zwei2
        card_mod:
          style: |
                      box-shadow: none;}
        cards:
          - type: custom:mushroom-entity-card
            tap_action:
              action: navigate
              navigation_path: home
            entity: person.waldemar
            layout: horizontal
            primary_info: none
            secondary_info: none
            icon_color: blue
            icon: mdi:home
            entity: alarm_control_panel.alarm
            layout: horizontal
            primary_info: none
            icon_color: green
            icon: mdi:shield-home
            tap_action:
              action: navigate
              navigation_path: kameras
            entity: input_button.kameras
            layout: horizontal
            primary_info: none
            icon_color: blue
            icon: mdi:video
Hi everyone,
I am trying to make an icon that shows “dancing bars” to show that there is music playing.
I found a tutorial for scripting it in CSS but I can’t figure out how to implement that to an icon in Home Assistant. Can someone help?
The tutorial:
Bildschirm­foto 2023-05-31 um 11.10.51
cards:
    icon: mdi:washing-machine
    icon_color: orange
    primary: 'Washing Machine #2'
    card_mod:
      style:
        mushroom-shape-icon$: |
          ha-icon {
            --icon-animation: shake 400ms ease-in-out infinite;
            transform-origin: 50% 58%;
            clip-path: polygon(0 0, 0 100%, 35% 100%, 34% 68%, 60% 41%, 71% 56%, 65% 74%, 47% 79%, 32% 69%, 35% 100%, 100% 100%, 100% 0);
          @keyframes shake {
            0%, 100% { transform: translate(0, 0) rotate(0); }
            20%  { transform: translate(0.4px, -0.4px) rotate(-4deg); }
            40%  { transform: translate(-0.4px, 0.4px) rotate(4deg); }
            60%  { transform: translate(0.4px, 0.4px) rotate(-4deg); }
            80%  { transform: translate(-0.4px, -0.4px) rotate(4deg); }
    icon_color: orange
    card_mod:
      style:
          ha-icon {
            --icon-animation: spin 1s linear infinite;
            clip-path: circle(21.7% at 50% 58%);
          .shape {
            --shape-color: none;
          ha-card {
            width: 66px;
            top: -66px;
card_mod:
  style: |
    ha-card {
      height: 66px;
I work with my 1 PM
How do I enter this value into the system here?
sensor.washing_machine_power
Thank you
Can you share all the code please :):
hi,
Does anyone have the option of sharing their entire room view?
I have finished my main page, and now I want to move on to room views
Hello.
I`m having a question about badges.
Is there any possibility to place badge on top of main icon instead how it is right now on current photo?
You can move the badge around like this:
                card_mod:
                  style: |
                    mushroom-badge-icon {
                      left: 15px;
                      top: 15px;
Thank You very much!:slight_smile:
It may be useful for some of you - here’s my Custom Chips card for my Solar import / export
it changes icon, colour and text and value depending on values coming from my IotaWatt
two sensors used are
‘importing’ which is just measuring the current drawn from the grid
and ‘exporting’ which an integrator on the IotaWatt that pretty much just removes the negative from the number and reports as a positive Export
Here’s how it looks…
and
chips:
  - type: template
    entity: sensor.exporting
    icon: |-
      {% set state=states('sensor.exporting') %}
      {% if state | is_number and state | float > 0 %}
        mdi:transmission-tower-export
      {% elif state | is_number and state | float < 0 %}
        mdi:transmission-tower-off
      {% else %}
        mdi:transmission-tower-import
      {% endif %}
    icon_color: |-
        green
        blue
      {% else %}
        red
      {% endif %}
    content: >-
      {% set state=states('sensor.exporting') %} {% if state | is_number and
        Exporting {{ states('sensor.exporting') }} {{ state_attr('sensor.exporting', 'unit_of_measurement') }}
        Error
      {% else %}
        Importing {{ states('sensor.importing') }} {{ state_attr('sensor.importing', 'unit_of_measurement') }}
      {% endif %}
  - type: template
    entity: sensor.solar_production
    icon: mdi:solar-panel
    icon_color: |-
      {% set state=states('sensor.solar_production') %}
        green
        blue
      {% else %}
        red
      {% endif %}
    content: >-
      {{ states('sensor.solar_production') }} {{
      state_attr('sensor.solar_production', 'unit_of_measurement') }}
  - type: entity
    entity: sensor.total_pv_in_kw
    icon: mdi:solar-power-variant-outline
