Mushroom Cards - Build a beautiful dashboard easily 🍄 (Part 1)
I’m sorry if that came of aimed at you! It wasn’t! :slight_smile:
I took “person” as a search because I was looking for a person card (still am), and so I thought it might be a good idea to remind people of the thread search. :slight_smile: That’s all! :slight_smile:
I too have been looking for ideas for a person card all over. One thing, I wanted to integrate a map but we don’t go out to work so that seemed redundant, so I can’t up with the idea to have a conditional map card if someone isn’t home. Beyond that, it all seems a bit lacking.
Please post if you are blessed with inspiration.
Interesting idea, that is my problem, too. My wife an me both do work-from-home, so a map is something I’d only occasionnaly need.
If I stumble upon something, I’ll let you know for sure! :slight_smile: For now I’m trying to find a good generator for Memojis, still don’t own any Apple device. :crazy_face:
 script.bathroom_fan_timer
script:
  start_fantimer:
    sequence:
    - delay: "00:{{ states('input_number.toiletfan_input') | int }}:00"
    - data:
        entity_id: fan.toilet_fan
      service: fan.turn_off
am I wrong? right?
Thanks a lot …:blush::blush:
Are you asking about scripting? If so, this isn’t the topic, try searching the forum to see what questions people have asked before.
Best of :crossed_fingers:
You are right, thanks again
im trying to use your code to make a navigation bar but without any success with the dropdown menu
type: custom:stack-in-card
mode: horizontal
card_mod:
  style: |
    ha-card { border-radius: 50px;
              background: rgb(45, 45, 45);}
    :host {
      position: sticky;
      bottom: 5px;
cards:
  - type: custom:layout-card
    layout_type: grid
    layout:
      grid-template-columns: 60% 40%
      grid-template-rows: auto
      grid-template-areas: |
        "eins1 zwei2"
    cards:
      - type: custom:stack-in-card
        mode: horizontal
        view_layout:
          grid-area: eins1
        card_mod:
          style: |
            background: rgb(208, 208, 208);
            box-shadow: none;
        cards:
            layout_type: grid
            layout:
              grid-template-columns: 90% 10%
                "eins zwei"
            card_mod:
              style: |
                ha-card {
                  box-shadow: none;
            cards:
                view_layout:
                  grid-area: eins
                icon_color: black
                icon: mdi:home
                primary: TO CHANGE TO VIEW NAME
                entity: input_select.select_option
                tap_action:
                  action: toggle
                hold_action:
                  action: more-info
                card_mod:
                  style: |
                    ha-card {
                      box-shadow: none;
                      --spacing: 8px;
                      --icon-size: 35px;
                      --primary-text-color: rgb(var(--rgb-black));
                    mushroom-shape-icon {
                        --shape-color: none !important;
              - type: custom:mushroom-chips-card
                view_layout:
                  grid-area: zwei
                chips:
                  - type: template
                    card_mod:
                      style: |
                        ha-card {
                          position: absolute;
                          right: 0px;
                          top: 10px;
                          background: green;
                          box-shadow: none;
                    entity: input_select.menu
                    double_tap_action:
                      action: none
                    icon_color: white
                    icon: mdi:chevron-up
                    tap_action:
                      action: more-info
                    hold_action:
                      action: more-info
        mode: horizontal
        view_layout:
          grid-area: zwei2
        card_mod:
          style: |
                      box-shadow: none;}
        cards:
          - type: custom:mushroom-entity-card
            tap_action:
              action: navigate
              navigation_path: home
            entity: person.eduardo_martins
            layout: horizontal
            primary_info: none
            secondary_info: none
            icon_color: blue
            icon: mdi:home
            entity: alarm_control_panel.alarmo
            layout: horizontal
            primary_info: none
            icon_color: green
            icon: mdi:shield-home
            tap_action:
              action: navigate
              navigation_path: Garagem
            entity: input_button.kameras
            layout: horizontal
            primary_info: none
            icon_color: blue
            icon: mdi:video
Hi. I’m having problems with aligning my chips at the bottom of my card. They are aligning to the left of the card and I’d like them more centered. Please see attached picture and code for clarification. Any idea what I can try to resolve? I’ve tried changing the “alignment” on both chips.
mode: vertical
cards:
  - type: custom:mushroom-person-card
    entity: person.eric
    use_entity_picture: true
    hide_name: true
    hide_state: true
    layout: vertical
    tap_action:
      action: more-info
      browser_mod:
        command: popup
        deviceID: eric_pc
        title: Eric
        card:
          type: custom:mod-card
          style: |
            ha-card {
               padding-right: 45px;
               padding-left: 45px;
               padding-bottom: 45px;
    style: |
      ha-card {
        --chip-box-shadow: none;
        --chip-background: none;
        --chip-spacing: none;
        --chip-height: 33px
    chips:
      - type: entity
        entity: sensor.eric_iphone_zone_distance
        icon_color: blue
        icon: mdi:navigation-variant-outline
        card_mod:
          style: |
            ha-card {
              box-shadow: 0px 0px;
          alignment: center
      - type: entity
        entity: sensor.erics_iphone_battery_level
        icon_color: blue
        card_mod:
          style: |
            ha-card {
          alignment: center
chips
Here you have corrected
mode: vertical
cards:
    entity: person.eric
    hide_name: true
    hide_state: true
    layout: vertical
    tap_action:
      action: more-info
      browser_mod:
        command: popup
        deviceID: eric_pc
        title: Eric
        card:
          style: |
            ha-card {
               padding-left: 45px;
    card_mod:
      style: |
        ha-card {
          --chip-font-size: 0.25em;
          --chip-icon-size: 0.5em;
          --chip-border-width: 0;
          --chip-border: none;
          --chip-font-weight: normal;
    alignment: center
    chips:
      - type: entity
        icon_color: blue
        card_mod:
          style: |
            ha-card {
      - type: entity
        icon_color: blue
        card_mod:
          style: |
            ha-card {
That fixed it!! Thank you so much. I see the changes you made, but would you mind explaining what it did? Thank you!!
Any recommendation how to have distinct colors for background vs the cards?
what device does this fan switch control?
Hi danwooller,
thanks, found the wrong bracket!
But this also changes the icon and the shape. Looks then like that:
Unbenannt
Is there a way without resize the icon?
Thanks!
                chips:
                  - type: template
                    entity: cover.screenlinks
                    icon: |-
                      {{ iif(is_state(entity, 'open'), 'mdi:blinds-open', 'mdi:roller-shade-closed') }}
                    icon_color: |-
                      {{ iif(is_state(entity, 'open'), 'white', 'grey') }}
How can I set the position of the cover to 80 when opening ?
You have to put @ in front of their name so they get a notification.
Try
        card_mod:
          style:
            mushroom-shape-icon$: |
              .shape {
                width: calc(var(--icon-size) * 2) !important;
              ha-card {
               # margin-top: -12px;
                --icon-border-radius: 12px;
                #--icon-size: 50px;
                #margin-top: -12px;
                #margin-left: -52px;
I have been trying to create a heating card for each room using some of the great examples in here. I have gotten this far, but am stuck on how to close the gaps between the cards, and also how to make the font size of the temperature and when the automation was last triggered
mode: horizontal
cards:
    cards:
      - type: custom:mushroom-climate-card
        entity: climate.living_room_radiator
        show_temperature_control: false
        layout: vertical
        icon: mdi:sofa
        primary_info: none
        double_tap_action:
          action: more-info
        chips:
          - type: template
            icon: ''
            icon_color: ''
            content: >-
              {{ states('sensor.living_room_temperature_sensor_temperature')
              }}°C
          - type: entity
            entity: automation.trv_valve_living_room_radiator
            content_info: last-updated
            icon: ''
            use_entity_picture: false
            icon_color: red
        alignment: center
        cards:
            show_temperature_control: true
            layout: vertical
            icon_type: none
            primary_info: none
            double_tap_action:
              action: more-info
        chips:
          - type: template
            icon: mdi:pipe-valve
            icon_color: blue
            content: '{{ states(''sensor.living_room_trv_battery_level'') }}'
          - type: template
            icon: mdi:battery
            icon_color: green
            content: '{{ states(''sensor.living_room_temperature_sensor_battery'') }}%'
          - type: template
            icon: mdi:battery-bluetooth
            icon_color: green
            content: '{{ states(''sensor.living_room_trv_battery_level'') }}%'
        alignment: center
Im not the best person for that, but essentially it creates a new group and it calls card mod to implement the styles
Not an answer to your question but I have been using this same room card config and it causes my tablet to lag or become unresponsive after a few mins. Works great on phone and PC, have you experienced the same issue?
Here is how I make my light flash if a light is on.
card_mod:
              style:
                  .shape {
                    {% if is_state(config.entity, 'on') %}
                      {% if state_attr(config.entity, 'rgb_color') == none %}
                        --icon-color: rgb(255,190,137) !important;
                        --shape-color: rgb(255,190,137, 0.2 ) !important;
                        --icon-animation: illumination 1s infinite;
                        @keyframes illumination {
                          0%, 100% { clip-path: inset(0 0 0 0); }
                          80% { clip-path: polygon(0% 99%, 20% 55%, 22% 37%, 39% 20%, 61% 21%, 77% 35%, 79% 57%, 99% 100%); }
                      {% else %}
                        {% set r = state_attr(config.entity, 'rgb_color')[0] %}
                        {% set g = state_attr(config.entity, 'rgb_color')[1] %}
                        {% set b = state_attr(config.entity, 'rgb_color')[2] %}
                        --icon-color: rgb( {{r}}, {{g}}, {{b}} ) !important;
                        --shape-color: rgba( {{r}}, {{g}}, {{b}}, 0.2 ) !important;
                      {% endif %}
                    {% endif %}
Here is a link to my discussion form on my issue if anyone can help.
[[Dashboard Room Card Causes Tablet to Lag/unresponsive]]
Good evening, tell me how to make the icon blink when the motion sensor detects
type: custom:mushroom-template-card
icon: none
icon_color: blue
primary: Зал
secondary: |-
  {% set temperature = "sensor.ms_zal_temperature" %}
  {% set humidity = "sensor.ms_zal_humidity" %}
  {{ states(temperature) | round(1) }}°c
  {{ states(humidity) | round(1) }}%
card_mod:
  style:
      .shape:after {
        font-size: 21px;
        content: '📺';
        animation: boing 3s ease infinite;
        transform-origin: 50% 90%;
      ha-icon {
        width: 0px !important;
      @keyframes boing {
        0% { transform: scale3d(1, 1, 1); }
        7% { transform: scale3d(1.25, 0.75, 1); }
        10% { transform: scale3d(0.75, 1.25, 1); }
        12% { transform: scale3d(1.15, 0.85, 1); }
        16% { transform: scale3d(0.95, 1.05, 1); }
        19% { transform: scale3d(1.05, 0.95, 1); }
        25% { transform: scale3d(1, 1, 1); }
tap_action:
  action: fire-dom-event
  browser_mod:
    service: browser_mod.popup
      title: HTML content
      content:
        type: entities
        entities:
          - entity: automation.distantsiia_test
          - entity: automation.zavesti_dvigatel_mazda_v_3_00
          - entity: automation.zavesti_dvigatel_mazda_v_6_00
          - entity: switch.kalitka_relay2
            icon: mdi:garage
          - entity: sensor.time_to_work
title: Автомобиль
show_header_toggle: false
state_color: true
