Mushroom Cards - Build a beautiful dashboard easily šŸ„ (Part 1)
Hi, is anyone able to help please? Iā€™m hoping to have the icon change colour based on the temperature range of a sensorā€¦Iā€™ve got this so far but it only changes the icon to green? Basically Iā€™d like to change the colour if the temp is over say 15 degrees, then 20 then 25 for example?
icon_color: |
  {% if states(entity) | float > 15 %}
    green
  {% elif states(entity) | float > 20 %}
    yellow
  {% elif states(entity) | float > 25 %}
    orange
  {% elif states(entity) | float > 30 %}
    red
  {% else %}
    black
  {% endif %}
entity: sensor.bedroom_temperature_sensor_temperature
Just start with the high numbers. And it should work
icon_color: |
  {% if states(entity) | float > 30 %}
    red
    orange
    yellow
  {% elif states(entity) | float > 15 %}
    green
  {% else %}
    black
  {% endif %}
ā€œI like your approach! Are the colors for the background and cards specified in certain theme files? If so, could you please share them with me?ā€
For ex card-mod: background-color: rgba(var(ā€“rgb-card-background-color)
@rhysb is there a way to decrease the spacing between the chips ? The Bottom row has 5 chips, can I decrease the spacing between them ? Kindly guide
Just using it for the AC
Thanks so much, that worked!
@danwooler
Thank you, that worked!!!
Firstly, this is very nice, thank you.
I am having trouble with a couple of elements however:
The radial progress bar is not displaying correctly.
The zoom buttons are not obeying their custom positioning.
The latter isnā€™t really an issue to me. But I wonder if something has changed since you shared this code for the battery card to not render correctly (or perhaps my removing of ā€˜distance to xā€™ card has altered behaviour in some way?)
Thank you again. One last question. It looks great on my PC, but when I view it on the tablet the two bottom icons you helped me adjust are stacked vertically (Iā€™m assuming because it runs out of ā€œhorizontalā€ space). Any idea of something I can do to fix that?
Could you please share your code?
Wondering if someone can help me, Iā€™m new to this YAML stuff :grin:
Iā€™m hoping to make a mushroom person card, like @Mosher with a Memoji-style image and the red/green home and away badges.
However, I want to use a binary presence sensor entity to control the Home/Away state, not a person entity. I was able to change the entity to the binary sensor, and change the icon type to ā€œentity-pictureā€ with the code editor, but I canā€™t figure out how to set the actual Memoji picture I want to use.
Hereā€™s what I have so far:
type: custom:mushroom-person-card
entity: binary_sensor.nick_presence
layout: vertical
fill_container: false
icon_type: entity-picture
Any help would be appreciated, or if there is a better way to do it with a different card, please let me know!
I have a velux window
- type: custom:mushroom-chips-card
  chips:
    - type: template
      entity: cover.raamlinks
      icon: |-
        {{ iif(is_state(entity, 'open'), 'mdi:window-open-variant', 'mdi:window-closed-variant') }}
        icon_color: disable
If I open it, I want it always on position 78. I found some code, but donā€™t know how to use itā€¦
- service: cover.set_cover_position
       entity_id: X
       position: 78
and as long as it isnā€™t on position 0 or 78 I want the icon blinkingā€¦
type: entity-button
entity: light.bed_light
style: |
  @keyframes blink {
    50% {
      background: red;
  ha-card {
    animation: blink 2s linear infinite;
How can I manage this ?
Does this work?
{{ 'animation: blink 2s linear infinite;' if not is_state(config.entity, '0') and not is_state(config.entity, '78') }}
Anyone know whatā€™s going on here? I think it was after the 2023.6 update my mushroom dashboard started loading with everything overlapping.
If I click to a different page, then back, it goes back to normal.
like this ?
- type: template
  entity: cover.raamrechts
  icon: |-
  icon_color: disable
  style: |
    @keyframes blink {
      50% {
        background: red;
    ha-card {{ 'animation: blink 2s linear infinite;' if not is_state(config.entity, '0') and not is_state(config.entity, '78') }}
this does not workā€¦
I think maybe you need to look and whether your values are strings or integers. I donā€™t have that device so only tested with switches that use strings.
This is not technically a mushroom card problem, so youā€™re maybe better off asking in a template thread.
ok, thanks for helping me
Since one of the last homeassistant updates my browser mod with mushroom popup windowlook like this (notice the small lines around the mushroom cards):
What can i do to fix this?
chips:
  - type: template
    icon: >
      {% if is_state('light.alle_lichter', 'on') or
      is_state('switch.lichtsteckdosen', 'on') %}
        mdi:lightbulb-multiple
      {% elif is_state('light.alle_lichter', 'off') or
      is_state('switch.lichtsteckdosen', 'off') %}
        mdi:lightbulb-multiple-off
      {% endif %}
    icon_color: >
        #FDD835
        blue-grey
      {% endif %}
    entity: light.alle_lichter
    content: >-
      {{ expand('light.alle_lichter','switch.lichtsteckdosen') |
      selectattr('state', 'eq', 'on') | list | count}}
    card_mod: null
    tap_action:
      action: fire-dom-event
      browser_mod:
        service: browser_mod.popup
          title: Eingeschaltete Lichter
          content:
            type: custom:auto-entities
            filter:
              include:
                - group: switch.lichtsteckdosen
                  state: 'on'
                  options:
                    type: custom:mushroom-entity-card
                    layout: horziontal
                    icon_color: yellow
                    tap_action:
                      action: toggle
                    card_mod:
                      style: |
                        ha-card {
                          padding: 4px 12px !important;
                - group: light.alle_lichter
                  state: 'on'
                  options:
                    type: custom:mushroom-light-card
                    show_brightness_control: true
                    layout: horizontal
                    tap_action:
                      action: toggle
                    use_light_color: true
                    card_mod:
                      style: |
                        ha-card {
              exclude:
                - domain: light
                  attributes:
                    types: browser_mod
            card:
              type: entities
              cards: []
              show_header_toggle: false
              sort:
                method: friendly_name
      target: {}
  - type: template
    icon: |
      {% if is_state('group.all_doors', 'off') %}
        mdi:door
      {% else %}
        mdi:door-open
      {% endif %}
    icon_color: |
        green
      {% else %}
        red
      {% endif %}
    entity: group.all_doors
    content: >-
      {{ expand(states.group.all_doors) | selectattr( 'state', 'eq','on') | list
      | count }}
    card_mod: null
    tap_action:
      browser_mod:
          title: Geƶffnete TĆ¼ren/Fenster
          content:
            filter:
              include:
                - group: group.all_doors
                  state: 'on'
                  options:
                    layout: horizontal
                    tap_action:
                      action: more-info
                    card_mod:
                      style: |
                        ha-card {
              exclude:
                - domain: light
                  attributes:
                    types: browser_mod
            card:
              type: entities
              cards: []
              sort:
      target: {}
  - type: entity
    entity: person.menthe
alignment: end
https://github.com/thomasloven/hass-browser_mod/issues/587
                chips:
                  - type: template
                    entity: input_boolean.veluxscreen_links
                    icon: >
                      {% if is_state('input_boolean.veluxscreen_links', 'on')%}
                        mdi:blinds-open
                      {% elif is_state('cover.screenlinks', 'open')%}
                        mdi:blinds-open
                      {% else %}
                        mdi:roller-shade-closed
                      {% endif %}
                    icon_color: |-
                      {{ iif(is_state(entity, 'on'), 'white', 'grey') }}
                    card_mod:
                      style: |
                        mushroom-template-chip:nth-child(2)$: |
                          ha-icon {
                            {% if state_attr('cover.screenlinks','current_position')|int(default=-1) > 0 and state_attr('cover.screenlinks','current_position')|int(default=-1) < 78 %}
                            {% endif %}
                          @keyframes blink {
                            0% {
                              opacity: 0;
                            100% {
                              opacity: 1;
Can you tell me what is wrong here ? I want the icon blinking when the attribute is between 0 and 78 ā€¦
